F1300/F1350/F1399 RFI Filters
Features:
• T Circuit Configuration—Designed for Motor,
Capacitive and Other Low Impedance Loads
• Dual Coils — Higher Performance in Unknown RFI
and Noise Susceptibility Applications
• Integral IEC Connector and PC Mounted Versions
Now Available
1A
2A
6A
10A
15A
20A
Termination
Line/Load
MODE
.15
.50
Frequency - MHz
1.0
5.0
10
30
F1300AA01
F1300BB01
QC/QC
Wire/Wire
Common
Differential
40
2
65
57
65
69
65
70
65
70
65
60
F1350AA01
F1350BB01
QC/QC
Wire/Wire
Common
Differential
30
2
60
57
65
69
65
70
65
70
65
60
F1399AA02
F1399BB02
QC/QC
Wire/Wire
Common
Differential
40
5
65
45
65
70
65
65
65
60
40
50
F1300AA03
F1300BB03
F1300CA03
F1300CP03
QC/QC
Wire/Wire
IEC/QC
IEC/PC
Common
Differential
40
7
65
64
65
70
65
70
65
70
65
58
F1350AA03
F1350BB03
F1350CA03
F1350CP03
QC/QC
Wire/Wire
IEC/QC
IEC/PC
Common
Differential
30
7
60
64
65
70
65
70
65
70
65
58
F1399AA03
F1399BB03
F1399CA03
QC/QC
Wire/Wire
IEC/QC
Common
Differential
40
12
65
55
65
70
65
65
65
60
40
50
F1300AA06
F1300BB06
F1300CA06
QC/QC
Wire/Wire
IEC/QC
Common
Differential
12
10
48
40
60
70
65
70
65
70
65
60
F1350AA06
F1350BB06
F1350CA06
QC/QC
Wire/Wire
IEC/QC
Common
Differential
2
10
40
40
60
70
65
70
65
70
65
60
F1399AA06
F1399BB06
F1399CA06
QC/QC
Wire/Wire
IEC/QC
Common
Differential
30
5
55
40
65
70
65
65
65
60
40
50
F1300AA10
F1300BB10
F1300CA10
QC/QC
Wire/Wire
IEC/QC
Common
Differential
12
13
48
13
60
64
65
70
65
67
65
56
F1350AA10
F1350BB10
QC/QC
Wire/Wire
Common
Differential
2
13
40
13
60
64
65
70
65
67
65
56
F1399AA10
F1399BB10
F1399CA10
F1399DD10
QC/QC
Wire/Wire
IEC/QC
Screw/Screw
Common
Differential
5
5
40
12
52
50
60
65
60
60
50
55
F1300AA15
QC/QC
Common
Differential
14
15
35
10
44
45
56
70
58
67
55
56
F1300AA20
QC/QC
Common
Differential
5
44
60
35
65
60
65
57
60
45
F1350AA20
QC/QC
Common
Differential
2
35
61
35
63
60
60
57
50
45
F1399AA20
F1399DD20
QC/QC
Screw/Screw
Common
Differential
5
5
40
12
52
50
60
65
60
60
52
55
SINGLE PHASE FILTERS
3A
MINIMUM INSERTION LOSS - dB (50 ohm Circuit)
Part
Number
General Purpose
Nominal
Current
Rating
NOTE: Other combinations of terminals may be specified on special order.
Dimensions are in inches and millimeters
unless otherwise specified.
Values in parentheses are metric equivalents.
Curtis Industries
A Division of Powers Holdings, Inc.
1-800-657-0853
11
F1300/F1350/F1399 RFI Filters (continued)
General Purpose
Specifications:
Rated Voltage: 250VAC Maximum - 50/60 Hz
Rated Current:
115VAC
1A
2A
3A
6A
10A
250VAC
1A
1.5A
2.5A
4A
6A
Current Overload: 6X for 8 seconds
Hi-Pot Test (1 min):
F1300/F1350
Line to Ground:
1500VAC
Line to Line:
1768VDC
Insulation Resistance: 9 x 109 Ω at 100VDC
Ambient Temperature: 40°C Max. at rated current
Humidity Range: 0% to 95% R.H.
