F1100/F1150F/F1199 RFI Filters
Features:
SINGLE PHASE FILTERS
F1100/F1150/F1199
Simplified Schematic
L
LINE
General Purpose
• Most Economical Design
• Designed for General Purpose, Common Mode
Applications
• Available in Standard (F1100) and Low-Leakage (F1150)
(F1160) (F1170) (F1180) (F1190) (F1199) Models
G
N
Nominal
Current
Rating
115 VAC
1A
2A
3A
6A
10A
20A
30A
MINIMUM INSERTION LOSS - dB (50 ohm Circuit)
Part
Number
Termination
Line/Load
MODE
Frequency - MHz
.15
.50
1.0
5.0
10
30
F1100AA01
F1100BB01
QC/QC
Wire/Wire
Common
Differential
43
52
55
55
65
50
50
F1150AA01
F1150BB01
QC/QC
Wire/Wire
Common
Differential
37
50
55
50
65
50
50
F1199AA01
QC/QC
Common
Differential
32
5
45
14
45
23
43
47
43
50
40
45
F1199AA02
F1199BB02
QC/QC
Wire/Wire
Common
Differential
24
5
35
13
43
16
45
45
45
50
40
45
F1100AA03
F1100BB03
F1100PP03
QC/QC
Wire/Wire
PC/PC
Common
Differential
43
52
55
55
64
50
46
F1150AA03
F1150BB03
QC/QC
Wire/Wire
Common
Differential
37
50
55
50
64
50
46
F1199AA03
F1199BB03
QC/QC
Wire/Wire
Common
Differential
30
12
38
14
48
38
48
44
44
42
F1100AA06
F1100BB06
QC/QC
Wire/Wire
Common
Differential
10
22
2
30
5
46
51
50
57
45
49
F1150AA06
F1150BB06
QC/QC
Wire/Wire
Common
Differential
10
27
5
45
51
45
57
45
49
F1199AA06
F1199BB06
QC/QC
Wire/Wire
Common
Differential
9
5
28
14
42
33
50
42
47
42
F1100AA10
F1100BB10
QC/QC
Wire/Wire
Common
Differential
10
22
30
2
46
27
50
47
45
50
F1150AA10
F1150BB10
QC/QC
Wire/Wire
Common
Differential
10
2
45
27
45
47
45
50
F1199AA10
F1199BB10
F1199DD10
QC/QC
Wire/Wire
Screw/Screw
Common
Differential
9
5
25
14
38
33
42
42
40
42
F1100AA20
F1100DD20
QC/QC
Screw/Screw
Common
Differential
8
18
22
5
36
22
42
46
45
60
F1150AA20
F1150DD20
QC/QC
Screw/Screw
Common
Differential
8
15
32
22
38
46
45
60
F1199AA20
F1199DD20
QC/QC
Screw/Screw
Common
Differential
10
5
28
15
35
30
38
40
40
40
F1199DD30
Screw/Screw
Common
Differential
13
5
23
12
30
15
35
30
38
40
40
40
NOTE: Other combinations of terminals may be specified on special order.
4
www.curtisind.com
Curtis Industries
A Division of Powers Holdings, Inc.
Specifications subject to change.
Dimensions are shown for
reference purposes only.
F1100AA/F1150AA
Specifications:
(1, 3, 6, 10 and 20Amp) Dimensions
Amps
A
B
C
D
E
1A
2.500
(63,5)
1.750
(44,5)
.625
(15,8)
2.125
(53,9)
1.425
(362)
3A
2.500
(63,5)
1.750
(44,5)
.750
(19,1)
2.125
(53,9)
1.8
(45,8)
6A
2.500
(63,5)
1.750
(44,5)
.750
(19,1)
2.125
(53,9)
1.8
(45,8)
10A
2.500
(63,5)
1.750
(44,5)
1.125
(28,5)
2.125
(53,9)
1.8
(45,8)
20A
2.760
(70,6)
2.000
(60,8)
1.125
(28,5)
2.375
(60,3)
2.550
(64,8)
.188 Dia.
(4,77) 2 Holes
L
I
N
E
B
L
O
A
D
D
A
F1100
F1500
F1199
F1100
Except 20Amp
F1199
F1100
F1150
F1199
F1100DD/F1150DD
(20Amp Only) Dimensions
.188 Dia.
(4,77) 2 Holes
2.000
(50,8)
(5) No. 8-32
.625
Studs
(15,8)
L
I
N
E
L
O
A
D
2.760
(70,6)
.250 Q.C.
