F1350AA06
F1350AA06
    CURTISINDUSTRIES
    F1350AA06
F1350AA06 数据手册
F1300/F1350/F1399 RFI Filters Features: • T Circuit Configuration—Designed for Motor, Capacitive and Other Low Impedance Loads • Dual Coils — Higher Performance in Unknown RFI and Noise Susceptibility Applications • Integral IEC Connector and PC Mounted Versions Now Available 1A 2A 6A 10A 15A 20A Termination Line/Load MODE .15 .50 Frequency - MHz 1.0 5.0 10 30 F1300AA01 F1300BB01 QC/QC Wire/Wire Common Differential 40 2 65 57 65 69 65 70 65 70 65 60 F1350AA01 F1350BB01 QC/QC Wire/Wire Common Differential 30 2 60 57 65 69 65 70 65 70 65 60 F1399AA02 F1399BB02 QC/QC Wire/Wire Common Differential 40 5 65 45 65 70 65 65 65 60 40 50 F1300AA03 F1300BB03 F1300CA03 F1300CP03 QC/QC Wire/Wire IEC/QC IEC/PC Common Differential 40 7 65 64 65 70 65 70 65 70 65 58 F1350AA03 F1350BB03 F1350CA03 F1350CP03 QC/QC Wire/Wire IEC/QC IEC/PC Common Differential 30 7 60 64 65 70 65 70 65 70 65 58 F1399AA03 F1399BB03 F1399CA03 QC/QC Wire/Wire IEC/QC Common Differential 40 12 65 55 65 70 65 65 65 60 40 50 F1300AA06 F1300BB06 F1300CA06 QC/QC Wire/Wire IEC/QC Common Differential 12 10 48 40 60 70 65 70 65 70 65 60 F1350AA06 F1350BB06 F1350CA06 QC/QC Wire/Wire IEC/QC Common Differential 2 10 40 40 60 70 65 70 65 70 65 60 F1399AA06 F1399BB06 F1399CA06 QC/QC Wire/Wire IEC/QC Common Differential 30 5 55 40 65 70 65 65 65 60 40 50 F1300AA10 F1300BB10 F1300CA10 QC/QC Wire/Wire IEC/QC Common Differential 12 13 48 13 60 64 65 70 65 67 65 56 F1350AA10 F1350BB10 QC/QC Wire/Wire Common Differential 2 13 40 13 60 64 65 70 65 67 65 56 F1399AA10 F1399BB10 F1399CA10 F1399DD10 QC/QC Wire/Wire IEC/QC Screw/Screw Common Differential 5 5 40 12 52 50 60 65 60 60 50 55 F1300AA15 QC/QC Common Differential 14 15 35 10 44 45 56 70 58 67 55 56 F1300AA20 QC/QC Common Differential 5 — 44 — 60 35 65 60 65 57 60 45 F1350AA20 QC/QC Common Differential 2 — 35 — 61 35 63 60 60 57 50 45 F1399AA20 F1399DD20 QC/QC Screw/Screw Common Differential 5 5 40 12 52 50 60 65 60 60 52 55 SINGLE PHASE FILTERS 3A MINIMUM INSERTION LOSS - dB (50 ohm Circuit) Part Number General Purpose Nominal Current Rating NOTE: Other combinations of terminals may be specified on special order. Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 11 F1300/F1350/F1399 RFI Filters (continued) General Purpose Specifications: Rated Voltage: 250VAC Maximum - 50/60 Hz Rated Current: 115VAC 1A 2A 3A 6A 10A 250VAC 1A 1.5A 2.5A 4A 6A Current Overload: 6X for 8 seconds Hi-Pot Test (1 min): F1300/F1350 Line to Ground: 1500VAC Line to Line: 1768VDC Insulation Resistance: 9 x 109 Ω at 100VDC Ambient Temperature: 40°C Max. at rated current Humidity Range: 0% to 95% R.H. Termination: A: QC – Quick Connect C: IEC Receptacle B: Wire P: PC – P.C. Board Maximum Leakage Current: Each Line to Ground 115VAC, 60Hz: 250VAC, 50Hz: Agency Approvals: F1300 0.4mA .75mA 15A 15A 20A 16A F1350 D1399 0.25mA 0.25mA .40mA 0.45mA F1360 .15mA .25mA F1370 .002mA .005mA F1380 F1390 .015mA .030mA .025mA .050mA SINGLE PHASE FILTERS Except 15Amp A F1300AA (1, 3, 6, 10 and 15Amp) F1350AA (1, 3, 6 and 10Amp) Dimensions Amps A B C D