F2800BB10
F2800BB10
    CURTISINDUSTRIES
    F2800BB10
F2800BB10 数据手册
High Performance F2800 RFI Filters Specifications: • Designed for VDE “A” and FCC “B” Switching Power Supply Applications • Low-Leakage Current • Compact Case Sizes in Current Ratings up to 15A • Effective Reduction of Common Mode and Differential Mode Noise from 100KHz to 30MHz F2800 Simplified Schematic 3 & 6Amp L LOAD L LINE SINGLE PHASE FILTERS Features: G N N F2800 Simplified Schematic 10 & 15Amp L L OAD LINE L G N N Nominal Current Rating 26 Rated Voltage: 250VAC Maximum - 50/60 Hz Rated Current: 115VAC 250VAC 3A 1.5A 6A 4A 10A 6A 15A 12A Current Overload: 6X for 8 seconds Hi-Pot Test (1 min): Line to Ground 1500VAC Line to Line 1768VDC Insulation Resistance: 9 x 109 Ω at 100VDC Ambient Temperature: 40°C Max. at rated current Humidity Range: 0% to 95% R.H. Termination: A: QC – Quick Connect B: Wire Maximum Leakage Current: Each Line to Ground F2800 115VAC, 60Hz: 0.25mA 250VAC, 50Hz: 0.40mA Agency Approvals: MINIMUM INSERTION LOSS - dB (50 ohm Circuit) Part Number Termination Line/Load MODE .01 .05 .15 Frequency - MHz .50 1.0 5.0 10 30 3A F2800AA03 F2800BB03 QC/QC Wire/Wire Common Differential 10 5 30 25 35 50 35 60 35 65 40 50 45 45 50 45 6A F2800AA06 F2800BB06 QC/QC Wire/Wire Common Differential 5 5 20 10 30 40 35 60 40 60 40 50 40 50 50 45 10A F2800AA10 F2800BB10 QC/QC Wire/Wire Common Differential 5 7 15 20 25 50 30 60 35 60 40 60 45 60 50 55 15A F2800AA15 F2800BB15 QC/QC Wire/Wire Common Differential 8 10 21 30 29 70 33 70 36 70 38 70 45 70 50 60 www.curtisind.com Curtis Industries A Division of Powers Holdings, Inc. Specifications subject to change. Dimensions are shown for reference purposes only. F2800AA (3, 6 and 10Amp) Dimensions .188 Dia. (4,77) 2 Holes A D L O A D F E B F C .250 QC A B C D E F 3A 3.310 (84,1) 2.000 (50,8) 1.500 (38,2) 2.940 (74,7) 2.500 (63,5) .550 (14,0) 6A 3.310 (84,1) 2.000 (50,8) 1.500 (38,2) 2.940 (74,7) 2.500 (63,5) .550 (14,0) 10A 4.44 (113) 2.250 (57,1) 1.750 (44,4) 4.063 (103,2) 3.630 (92,2) .650 (16,5) Amps A B C D E 3A 3.310 (84,1) 2.000 (50,8) 1.500 (38,1) 2.940 (74,7) 2.500 (63,5) 6A 3.310 (84,1) 2.000 (50,8) 1.500 (38,1) 2.940 (74,7) 2.500 (63,5) 10A 4.690 (119) 2.250 (57,1) 1.750 (44,4) 4.063 (103,2) 3.630 (92,2) (6,4) F2800BB (3, 6 and 10Amp) Dimensions .188 Dia. (4,77) 2 Holes A D L I N E .250±.062 (6,35) Typ. L O A D 4.00 (101,6) Min.) B E C No. 18 Gauge Wire 4.10 (104,1) 3.96 (100,5) F2800AA F2800BB (15Amp) Dimensions 3.12 (79,25) 2.00 (50,8) L I N E .65 Max. (16,51) L O A D 2.00 (50,03) SINGLE PHASE FILTERS Amps High Performance L I N E 3.54±.015 (89,9) .156 .56 (3,96) (14,22) .250 x .031 QC (6,35) x (,78) Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 27
F2800BB10 价格&库存
很抱歉,暂时无法提供与“F2800BB10”相匹配的价格&库存,您可以联系我们找货
F2800BB10
  • 10+713.1754710+92.69131
