62-AFC-030-5-11
62-AFC-030-5-11
    APITECHNOLOGIES
    LINEFILTER250VAC3ACHASSMNT
62-AFC-030-5-11 数据手册
The Electromagnetic Spectrum Innovator CONTACT US DATA SHEET Power Line Filters Compact design requires minimal real estate and delivers excellent filtering characteristics for both differential and common mode. RoHS compliant, easily installed for a broad array of applications. 2-6 2-3 4-6 Appliance Filters 11-MPC Series 62-AL/62-AC Series 7 - 22 Single Stage 7-8 62-PPF/PQF/PRF Series 9 - 10 Single Stage Wiries Leads 62-PML Series 11 - 12 Single Stage With Wire Leads for Medical Applications 12-PML & 12-PMF Series 13 - 14 62-LMF & LMB Series 15 - 16 62-PMF & PMB Series 17 - 18 12-PMF Series 19 - 20 21 - 22 Higher Current 62-PMB Series 12-PMB Series 23 - 25 DC - Higher Current 23 - 25 12-PMF & PMB DC Series 26 - 33 Dual Stage 26 - 27 62-MMF Series 28 - 29 12-MMF & 12-MMB Series 30 - 31 12-MMF & 12-MMB Series 32 - 33 12-MMF & 12-MMB Series www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 1 The Electromagnetic Spectrum Innovator DATA SHEET Power Line Filters | Appliance Filters 11-MPC Series Features Circuit Diagram • Miniature general purpose PCB mounted flter Circuit 1 • Requires minimal PCB real estate space • Low cost • Operating temperature: -25°C to +70°C • Two forms of cases are available: metal case and plastic case Circuit 2 Applications • Personal computers and peripherals Circuit 3 • Digital AV equipment • Measuring instruments • Medical equipment • Monitors and display units Circuit 4 • Home appliances Specifcations Model 11-MPC-001-5-A 11-MPC-003-5-E 11-MPC-006-5-B 11-MPC-006-5-C 11-MPC-016-5-B Leakage Circuit Temperature Rise Rated Voltage Rated (@ 50/60Hz) Current Current (Max.) Diagram Figure (Max.) 1A 3A 120/250VAC 6A 16A 0.50mA 0.50mA 0.2mA 2 3 2 4 A E A1 C B 30°C Note: Test voltage: 1500VAC one minute, line to ground Insulation resistance: 300 Mohm min. at 500VDC Voltage drop: 1V max. at rated current Weight: 17.5g www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 2 The Electromagnetic Spectrum Innovator DATA SHEET Power Line Filters | Miniature Printed Circuit Board 11-MPC Series Figure A Figure A1 01±1 5 PLCS .315(8)±.5 + 0.984 .315(8)±.5 1251 ' 1 ~ ,,,~ ~ L .315 Figure C .31 5 J [8]±.2 Figure B ul J: +---------e----t=ilg[ } (25).007 (5().8) .787 c 1------r,_06(27) L----= [20]±1 .0 2.5 (64) ~ LF ~ p J 28.0 35.0 19(30) , 11(29) i:=,9(10)-1-stJ □ I l - 14 (Jss1 - I I i--:...- 1.9 (49) ____:_i ±.07 17(44) - - - l 45 (11.5) 14 ~ (35) (1 1.5) 1 45.0 j l .30(75) I (2i:i9J - Figure E Figure D 0 .O3(1 )(SX) +----+------+ J 1.4 (36) 1_11 _i L15 (27) (4) Dimensions in inches (mm) Normal Mode Common Mode son son Level Meter Level Meter 11-MPC-001 11-MPC-001 80 80 11 70 II I 11 -MPC-00 1-5-8 - .., Ill 60 .s C ' \. 