F1200DD20
F1200DD20
    CURTISINDUSTRIES
    F1200DD20
F1200DD20 数据手册
F1200/F1250/F1299 RFI Filters Features: • Designed for General Purpose Common Mode and Differential Mode Applications • Higher Line-to-Line Capacitance for Protection from Pulsed, Intermittent, or Continuous RFI 1A 2A 6A 10A 20A 30A Termination Line/Load MODE .15 .50 Frequency - MHz 1.0 5.0 10 30 F1200AA01 F1200BB01 QC/QC Wire/Wire Common Differential 20 4 35 38 43 59 52 66 55 62 50 54 F1250AA01 F1250BB01 QC/QC Wire/Wire Common Differential 20 4 30 38 37 59 50 66 50 62 50 54 F1299AA02 F1299BB02 QC/QC Wire/Wire Common Differential 24 6 35 35 43 50 45 55 45 50 40 45 F1200AA03 F1200BB03 F1200CA03 QC/QC Wire/Wire IEC/QC Common Differential 20 4 35 38 43 59 52 70 55 64 50 59 F1250AA03 F1250BB03 F1250CA03 QC/QC Wire/Wire IEC/QC Common Differential 20 4 30 38 37 59 50 70 50 64 50 59 F1299AA03 F1299BB03 F1299CA03 QC/QC Wire/Wire IEC/QC Common Differential 26 6 37 40 45 55 45 55 45 50 40 45 F1200AA06 F1200BB06 F1200CA06 QC/QC Wire/Wire IEC/QC Common Differential 10 9 22 25 30 48 46 70 50 70 45 62 F1250AA06 F1250BB06 F1250CA06 QC/QC Wire/Wire IEC/QC Common Differential 10 9 20 25 27 48 45 70 45 70 45 62 F1299AA06 F1299BB06 F1299CA06 QC/QC Wire/Wire IEC/QC Common Differential 20 6 31 35 40 50 45 55 45 50 40 45 F1200AA10 F1200BB10 F1200CA10 QC/QC Wire/Wire IEC/QC Common Differential 10 10 22 16 30 43 46 70 50 70 45 66 F1250AA10 F1250BB10 F1250CA10 QC/QC Wire/Wire IEC/QC Common Differential 10 10 20 16 27 43 45 70 45 70 45 66 F1299AA10 F1299BB10 F1299CA10 F1299DD10 QC/QC Wire/Wire IEC/QC Screw/Screw Common Differential 9 14 20 14 25 38 38 50 42 48 40 45 F1200AA20 F1200DD20 QC/QC Screw/Screw Common Differential 10 9 22 19 30 44 42 70 47 70 40 70 F1250AA20 F1250DD20 QC/QC Screw/Screw Common Differential 10 9 20 19 25 44 38 70 40 70 40 70 F1299AA20 F1299DD20 QC/QC Screw/Screw Common Differential 10 14 20 14 28 38 35 50 38 48 40 45 F1200DD30 Screw/Screw Common Differential 7 11 15 13 20 44 34 70 42 60 40 57 F1299DD30 Screw/Screw Common Differential 12 15 23 40 30 55 35 55 38 55 40 50 SINGLE PHASE FILTERS 3A MINIMUM INSERTION LOSS - dB (50 ohm Circuit) Part Number General Purpose Nominal Current Rating • Available in Standard (F1200) and Low-Leakage (F1250) (F1260) (F1270) (F1280) (F1299) Models • Available with Integral IEC Connector up to 10Amps NOTE: Other combinations of terminals may be specified on special order. Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 7 F1200/F1250/F1299 RFI Filters (continued) F1200/F1250 Simplified Schematic SINGLE PHASE FILTERS L L LO A D LINE G N N F1299 Simplified Schematic L L G N N F1280 .015mA .025mA LO A D Rated Voltage: 250VAC Maximum - 50/60 Hz Rated Current: 115VAC 1A 2A 3A 6A 10A 20A 30A 250VAC 1A 1.5A 2.5A 4A 6A 10A 15A Current Overload: 6X for 8 seconds Hi-Pot Test (1 min): F1200 Series F1299 Series Line to Ground: 1500VAC 1500VAC Line to Line: 1768VDC 1450VDC Insulation Resistance: 9 x 109 Ω at 100VDC Ambient Temperature: 40°C Max at rated current Humidity Range: 0% to 95% R.H. Termination: A: QC – Quick Connect C: IEC Receptacle B: Wire D: Screw Maximum Leakage Current: