Series F3480/F3600
Specifications:
Rated Voltage: 480 VAC - 50/60 Hz
600 VAC - 50/60 Hz
Rated Current:
480 VAC - 9A to 608A
600 VAC - 8A to 600A
Current Overload: 6X for 8 seconds
Hi-Pot Test (1 min):
480VAC
Line to Ground
2210 VDC
Line to Line
2780 VDC
600VAC
3150 VDC
3150 VDC
Insulation Resistance: 1000 MΩ min. at 250 VDC
Ambient Temperature: 0°C to 40°C (32°F to 104°F)
Humidity Range: 0% to 95% R.H.
Termination:
• Wire
• Terminal Blocks
• Pressure Terminal Blocks
Weight: 3 to 65lbs (1.36 to 29.50kg)
Agency Approvals:
THREE-PHASE FILTERS
(F3480 Only)
Designed to attenuate conducted interference
in a small package providing excellent insertion
loss, the F3480/F3600 series filters will provide
effective EMC solutions up to 600A at 600VAC and
power applications up to 360kVA. With effective
noise suppression in the critical 150kHz-30MHz
range, this advanced 2-stage filter line will support
both Delta and Wye connected loads. Curtis
three phase filters are designed to provide EMC
solutions in many applications such as:
- Motor
- Motor Control Centers
- Facility Filters
- Uninterruptible Power Supplies
- Power Conditioning Units
- Laser Welders
- Automated Test Equipment
- Robotics
- CNC Machinery
- Elevators
- Industrial Ovens
F3480 Simplified Schematic
A
A
B
B
C
C
G
G
LINE
F3600 Simplified Schematic
A
A
B
B
C
C
N
N
G
G
LINE
60
www.curtisind.com
LOAD
Curtis Industries
A Division of Powers Holdings, Inc.
LOAD
Specifications subject to change.
Dimensions are shown for
reference purposes only.
3-Phase Power Line Filters
Ordering Information:
F3600 T 600
3-Phase Series:
F3480 = 480 VAC
F3600 = 600 VAC
Current Rating 008 - 608
(Refer to Charts)
T = Terminal Blocks
B = Wire Leads
A = .250 Q.C. Terminal
(8 - 50A Only)
F3480 Series - 480 VAC
Rated
Current
(Amps)
608A
322A
135A
112A
80A
60A
F3480T608
140mA
F3480B608
F3480T322
90mA
F3480B322
F3480T185
90mA
F3480B185
F3480T136
80mA
F3480B136
F3480T112
80mA
F3480B112
F3480T080
30mA
F3480B080
F3480T060
30mA
F3480B060
50A
F3480A050
F3480B050
F3480T050
15mA
32A
F3480A032
F3480B032
F3480T032
7mA
16A
F3480A016
F3480B016
F3480T016
3mA
9A
F3480A009
F3480B009
F3480T009
3mA
Dimensions are in inches and millimeters
unless otherwise specified.
Values in parentheses are metric equivalents.
Dimensions (Inches)
Minimum
Insertion Loss (dB)
CM
DM
.15
60
30
.5
70
40
CM
DM
.15
60
30
.5
70
40
CM
DM
.15
60
30
.5
70
35
CM
DM
.15
60
25
.5
65
35
CM
DM
.15
60
25
.5
65
35
CM
DM
.15
60
15
.5
70
25
CM
DM
.15
60
15
.5
70
25
CM
DM
.15
60
10
.5
75
40
CM
DM
.15
60
10
.5
70
45
CM
DM
.15
50
10
.5
70
50
CM
DM
.15
60
30
.5
80
45
Frequency (MHz)
1
5
70
60
40
35
Frequency (MHz)
1
5
70
65
40
40
Frequency (MHz)
1
5
70
65
35
45
Frequency (MHz)
1
5
70
60
45
30
Frequency (MHz)
1
5
70
60
45
30
Frequency (MHz)
1
5
70
65
45
40
Frequency (MHz)
1
5
70
65
45
40
Frequency (MHz)
1
5
80
75
50
50
Frequency (MHz)
1
5
