F1199AA20
F1199AA20
    CURTISINDUSTRIES
    F1199AA20
F1199AA20 数据手册
F1100/F1150F/F1199 RFI Filters Features: SINGLE PHASE FILTERS F1100/F1150/F1199 Simplified Schematic L LINE General Purpose • Most Economical Design • Designed for General Purpose, Common Mode Applications • Available in Standard (F1100) and Low-Leakage (F1150) (F1160) (F1170) (F1180) (F1190) (F1199) Models G N Nominal Current Rating 115 VAC 1A 2A 3A 6A 10A 20A 30A MINIMUM INSERTION LOSS - dB (50 ohm Circuit) Part Number Termination Line/Load MODE Frequency - MHz .15 .50 1.0 5.0 10 30 F1100AA01 F1100BB01 QC/QC Wire/Wire Common Differential 20 35 43 52 55 55 65 50 50 F1150AA01 F1150BB01 QC/QC Wire/Wire Common Differential 20 30 37 50 55 50 65 50 50 F1199AA01 QC/QC Common Differential 32 5 45 14 45 23 43 47 43 50 40 45 F1199AA02 F1199BB02 QC/QC Wire/Wire Common Differential 24 5 35 13 43 16 45 45 45 50 40 45 F1100AA03 F1100BB03 F1100PP03 QC/QC Wire/Wire PC/PC Common Differential 20 35 43 52 55 55 64 50 46 F1150AA03 F1150BB03 QC/QC Wire/Wire Common Differential 20 30 37 50 55 50 64 50 46 F1199AA03 F1199BB03 QC/QC Wire/Wire Common Differential 20 5 30 12 38 14 48 38 48 44 44 42 F1100AA06 F1100BB06 QC/QC Wire/Wire Common Differential 10 22 2 30 5 46 51 50 57 45 49 F1150AA06 F1150BB06 QC/QC Wire/Wire Common Differential 10 20 2 27 5 45 51 45 57 45 49 F1199AA06 F1199BB06 QC/QC Wire/Wire Common Differential 9 5 20 12 28 14 42 33 50 42 47 42 F1100AA10 F1100BB10 QC/QC Wire/Wire Common Differential 10 22 30 2 46 27 50 47 45 50 F1150AA10 F1150BB10 QC/QC Wire/Wire Common Differential 10 20 27 2 45 27 45 47 45 50 F1199AA10 F1199BB10 F1199DD10 QC/QC Wire/Wire Screw/Screw Common Differential 9 5 20 12 25 14 38 33 42 42 40 42 F1100AA20 F1100DD20 QC/QC Screw/Screw Common Differential 8 18 22 5 36 22 42 46 45 60 F1150AA20 F1150DD20 QC/QC Screw/Screw Common Differential 8 15 20 5 32 22 38 46 45 60 F1199AA20 F1199DD20 QC/QC Screw/Screw Common Differential 10 5 20 12 28 15 35 30 38 40 40 40 F1199DD30 Screw/Screw Common Differential 13 5 23 12 30 15 35 30 38 40 40 40 NOTE: Other combinations of terminals may be specified on special order. 4 www.curtisind.com Curtis Industries A Division of Powers Holdings, Inc. Specifications subject to change. Dimensions are shown for reference purposes only. F1100AA/F1150AA Specifications: (1, 3, 6, 10 and 20Amp) Dimensions Amps A B C D E 1A 2.500 (63,5) 1.750 (44,5) .625 (15,8) 2.125 (53,9) 1.425 (362) 3A 2.500 (63,5) 1.750 (44,5) .750 (19,1) 2.125 (53,9) 1.8 (45,8) 6A 2.500 (63,5) 1.750 (44,5) .750 (19,1) 2.125 (53,9) 1.8 (45,8) 10A 2.500 (63,5) 1.750 (44,5) 1.125 (28,5) 2.125 (53,9) 1.8 (45,8) 20A 2.760 (70,6) 2.000 (60,8) 1.125 (28,5) 2.375 (60,3) 2.550 (64,8) .188 Dia. (4,77) 2 Holes L I N E B L O A D D A F1100 F1500 F1199 F1100 Except 20Amp F1199 F1100 F1150 F1199 F1100DD/F1150DD (20Amp Only) Dimensions .188 Dia. (4,77) 2 Holes 2.000 (50,8) (5) No. 8-32 .625 Studs (15,8) L I N E L O A D 2.760 (70,6) .250 Q.C. (6.4) F1100BB/FB1150BB (1, 3, 6 and 10Amp) Dimensions Amps A B C D E 1A 2.500 (63,5) 1.750 (44,5) .625 (15,8) 2.125 (53,9) .875 (22,2) 3A 2.500 (63,5) 1.750 (44,5) .750 (19,1) 2.125 (53,9) 1.250 (31,8) 6A 2.500 (63,5) 