Each Line to Ground F1200 F1250 F1299 F1260 F1270 115VAC, 60Hz: 0.40mA 0.25mA .15mA .25mA .002mA 250VAC, 50Hz: .75mA .40mA .25mA .45mA .005mA Agency Approvals F1200: LINE General Purpose Specifications: F1299 .030mA .050mA Except 30Amp Agency Approvals F1299: F1200AA/F1250AA (1, 3, 6, 10 and 20Amp) Dimensions Amps A B C D E F 1A 2.750 (69,9) 2.00 (50,8) .875 (22,2) 2.375 (60,3) 1.750 (44,5) .550 (14,0) 3A 2.750 (69,9) 2.00 (50,8) 1.125 (28,5) 2.375 (60,3) 1.750 (44,5) .550 (14,0) 6A 2.750 (69,9) 2.00 (50,8) 1.125 (28,5) 2.375 (60,3) 1.750 (44,5) .550 (14,0) 10A 2.750 (69,9) 2.00 (50,8) 1.125 (28,5) 2.375 (60,3) 2.000 (50,8) .550 (14,0) 20A 3.310 (84,1) 2.50 (63,5 ) 1.500 (38,1) 2.940 (74,7) 2.000 (50,8) .550 (14,0) .188 Dia. (4,77) 2 Holes L I N E B F L O A D A D E F C .250 QC (6,4) F1200BB/FB1250BB (1, 3, 6 and 10Amp) Dimensions 8 Amps A B C D E 1A 2.750 (69,9) 2.00 (50,8) .875 (22,2) 2.375 (60,3) 1.750 (44,5) 3A 2.750 (69,9) 2.00 (50,8) 1.125 (28,5) 2.375 (60,3) 1.750 (44,5) 6A 2.750 (69,9) 2.00 (50,8) 1.125 (28,5) 2.375 (60,3) 1.750 (44,5) 10A 2.750 (69,9) 2.00 (50,8) 1.125 (28,5) 2.375 (60,3) 2.000 (50,8) www.curtisind.com .188 Dia. (4,77) 2 Holes B .250±.062 (6,35) Typ. 4.000 (101,6) Min. No. 18 Gauge Wire Curtis Industries A Division of Powers Holdings, Inc. L I N E L O A D D A E C Specifications subject to change. Dimensions are shown for reference purposes only. F1200CA/F1250CA (3, 6, and 10Amp) Dimensions L I N E D (2) No. 6-32 UNC2B L O A D B C F1200DD/F1250DD A B C D 3A 2.55 (64,8) 2.000 (50,8) 1.50 (38,1) 1.575 (40,0) 6A 3.05 (77,5) 2.000 (50,8) 1.500 (38,1) 1.575 (40,0) 10A 3.05 (77,5) 2.000 (50,8) 1.500 (38,1) 1.575 (40,0) F1200DD30 (20Amp Only) Dimensions (30Amp Only) Dimensions .188 Dia. (4,77) 2 Holes 2.500 (63,5) .625 (15,8) L O A D 2.940 (74,7) 2.000 (50,8) 3.370 (85,57) 3.312 (84,1) .625 (15,8) .590 (14,99) L O A D No. 8-32 Stud 4.140 (105,2) 3.750 (95,25) 3.140 (79,75) 1.520 (38,61) 1.500 (38,1) Also Available with .250” Quick Connect Terminals L I N E 2.000 (50,8) .250 X .156 Slot 3.875 (98,42) F1299AA (2, 3, 6, 10 and 20Amp) Dimensions Amps A B C D E 2A 2.81 (71,4) 2.07 (52,6) 0.91 (23,1) 2.375 (60,33) 3.10 (78,7) 3A 2.81 (71,4) 2.07 (52,6) 1.16 (29,5) 2.375 (60,33) 3.10 (78,7) 6A 2.81 (71,4) 2.07 (52,6) 1.16 (29,5) 2.375 (60,33) 3.10 (78,7) 10A 2.81 (71,4) 2.07 (52,6) 1.16 (29,5) 2.375 (60,33) 3.35 (85,1) 20A 3.35 (85,1) 2.56 (65,0) 1.53 (38,9) 2.938 (74,63) 3.35 (85,1) Dimensions are in inches and millimeters unless otherwise speci?ed. Values in parentheses are metric equivalents. 6.36(0.25) FASTON TERMINA WITH Ø1.78 (0.070) HOLE (SLOTTED HOLE FOR GROUND) A D L SINGLE PHASE FILTERS (5) No. 8-32 Studs .600 (15,24) L I N E General Purpose Refer to Page 40 for Standard Mounting Cutouts A Amps B E Curtis Industries A Division of Powers Holdings, Inc. C 1-800-657-0853 9 F1200/F1250/F1299 RFI Filters (continued) SINGLE PHASE FILTERS General Purpose F1299BB (2, 3, 6 and 10Amp) Dimensions Amps A B C D E 2A 2.81 (71,4) 2.07 (52,6) 0.91 (23,1) 2.375 (60,33) 1.81 (46,0) 3A 2.81 (71,4) 2.07 (52,6) 1.16 (29,5) 2.375 (60,33) 3.10 (78,7) 6A 2.81 (71,4) 2.07 (52,6) 1.16 (29,5) 2.375 (60,33) 3.10 (78,7) 10A 2.81 (71,4) 2.07 (52,6) 1.16 (29,5) 2.375 (60,33) 2.07 (52,6) WIRE LEADS, 18AWG, (16AWG FOR 10A). 