Termination: A: QC – Quick Connect
C: IEC Receptacle
B: Wire
P: PC – P.C. Board
Maximum Leakage Current: Each Line to Ground
115VAC, 60Hz:
250VAC, 50Hz:
Agency Approvals:
F1300
0.4mA
.75mA
15A
15A
20A
16A
F1350 D1399
0.25mA 0.25mA
.40mA 0.45mA
F1360
.15mA
.25mA
F1370
.002mA
.005mA
F1380 F1390
.015mA .030mA
.025mA .050mA
Except 15Amp
A
F1300AA (1, 3, 6, 10 and 15Amp)
F1350AA (1, 3, 6 and 10Amp) Dimensions
Amps
A
B
C
D
E
1A
2.750
(69,9)
1.750
(44,5)
1.125
(28,5)
2.375
(60,3)
2.925
(74,3)
3A
3.312
(84,1)
2.000
(50,8)
1.125
(28,5)
2.940
(74,7)
3.49
(88,7)
6A
3.312
(84,1)
2.000
(50,8)
1.125
(28,5)
2.940
(74,7)
3.49
(88,7)
10A
3.312
(84,1)
2.000
(50,8)
1.500
(38,1)
2.940
(74,7)
3.49
(88,7)
15A
3.312
(84,1)
2.000
(50,8)
1.500
(38,1)
2.940
(74,7)
3.49
(88,7)
L
I
N
E
.250 QC
(6,4)
A
B
C
D
E
1A
2.750
(69,9)
1.750
(44,5)
1.125
(28,5)
2.375
(60,3)
2.000
(50,8)
3A
3.312
(84,1)
2.000
(50,8)
1.125
(28,5)
2.940
(74,7)
2.500
(63,5)
6A
3.312
(84,1)
2.000
(50,8)
1.125
(28,5)
2.940
(74,7)
2.500
(63,5)
10A
3.312
(84,1)
2.000
(50,8)
1.500
(38,1)
2.940
(74,7)
2.500
(63,5)
www.curtisind.com
B
E
F1300BB/F1350BB
12
L
O
A
D
C
A
.188 Dia.
(4,77)
2 Holes
Amps
.188 Dia.
(4,77)
2 Holes
D
D
L
I
N
E
L
O
A
D
E
B
4.000
(101,6)
Min.
.250±.062
(6,35) Typ.
C
No. 18 Gauge Wire
Curtis Industries
Specifications subject to change.
Dimensions are shown for
reference purposes only.
F1300/F1350 Simplified Schematic
L
LO A D
LINE
L
G
N
N
L
I
N
E
Refer to Page 40
for Standard
Mounting Cutouts
A
B
C
D
E
3A
2.500
(63,6)
2.000
(50,8)
1.500
(38,1)
.550
(14,0)
.565
(14,3)
6A
2.500
(63,5)
2.000
(50,8)
1.500
(38,1)
.550
(14,0)
.565
(14,3)
10A
2.880
(73,1)
2.120
(53,8)
1.500
(38,1)
.65
(16,0)
.565
(14,3)
L
I
N
E
L
O
A
D
(2) No. 6-32
UNC2B
E
B
D
A
C
.250 QC
(6,4)
Amps
L
O
A
D
2.000
(50,8)
F1300CP/F1350CP
(3Amp Only) Dimensions
.935
(23,7)
(2) No. 6-32
UNC2B
.500
(12,7)
1.500
(38,1)
2.500
(68,3)
.210
(53,3)
Refer to Page 40
for Standard
Mounting Cutouts
1.540
(39,1)
.25
(6,35)
.65
(16,51)
F1300AA/F1350AA
(20Amp Only) Dimensions
General Purpose
F1300CA (3, 6 and 10Amp)
F1350CA (3 and 6Amp) Dimensions
.65
(16,51)
3.75
(95,25)
3.35
(85,09)
4.12
(104.64)
.156
(3,96)
2.00
(50,8)
1.52
(38,61)
.96
(24,38)
3.92
(99,56)
Curtis Industries
1-800-657-0853
13
F1100/F1150
F1300/F1399 RFI
RFI Filters
Filters (continued)
F1399 Simplified Schematic
BLUE
BROWN
BROWN
General Purpose
LINE
LO A D
BLUE
G/Y
D
A
E
C
Amps
A
B
C
D
E
2A
3.35
(85,1)
1.81
(46,0)
1.16
(29,5)
2.375
(60,33)
2.78
(70,6)
3A
3.85
(97,8)
2.07
(52,6)
1.16
(29,5)
2.938
(74,63)
3.35
(85,1)
6A
3.85
(97,8)
2.07
(52,6)
1.16
(29,5)
2.938
(74,63)
3.35
(85,1)
10A
3.85
(97,8)
2.07
(52,6)
1.53
(38,9)
2.938
(74,63)
3.35
(85,1)
5.23
(132,8)
3.37
(85,6)
1.53
(38,9)
3.75
(95,25)
4.20
(106.7)
F1399DD (10 and 20Amp) Dimensions
Amps
A
B
C
D
E
10A
3.96
(100,6)
2.07
(52,6)
1.53
(38,9)
2.938
(74,63)
3.35
(85,1)
20A
5.34
(135,6)
