3-phase + neutral line filters
FN 256
Compact general purpose
three-phase and neutral line EMC filter
n
Three-phase and neutral line filter for
general purpose four-wire filtering
n Compact space-saving design
n Choice of connection style
n Low operating leakage current
Technical specifications
Maximum continuous operating voltage:
Operating frequency:
Rated currents:
High potential test voltage:
Protection category:
Overload capability:
Temperature range (operation and storage):
Flammability corresponding to:
Design corresponding to:
MTBF @ 50°C/400V (Mil-HB-217F):
Typical electrical schematic
3x 480/277VAC
dc to 60Hz
8 to 160A @ 50°C
P –> E 2650VDC for 2 sec
P –> P 2100VDC for 2 sec
IP20
IP00 (filters with connectors -28)
4x rated current at switch on,
1.5x rated current for 1 minute, once per hour
-25°C to +100°C (25/100/21)
UL 94V-2 or better
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
600,000 hours
Features and benefits
n
FN 256 filters are designed specifically for
Approvals
L
L1
L1‘
L2
L2‘
L3
L3‘
Cx
R
N
N‘
Cy
R1
E
E
Line
Typical applications
n
General purpose four-wire filtering
also increase conducted immunity and
n
High-power office equipment
ranging from industrial controls to medical
thus contribute to overall system reliability.
n
Power supplies
electronics systems. These typically involve
n
n UPS
insufficiently filtered converters and
ratings in line with common fuse values
n
Medical applications
switch-mode power supplies on different
support a fast and easy application-specific
n
Electrical cabinets
phases, causing current imbalance and
filter selection and deployment.
n
Control panels
significant interference problems.
n
n
applications involving asymmetric loads,
n
Used as a mains input filter, FN 256 filters
Choice of connection style as well as filter
A light weight aluminium housing with a
Employing single-stage filter circuits for
small footprint ensures that the filters can
each phase and the neutral line, FN 256 fil-
be easily accommodated on control panels
ters provide high attenuation of both sym-
and in tight power cabinets.
metrical and asymmetrical interference.
Load
> Components > FN 256
Filter selection table
Filter*
FN 256-8-46
FN 256-16-46
FN 256-25-47
FN 256-36-47
FN 256-64-52
FN 256-80-..
FN 256-120-..
FN 256-160-..
Rated current
@ 50°C (40°C)
Leakage current**
@ 400VAC/50Hz
Power loss
@ 25°C/50Hz
[A] [mA]
8 (8.8)
3.4
16 (17.5)
3.4
25 (27)
3.4
36 (39)
3.4
64 (70)
3.4
80 (88)
3.4
120 (131)
5.0
160 (175)
6.8
Input/Output
connections
Weight
[W]
2.7
-46
6.0
-46
11.6
-47
14.8
-47
18.4
-52
18.8
-28***
-34
25.1
-28***
-35
30.7
-28***
-40
[kg]
0.8
1.1
1.4
1.5
2.2
4.5
6.1
8.0
To compile a complete part number, please replace the -.. with the required I/O connection style.
Maximum leakage under normal operating conditions, based on the assumption that all three phases and the neutral conductor are connected to the supply and the consumer. In this case, the
current will mainly return through the neutral line, not as earth leakage.