E 1A 2.750 (69,9) 1.750 (44,5) 1.125 (28,5) 2.375 (60,3) 2.925 (74,3) 3A 3.312 (84,1) 2.000 (50,8) 1.125 (28,5) 2.940 (74,7) 3.49 (88,7) 6A 3.312 (84,1) 2.000 (50,8) 1.125 (28,5) 2.940 (74,7) 3.49 (88,7) 10A 3.312 (84,1) 2.000 (50,8) 1.500 (38,1) 2.940 (74,7) 3.49 (88,7) 15A 3.312 (84,1) 2.000 (50,8) 1.500 (38,1) 2.940 (74,7) 3.49 (88,7) L I N E .250 QC (6,4) (1, 3, 6 and 10Amp) Dimensions A B C D E 1A 2.750 (69,9) 1.750 (44,5) 1.125 (28,5) 2.375 (60,3) 2.000 (50,8) 3A 3.312 (84,1) 2.000 (50,8) 1.125 (28,5) 2.940 (74,7) 2.500 (63,5) 6A 3.312 (84,1) 2.000 (50,8) 1.125 (28,5) 2.940 (74,7) 2.500 (63,5) 10A 3.312 (84,1) 2.000 (50,8) 1.500 (38,1) 2.940 (74,7) 2.500 (63,5) www.curtisind.com B E F1300BB/F1350BB 12 L O A D C A .188 Dia. (4,77) 2 Holes Amps .188 Dia. (4,77) 2 Holes D D L I N E L O A D E B 4.000 (101,6) Min. .250±.062 (6,35) Typ. C No. 18 Gauge Wire Curtis Industries A Division of Powers Holdings, Inc. Specifications subject to change. Dimensions are shown for reference purposes only. F1300/F1350 Simplified Schematic L LO A D LINE L G N N L I N E Refer to Page 40 for Standard Mounting Cutouts A B C D E 3A 2.500 (63,6) 2.000 (50,8) 1.500 (38,1) .550 (14,0) .565 (14,3) 6A 2.500 (63,5) 2.000 (50,8) 1.500 (38,1) .550 (14,0) .565 (14,3) 10A 2.880 (73,1) 2.120 (53,8) 1.500 (38,1) .65 (16,0) .565 (14,3) L I N E L O A D (2) No. 6-32 UNC2B E B D A C .250 QC (6,4) SINGLE PHASE FILTERS Amps L O A D 2.000 (50,8) F1300CP/F1350CP (3Amp Only) Dimensions .935 (23,7) (2) No. 6-32 UNC2B .500 (12,7) 1.500 (38,1) 2.500 (68,3) .210 (53,3) Refer to Page 40 for Standard Mounting Cutouts 1.540 (39,1) .25 (6,35) .65 (16,51) F1300AA/F1350AA (20Amp Only) Dimensions General Purpose F1300CA (3, 6 and 10Amp) F1350CA (3 and 6Amp) Dimensions .65 (16,51) 3.75 (95,25) 3.35 (85,09) 4.12 (104.64) .156 (3,96) 2.00 (50,8) 1.52 (38,61) .96 (24,38) 3.92 (99,56) Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 13 F1100/F1150 F1300/F1399 RFI RFI Filters Filters (continued) F1399 Simplified Schematic BLUE BROWN BROWN General Purpose LINE LO A D BLUE G/Y D A E C Amps A B C D E 2A 3.35 (85,1) 1.81 (46,0) 1.16 (29,5) 2.375 (60,33) 2.78 (70,6) 3A 3.85 (97,8) 2.07 (52,6) 1.16 (29,5) 2.938 (74,63) 3.35 (85,1) 6A 3.85 (97,8) 2.07 (52,6) 1.16 (29,5) 2.938 (74,63) 3.35 (85,1) 10A 3.85 (97,8) 2.07 (52,6) 1.53 (38,9) 2.938 (74,63) 3.35 (85,1) 5.23 (132,8) 3.37 (85,6) 1.53 (38,9) 3.75 (95,25) 4.20 (106.7) F1399DD (10 and 20Amp) Dimensions Amps A B C D E 10A 3.96 (100,6) 2.07 (52,6) 1.53 (38,9) 2.938 (74,63) 3.35 (85,1) 20A 5.34 (135,6) 3.37 (85,6) 1.53 (38,9) 3.75 (95,25) 4.20 (106,7) D Amps A B C D E 2A 2.07 (52.6) 1.81 (46,0) 1.16 (29,5) 2.375 (60,33) 2.78 (70,6) 3A 2.56 (65,0) 2.07 (52,6) 1.16 (29,5) 2.938 (74,63) 3.35 (85.1) 6A 2.56 (65,0) 2.07 (52,6) 1.16 (29,5) 2.938 (74,63) 3.35 (85.1) 10A 2.56 (65,0) 2.07 (52,6) 1.53 (38,9) 2.938 (74,63) 3.35 (85,1) B A #6-32 INSERT C 16.0 (0.63) 6.35(0.25) FASTON TERMINAL, WITH Ø1.78(0.070) HOLE (SLOTTED HOLE FOR GROUND) D IEC CONNECTOR F1399CA (3, 6 and 10Amp) Dimensions Amps A B C D 3A 4.33 (110,0) 2.25 (57,2) 1.28 (32,5) 1.575 (40,0) 6A 4.33 (110,0) 2.25 (57,2) 1.28 (32,5) 1.575 (40,0) 10A 4.33 (110,0) 2.25 (57,2) 1.53 (38,9) 1.575 (40,0) #8-32 SCREW TERMINAL SLOTTED HOLE, 6.4(.25)X4.0(.16) #8-32 SCREW TERMINAL B A E A C F1399BB (2, 3, 6 and 10Amp) Dimensions B 20A B D A 6.36(0.25) FASTON TERMINAL WITH Ø1.78 (0.070) HOLE (SLOTTED HOLE FOR GROUND) F1399AA (2, 3, 6, 10 and 20Amp) Dimensions SINGLE PHASE FILTERS WIRE LEADS, 18AWG, (16AWG FOR 10A). 