F1700/F1799 RFI Filters
Specifications:
High Performance
Features:
F1700 Simplified Schematic
L
LOAD
LINE
L
G
N
N
F1799 Simplified Schematic
L
LOAD
L
LINE
SINGLE PHASE FILTERS
Rated Voltage: 250VAC Maximum - 50/60 Hz
Rated Current:
115VAC
250VAC
3A
2.5A
6A
4A
10A
6A
20A
10A
30A
15A
Current Overload: 6X for 8 seconds
Hi-Pot Test (1 min):
Line to Ground
1500VAC
Line to Line
1768VDC
Insulation Resistance: 9 x 109 Ω at 100VDC
Ambient Temperature: 40°C Max. at rated current
Humidity Range: 0% to 95% R.H.
Termination:
A: QC – Quick Connect
C: IEC Receptacle
B: Wire
D: Screw
Maximum Leakage Current:
Each Line to Ground F1700 F1710 F1720 F1740 F1799
115VAC, 60Hz: 0.40mA .15mA .002mA .060mA 0.25mA
250VAC, 50Hz: 0.75mA .25mA .005mA .120mA 0.45mA
Agency Approvals:
• General Purpose —
Designed for
Applications with
Higher Differential
Mode Noise
• Higher Line-to-Line
Capacitance for
Protection from Pulsed,
Intermittent or Continuous RFI
• A Cost-Effective Replacement for Independent
Coil Design in Many SMPS Applications
• Available with Integral IEC Connector
G
Nominal
Current
Rating
Except 30Amp
N
N
MINIMUM INSERTION LOSS - dB (50 ohm Circuit)
Part
Number
Termination
Line/Load
MODE
.15
.50
1.0
5.0
10
30
Common
Differential
35
60
43
65
52
65
55
50
50
50
QC/QC
Common
Differential
34
60
40
65
45
65
45
50
40
50
F1720AA03
QC/QC
Common
Differential
32
60
35
65
35
60
35
55
40
40
F1740AA03
QC/QC
Common
Differential
30
60
35
65
35
60
35
55
40
40
6A
F1700AA06
F1700BB06
F1700CA06
QC/QC
Wire/Wire
IEC/QC
Common
Differential
10
15
22
50
30
65
46
60
50
60
45
60
10A
F1700AA10
F1700BB10
F1700CA10
QC/QC
Wire/Wire
IEC/QC
Common
Differential
10
45
30
60
46
65
50
60
45
55
F1700AA20
QC/QC
Screw/Screw
Common
Differential
10
15
22
45
30
60
42
65
47
60
40
55
F1700DD20
F1720DD20
Screw/Screw
Common
Differential
10
15
22
45
30
60
42
65
47
60
52
55
F1700DD30
Screw/Screw
Common
Differential
7
15
15
45
34
65
42
60
40
55
F1799DD30
Screw/Screw
Common
Differential
10
15
45
65
55
65
60
65
60
60
50
55
3A
20A
30A
F1700AA03
F1700BB03
F1700CA03
QC/QC
Wire/Wire
IEC/QC
F1710AA03
NOTE: Other combinations of terminals may be specified on special order.
22
www.curtisind.com
Curtis Industries
A Division of Powers Holdings, Inc.
Specifications subject to change.
Dimensions are shown for
reference purposes only.
F1700AA, 1710, 1720, 1740 (3, 6 and 10Amp) Dimensions
A
D
L
O
A
D
F
B
C
D
E
F
3A
2.750
(69,8)
1.750
(44,4)
1.125
(28,5)
2.375
(60,3)
2.000
(50,8)
.550
(14,0)
6A
3.312
(84,1)
2.000
(50,8)
1.125
(28,5)
2.940
(74,7)
2.500
(63,5)
.550
(14,0)
10A
3.312
(84,1)
2.000
(50,8)
1.500
(38,2)
2.940
(74,7)
2.500
(63,5)
.550
(14,0)
B
E
20A
F
.250 QC
E
A
B
C
D
E
3A
2.750
(69,8)
1.750
(44,4)
1.125
(28,5)
2.375
(60,3)
2.000
(50,8)
6A
3.312
(84,1)
2.000
(50,8)
1.125
(28,5)
2.940
(74,7)
2.500
(63,5)
10A
3.312
(84,1)
2.000
(50,8)
1.500
(38,1)
2.940
(74,7)
2.500
(63,5)
Refer to Page 40
for Standard
Mounting Cutouts
C
A
B
C
D
E
3A
2.000
(50,8)
1.500
(38,1)
.550
(14,0)
.565
(14,3)
6A
2.500
(63,5)
2.000
(50,8)
1.500
(38,1)
.550
(14,0)
.565
(14,3)
10A
2.500
(63,5)
2.000
(50,8)
1.500
(38,1)
.550
(14,0)
.565
(14,3)
B
E
1.520
(38,6)
.250
±.062
(6,35)
.188 Dia.