11-MPC-001-2-8 ";; 50 40 --- :::::v' 0 € 30 :,: ~i--.,,., .: 20 I"- 0 0.1 11 0.2 r--.. -- T 11 -MPC-002 -5-0 II .s5 60 11-MPC-001-5-8 , - ...... 11 -MPC-001-2-8 ' x. [/ 40 € 30 :,: .,.,.,,.,/ .: 20 I'--. v 10 10 0.2 1 / .,,,,.v A 11-MPC-003-5-E 50 - .., Ill i 11 -MPC-006 -5-8 - € 30 20 10 0 0.1 -~-- .,.,,., .,,,/' ~ ,: .... I 0.2 50 11 -MPC-016-5-8 I I I 11-MPC-003-5-E .,,~ Y1/ C 0 € 30 ' - 11-MPC-016-5-8 j I I II II 5 10 20 10 20 50 Frequency (MHz) www.apitech.com | 855.294.3800 | communications@apitech.com | 0 0.1 '>-: ~~ I --' 40 ~...- II II 0.5 I 60 0 I 10 20 50 11-MPC-003;-006;-016 70 40 .,, 2 0.5 80 11 -MPC-006-5-C C\ .3 5 I' \ Frequency (MHz) 70 j \ ~ .,,-'i,;" ~ t- 11-MPC-002-5-B ~ 0.1 50 20 11-MPC-003;-006;-016 60 .... r--...' 0s, "i,; 0 5 0.5 80 ..,- -:.~ '/7 V I/ ½ ~-MPC-001 -5-A Frequency (MHz) Ill h µ___ 1 1 ;- 50 l...,,.I 11-MPC-002-5-8 10 - Ill 11-MPC-002-5-D 1 1 70 11-MPC-001 -5-A ...... .,.,.,,., ~ ~ 0.2 .,,~ ~ / ~ ....--- '~ .,,V r--,, \ 11-MPC-006-5-C 11 -M PC-006-5-8 5 0.5 .,,...- 1/•" I'- ,::::;., - .,, 10 20 50 Frequency (MHz) www.linkedin.com/company/api-technologies-corp-/ 3 The Electromagnetic Spectrum Innovator DATA SHEET Power Line Filters | Appliance Filters 62-AL/62-AC Series Tested and found to be IAW VDE 0565 Part 3 Features • Low-cost plastic case • Compact design requires minimal real estate space • Suitable for products that must conform to FCC regulations • Wide variety of circuit and fltering options • Excellent fltering characteristics for both normal mode and common mode • Epoxy molded for reliability • Operating temperature: -25°C to +85°C (including temperature rise, see graph on page 5) Applications Circuit Diagrams • Personal computers and peripherals • Digital equipment 62-A*L Series • Industrial equipment ,________________ ) • Vending machines • Home appliances 62-A*C Series • Ofce equipment ,________________ ) *R = w/ Bleeder Resistor F = w/o Bleeder Resistor 1.220 (31.0) r l.573 r .994 .177x .138 (4 .Sx3.5) -I1(9.4) .371 1+---- 1.527 (38 .8) ----+I .371 1 1 (94) ------!57 (16.7) ! .374 (9.5) .263 (6.7) CT (40.0)D (24. 0) ... 1 W+w i i Dimensions in inches (mm) www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 4 The Electromagnetic Spectrum Innovator DATA SHEET Power Line Filters | Appliance Filters 62-AL/62-AC Series Specifcations Rated Voltage (@ 50/60Hz) Model Rated Current Leakage Current (Max.) Capacitance CY CX 62-AFL-010-3-11 0.35mA 2200pF 62-AFC-010-3-11 1.0A 62-AFL-010-5-11 0.50mA 3300pF 62-AFC-010-5-11 62-AFL-016-3-11 2200pF 0.35mA 62-AFC-016-3-11 1.6A 62-AFL-016-5-11 3300pF 0.50mA 62-AFC-016-5-11 62-AFL-030-3-11 0.35mA 2200pF 62-AFC-030-3-11 3.0A 0.1uF 250VAC 62-AFL-030-5-11 0.50mA 3300pF 62-AFC-030-5-11 62-AFL-045-3-11 2200pF 0.35mA 62-AFC-045-3-11 4.5A 62-AFL-045-5-11 3300pF 0.50mA 62-AFC-045-5-11 62-AFL-060-3-11 2200pF 0.35mA 62-AFC-060-3-11 3.0A 62-AFL-060-5-11 3300pF 0.50mA 