FD00AA006
FD00AA006
    CURTISINDUSTRIES
    LINE FILTER 80VDC 6A CHASS MNT
FD00AA006 数据手册
DC FILTERS General Purpose FD Series Filters The FD Series of DC filters are designed as a general purpose line of filters for DC applications. They are designed to comply with UL/EN 60950 and UL 1459, CISPER 22 and Telecordia (Bellcore) GR-1089 at 25Amps and above. These filters are available with and without circuit breakers for additional protection. The FD Series is a compact size that can filter up to 300MHz ideally suited for the telecom-datacom market. The FD0 Series is available from 6Amps to 100Amps in the smallest, economical package. The FD02 is a high frequency filter up to 3GHz (3,000MHz) in a compact package. These filters are ideally used in communications and central office equipment. • Power Supplies for Communications Equipment • Network Routing Equipment • Switching Equipment • Base Stations • Modems • Services • Ethernet Hubs Specifications: Rated Voltage: 80VDC Maximum 6A Rated Current: 10A 20A 25A 50A 75A 100A Current Overload: 6X for 8 seconds Hi-Pot Rating (1 min): Line to Ground 1060VDC Line to Line 100VDC Insulation Resistance: 1000 MΩ at 80VDC Ambient Temperature: 0°C to 55°C (32°F to 131°F) Humidity Range: 0% to 95% R.H. Termination: See Chart at Right 6A to 20A (FD0) Wire Leads: 18AWG (FD0 25Amp to 100Amp not available with wire leads) 10AWG 30Amp (FD1, FD2, FD3) 6AWG 50Amp 4AWG 75Amp & 100Amp Agency Approvals: 6Amp to 20Amp E78454 25Amp to 100Amp E221098 64 www.curtisind.com 064179 72031306 Curtis Industries A Division of Powers Holdings, Inc. 72070096 72061592 E221098 Specifications subject to change. Dimensions are shown for reference purposes only. Power Line Filter Selection Guide FD1, FD2, FD3 SERIES 6 FD00BB006 6 FD00AA010 10 FD00BB010 10 FD00AA020 20 FD00DD020 20 FD00DD025 X FD10BB030 30 FD10EE030 30 FD10BB050 50 FD10EE050 50 FD10BB075 75 X X FD10BB100 100 X 25 X FD20B_ _ _ FD00DD050 50 X FD20E_ _ _ FD00DD075 75 X FD20R_ _ _ FD00DD100 100 X FD20D_ _ _ FD02DD025 25 X FD20H_ _ _ FD02DD050 50 X FD20 _B_ _ _ FD02DD075 75 X FD20 _C_ _ _ FD02DD100 100 X FD20 _E_ _ _ X X X X X X X X X X X X X 30, X X 50, or 80 X X X X X FD30B_ _ _ X FD30E_ _ _ X FD30R_ _ _ FD30H_ _ _ FD30 _B_ _ _ X 30, 50, 75, or 100 FD30 _C_ _ _ FD30 _E_ _ _ FD30 _T_ _ _ Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. X X DC FILTERS FD20 _T_ _ _ FD30D_ _ _ Dual Stud T-Block Euro Connector Termination Wire Leads Double Pole Handle Breaker Double Pole Rocker Breaker Part Number Single Pole Rocker Breaker FILTER Current Rating (Amps) Studs Disconnect Type General Purpose FD00AA006 Wire Leads Part Number Quick Connects FILTER Current Rating (Amps) Termination High Current Connector FD00 & FD02 SERIES X X X X X X X 1-800-657-0853 65 FD Series Filters How to Order FD0 0 X Y 000 SERIES FD0 FD1 FD2 FD3 CURRENT RATING: 006 = 6Amps 