(4.77)
2 Holes
2.000
(50,8)
L
I
N
E
No. 18 Gauge Wire
F1700DD20 (20Amp) Dimensions
5.075
(128,9)
4.140
(105,2)
Type.
C
D
2.000
(50,8)
A
4.00 Min.
(101,6)
A
Amps
D
L
O
A
D
(2) No. 6-32
UNC2B
B
F1700DD30
(30Amp)
Dimensions
(4) .250 x .156
(6,35) (3,95)
L
O
A
D
Amps
L
O
A
D
L
I
N
E
(3, 6 and
10Amp)
Dimensions
F1700BB (3, 6 and 10Amp) Dimensions
L
I
N
E
See 1700DD20 for Case Dimensions
F1700CA
C
(6,4)
.188 Dia.
(4.77)
2 Holes
A
High Performance
L
I
N
E
Amps
3.312
(84,1)
3.750
(95,2)
Terminals
No. 8-32 (5)
F1799DD (30Amp) Dimensions
2.500
(63,5)
L
I
N
E
L
O
A
D
2.940
(74,7)
3.312
(84,1)
(5) No. 8-32 Studs
.625
(15,87)
2.000
(50,8)
Also Available
with .250” Quick
Connect Terminals
Dimensions are in inches and millimeters
unless otherwise specified.
Values in parentheses are metric equivalents.
.625
(15,87)
1.500
(38,1)
SLOTTED HOLE,
6.4(.25)X4.0(.16)
#8-32 SCREW
TERMINAL
3.5
(88,90)
3.12
(79,2)
3.96
(110,6)
50.8 (2.00)
5.95
(151,1)
Curtis Industries
2.18
(55,4)
1-800-657-0853
23
Standard Mounting Cutouts
F1200CA, F1300CA, F1400CA,
F1500CA, F1600CA, F1700CA
F1500FA, F1600FA,
1.20
(30.5)
.187
(4,75)
.638
(16,21)
.140 Dia.
(3,55)
2 Holes
✱.09 R
(2,29)
1.275
(32,39)
.90
(22,9)
.140 Dia.
(3,55)
2 Holes
1.575
(40,0)
.234
(5,94)
1.145
(29,08)
.450
(11,43)
✱ for mounting
from back side
1.417
(36,0)
How to Order
The Curtis part numbering system is made up of four
elements. Each element denotes a specific requirement
(mechanical or electrical) which, when properly
sequenced, fully identifies the required catalog filter. As
shown, the first five alpha/numeric characters denote
the series type; the sixth character (alpha) denotes the
type of line termination; the seventh character (alpha)
denotes the type of load termination; the last two
characters (numeric) denote the current rating.
Compose your part number as follows: Select the series
required, add two alpha character for the line and load
termination, followed by two numeric characters for
the required current rating. For example, F1100AB06
completely identifies an F1100 series filter with quick
connects on line side and wire leads on load side, with
a 6-amp rating.
F1100
X
X
SERIES
PE = Power Entry
PM = Medical
Power Entry
LINE TERMINATION
A = Quick Connects
B = Wire Leads
C = IEC Connector
D = Screw Terminals
(20 & 30 amp only)
F = Fused IEC
P = Printed Circuit Pins
W= Dual Fused IEC
J = Switched IEC
40
www.curtisind.com
LOAD
TERMINATION
A = Quick Connects
B = Wire Leads
D = Screw Terminals
(20 & 30 amp only)
S = Solder Tab
X
CURRENT
RATING
01 = 1 Amp
03 = 3 Amps
06 = 6 Amps
10 = 10 Amps
15 = 15 Amps
20 = 20 Amps
30 = 30 Amps
F1300CP, F1600CP
1.500
(38,1)
.600
(15,2)
N
.700
(17,8)
1.400
(35,6)
.062 Hole Dia.
(1,57)
5 Holes
L
F5500/5600/5700 SERIES
1.575
(40,01)
.90
(22,8)
.140 Dia.
(3,55)
2 Holes
.234 R.
(5,94)
(Typ.)
Curtis Industries
1.20
(30,48)