62-AFC-060-5-11 Note: All types are designed to meet the requirement of UL 1283, CSA 22.2. VDE 0565-3 Test voltage: 1500VAC one minute, line to ground Insulation resistance: 300 Mohm min. at 500VDC Voltage drop: 1V max. Inductance (L1) Temperature Rise (Max.) 11.0mH 6.0mH 2.4mH 40°C 1.0mH 0.53mH * Available with bleeder resistor Replace F with R for part number perature Characteristics 120 100 "' " '-- 80 l "" I\ C: 60 ~ :::, () 40 '\ 20 0 20 30 40 50 60 70 Ambient Temperature (°C) \ I\ 80 90 www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 5 The Electromagnetic Spectrum Innovator DATA SHEET Power Line Filters | Appliance Filters 62-AL/62-AC Series Common Mode Normal Mode SOQ Level Meter SOQ Level Meter 62-AFL-xxx-3-11 62-AFL-XXX-3-11 80 80 1- 70 62-AFL-030-3- 11 62-AFL-045-3-11 - , 62-AFL-016-3-11 - 70 62-AFL-016·3· 11 - 60 f 50 - 40 'l! & t: 30 i 20 62-AFL-010-3-1 1 ,,.,... i \ .:::, ··:::> / \ / _,/ ,...i-- -- ..____ r-- \\ :;:::. ........ 0 0.1 ~ . 40 t: 30 j 20 62-AFL-060-3- 11 ..... ·_ - f 62-AFL-045-3-11 11111 I 10 0.2 10 0.5 60 ";" 50 :---. 20 62-AFL-010-3-11 .... ~~"' 62-AFL-060-3-11 I I I 11 0 0. 1 62-AFC-XXX-3-11 1g j 0.2 0.5 r- 62-AFC-030-3-11 62-AFC-010-3-11 -- 50 ,3 40 ::::. ......... ,,. i-- 0 t: ] 30 ,... i-- / 20 in \ ' i---,.........-~ _§ ~ 50 I\\ 40 I. H 0 30 --- 20 s2-AFC·-04s-a-1,-- 10 0 10 0.5 20 50 0. 1 0.2 " ,,~ ,, 62-A FC-010.-3-11 v _i,; ' ~ 62-AFC-045-3-11 62-A FC-060-3-11 10 0.5 Frequency (MHz) 20 50 Frequency (MHz) 62-AFL-xxx-5-11 62-AFL-xxx-5-11 80 80 62-A FL-030-5-1 1 70 62-AFL-016-5-1 1 62-AFL-010-5-1 1 -a, 60 ~ _,... ;- 50 ~ 20 '- I 62-AFC-060-3- 11 0.2 I'\ 60 1 \ 0 0.1 ,--._ 62-AFC-016-3-11 ;- 50 ~ :;:::. ........ 10 62-AFC-030-3-11 70 \ ......... 10 - 62-AFC-XXX-3-11 80 60 r ·--- Frequency (M Hz) 80 62-AFC-016·3· 11 --..: I I Frequency (MHz) 70 ...t 62-AFL-030-3- 11 10 50 " " :;.ii"" .ai 40 / ..... 30 ....,.. 11 20 ' ~ ....._ I\ \___ --- ~ . j ,,,...- 20 62-AFL-060-5- 11 10 0.5 20 \ . ~ ~ -- ,_ I "~ r--... 62-AFL-060-5-11 10 1111 0.2 62-AFL-030-5-11 \. .,, ., 40 ,: 30 62-AFL-045-5- 11 0 0. 1 ' 62-AFL-010-5-1 1 ;- 50 ---::::: \ \ -v~ 10 62-AFL-016-5-11 :::-- ,... ,... 11 Ill 70 -a, 60 62-AFL-045-5-1 1 / r,: ,..., / 0 50 0. 1 0.2 0.5 10 20 50 Frequency (MHz) Frequency (M Hz) 62-AFC-xxx-5-11 62-AFC-xxx-5-11 80 80 70 62-AFC-016-5-11 - ....,.. v I\/, ,... r\ ..... I\ 10 0 0. 1 0.2 I\.. >-,-.... >-- § § 62-AFC-060-5- 11 . . ... . .- - 62-AFC-045-5-11 62-AFC-030-5-11- 62-AFC-016-5-11 10 0.5 ! "~,.,_ ~ ....,...,,,.. ....,.. ..... 1111 70 I I I 62-AFC-010-5-11 20 ' \ 60 62-AFC-010-5-11 50 \. _ ""-~,... 40 t: 30 j 20 62-AFC-030-5-11 .,,,. II""' k:;;ii; ~ ~- Frequency (MHz) www.apitech.com | 855.294.3800 | communications@apitech.com | I ....._ :::::::-l ....... / ; --..::::: L62-AFC-045-5-11 10 50 - - 62-AFC-060-5-11 0 0. 