102(4.0) MIN. BLUE BLUE G/Y A D BROWN B BROWN E C F1299CA (3, 6 and 10Amp) Dimensions Amps A B C D 3A 3.21 (81,5) 2.25 (57,2) 1.28 (32,5) 1.575 (40,0) 6A 3.21 (81,5) 2.25 (57,2) 1.28 (32,5) 1.575 (40,0) 10A 3.71 (94,2) 2.25 (57,2) 1.28 (32,5) 1.575 (40,0) B #6-32 INSERT A C 16.0 (0.63) 6.35(0.25) FASTON TERMINAL, WITH Ø1.78(0.070) HOLE (SLOTTED HOLE FOR GROUND) D IEC CONNECTOR F1299DD (10, 20 and 30Amp) Dimensions Amps A B C D E 10A 2.81 (71,40) 2.07 (52,6) 1.16 (29,5) 2.375 (60,33) 3.46 (87,9) 20A 3.35 (85,1) 2.56 (65,0) 1.53 (38,9) 2.938 (74,63) 3.46 (87,9) 30A 4.20 (106,7) 3.38 (85,9) 1.53 (38,9) 3.750 (95,25) 5.34 (135,6) MOUNTING FLANGE #8-3 SCREW TERMINAL A D B E C SLOTTED HOLE, 6.4(.25)X4.0(.16) #8-32 SCREW TERMINAL A B D 50.8 (2.00) C E 10 www.curtisind.com Curtis Industries A Division of Powers Holdings, Inc. Specifications subject to change. Dimensions are shown for reference purposes only. Standard Mounting Cutouts F1200CA, F1300CA, F1400CA, F1500CA, F1600CA, F1700CA F1500FA, F1600FA, 1.20 (30.5) .187 (4,75) .638 (16,21) .140 Dia. (3,55) 2 Holes ✱.09 R (2,29) 1.275 (32,39) .90 (22,9) .140 Dia. (3,55) 2 Holes 1.575 (40,0) .234 (5,94) 1.145 (29,08) .450 (11,43) ✱ for mounting from back side 1.417 (36,0) SINGLE PHASE FILTERS How to Order The Curtis part numbering system is made up of four elements. Each element denotes a specific requirement (mechanical or electrical) which, when properly sequenced, fully identifies the required catalog filter. As shown, the first five alpha/numeric characters denote the series type; the sixth character (alpha) denotes the type of line termination; the seventh character (alpha) denotes the type of load termination; the last two characters (numeric) denote the current rating. Compose your part number as follows: Select the series required, add two alpha character for the line and load termination, followed by two numeric characters for the required current rating. For example, F1100AB06 completely identifies an F1100 series filter with quick connects on line side and wire leads on load side, with a 6-amp rating. F1100 X X SERIES PE = Power Entry PM = Medical Power Entry LINE TERMINATION A = Quick Connects B = Wire Leads C = IEC Connector D = Screw Terminals (20 & 30 amp only) F = Fused IEC P = Printed Circuit Pins W= Dual Fused IEC J = Switched IEC 40 www.curtisind.com LOAD TERMINATION A = Quick Connects B = Wire Leads D = Screw Terminals (20 & 30 amp only) P = Printed Circuit Pins S = Solder Tab X CURRENT RATING 01 = 1 Amp 03 = 3 Amps 06 = 6 Amps 10 = 10 Amps 15 = 15 Amps 20 = 20 Amps 30 = 30 Amps F1300CP, F1600CP 1.500 (38,1) .600 (15,2) N .700 (17,8) 1.400 (35,6) .062 Hole Dia. (1,57) 5 Holes L F5500/5600/5700 SERIES 1.575 (40,01) .90 (22,8) .140 Dia. (3,55) 2 Holes .234 R. (5,94) (Typ.) Curtis Industries A Division of Powers Holdings, Inc. 1.20 (30,48) Specifications subject to change. Dimensions are shown for reference purposes only.
F1200DD20 价格&库存
很抱歉,暂时无法提供与“F1200DD20”相匹配的价格&库存,您可以联系我们找货