102(4.0) MIN. E B D C 50.8 (2.00) C E 14 www.curtisind.com Curtis Industries A Division of Powers Holdings, Inc. Specifications subject to change. Dimensions are shown for reference purposes only. Standard Mounting Cutouts F1200CA, F1300CA, F1400CA, F1500CA, F1600CA, F1700CA F1500FA, F1600FA, 1.20 (30.5) .187 (4,75) .638 (16,21) .140 Dia. (3,55) 2 Holes ✱.09 R (2,29) 1.275 (32,39) .90 (22,9) .140 Dia. (3,55) 2 Holes 1.575 (40,0) .234 (5,94) 1.145 (29,08) .450 (11,43) ✱ for mounting from back side 1.417 (36,0) SINGLE PHASE FILTERS How to Order The Curtis part numbering system is made up of four elements. Each element denotes a specific requirement (mechanical or electrical) which, when properly sequenced, fully identifies the required catalog filter. As shown, the first five alpha/numeric characters denote the series type; the sixth character (alpha) denotes the type of line termination; the seventh character (alpha) denotes the type of load termination; the last two characters (numeric) denote the current rating. Compose your part number as follows: Select the series required, add two alpha character for the line and load termination, followed by two numeric characters for the required current rating. For example, F1100AB06 completely identifies an F1100 series filter with quick connects on line side and wire leads on load side, with a 6-amp rating. F1100 X X SERIES PE = Power Entry PM = Medical Power Entry LINE TERMINATION A = Quick Connects B = Wire Leads C = IEC Connector D = Screw Terminals (20 & 30 amp only) F = Fused IEC P = Printed Circuit Pins W= Dual Fused IEC J = Switched IEC 40 www.curtisind.com LOAD TERMINATION A = Quick Connects B = Wire Leads D = Screw Terminals (20 & 30 amp only) P = Printed Circuit Pins S = Solder Tab X CURRENT RATING 01 = 1 Amp 03 = 3 Amps 06 = 6 Amps 10 = 10 Amps 15 = 15 Amps 20 = 20 Amps 30 = 30 Amps F1300CP, F1600CP 1.500 (38,1) .600 (15,2) N .700 (17,8) 1.400 (35,6) .062 Hole Dia. (1,57) 5 Holes L F5500/5600/5700 SERIES 1.575 (40,01) .90 (22,8) .140 Dia. (3,55) 2 Holes .234 R. (5,94) (Typ.) Curtis Industries A Division of Powers Holdings, Inc. 1.20 (30,48) Specifications subject to change. Dimensions are shown for reference purposes only.
F1350AA06
物料型号:F1300/F1350/F1399
器件简介:这些是用于电机、电容性及其他低阻抗负载的射频干扰(RFI)滤波器,具有T型电路配置和双线圈设计,以提供在未知RFI和噪声敏感性应用中的高性能。
引脚分配:文档中提供了不同型号的引脚分配,例如F1300AA01、F1350AA01等,包括快速连接(QC)、线对线(Wire/Wire)、IEC/QC和PC板(IEC/PC)等不同配置。
参数特性:包括额定电压、额定电流、电流过载、高压测试、绝缘电阻、环境温度、湿度范围和最大漏电流等。
功能详解:文档提供了详细的规格说明,例如额定电压为250VAC最大,频率范围从40MHz到30MHz,插入损耗从0.15dB到70dB不等。
应用信息:适用于单相电源滤波,特别是在电机驱动和其他低阻抗应用中,以减少射频干扰。
封装信息:提供了不同型号的尺寸信息,包括英寸和毫米单位,并注明尺寸仅供参考。
制造商信息:Curtis Industries,Powers Holdings, Inc.的一个部门,提供了联系方式和网站信息。
F1350AA06 价格&库存
很抱歉,暂时无法提供与“F1350AA06”相匹配的价格&库存,您可以联系我们找货