(6.4)
F1100BB/FB1150BB
(1, 3, 6 and 10Amp) Dimensions
Amps
A
B
C
D
E
1A
2.500
(63,5)
1.750
(44,5)
.625
(15,8)
2.125
(53,9)
.875
(22,2)
3A
2.500
(63,5)
1.750
(44,5)
.750
(19,1)
2.125
(53,9)
1.250
(31,8)
6A
2.500
(63,5)
1.750
(44,5)
.750
(19,1)
2.125
(53,9)
1.250
(31,8)
10A
2.500
(63,5)
1.750
(44,5)
1.125
(28,5)
2.125
(53,9)
1.250
(31,8)
.188 Dia.
(4,77) 2 Holes
2.375
(60,3)
B
2.000
(50,8)
E
C
F1150
F1199
General Purpose
Rated Voltage: 250VAC Maximum - 50/60 Hz
Rated Current:
115VAC
250VAC
1A
1A
2A
1.5A
3A
2.5A
6A
4A
10A
6A
20A
10A
30A
15A
Current Overload: 6X for 8 seconds
Hi-Pot Test (1 min):
F1100/F1150
F1199
Line to Ground:
1500VAC
1500VAC
Line to Line:
1768VDC
1450VDC
Insulation Resistance: 9 x 109 Ω at 100VDC
Ambient Temperature: 40°C Max. at rated current
Humidity Range: 0% to 95% R.H.
Termination:
A: QC – Quick Connect
D: Screw
B: Wire
P: PCB Mount
Maximum Leakage Current:
Each Line to Ground
F1100
F1150
F1199
115VAC, 60Hz:
0.40mA
0.25mA
0.25mA
250VAC, 50Hz:
.75mA
0.40mA
0.45mA
Agency Approvals:
.625
(15,8)
1.125
(25,5)
L
I
N
E
L
O
A
D
E
A
D
4.000
(101,6)
Min.
.250±.062
(6,35) Typ.
C
No. 18 Gauge Wire
Dimensions are in inches and millimeters
unless otherwise specified.
Values in parentheses are metric equivalents.
Curtis Industries
1-800-657-0853
5
F1100/F1150/F1199 RFI Filters (continued)
General Purpose
F1199AA (1, 2, 3, 6, 10 and 20Amp) Dimensions
F1199BB (2, 3, 6 and 10Amp) Dimensions
Amps
A
B
C
D
E
Amps
A
B
C
D
E
1A
2.53
(64,3)
1.82
(46,2)
0.66
(16,8)
2.126
(54,0)
2.25
(57,2)
2A
2.53
(64,3)
1.82
(46,2)
0.66
(16,8)
2.126
(54,0)
0.96
(24,4)
2A
2.53
(64,3)
1.82
(46,2)
0.66
(16,8)
2.126
(54,0)
2.25
(57,2)
3A
2.53
(64,3)
1.82
(46,2)
0.78
(19,8)
2.126
(54,0)
1.32
(33,5)
3A
2.53
(64,3)
1.82
(46,2)
0.78
(19,8)
2.126
(54,0)
2.61
(66,3)
6A
2.53
(64,3)
1.82
(46,2)
0.78
(19,8)
2.126
(54,0)
1.32
(33,5)
6A
2.53
(64,3)
1.82
(46,2)
0.78
(19,8)
2.126
(54,0)
2.61
(66,3)
10A
2.53
(64,3)
1.82
(46,2)
1.16
(29,5)
2.126
(54,0)
1.32
(33,5)
10A
2.53
(64,3)
1.82
(46,2)
1.16
(29,5)
2.126
(54,0)
2.61
(66,3)
20A
2.81
(71,4)
2.07
(52,6)
1.16
(29,5)
2.375
(60,33)
3.36
(85,3)
WIRE LEADS, 18AWG,
(16AWG FOR 10A).
102(4.0) MIN.
BLUE
6.36(0.25) FASTON TERMINAL
WITH Ø1.78 (0.070) HOLE
(SLOTTED HOLE
FOR GROUND)
A D
G/Y
A D
BROWN
B
BROWN
E
B
E
BLUE
C
C
F1199DD (10, 20 and 30Amp) Dimensions
Amps
A
B
C
D
E
10A
2.53
(64,3)
1.82
(46,2)
1.16
(29,5)
2.126
(54,0)
2.72
(69,1)
20A
2.81
(71,4)
2.07
(52,6)
1.16
(29,5)
2.375
(60,33)
3.46
(87,9)
30A
4.20
(106,7)
3.38
(85,9)
1.53
(38,9)
3.75
(95,25)
5.34
(135,6)
F1100PP Recommended PC Mounting
.250 Dia. Pads
5 Places
1.75
MOUNTING
FLANGE
#8-3 SCREW
TERMINAL
.210
Stamp this surface
1.25
A D
B
E
.062 Dia. Hole
5 Places
C
L
I
N
E
L
O
A
D
.500
.750
1.00
.75
6
www.curtisind.com
Curtis Industries
