F3480T032
F3480T032
    CURTISINDUSTRIES
    F3480T032
F3480T032 数据手册
Series F3480/F3600 Specifications: Rated Voltage: 480 VAC - 50/60 Hz 600 VAC - 50/60 Hz Rated Current: 480 VAC - 9A to 608A 600 VAC - 8A to 600A Current Overload: 6X for 8 seconds Hi-Pot Test (1 min): 480VAC Line to Ground 2210 VDC Line to Line 2780 VDC 600VAC 3150 VDC 3150 VDC Insulation Resistance: 1000 MΩ min. at 250 VDC Ambient Temperature: 0°C to 40°C (32°F to 104°F) Humidity Range: 0% to 95% R.H. Termination: • Wire • Terminal Blocks • Pressure Terminal Blocks Weight: 3 to 65lbs (1.36 to 29.50kg) Agency Approvals: THREE-PHASE FILTERS (F3480 Only) Designed to attenuate conducted interference in a small package providing excellent insertion loss, the F3480/F3600 series filters will provide effective EMC solutions up to 600A at 600VAC and power applications up to 360kVA. With effective noise suppression in the critical 150kHz-30MHz range, this advanced 2-stage filter line will support both Delta and Wye connected loads. Curtis three phase filters are designed to provide EMC solutions in many applications such as: - Motor - Motor Control Centers - Facility Filters - Uninterruptible Power Supplies - Power Conditioning Units - Laser Welders - Automated Test Equipment - Robotics - CNC Machinery - Elevators - Industrial Ovens F3480 Simplified Schematic A A B B C C G G LINE F3600 Simplified Schematic A A B B C C N N G G LINE 60 www.curtisind.com LOAD Curtis Industries A Division of Powers Holdings, Inc. LOAD Specifications subject to change. Dimensions are shown for reference purposes only. 3-Phase Power Line Filters Ordering Information: F3600 T 600 3-Phase Series: F3480 = 480 VAC F3600 = 600 VAC Current Rating 008 - 608 (Refer to Charts) T = Terminal Blocks B = Wire Leads A = .250 Q.C. Terminal (8 - 50A Only) F3480 Series - 480 VAC Rated Current (Amps) 608A 322A 135A 112A 80A 60A F3480T608 140mA F3480B608 F3480T322 90mA F3480B322 F3480T185 90mA F3480B185 F3480T136 80mA F3480B136 F3480T112 80mA F3480B112 F3480T080 30mA F3480B080 F3480T060 30mA F3480B060 50A F3480A050 F3480B050 F3480T050 15mA 32A F3480A032 F3480B032 F3480T032 7mA 16A F3480A016 F3480B016 F3480T016 3mA 9A F3480A009 F3480B009 F3480T009 3mA Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. Dimensions (Inches) Minimum Insertion Loss (dB) CM DM .15 60 30 .5 70 40 CM DM .15 60 30 .5 70 40 CM DM .15 60 30 .5 70 35 CM DM .15 60 25 .5 65 35 CM DM .15 60 25 .5 65 35 CM DM .15 60 15 .5 70 25 CM DM .15 60 15 .5 70 25 CM DM .15 60 10 .5 75 40 CM DM .15 60 10 .5 70 45 CM DM .15 50 10 .5 70 50 CM DM .15 60 30 .5 80 45 Frequency (MHz) 1 5 70 60 40 35 Frequency (MHz) 1 5 70 65 40 40 Frequency (MHz) 1 5 70 65 35 45 Frequency (MHz) 1 5 70 60 45 30 Frequency (MHz) 1 5 70 60 45 30 Frequency (MHz) 1 5 70 65 45 40 Frequency (MHz) 1 5 70 65 45 40 Frequency (MHz) 1 5 80 75 50 50 Frequency (MHz) 1 5 80 75 50 50 Frequency (MHz) 1 5 80 75 50 40 Frequency (MHz) 1 5 80 70 50 50 10 45 30 30 30 20 10 55 35 30 45 20 10 55 40 30 45 30 10 50 30 30 40 20 10 50 30 30 40 20 10 55 40 30 45 30 10 55 40 30 45 30 10 70 50 30 50 40 10 65 50 30 45 40 10 65 40 30 50 40 10 60 50 30 50 50 A B C D E F G 18.75 5.25 5.93 