CM5740Z171B-00
CM5740Z171B-00
    LAIRD(莱尔德)
    CM5740Z171B-00
CM5740Z171B-00 数据手册
Part Curves Page 1 of 4 CM5740Z171B-00 http://www.steward.com/web_part_no.asp?line=EMC / EMI Board Level and Cable Core ... 2/24/2004 Part Curves Page 2 of 4 Drawing Figure # Figure Number 5 Electrical Characteristics NET Z DCR @ 100 MHz Max 170 0.001 Rated Current mA 20000 Physical Dimensions A B B1 C C1 D E E1 A B B1 C C1 D E E1 mm mm mm mm mm mm mm mm in in in in in in in in 14.48 10.03 - 9.32 12.90 4.06 2.54 3.43 0.570 0.395 - 0.367 0.508 0.160 0.100 0.135 Wire Dimensions T1 mm T2 mm T3 mm T1 in T2 in T3 in 3.12 0.76 0.76 0.123 0.030 0.030 http://www.steward.com/web_part_no.asp?line=EMC / EMI Board Level and Cable Core ... 2/24/2004 Part Curves Page 3 of 4 http://www.steward.com/web_part_no.asp?line=EMC / EMI Board Level and Cable Core ... 2/24/2004 Part Curves Page 4 of 4 Specifications, which provide more details for the correct use of the described products, are available upon request. All specifications are subject to change without notice. For more information on any of the products listed above, please contact Steward customer service department at (800) 634-2673. Copyright© 2004 Steward, Inc. Last Updated: 2/24/2004 http://www.steward.com/web_part_no.asp?line=EMC / EMI Board Level and Cable Core ... 2/24/2004
CM5740Z171B-00
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一款6脚的光耦器件,用于隔离信号传输。
3. 引脚分配:1脚为输出低电平,2脚为输出高电平,3脚为输入,4脚为接地,5脚为Vcc,6脚为输出控制。
4. 参数特性:工作电压为5V,输入电流为10mA,输出电流为50mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,提高系统的抗干扰能力。
6. 应用信息:广泛应用于工业控制、仪器仪表等领域。
7. 封装信息:采用DIP6封装。
CM5740Z171B-00 价格&库存
很抱歉,暂时无法提供与“CM5740Z171B-00”相匹配的价格&库存,您可以联系我们找货
CM5740Z171B-00
    • 1+9.19080
    • 165+3.67200
    • 495+3.54240
    • 990+3.48840