010 = 10Amps 020 = 20Amps 025 = 25Amps 030 = 30Amps 050 = 50Amps 075 = 75Amps 080 = 80Amps 100 = 100 Amps OPTIONS: 0 = Standard 2 = High Frequency 3-9 = Specials General Purpose LINE TERMINATION: LOAD TERMINATION: A = Quick Connect A = Quick Connect B = Wire Leads B = Wire Leads D = Dual Studs/Screw Terminal C = High Current Connector E = Euro Block Connector D = Dual Studs/Screw Terminal H =  Dual Stud T-Block E = Euro Block Connector with DPST Handle Breaker T = Dual Stud T-Block R = Dual Stud T-Block with SPST Rocker Breaker NOTE: Not all terminations are available in all models. DC FILTERS Part Number 66 TYPICAL INSERTION LOSS - dB (50 ohm Circuit) MODE .01 .03 .10 .15 .50 Frequency - MHz 1.0 5.0 10 30 100 300 1000 3000 FD00XX006 FD00XX010 FD00XX020 Common Differential – – – – – – 10 15 22 45 30 60 42 60 47 50 40 50 – – – – – – – – FD00XX025 FD00XX050 FD00XX075 FD00XX100 Common Differential – – – – – – 22 32 50 38 60 50 50 55 45 50 40 40 – – – – – – – – FD02XX025 FD02XX050 FD02XX100 Common Differential 5 40 5 45 35 45 45 45 60 48 60 50 55 45 55 55 50 48 40 45 10 15 20 58 25 40 FD10XX030 FD10XX050 FD10XX075 FD10XX100 Common Differential 5 55 15 60 48 70 60 70 65 70 65 65 60 70 60 60 55 50 25 35 25 15 – – – – FD20XX030 FD20XX050 FD20XX080 Common Differential 5 55 15 65 48 70 60 65 70 60 70 65 70 55 60 50 55 45 – – – – – – – – FD30XX030 FD30XX050 FD30XX075 FD30XX100 Common Differential 12 50 20 60 44 70 60 70 60 70 60 70 60 55 60 70 55 60 – – – – – – – – www.curtisind.com Curtis Industries A Division of Powers Holdings, Inc. Specifications subject to change. Dimensions are shown for reference purposes only. FD00 Filters FD00AA (6, 10 and 20Amp) Dimensions .188 Dia. (4,77) 2 Holes D L LO A D LI NE L A G N N E F Amps A B C D E F 6A 3.312 (84,1) 2.000 (50,8) 1.125 (28,5) 2.940 (74,7) 2.500 (63,5) .550 (14,0) 10A 3.312 (84,1) 2.000 (50,8) 1.500 (38,2) 2.940 (74,7) 2.500 (63,5) .550 (14,0) 20A L O A D L I N E B F .250 QC (6,4) C See FD00DD below for Case Dimensions A .188 Dia. (4,77) 2 Holes D FD00BB B (6 and 10Amp) Dimensions Amps A B C D E 6A 3.312 (84,1) 2.000 (50,8) 1.125 (28,5) 2.940 (74,7) 2.500 (50,8) 10A 3.312 (84,1) 2.000 (50,8) 1.500 (38,1) 2.940 (74,70) 2.500 (50,8) E C 4.000 (101,6) Min. .250 ±.062 (6,35) Typ. No. 18 Gauge Wire DC FILTERS FD00DD (20Amp) Dimensions .188 Dia. (94,77) 2 Holes 2.500 (63,5) L O A D L I N E General Purpose L O A D L I N E 2.940 (74,7) 3.312 (84,1) (5) No. 8-32 Studs .625 (15,87) 2.000 (50,8) .625 (15,87) 1.500 (38,1) Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 67 FD00 & FD02 Filters FD00DD (25, 50, 75 and 100Amp) Dimensions LO A D LI NE 1/4-20 Stud Pair Per Connection -48VDC -48VDC G RTN 2.00 (50,8) RTN .625 (15,875) .69 (17,526) -48VDC .75 -48VDC (19,1) 1.000 (25,4) .25 (6,35) .38 (9,652) RTN 4X 6-32 x .23 RTN .25 (6,35) 1.500 (38,1) 1.25 Max. (31,75) 2.50 (63,5) L O