F1500AA03
F1500AA03
    CURTISINDUSTRIES
    F1500AA03
F1500AA03 数据手册
F1500 RFI Filters High Performance Specifications: • IEC Connector Plus Common and Differential Mode Performance in Compact Case • “L” Circuit Configuration — Cost-Effective in Many Linear and Switching Power Supply Applications • High-Inductance Design for Greater Attenuation • Available with 0.250" Quick Connect Terminals or Wire Leads on the Load Side F1500AX/F1500CX Simplified Schematic F1500FX Simplified Schematic LOAD LINE G N N N N L L LOAD G Nominal Current Rating Except Quick Connect Termination on Line Input L L LINE SINGLE PHASE FILTERS Features: Rated Voltage: 250VAC Maximum - 50/60 Hz Rated Current: 115VAC 250VAC 3A 1.5A 6A 3A 10A 6A 15A 8A Current Overload: 6X for 8 seconds Hi-Pot Test (1 min): Line to Ground 1500VAC Line to Line 1768VDC Insulation Resistance: 9 x 109 Ω at 100VDC Ambient Temperature: 40°C Max. at rated current Humidity Range: 0% to 95% R.H. Termination: A: QC – Quick Connect B: Wire C: IEC Receptacle F: IEC Receptacle with Fuse Holder Maximum Leakage Current: Each Line to Ground F1500 115VAC, 60Hz: 0.25mA 250VAC, 50Hz: 0.40mA Agency Approvals: MINIMUM INSERTION LOSS - dB (50 ohm Circuit) Part Number Termination Line/Load MODE .15 .50 Frequency - MHz 1.0 5.0 10 30 3A F1500AA03 F1500CA03 F1500FA03 F1500CB03 QC/QC IEC/QC Fused IEC/QC QC/Wire Common Differential 32 35 43 60 50 65 50 60 50 55 50 40 6A F1500AA06 F1500CA06 F1500FA06 F1500CB06 IEC/QC Fused IEC/QC QC/Wire Common Differential 32 30 42 60 45 65 45 65 45 60 45 50 10A F1500AA10 F1500CA10 F1500FA10 F1500CB10 QC/QC IEC/QC Fused IEC/QC Common Differential 29 15 36 50 39 65 45 65 45 60 45 50 15A F1500CA15 F1500CB15 IEC/QC IEC/Wire Common Differential 26 35 32 60 36 65 44 65 46 65 52 65 NOTE: Other combinations of terminals may be specified on special order. 18 www.curtisind.com Curtis Industries A Division of Powers Holdings, Inc. Specifications subject to change. Dimensions are shown for reference purposes only. .188 Dia. (4,77) 2 Holes F1500AA (3 and 10Amp) Dimensions Refer to Page 40 for Standard Mounting Cutouts E L I N E B A B C D E 3A 3.31 (84,1) 2.000 (50,8) 1.13 (28,7) 2.938 (74,6) 2.50 (63,5) 10A 3.31 (84,1) 2.000 (50,8) 1.50 (38,1) 2.938 (74,6) 2.50 (63,5) High Performance Amps L O A D D A C F1500CA E (3, 6, 10 and 15Amp) Dimensions F1500CB L O A D Refer to Page 40 for Standard Mounting Cutouts B SINGLE PHASE FILTERS L I N E (3, 6, 10 and 15Amp) Dimensions (2) No. 6-32 UNC2B A B C D E 3A 2.000 (50,8) 2.000 (50,8) 1.500 (38,1) .550 (14,0) .565 (14,3) 6A 2.500 (63,5) 2.000 (50,8) 1.500 (38,1) .550 (14,0) .565 (14,3) 10A 2.500 (63,5) 2.000 (50,8) 1.500 (38,1) .550 (14,0) .565 (14,3) 15A 3.25 (82,6) 2.25 (57,2) 1.75 (44,5) .550 (14,0) .705 (17,9) C .250 QC (6,4) (1) 5mm x 20mm Fuse (not included) E F1500FA L O A D L I N E (3, 6 and 10Amp) Dimensions Refer to Page 40 for Standard Mounting Cutouts (2) No. 6-32 UNC2B Amps A B C D E 3A 2.000 (50,8) 2.000 (50,8) 1.500 (38,1) .550 (14,0) .752 (19,1) 6A 2.500 (63,5) 2.000 (50,8) 1.500 (38,1) .550 (14,0) .752 (19,1) 10A 2.500 (63,5) 2.000 (50,8) 1.500 (38,1) .550 (14,0) .752 (19,1) Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. D A Amps A C Curtis Industries A Division of Powers Holdings, Inc. B D .250 QC (6,4) 1-800-657-0853 19 Standard Mounting Cutouts F1200CA, F1300CA, F1400CA, F1500CA, F1600CA, F1700CA F1500FA, F1600FA, 1.20 (30.5) .187 (4,75) .638 (16,21) .140 Dia. (3,55) 2 Holes ✱.09 R (2,29) 1.275 (32,39) .90 (22,9) .140 Dia. (3,55) 2 Holes 1.575 (40,0) .234 (5,94) 1.145 (29,08) .450 (11,43) ✱ for mounting from back side 1.417 (36,0) SINGLE PHASE FILTERS How to Order The Curtis part numbering system is made up of four elements. Each element denotes a specific requirement (mechanical or electrical) which, when properly sequenced, fully identifies the required catalog filter. As shown, the first five alpha/numeric characters denote the series type; the sixth character (alpha) denotes the type of line termination; the seventh character (alpha) denotes the type of load termination; the last two characters (numeric) denote the current rating. Compose your part number as follows: Select the series required, add two alpha character for the line and load termination, followed by two numeric characters for the required current rating. For example, F1100AB06 completely identifies an F1100 series filter with quick connects on line side and wire leads on load side, with a 6-amp rating. F1100 X X SERIES PE = Power Entry PM = Medical Power Entry LINE TERMINATION A = Quick Connects B = Wire Leads C = IEC Connector D = Screw Terminals (20 & 30 amp only) F = Fused IEC P = Printed Circuit Pins W= Dual Fused IEC J = Switched IEC 40 www.curtisind.com LOAD TERMINATION A = Quick Connects B = Wire Leads D = Screw Terminals (20 & 30 amp only) P = Printed Circuit Pins S = Solder Tab X CURRENT RATING 01 = 1 Amp 03 = 3 Amps 06 = 6 Amps 10 = 10 Amps 15 = 15 Amps 20 = 20 Amps 30 = 30 Amps F1300CP, F1600CP 1.500 (38,1) .600 (15,2) N .700 (17,8) 1.400 (35,6) .062 Hole Dia. (1,57) 5 Holes L F5500/5600/5700 SERIES 1.575 (40,01) .90 (22,8) .140 Dia. (3,55) 2 Holes .234 R. (5,94) (Typ.) Curtis Industries A Division of Powers Holdings, Inc. 1.20 (30,48) Specifications subject to change. Dimensions are shown for reference purposes only.
F1500AA03 价格&库存
很抱歉,暂时无法提供与“F1500AA03”相匹配的价格&库存,您可以联系我们找货
