FN3310-250-99-R5
FN3310-250-99-R5
    SCHAFFNER(夏弗纳)
    LINEFILTER520VAC250ACHASS
FN3310-250-99-R5 数据手册
DATASHEET 3-Phase Filters FN 3311 and FN 3310 Compact power line AC EMC/EMI filter High current 3-phase filter up to 2300A Extremly compact and light weight design Approvals Minimum installation foot print Performance optimised for standard purpose applications FN 3310 series without Cy capacitors to ground The FN 3311 / FN 3310 poduct series of standard EMC/EMI filters are based on Schaffner’s many years of expertise in filter design for all types of converter and inverter applications. Installed between the PV inverter and the power grid, the FN 3311 / FN 3310 AC filters are used to influence positively the conducted emissions on the grid side to help to comply with the required emission standards. Features and benefits Technical specifications Maximum continuous operating voltage Operating frequency Rated currents High potential test voltage Protection category Overload capability Temperature range (operation and storage) Climatic category Terminals/Housing Flammability corresponding to Design corresponding to 3x 520/300 VAC for FN 3311 3x 520 VAC for FN 3310 DC to 60Hz 250 to 2300 A @ 50°C P –> E 2kVAC for 2 sec P –> P 2.25kVDC for 2 sec IP00 4x rated current at switch on, max. 8 sec 1.5x rated current for 1 minute, once per hour -40°C to +100°C 40/100/21 acc. to IEC60068-1 Ni plated cu bars/Metal UL 94V-0 UL 1283, CSA 22.2 No. 8, IEC/EN 60939, EN60721-3 The FN 3311 / FN 3310 series are the most compact dedicated high current AC filters, not only suitable for PV applications, but being an optimum fit with most modern PV inverter topologies. In addition the filters can be configured in a very flexible way to fulfil custom specific application requirements. All FN 3311 / FN 3310 come in unsymmetrical housings, which help to prevent inverse installation and wrong electrical connection. Along with solar panel-side installed Schaffner DC EMC/EMI filters FN 2211 / FN 2210, the AC filters FN 3311 / FN 3310 are key to meet the stringent international standards for electromagnetic compatibility and help to ensure a reliable and fault-free operation of the entire PV system. Typical applications The FN 3311 / FN 3310 series are primarily designed for all kind of power line connected converter and inverter applications between 250 and 2'300 A. However, they are optimised for PV inverter and can potentially also be applied for general purpose motor drives applications. Typical electrical schematic FN 3311 Typical electrical schematic FN 3310 2 EMC/EMI Products Schaffner Group Datasheets 2015 Filter selection table Filters */** Rated current FN 3311 with Cy caps FN 3311-250-99-C16-R55 Typical inverter FN 3311-600-99-C16-R55 100 0.06 18 2.3 600 250 0.06 33 4.0 FN 3311-1000-99-C16-R55 1000 FN 3311-2300-99-C16-R55 2300 1500 FN 3311-1500-99-C16-R55 FN 3310 without Cy caps 400 500 800/1000 250 FN 3310-250-99-R5 9.9 250 33 4.0 FN 3310-2300-99-R5 2300 1500 5.5 2.3 400 0.06 133 18 1000 FN 3310-1500-99-R5 0.06 70 3.1 100 FN 3310-1000-99-R5 600 0.06 30 18.2 150 FN 3310-600-99-R5 0.06 [kg] 201 400 FN 3310-400-99-R5 @ 25 °C/DC [W] Weight 250 150 @ 520VAC/50Hz [mA] Power losss AC power rating*** [kVA] 400 FN 3311-400-99-C16-R55 Leakage current**** @ 50 °C [A] 30 70 500 133 800/1000 201 3.1 5.5 9.9 18.2 * Filters with higher current ratings available upon request. ** Filters with reduced Cy capacitance to ground for high asymmetrical currents and higher voltages available upon request. *** Calculated at rated current, 480 VAC (FN 3311) / 690 VAC (FN 3311HV) and cos phi = 0.8. The exact value depends upon the efficiency of the drive, the motor and the entire application. **** Leakage current according IEC 60939-1 Typical filter attenuation FN 3311-xxx-99-C16-R55 Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym 250 / 400 A types 600 A types 1'000 / 1'500 A types 2'300A types Typical block schematic 1 PV modules 2 Schaffner DC filter FN 22xx 3 