41.25 16.00 8.00 .28 x .40 18.75 5.25 4.50 -- 10.50 5.25 4.63 23.50 10.50 5.25 4.50 -- 8.00 4.00 .28 x .40 11.25 4.12 4.25 20.25 11.25 4.12 3.50 -- 10.00 5.00 .20 x .30 8.50 4.12 4.25 16.00 7.00 3.50 .20 x .30 8.50 4.12 3.50 -- 8.50 4.12 4.25 16.00 8.50 4.12 3.50 -- 7.00 3.50 .20 x .30 8.50 4.12 4.25 16.00 8.50 4.12 3.50 -- 7.00 3.50 .20 x .30 8.50 4.12 4.25 16.00 7.00 3.50 .20 x .30 8.50 4.12 3.50 -- 8.00 5.12 2.25 --10.10 5.00 -- .19 x .25 8.00 5.12 2.25 --10.10 5.00 -- .19 x .25 6.00 3.88 2.00 --10.10 4.00 -- .16 x .20 6.00 3.88 2.00 --10.10 4.00 -- .16 x .20 Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 THREE-PHASE FILTERS 185A Part Number Maximum Leakage Each L/G (250V, 60Hz) 61 Series F3480/F3600 F3480B & F3600B Dimensions F F3480T & F3600T Dimensions E E G (Slots) F G (Slots) B B NOTE: “N” Lead Not on F3480 NOTE: “N” Terminal Not on F3480 A D A C C LINE LOAD LINE 60A & Above LOAD 60A & Above G (Slots) E G (Slots) E B B NOTE: Only 3 Leads on F3480 (Plus Ground) NOTE: Only 3-Pole Terminal Block on F3480 A D A C C LINE LINE LOAD 50A & Below LOAD 50A & Below THREE-PHASE FILTERS F3600 Series - 600 VAC 62 Rated Current (Amps) 600A 300A 180A 80A Part Number F3600T600 Maximum Leakage Each L/G (250V, 60Hz) 120mA F3600B600 F3600T300 60mA F3600B300 F3600T180 60mA F3600B180 F3600T080 30mA F3600B080 45A F3600A045 F3600B045 F3600T045 10mA 25A F3600A025 F3600B025 F3600T025 8mA 16A F3600A016 F3600B016 F3600T016 4mA 8A F3600A008 F3600B008 F3600T008 4mA www.curtisind.com Dimensions (Inches) Minimum Insertion Loss (dB) CM DM .15 60 20 .5 60 35 CM DM .15 60 25 .5 60 30 CM DM .15 60 20 .5 60 30 CM DM .15 60 15 .5 60 25 CM DM .15 60 10 .5 60 10 CM DM .15 60 5 .5 60 5 CM DM .15 50 5 .5 70 5 CM DM .15 60 5 .5 70 10 Frequency (MHz) 1 5 50 50 35 30 Frequency (MHz) 1 5 50 50 35 45 Frequency (MHz) 1 5 60 60 35 45 Frequency (MHz) 1 5 60 60 25 40 Frequency (MHz) 1 5 80 70 15 50 Frequency (MHz) 1 5 80 70 30 50 Frequency (MHz) 1 5 80 70 35 40 Frequency (MHz) 1 5 80 70 50 40 10 40 25 30 30 20 10 40 30 30 30 20 10 50 40 30 40 30 10 50 40 30 40 30 10 60 40 30 45 30 10 60 40 30 45 30 10 60 40 30 45 40 10 60 40 30 45 40 A B C D 18.75 5.25 5.93 41.25 18.75 5.25 4.50 -- 10.50 5.25 5.93 26.50 10.50 5.25 4.50 -- 11.25 4.12 4.25 20.25 11.25 4.12 3.50 -- 8.50 4.12 4.25 16.00 8.50 4.12 3.50 -- 8.00 5.12 2.25 8.00 5.12 6.00 6.00 Curtis Industries A Division of Powers Holdings, Inc. E F G 16.00 8.00 .28 x .40 8.00 4.00 .28 x .40 10.00 5.00 .20 x .30 7.00 3.50 .20 x .30 --10.10 5.00 -- .19 x .25 2.25 --10.10 5.00 -- .19 x .25 3.88 2.00 --8.10 4.00 -- .16 x .20 3.88 2.00 --8.10 4.00 -- .16 x .20 Specifications subject to change. Dimensions are shown for reference purposes only.
F3480T032
1. 物料型号:F3480/F3600系列三相滤波器,适用于480 VAC和600 VAC系统。 2. 器件简介:这些滤波器设计用于在小型封装中衰减传导干扰,提供出色的插入损耗,为高达600A的600VAC和高达360kVA的功率应用提供有效的电磁兼容性(EMC)解决方案。 3. 引脚分配:文档中提供了不同型号滤波器的引脚分配图,包括LINE、LOAD和GROUND。 4. 参数特性:包括额定电流、最大漏电流、最小插入损耗、尺寸、重量、湿度范围、环境温度、绝缘电阻和耐压测试等。 5. 功能详解:滤波器支持Delta和Wye连接负载,有效抑制150kHz至30MHz的关键频率范围内的噪声。 6. 应用信息:适用于电机、电机控制中心、设施滤波器、不间断电源、电源调节单元、激光焊接机、自动化测试设备和机器人等多种应用。 7. 封装信息:提供了不同额定电流的滤波器尺寸和安装选项,包括端子块和电线引出。
F3480T032 价格&库存
很抱歉,暂时无法提供与“F3480T032”相匹配的价格&库存,您可以联系我们找货