3.37
(85,6)
1.53
(38,9)
3.75
(95,25)
4.20
(106,7)
D
Amps
A
B
C
D
E
2A
2.07
(52.6)
1.81
(46,0)
1.16
(29,5)
2.375
(60,33)
2.78
(70,6)
3A
2.56
(65,0)
2.07
(52,6)
1.16
(29,5)
2.938
(74,63)
3.35
(85.1)
6A
2.56
(65,0)
2.07
(52,6)
1.16
(29,5)
2.938
(74,63)
3.35
(85.1)
10A
2.56
(65,0)
2.07
(52,6)
1.53
(38,9)
2.938
(74,63)
3.35
(85,1)
B
A
#6-32
INSERT
C
16.0
(0.63)
6.35(0.25) FASTON TERMINAL,
WITH Ø1.78(0.070) HOLE
(SLOTTED HOLE FOR GROUND)
D
IEC CONNECTOR
F1399CA (3, 6 and 10Amp) Dimensions
Amps
A
B
C
D
3A
4.33
(110,0)
2.25
(57,2)
1.28
(32,5)
1.575
(40,0)
6A
4.33
(110,0)
2.25
(57,2)
1.28
(32,5)
1.575
(40,0)
10A
4.33
(110,0)
2.25
(57,2)
1.53
(38,9)
1.575
(40,0)
#8-32 SCREW
TERMINAL
SLOTTED HOLE,
6.4(.25)X4.0(.16)
#8-32 SCREW
TERMINAL
B
A
E
A
C
F1399BB (2, 3, 6 and 10Amp) Dimensions
B
20A
B
D
A
6.36(0.25) FASTON TERMINAL
WITH Ø1.78 (0.070) HOLE
F1399AA (2, 3, 6, 10 and 20Amp) Dimensions
WIRE LEADS, 18AWG,
(16AWG FOR 10A).
102(4.0) MIN.
E
B
D
C
50.8 (2.00)
C
E
14
www.curtisind.com
Curtis Industries
Standard Mounting Cutouts
F1200CA, F1300CA, F1400CA,
F1500CA, F1600CA, F1700CA
F1500FA, F1600FA,
1.20
(30.5)
.187
(4,75)
.638
(16,21)
.140 Dia.
(3,55)
2 Holes
✱.09 R
(2,29)
1.275
(32,39)
.90
(22,9)
.140 Dia.
(3,55)
2 Holes
1.575
(40,0)
.234
(5,94)
1.145
(29,08)
.450
(11,43)
✱ for mounting
from back side
1.417
(36,0)
How to Order
The Curtis part numbering system is made up of four
elements. Each element denotes a specific requirement
(mechanical or electrical) which, when properly
sequenced, fully identifies the required catalog filter. As
shown, the first five alpha/numeric characters denote
the series type; the sixth character (alpha) denotes the
type of line termination; the seventh character (alpha)
denotes the type of load termination; the last two
characters (numeric) denote the current rating.
Compose your part number as follows: Select the series
required, add two alpha character for the line and load
termination, followed by two numeric characters for
the required current rating. For example, F1100AB06
completely identifies an F1100 series filter with quick
connects on line side and wire leads on load side, with
a 6-amp rating.
F1100
X
X
SERIES
PE = Power Entry
PM = Medical
Power Entry
LINE TERMINATION
A = Quick Connects
B = Wire Leads
C = IEC Connector
D = Screw Terminals
(20 & 30 amp only)
F = Fused IEC
P = Printed Circuit Pins
W= Dual Fused IEC
J = Switched IEC
40
www.curtisind.com
LOAD
TERMINATION
A = Quick Connects
B = Wire Leads
D = Screw Terminals
(20 & 30 amp only)
S = Solder Tab
X
CURRENT
RATING
01 = 1 Amp
03 = 3 Amps
06 = 6 Amps
10 = 10 Amps
15 = 15 Amps
20 = 20 Amps
30 = 30 Amps
F1300CP, F1600CP
1.500
(38,1)
.600
(15,2)
N
.700
(17,8)
1.400
(35,6)
.062 Hole Dia.
(1,57)
5 Holes
L
F5500/5600/5700 SERIES
1.575
(40,01)
.90
(22,8)
.140 Dia.
(3,55)
2 Holes
.234 R.
(5,94)
(Typ.)
Curtis Industries
1.20
(30,48)