1.750 (44,5) .750 (19,1) 2.125 (53,9) 1.250 (31,8) 10A 2.500 (63,5) 1.750 (44,5) 1.125 (28,5) 2.125 (53,9) 1.250 (31,8) .188 Dia. (4,77) 2 Holes 2.375 (60,3) B 2.000 (50,8) SINGLE PHASE FILTERS E C F1150 F1199 General Purpose Rated Voltage: 250VAC Maximum - 50/60 Hz Rated Current: 115VAC 250VAC 1A 1A 2A 1.5A 3A 2.5A 6A 4A 10A 6A 20A 10A 30A 15A Current Overload: 6X for 8 seconds Hi-Pot Test (1 min): F1100/F1150 F1199 Line to Ground: 1500VAC 1500VAC Line to Line: 1768VDC 1450VDC Insulation Resistance: 9 x 109 Ω at 100VDC Ambient Temperature: 40°C Max. at rated current Humidity Range: 0% to 95% R.H. Termination: A: QC – Quick Connect D: Screw B: Wire P: PCB Mount Maximum Leakage Current: Each Line to Ground F1100 F1150 F1199 115VAC, 60Hz: 0.40mA 0.25mA 0.25mA 250VAC, 50Hz: .75mA 0.40mA 0.45mA Agency Approvals: .625 (15,8) 1.125 (25,5) L I N E L O A D E A D 4.000 (101,6) Min. .250±.062 (6,35) Typ. C No. 18 Gauge Wire Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 5 F1100/F1150/F1199 RFI Filters (continued) SINGLE PHASE FILTERS General Purpose F1199AA (1, 2, 3, 6, 10 and 20Amp) Dimensions F1199BB (2, 3, 6 and 10Amp) Dimensions Amps A B C D E Amps A B C D E 1A 2.53 (64,3) 1.82 (46,2) 0.66 (16,8) 2.126 (54,0) 2.25 (57,2) 2A 2.53 (64,3) 1.82 (46,2) 0.66 (16,8) 2.126 (54,0) 0.96 (24,4) 2A 2.53 (64,3) 1.82 (46,2) 0.66 (16,8) 2.126 (54,0) 2.25 (57,2) 3A 2.53 (64,3) 1.82 (46,2) 0.78 (19,8) 2.126 (54,0) 1.32 (33,5) 3A 2.53 (64,3) 1.82 (46,2) 0.78 (19,8) 2.126 (54,0) 2.61 (66,3) 6A 2.53 (64,3) 1.82 (46,2) 0.78 (19,8) 2.126 (54,0) 1.32 (33,5) 6A 2.53 (64,3) 1.82 (46,2) 0.78 (19,8) 2.126 (54,0) 2.61 (66,3) 10A 2.53 (64,3) 1.82 (46,2) 1.16 (29,5) 2.126 (54,0) 1.32 (33,5) 10A 2.53 (64,3) 1.82 (46,2) 1.16 (29,5) 2.126 (54,0) 2.61 (66,3) 20A 2.81 (71,4) 2.07 (52,6) 1.16 (29,5) 2.375 (60,33) 3.36 (85,3) WIRE LEADS, 18AWG, (16AWG FOR 10A). 102(4.0) MIN. BLUE 6.36(0.25) FASTON TERMINAL WITH Ø1.78 (0.070) HOLE (SLOTTED HOLE FOR GROUND) A D G/Y A D BROWN B BROWN E B E BLUE C C F1199DD (10, 20 and 30Amp) Dimensions Amps A B C D E 10A 2.53 (64,3) 1.82 (46,2) 1.16 (29,5) 2.126 (54,0) 2.72 (69,1) 20A 2.81 (71,4) 2.07 (52,6) 1.16 (29,5) 2.375 (60,33) 3.46 (87,9) 30A 4.20 (106,7) 3.38 (85,9) 1.53 (38,9) 3.75 (95,25) 5.34 (135,6) F1100PP Recommended PC Mounting .250 Dia. Pads 5 Places 1.75 MOUNTING FLANGE #8-3 SCREW TERMINAL .210 Stamp this surface 1.25 A D B E .062 Dia. Hole 5 Places C L I N E L O A D .500 .750 1.00 .75 6 www.curtisind.com Curtis Industries A Division of Powers Holdings, Inc. Specifications subject to change. Dimensions are shown for reference purposes only.
F1199AA20
1. 物料型号:文档列出了不同型号的F1100、F1150和F1199 RFI滤波器,包括它们的额定电流和特定型号的组合。
2. 器件简介:这些滤波器设计用于一般用途和共模应用,具有最经济的设计,并提供标准型和低泄漏型等多种型号。
3. 引脚分配:文档提供了不同型号滤波器的引脚分配和端接方式,包括快速连接(QC)、接线(Wire)、螺丝(Screw)和PCB安装(P)。
4. 参数特性:包括额定电压、额定电流、过载电流、绝缘电阻、环境温度和湿度范围等。
5. 功能详解:文档提供了滤波器的简化原理图和插入损耗数据,展示了在不同频率下的最小插入损耗。
6. 应用信息:虽然文档没有直接提供应用信息,但从其参数和设计可以推断这些滤波器适用于需要减少射频干扰的单相电源线路。
7. 封装信息:文档提供了不同型号滤波器的尺寸和安装细节,包括快速连接终端、螺丝终端和PCB安装选项。
F1199AA20 价格&库存
很抱歉,暂时无法提供与“F1199AA20”相匹配的价格&库存,您可以联系我们找货
F1199AA20
  • 1+278.485941+35.97822
  • 10+227.2549810+29.35958
  • 30+206.6043030+26.69167
库存:65
F1199AA20
    库存:5