80
75
50
50
Frequency (MHz)
1
5
80
75
50
40
Frequency (MHz)
1
5
80
70
50
50
10
45
30
30
30
55
35
30
45
55
40
30
45
30
10
50
30
30
40
50
30
30
40
55
40
30
45
30
10
55
40
30
45
30
10
70
50
30
50
40
10
65
50
30
45
40
10
65
40
30
50
40
10
60
50
30
50
50
A
B
C
D
E
F
G
18.75
5.25
5.93
41.25
16.00
8.00
.28 x
.40
18.75
5.25
4.50
10.50
5.25
4.63
23.50
10.50
5.25
4.50
8.00
4.00
.28 x
.40
11.25
4.12
4.25
20.25
11.25
4.12
3.50
10.00
5.00
.20 x
.30
8.50
4.12
4.25
16.00
7.00
3.50
.20 x
.30
8.50
4.12
3.50
8.50
4.12
4.25
16.00
8.50
4.12
3.50
7.00
3.50
.20 x
.30
8.50
4.12
4.25
16.00
8.50
4.12
3.50
7.00
3.50
.20 x
.30
8.50
4.12
4.25
16.00
7.00
3.50
.20 x
.30
8.50
4.12
3.50
8.00
5.12
2.25
--10.10
5.00
.19 x
.25
8.00
5.12
2.25
--10.10
5.00
.19 x
.25
6.00
3.88
2.00
--10.10
4.00
.16 x
.20
6.00
3.88
2.00
--10.10
4.00
.16 x
.20
Curtis Industries
1-800-657-0853
THREE-PHASE FILTERS
185A
Part
Number
Maximum
Leakage
Each L/G
(250V,
60Hz)
61
Series F3480/F3600
F3480B & F3600B Dimensions
F
F3480T & F3600T Dimensions
E
E
G (Slots)
F
G (Slots)
B
B
NOTE:
“N” Lead Not
on F3480
NOTE:
“N” Terminal
Not on F3480
A
D
A
C
C
LINE
LOAD
LINE
60A & Above
LOAD
60A & Above
G (Slots)
E
G (Slots)
E
B
B
NOTE:
Only 3 Leads on
F3480 (Plus Ground)
NOTE:
Only 3-Pole Terminal
Block on F3480
A
D
A
C
C
LINE
LINE
LOAD
50A & Below
LOAD
50A & Below
THREE-PHASE FILTERS
F3600 Series - 600 VAC
62
Rated
Current
(Amps)
600A
300A
180A
80A
Part
Number
F3600T600
Maximum
Leakage
Each L/G
(250V,
60Hz)
120mA
F3600B600
F3600T300
60mA
F3600B300
F3600T180
60mA
F3600B180
F3600T080
30mA
F3600B080
45A
F3600A045
F3600B045
F3600T045
10mA
25A
F3600A025
F3600B025
F3600T025
8mA
16A
F3600A016
F3600B016
F3600T016
4mA
8A
F3600A008
F3600B008
F3600T008
4mA
www.curtisind.com
Dimensions (Inches)
Minimum
Insertion Loss (dB)
CM
DM
.15
60
60
35
CM
DM
.15
60
25
.5
60
30
CM
DM
.15
60
60
30
CM
DM
.15
60
15
.5
60
25
CM
DM
.15
60
10
.5
60
10
CM
DM
.15
60
5
.5
60
5
CM
DM
.15
50
5
.5
70
5
CM
DM
.15
60
5
.5
70
10
Frequency (MHz)
1
5
50
50
35
30
Frequency (MHz)
1
5
50
50
35
45
Frequency (MHz)
1
5
60
60
35
45
Frequency (MHz)
1
5
60
60
25
40
Frequency (MHz)
1
5
80
70
15
50
Frequency (MHz)
1
5
80
70
30
50
Frequency (MHz)
1
5
80
70
35
40
Frequency (MHz)
1
5
80
70
50
40
10
40
25
30
30
40
30
30
30
50
40
30
40
30
10
50
40
30
40
30
10
60
40
30
45
30
10
60
40
30
45
30
10
60
40
30
45
40
10
60
40
30
45
40
A
B
C
D
18.75
5.25
5.93
41.25
18.75
5.25
4.50
10.50
5.25
5.93
26.50
10.50
5.25
4.50
11.25
4.12
4.25
20.25
11.25
4.12
3.50
8.50
4.12
4.25
16.00
8.50
4.12
3.50
8.00
5.12
2.25
8.00
5.12
6.00
6.00
Curtis Industries
E
F
G
16.00
8.00
.28 x
.40
8.00
4.00
.28 x
.40
10.00
5.00
.20 x
.30
7.00
3.50
.20 x
.30
--10.10
5.00
.19 x
.25
2.25
--10.10
5.00
.19 x
.25
3.88
2.00
--8.10
4.00
.16 x
.20
3.88
2.00
--8.10
4.00
.16 x
.20
很抱歉,暂时无法提供与“F3600T600”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+30290.1699510+3926.18273