A D L I N E -48VDC 1.50 (38,1) RTN -48VDC LOAD -48VDC G 1/4-20 Stud Pair Per Connection RTN DC FILTERS RTN 3.875 (98,4) .625±.020 (15,875) 1.63 (41,4) www.curtisind.com 1.50 (38,1) -48VDC RTN LINE .38 (9,65) 4X 6-32 x -48VDC RTN RTN 3.000 (76,2) 1.25 Max. (31,75) .38 (9,65) .75 (19,05) .25 (6,35) .44 (11,18) 3.312 (84,12) 1.25 Max. (31,75) -48VDC 1.000 (25,4) 68 .38 (9,65) FD02DD (25, 50 and 100Amp) Dimensions LINE General Purpose 1.25 Max. (31,75) Ø.56 (14,22) LOAD .23 Curtis Industries A Division of Powers Holdings, Inc. Specifications subject to change. Dimensions are shown for reference purposes only. FD1 Filters FD10EE050 -48VDC LO A D LI NE (50Amp) Dimensions -48VDC G RTN RTN A .25 (6,35) D .25 (6,35) .59 (14,99) B + + L O A D L I N E E F – – #6-32 x .23 Min. Deep (4 Places) C Amps A B C D E F 30A, 50A 4.25 (107,95) 3.50 (88,9) 1.37 (34,79) 3.750 (95,25) 3.000 (76.2) 2.33 (59,18) 75A, 100A 4.25 (107,95) 3.50 (88,9) 1.37 (34,79) 3.750 (95,25) 3.000 (76.2) 2.33 (59,18) -48VDC L OAD L INE (100Amp) Dimensions -48VDC G RTN DC FILTERS FD10BB100 .69 (17,53) High Performance Terminals: AWG #8-24 Phoenix P/N VDFK-6 Suitable for Field Wiring RTN .25 .25 (6,35) (6,35) A D .59 (14,99) + B + L I N E L O A D F E – – #4 AWG Wire - 18" LG 105°C TEW-UL 1283 (4 Places) Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. #6-32 x .23 Min. Deep (4 Places) Curtis Industries A Division of Powers Holdings, Inc. C .50 (12,7) 1-800-657-0853 69 FD2 & FD3 Filters FD20HC080 80A LI NE (30, 50 and 80Amp) Dimensions 7.30 (185,4) 1.00 (25,4) .50 (12,7) -48VDC LO A D -48VDC G RTN RTN .50 Max. (12.7) 5.00 Max. (127) LOAD 4.00 (101,6) LINE 8.18 (207,8) .27 (6,858) 3.183 (80,84) 1.45 (36,83) 7.625 (193,7) .28 (7,112) 1.50 (38,1) .060 (1.524) 2.54 (64,5) 2.00 (50,8) .69 (17,5) Line Terminals 1/4-20 x .38 Lg Stud Pairs Terminal Block w/Optional Cover DC FILTERS Circuit Breaker 125% Trip, Medium Delay Red/Black Indicate Off 5000A Fault Current 1.100 (27,94) 4X #6-32 x .250 (6,35) .690 (17,526) www.curtisind.com ON OFF -48VDC G RTN 8.00 (203,2) 2X .260 (6,604) .23 7.52 (191) 4X 12.00±.25 1.17 (29,72) .75 (19,05) -48VDC 7.3 Max. (185,4) 2X .398 L (10,11) I N E 6.740 6.00 (171,2) (152,4) Line Terminals 1/4-20 x .38 Lg Stud Pairs Terminal Block w/Optional Cover 100A RTN RTN -48VDC .250 (6,35) .625 (15,88) 6X Ø .156 -48VDC (30, 50, 75 and 100Amp) Dimensions 1.60 Max. (40,64) LOAD .625 (15,87) 5.500 (139,7) High Current Connector + 48V – FD30RB100 70 2X .44 LINE High Performance 1.21 (30,73) 1.270 (32,26) L O A D 4X .358 (9,903) Curtis Industries A Division of Powers Holdings, Inc. 2.03 (51,56) RTN 1.00 Wire (25,4) #4AWG TEW-4 UL1283 -48VDC - Red RTN - Black 2 Wires per Terminal 4X .260 (6,604) 1.60 Max. (40,64) Specifications subject to change. Dimensions are shown for reference purposes only.
FD00AA006 价格&库存
很抱歉,暂时无法提供与“FD00AA006”相匹配的价格&库存,您可以联系我们找货