*** Filters with -28 connections are rated for 40°C environmental temperature only.
Typical filter attenuation
Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym; C = 0.1Ω/100Ω sym; D = 100Ω/0.1Ω sym
8A types
16A types
25A types
36A types
64A types
80A types
120A types
160A types
> Components > FN 256
Mechanical data
8 to 64A types
80 to 160A types (-28)
80 to 160A types (-34, -35, -40)
Dimensions
8A
16A
25A
36A
64A
80A (-28)
80A (-34)
120A (-28) 120A (-35) 160A (-28) 160A (-40)
A
B
C
D
E
F
G
H
I
J
K
L
120 120 130 130 140 160 160 180 180 200 200
143 143 153 153 153 170 170 170 170 170 170
80 80 115 115 125 110 110 130 140 130 160
115 115 125 125 125 140 140 140 140 140 140
80 80 90 90 100 110 110 130 130 150 150
127.5 127.5 137.5 137.5 137.5 153.5 153.5 153.5 153.5 153.5 153.5
6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5
1 1 1 1 1.5 1.5 1.5 1.5 1.5 1.5 1.5
18 18 18 18 18 33.5
39 33.5
45 33.5
49.5
M6 M6 M6 M6 M6 M10 M10 M10 M10 M10 M10
12 12 13 13 13 17.5 17.5 17.5 17.5 17.5 17.5
33 33 50 50 50 30 30 30 30 30 30
All dimensions in mm; 1 inch = 25.4mm
Tolerances according: ISO 2768-m / EN 22768-m
Filter input/output connector cross sections
-28 (M10)
-34 -35 -40 -46 -47 -52
Solid wire n/a
Flex wire n/a
AWG type wire
n/a
Recommended torque 15 - 17Nm
35mm2 50mm2 95mm2 10mm2 16mm2 25mm2
25mm2 50mm2 95mm2 6mm2 10mm2 16mm2
AWG 2
AWG 1/0
AWG 4/0
AWG 10
AWG 8
AWG 4
4.0 - 4.5Nm
7 - 8Nm
17 - 20Nm
0.7 - 0.8Nm
1.9 - 2.2Nm
1.9 - 2.2Nm
Please visit www.schaffner.com to find more details on filter connectors.
Your local partner: To find your local partner within Schaffner’s global network, please go to www.schaffner.com
May 2011
Headquarters and
global innovation and
development center
Schaffner Group
Nordstrasse 11
4542 Luterbach
Switzerland
T +41 32 681 66 26
F +41 32 681 66 30
info@schaffner.ch
www.schaffner.com
Sales and application centers
China
Schaffner EMC Ltd. Shanghai
Building 11, Lane 1365
East Kangqiao Road
Shanghai 201319
T +86 21 6813 9855
F +86 21 6813 9811
cschina@schaffner.com
www.schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
F +49 721 569110
germanysales@schaffner.com
Finland
Schaffner Oy
Tynninkuja 7
08700 Lohja
T +358 19 35 72 71
F +358 19 32 66 10
finlandsales@schaffner.com
France
Schaffner EMC S.A.S.
112, Quai de Bezons
95103 Argenteuil
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Italy
Schaffner EMC S.r.l.
Via Galileo Galilei, 47
20092 Cinisello Balsamo (MI)
T +39 02 66 04 30 45/47
F +39 02 61 23 943
italysales@schaffner.com
Japan
Schaffner EMC K.K.
Mitsui-Seimei Sangenjaya Bldg. 7F
1-32-12, Kamiuma, Setagaya-ku
Tokyo 154-0011
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
www.schaffner.jp
Sweden
Schaffner EMC AB
Turebergstorg 1, 6
19147 Sollentuna
T +46 8 5792 1121 / 22
F +46 8 92 96 90
swedensales@schaffner.com
Switzerland
Schaffner EMV AG
Nordstrasse 11
4542 Luterbach
T +41 32 681 66 26
F +41 32 681 66 41
sales@schaffner.ch
Schaffner‘s global network, please go to
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1
05-09 Kampong Ubi Industrial
Estate
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
© 2011 Schaffner EMC.
Specifications subject to change without
notice. All trademarks recognized.
Spain
Schaffner EMC España
Calle Caléndula 93,
Miniparc III, Edificio E
El Soto de la Moraleja,
Alcobendas
28109 Madrid
T +34 618 176 133
spainsales@schaffner.com
Taiwan
Schaffner EMV Ltd.
6th Floor, No 413
Rui Guang Road
Neihu District
Taipei City 114
T +886 2 87525050
F+886 2 87518086
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muang P.O. Box 14
Lamphun 51000
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
UK
Schaffner Ltd.
5 Ashville Way
Molly Millars Lane
Wokingham
Berkshire RG41 2PL
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
www.schaffner.uk.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey 08837
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
www.schaffner.com/us
www.schaffner.com
May 2011
Schaffner is an ISO-registered company.
Its products are designed and manufactured under the strict quality and environmental requirements of the ISO 9001 and
ISO 14001 standards.
This document has been carefully
checked. However, Schaffner does not
assume any liability for errors or inaccuracies.
很抱歉,暂时无法提供与“FN256-16-46”相匹配的价格&库存,您可以联系我们找货