1 0.2 10 0.5 20 50 Freq uency (MHz) www.linkedin.com/company/api-technologies-corp-/ 6 The Electromagnetic Spectrum Innovator DATA SHEET Power Line Filters | Single Stage 62-PPF/PQF/PRF Series Tested and found to be IAW VDE 0565 Part 3 Features Applications • Low-cost plastic case • Personal computers and peripherals • Compact design requires minimal real estate space • Digital equipment • Suitable for products that must conform to FCC and FTZ regulations • Industrial equipment • Vending machines • Wide variety of circuit and fltering options • Ofce equipment • Excellent fltering characteristics for both normal mode and common mode Circuit Diagrams o------+---, • Epoxy molded for reliability s2-POF' Series ; l L, ~ ~ - - - _ ,,, ,- Ctl._ ::;:: T"'l_____,.._ c, : _ ~ R ~jJ1 T :!: .z::;:;,--v ccv: - o-!-J. ~ 1________________ 1 • Operating temperature: -25°C to +85°C (including temperature rise, see graph on page 8) ----------------- ~ L, .---,-+-o 62-PPF' j - r' 1 j_ _c ~ - - =:= ~ c, ; _ · S enes x- - - 1 R 11 ~ 1________________ 1 ~ I I 62-PRF S 62-PQF-020-5-11 62-PQF-020-5-12 62-PPF-020-5-11 62-PPF-020-5-12 62-PQF-030-5-11 62-PQF-030-5-12 62-PPF-030-5-11 62-PPF-030-5-12 62-PQF-060-5-11 62-PQF-060-5-12 62-PPF-060-5-11 62-PPF-060-5-12 62-PRF-010-5-11 62-PRF-010-5-12 62-PRF-020-5-11 62-PRF-020-5-12 62-PRF-030-5-11 62-PRF-030-5-12 1 j I ~ ~ ____s__ ·R· 11 ~j T ::!:cvi - ~ '----------------• Specifcations Model . enes *Bleeder Resistor is available only for 62-P(Q/R/P)F-XXX-X-12w Rated Voltage (@ 50/60Hz) Rated Current Leakage Current (Max.) Capacitance CY CX 2A 3A 250VAC 0.50mA 6A 1A 2A 3A Note: All types are designed to meet the requirement of UL 1283, CSA 22.2. VDE 0565-3 Test voltage: 1500VAC one minute, line to ground Insulation resistance: 300 Mohm min. at 500VDC www.apitech.com | 855.294.3800 | communications@apitech.com | 3300pF 0.1uF .22uF 0.1uF .22uF 0.1uF .22uF 0.1uF .22uF 0.1uF .22uF 0.1uF .22uF 0.1uF .22uF 0.1uF .22uF 0.1uF .22uF Inductance (L1) Temperature Rise (Max.) 15mH 8mH 2.1mH 30°C 486uH 181uH 97uH Voltage drop: 1V max. (except 62-PRF-010-5-11) at rated current 62-PRF-010-5-11: 1.5V max. at rated current Weight: 62-PPF & PQF Series: 2.11 ounces (60 grams) 62-PRF Series: 1.76 ounces (50 grams) www.linkedin.com/company/api-technologies-corp-/ 7 The Electromagnetic Spectrum Innovator DATA SHEET Power Line Filters | Single Stage 62-PPF/PQF/PRF Series Temperature Characteristics Normal Mode 120 100 "'-~ "" ~ 80 l 'E 60 ~ '\ s (.) 40 son Level Meter ~ 20 0 20 30 40 50 60 70 '\ 80 62-PQF Series 80 I', 70 .Ir\ 62-PQF-020-5-12 90 Ambient Temperature (°C) a, 60 i" 50 _9 40 ..,- C 0 t: j Fast-on tab #11 0 ~-;.[:::. ... -"'~, .,:::::; .... 30 20 '\ ,.; "-, ('b 1/ --~ - I :,-(_ V ..,.....