FN2211-1500-99-C30-R55
    SCHAFFNER(夏弗纳)
    LINE FILTER 1KVDC 1.5KA CHASS
FN2211-1500-99-C30-R55 数据手册
DATASHEET DC Filters FN 2211 and FN 2210 Compact high current DC EMC/EMI filter Reduces conducted emissions towards the solar panel Approvals Reduces the probability of EMI radiation off the solar panel Helps to prevent premature panel aging Helps to meet international EMC regulations Most compact standard solution in the industry FN 2210 without Cy capacitors to ground The FN 2211 / FN 2210 series are the most compact dedicated high current DC filters for PV inverters in the industry and therefore are an optimum fit with most modern PV inverter generation. In addition the filters can be configured in a very flexible way to fulfil customized application requirements. All FN 2211 / FN 2210 come in unsymmetrical housings, which help to prevent inverse installation and wrong electrical connection. Along with grid-side installed Schaffner AC EMC/EMI filters FN 2211 / FN 2210, the DC filters FN 2211 / FN 2210 are key to meet the stringent international standards for electromagnetic compatibility and help to ensure a reliable and fault-free operation of the entire PV system. Features and benefits Technical specifications Maximum continuous operating voltage Operating frequency 1000 VDC DC High potential test voltage P -> E 4800VDC for 2 sec P -> P 3600VDC for 2 sec Rated currents Protection category Overload capability Temperature range (operation and storage) Climatic category Terminals/Housing Flammability corresponding to Design corresponding to 250 to 2300 A @50°C IP00 4x rated current at switch on, max. 8 sec 1.5x rated current for 1 minute, once per hour -40°C to +100°C 40/100/21 acc. to IEC60068-1 Ni plated cu bars/Metal UL 94V-0 UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939, EN60721-3, EN62109 Installed between the PV inverter and the solar panel, the FN 2211 and FN 2210 DC filters are used to influence positively the conducted emissions on the panel side of the system. Therefore the DC filters significantly reduce the potential for highfrequency (HF) interference radiation of the panel. The filter also helps to prevent premature panel aging because of HF stray and leakage currents. Typical applications The FN 2211 / FN 2210 series are primarily designed for PV inverter applications between 250 and 2'300 A. However, they can potentially also be applied in other DC applications within published specifications, like UPS, DC motor drives, energy/battery storage systems, or DC charger installations. Typical electrical schematic FN 2211 Typical electrical schematic FN 2210 2 EMC/EMI Products Schaffner Group Datasheets 2015 Filter selection table Filters * Rated current Power losss @ 50 °C [A] FN 2211 with Cy caps FN 2211-250-99-C30-R55 @ 25 °C/DC [W] FN 2211-600-99-C30-R55 [kg] 250 15 3.0 600 25 4.6 400 FN 2211-400-99-C30-R55 Weight FN 2211-1000-99-C30-R55 1000 FN 2211-2300-99-C30-R55 24 55 1500 4.0 6.8 2300 84 116 11.5 FN 2210-250-99-R5 250 15 2.4 FN 2210-600-99-R5 600 25 3.8 FN 2211-1500-99-C30-R55 FN 2210 without Cy caps 400 FN 2210-400-99-R5 FN 2210-1000-99-R5 1000 FN 2210-2300-99-R5 2300 24 55 1500 FN 2210-1500-99-R5 84 116 17.5 3.1 6.2 11.3 17.5 * Filters with reduced Cy capacitance to ground for high asymmetrical currents and higher voltages available upon request. Typical filter attenuation FN 2211-xxx-99-C30-R55 Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym 250 / 400 / 600 A types 1000 A types 1'500 / 2'300 A types Typical block schematic 1 PV modules 2 Schaffner DC filter FN 22xx 3 Central Inverter 4 Schaffner magnetic components 5 Schaffner AC EMC/EMI filter FN 3xxx Important note: depending on the grounding scheme of the solar power system, including the solar panel and the grid side transformer, the appropriate DC- and AC EMC/EMI filter version need to be selected. For support, please contact your local Schaffner sales office or partner. EMC/EMI Products 3 Schaffner Group Datasheets 2015 Busbar connections Mechanical data 250 to 2'300 A types 250 to 1'000 A types 1'500 A types 2'300 A types Note: all FN 