Central Inverter 4 Schaffner magnetic components 5 Schaffner AC EMC/EMI filter FN 3xxx Important note: depending on the grounding scheme of the solar power system, including the solar panel and the grid side transformer, the appropriate DC- and AC EMC/EMI filter version need to be selected. For support, please contact your local Schaffner sales office or partner. EMC/EMI Products 3 Schaffner Group Datasheets 2015 Busbar connections Mechnical data 250 to 2'300 A types 250 to 1'000 A types 1'500 A types 2'300 A types Note: all FN 3311 and FN 3310 provide unsymmetrical mounting hole patterns to prevent inverse filter installation in the field. Dimensions FN 3311 / FN 3310 250 A FN 3311 / FN 3310 400 A FN 3311 / FN 3310 600 A FN 3311 / FN 3310 1'000 A FN 3311 / FN 3310 1'500 A FN 3311 / FN 3310 2'300 A A 170 175 190 190 195 220 C 140 140 140 140 150 165 B D E F1 F2 G H J 195 235 195 155 160 210 250 205 170 175 220 265 220 180 185 220 305 220 180 185 225 360 240 215 220 280 410 265 235 240 Ø7 Ø9 Ø9 Ø9 Ø 11 Ø 11 M6 M8 M8 M8 M10 M10 1.5 2 2 2.5 2.5 2.5 K 200 (+/- 1) 210 (+/- 1) 225 (+/- 1) 225 (+/- 1) 241 (+/- 1) 266 (+/- 1) M 41 46 50 53 59 60.5 L N O 215 24.5 230 27 245 29.5 245 29.5 265 26 34.8 P 49 (+/- 0.5) 54 (+/- 0.5) 59 (+/- 0.5) 59 (+/- 0.5) 69.5 (+/- 0.5) V 20 25 25 40 60 X 10 12.5 12.5 20 Ø9 Ø 11 Ø 11 S W Y Z 3 32.5 4 37.5 8 37.5 8 57.5 Ø 13.5 26 10 17 82.5 Ø 13.5 All dimensions in mm; 1 inch=25.4mm Tolerances according: ISO 2768-m / EN 22768-m, if not stated otherwise Please see the brochure "Basics in EMC and Power Quality" on our website www.schaffner.com/downloads to find more details on filter connectors. 290 35 40 80 (+/- 0.5) 40 70 15 20 95 Ø 13.5 4 EMC/EMI Products Headquarters, global innovation and development center Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 6816 626 F +41 32 6816 630 info@schaffner.com http://www.schaffner.com Schaffner Group Sales and application centers China Schaffner EMC Ltd. Shanghai T20-3, No 565 Chuangye Road Pudong New Area 201201 Shanghai T +86 21 3813 9500 F +86 21 3813 9501 / 02 cschina@schaffner.com http://www.schaffner.com.cn/ Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 19 35 72 71 finlandsales@schaffner.com France Schaffner EMC S.A.S. 112 Quai de Bezons Boîte postale 133 95100 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com Italy Schaffner EMC S.r.l. Via Galileo Galilei 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45 /47 F +39 02 61 23 943 italysales@schaffner.com To nd your local partner within Schaffner‘s global network: www.schaffner.com © 2015 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published speci cations are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published speci cations. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Datasheets Japan Schaffner EMC K.K. 1-32-12, Kamiuma, Setagaya-ku 7F Mitsui-seimei Sangenjaya Bldg. 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com http://www.schaffner.jp Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 05-09 Kampong Ubi Industrial Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E, Alcobendas Miniparc III, Edificio E El Soto de la Moraleja Alcobendas 28109 Madrid M +34 618 176 133 T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 F +41 32 681 66 41 switzerlandsales@schaffner.com Taiwan R.O.C. Schaffner EMV Ltd. 6 Floor, No. 413 Rui Guang Road 114 Neihu District Taipei City T +886 2 87525050 F +886 2 87518086 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com http://www.schaffner.uk.com USA Schaffner EMC Inc. 52 Mayfield Avenue 08837 Edison, New Jersey T +1 800 367 5566 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com http://www.schaffner.com/us Schaffner MTC LLC 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 http://www.schaffner-mtc.com Schaffner Trenco LLC 2550 Brookpark Road 44134 Cleveland, Ohio T +1 216 741 5282 F +1 216 741 4860 http://schaffner-trenco.com 2015
FN3310-250-99-R5 价格&库存
很抱歉,暂时无法提供与“FN3310-250-99-R5”相匹配的价格&库存,您可以联系我们找货