- '\ - 62- POF-020-5- 11 ~ ~ I I! 62- PQF-060-5- 12 I I 62-PQF-060-5-11 ~ n/ '.Y ~ 10 I I 0 0.1 0.2 2 0.5 10 20 50 Frequency (MHz) 1 .354 .177 X .138 (4.5 r--- X 3.5) 1 lh ,.947 (49 5) -------, (9) 1 ~it ~ t ·~,j ~____:90(1t ! Also available with .250 Fast-ons lF. . .,iJ ll= 2006 (51) 62-PPF Series ~ Dimensions in inches (mm) 80 a, ; 60 " 40 - Common Mode "'-- - 0.2 10 0.5 80 / 62- P(Q/P)-060-5-11 - - ;- 50 ,,K :g ~ :! 40 0 30 20 .,,,-- .11-- 12-PMF-006-2-B 0.2 I 0.5 10 20 20 10 I I II II 50 Frequency (MHz) www.apitech.com | 855.294.3800 | communications@apitech.com | 0 0.1 ,," v/ ~ ,I~ 11-PML-001-2-C 11 0 / 'e 30 I'--... ...... C, 11-PML-001-2-C - ~ 40 rx,v -- 60 '";; 50 • D- i.-- 50 12-PMF-001;-002;-006;-010 80 11 10 0. 1 10 5 Frequency (MHz) 80 i ~~ I Frequency (MHz) 70 I ~ r 60 --;; 50 ls 12-PML-006-2-A , -,;:;:::lo" 12-PML-001-2-A 0.2 0.5 ~ / .,~~ '\ \ ,:;~ \ '\ -- 12- PMF-006-2- B 1 1111 10 I 20 50 Frequency (MHz) www.linkedin.com/company/api-technologies-corp-/ 12 The Electromagnetic Spectrum Innovator DATA SHEET Power Line Filters | Single Stage 62-LMF & LMB Series Tested and found to be IAW VDE 0565 Part 3 Features • Space saving, compact designs • Suitable for products that must conform to FCC and FTZ regulations • Excellent fltering characteristics for both normal mode and common mode • Structure provides efective shielding for noise generated externally and internally • Metal case provides efective shielding • Rugged construction • Operating temperature: -25°C to +85°C (including temperature rise, see graph on page 14) Circuit Diagram ---. r---- Applications I Cy 1 3 I I I I I • Digital equipment • Ofce automation equipment Cx IR • Computers and peripherals I I I I I • Instrumentation and controls 2 th I I I 1_ _ _ _ _ _ _ _ _ _ _ ------.I 4 Specifcations Model 62-LMB-030-5-11 62-LMF-030-5-11 62-LMB-050-5-11 62-LMF-050-5-11 62-LMB-080-5-11 62-LMF-080-5-11 62-LMB-100-5-11 62-LMF-100-5-11 Rated Voltage (@ 50/60Hz) Rated Current Leakage Current (Max.) Capacitance CY CX Inductance (L1) 3A 0.1uF 14mH 5A 0.1uF & .22uF 7.0mH 8A .22uF 4.2mH 10A .33uF 2.2mH 250VAC 0.50mA Note: Test voltage: 1500VAC one minute, line to ground Insulation resistance: 300 Mohm min. at 500VDC Voltage drop: 1V max. at rated current Discharge time: 0.4 sec. max. Weight: 5.3 ounces (150 grams) www.apitech.com | 855.294.3800 | communications@apitech.com | 0.50mA Temperature Rise (Max.) 45°C * 62-LMF - designates Fast-on terminals 62-LMB - designates Bolt-in terminals 62-LML - wire lead in/outputs also available www.linkedin.com/company/api-technologies-corp-/ 13 The Electromagnetic Spectrum Innovator DATA SHEET Power Line Filters | Single Stage 62-LMF & LMB Series Characteristics 80 l C 60 ~ u 40 20 20 30 40 50 60 70 Ambient Temperature CC) 80 90 62-LMB 62-LMF 1.10 J .708 .66 (28.0) .61 --~---- - 1.97- ~------+< .66 (16.8) (50.0) (16.8) (18.0) (18.0) .255 (6.5) .255 (6.5) - l
62-AFC-030-5-11 价格&库存
很抱歉,暂时无法提供与“62-AFC-030-5-11”相匹配的价格&库存,您可以联系我们找货