2211 and FN 2210 provide unsymmetrical mounting hole patterns to prevent inverse filter installation in the field. Dimensions FN 2211 FN 2210* FN 2211 FN 2210* FN 2211 FN 2210* FN 2211 FN 2210* FN 2211 FN 2210* FN 2211 FN 2210* A 220 205 235 215 240 225 265 265 275 275 305 305 C* 135 95 150 100 150 100 160 110 200 150 210 210 277 260 240 265 250 300 300 315 315 345 345 250 A B D E F1 F2 G H J 160 250 A 145 285 270 130 120 245 135 Ø7 1.5 M6 125 Ø7 1.5 M6 400 A 175 310 140 145 Ø9 2 M8 400 A 160 290 125 130 Ø9 2 M8 600 A 175 315 140 145 Ø9 2 M8 600 A 170 300 135 140 Ø9 2 M8 1'000 A 180 380 140 145 Ø 11 2.5 M8 1'000 A 180 380 140 145 Ø 11 2.5 M8 1'500 A 215 440 175 180 Ø 11 2.5 M10 1'500 A 215 440 175 180 Ø 11 2.5 M10 2'300 A 230 495 190 195 Ø 11 2.5 M10 2'300 A 230 495 190 195 Ø 11 2.5 M10 K 250 (+/- 1) 230 (+/- 1) 265 (+/- 1) 245 (+/- 1) 270 (+/- 1) 255 (+/- 1) 310 (+/- 1) 310 (+/- 1) 321 (+/- 1) 321 (+/- 1) 351 (+/- 1) 351 (+/- 1) M 41 41 46 46 49.5 49.5 53 53 58 58 60.5 60.5 93 (+/- 0.5) L N 265 245 285 265 290 275 330 330 345 26 345 26 375 35 P 84 (+/- 0.5) 74 (+/- 0.5) 86 (+/- 0.5) 71 (+/- 0.5) 84 (+/- 0.5) 79 (+/- 0.5) 86 (+/- 0.5) 86 (+/- 0.5) 86 (+/- 0.5) 86 (+/- 0.5) 93 (+/- 0.5) V 20 20 25 25 25 25 40 40 60 60 70 10 12.5 12.5 12.5 12.5 Ø9 Ø 11 Ø 11 Ø 11 Ø 11 S W X Y Z 3 10 32.5 Ø9 3 32.5 4 37.5 4 37.5 8 37.5 8 37.5 8 20 57.5 Ø 13.5 26 26 40 375 35 40 70 8 10 10 15 15 57.5 82.5 82.5 82.5 95 20 Ø 13.5 17 Ø 13.5 17 Ø 13.5 * FN 2210 with flat top (Dimension C) All dimensions in mm; 1 inch=25.4mm Tolerances according: ISO 2768-m / EN 22768-m, if not stated otherwise Please see the brochure "Basics in EMC and Power Quality" on our website www.schaffner.com/downloads to find more details on filter connectors. 20 Ø 13.5 20 Ø 13.5 4 EMC/EMI Products Headquarters, global innovation and development center Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 6816 626 F +41 32 6816 630 info@schaffner.com http://www.schaffner.com Schaffner Group Sales and application centers China Schaffner EMC Ltd. Shanghai T20-3, No 565 Chuangye Road Pudong New Area 201201 Shanghai T +86 21 3813 9500 F +86 21 3813 9501 / 02 cschina@schaffner.com http://www.schaffner.com.cn/ Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 19 35 72 71 finlandsales@schaffner.com France Schaffner EMC S.A.S. 112 Quai de Bezons Boîte postale 133 95100 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com Italy Schaffner EMC S.r.l. Via Galileo Galilei 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45 /47 F +39 02 61 23 943 italysales@schaffner.com To nd your local partner within Schaffner‘s global network: www.schaffner.com © 2015 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published speci cations are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published speci cations. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Datasheets Japan Schaffner EMC K.K. 1-32-12, Kamiuma, Setagaya-ku 7F Mitsui-seimei Sangenjaya Bldg. 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com http://www.schaffner.jp Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 05-09 Kampong Ubi Industrial Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E, Alcobendas Miniparc III, Edificio E El Soto de la Moraleja Alcobendas 28109 Madrid M +34 618 176 133 T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 F +41 32 681 66 41 switzerlandsales@schaffner.com Taiwan R.O.C. Schaffner EMV Ltd. 6 Floor, No. 413 Rui Guang Road 114 Neihu District Taipei City T +886 2 87525050 F +886 2 87518086 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com http://www.schaffner.uk.com USA Schaffner EMC Inc. 52 Mayfield Avenue 08837 Edison, New Jersey T +1 800 367 5566 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com http://www.schaffner.com/us Schaffner MTC LLC 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 http://www.schaffner-mtc.com Schaffner Trenco LLC 2550 Brookpark Road 44134 Cleveland, Ohio T +1 216 741 5282 F +1 216 741 4860 http://schaffner-trenco.com 2015
FN2211-1500-99-C30-R55 价格&库存
很抱歉,暂时无法提供与“FN2211-1500-99-C30-R55”相匹配的价格&库存,您可以联系我们找货
  • 1+10641.986761+1364.94912
