LI1210E600R-00
LI1210E600R-00
    LAIRD(莱尔德)
    LI1210E600R-00
LI1210E600R-00 数据手册
EMI Ferrite Chip Beads Steward’s surface mount ferrite chips provide compact, cost effective EMI filtering for densely packed PCB designs. The small footprint enables placement very close to troublesome high frequency devices. Our proprietary SMT construction yields rugged components with impedance versus frequency characteristics superior to those of similar products. Features: • Small footprint • Excellent retention under bias • Rugged, monolithic construction • Superior impedance vs. frequency characteristics • Economical • Broad range of sizes ( from 0402 up to 2220 and 3312 ) • Broad range of impedance values and current ratings Applications: • Filtering of power input pins and devices using high speed clocks • Filtering of low frequency input/output signals of shielded enclosures • High frequency filtering of medium speed clocks and video signals • Prevention of oscillations in high frequency amplifiers • Data bus filtration • Discrete component filtration in power supplies • Telecom Products Test Specifications: • Maximum current ratings are determined by testing to a maximum temperature rise of 40oC with continuous operating current • Board level components are rated up to a maximum of 75 volts. Tested with: • E4991A (100kHz - 3.0 GHz) or HP8753 (to 6 GHz) Network/Spectrum Analyzer • HP43961A Impedance Test Kit • HP16193A Test Fixture or Inter-Continental Microwave custom fixtures • HP16200A DC Bias Adapter • Philips PM2811 DC Power Supply • Ambient Temperature 23.5oC + 2o • Bandwidth 3 kHz • Sweep Time 423 ms • Impedance is rated at + 25% @100MHz Chip Bead DM Ultra High Current Chips (10 Amps +) LI HI High Current Chips HZ High Impedance Chips ( 400 Ohms) Low Current Chips (< 1 Amp and < 400 Ohms) MI Mid Current Chips (1-2 Amps) DA Chip Array (< 1 Amp) Chip Array Ambient Temperature Range: -55°C to +125°C METRIC IMPEDANCE ( Z ) ( EIA ) TYPICL OHMS @ PKG. SIZE 100MHz 500MHz 1GHz PART NUMBER DCR MAX OHMS RATED I MAX (continuous) mA Ultra High Current Chips METRIC IMPEDANCE ( Z ) ( EIA ) TYPICL OHMS @ PKG. SIZE 100MHz 500MHz 1GHz PART NUMBER DCR MAX OHMS RATED I MAX (continuous) mA High Current Chips (Continued) DM1612X560R-00 4131 (1612) 56 90 100 0.004 10,000 HI1206N101R-00 100 144 150 0.035 3,000 DM3312X101R-00 8531 (3312) 100 175 225 0.004 10,000 HI1206P121R-00 120 168 124 0.030 4,000 60 102 107 0.010 6,000 75 168 124 0.030 3,000 HI1806T600R-00 High Current Chips 4516 (1806) HI0603P600R-00 1608 (0603) 60 90 95 0.040 3,000 HI1806N750R-00 HI0805Q310R-00 2012 (0805) 31 42 46 0.025 4,500 HI1812T800R-00 4532 (1812) 80 121 129 0.010 6,000 HI0805P121R-00 120 183 152 0.040 3,000 HI2220T101R-00 5650 (2220) 100 148 152 0.015 6,000 HI0805R121R-00 120 183 152 0.020 5,000 HI2220R151R-00 150 215 196 0.020 5,000 33 45 50 0.030 4,000 HI2220P171R-00 170 318 349 0.035 4,000 HI1206T500R-00 50 73 80 0.010 6,000 HI2220R181R-00 180 279 265 0.020 5,000 HI1206N800R-00 80 120 129 0.035 3,000 HI2220P251R-00 250 172 91 0.035 4,000 HI1206P330R-00 3216 (1206) continued on right Steward continued on next page U.S.A. • Telephone: +1-(423)-867-4100 • Fax +1-(423)-867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: +44-(0)-1506-414200 • Fax +44-(0)-1506-410694 SINGAPORE • Telephone: +65-337-9667 • Fax +65-337-9686 BROCH0009 4/2001 REV 5 Page 2 METRIC IMPEDANCE ( Z ) ( EIA ) TYPICL OHMS @ PKG. SIZE 100MHz 500MHz 1GHz PART NUMBER DCR MAX OHMS RATED I MAX (continuous) mA High Current Chips (Continued) HI2220Q301R-00 5650 (2220) METRIC IMPEDANCE ( Z ) ( EIA ) TYPICL OHMS @ PKG. SIZE 100MHz 500MHz 1GHz PART NUMBER DCR MAX OHMS RATED I MAX (continuous) mA Mid Current Chips (Continued) 300 188 108 0.020 5,000 MI0805L301R-00 300 271 147 0.100 2,000 HI2220Q401R-00 400 159 99 0.025 4,500 MI0805L331R-00 330 262 142 0.100 2,000 HI2220P551R-00 550 670 343 0.035 4,000 MI0805K601R-00 600 275 140 0.100 1,500 HI2220P601R-00 600 184 106 0.035 4,000 MI1206K190R-00 19 55 70 0.080 1,500 HI2220P701R-00 700 140 90 0.035 4,000 MI1206K260R-00 26 38 40 0.060 1,500 HI2220V801R-00 800 123 78 0.010 8,000 MI1206K310R-00 31 45 50 0.080 1,500 500 215 133 0.035 4,000 MI1206J700R-00 70 104 107 0.100 1,000 HI2520P601R-00 600 639 165 0.035 4,000 MI1206K900R-00 90 142 158 0.080 1,500 HI2520P751R-00 750 173 114 0.035 4,000 MI1206K101R-00 100 146 152 0.075 1,500 MI1206M301R-00 300 142 158 0.050 2,500 HI2520P501R-00 6350 (2520) Mid Current Chips MI0603K300R-00 1608 (0603) 3216 (1206) 30 41 43 0.090 1,500 MI1206L501R-00 500 150 82 0.060 2,000 MI0603J600R-00 60 92 103 0.100 1,000 MI1206K601R-00 600 250 130 0.100 2,000 MI0603J680R-00 68 106 99 0.100 1,000 MI1806J800R-00 4516 (1806) 80 129 131 0.150 1,000 MI0603M121R-00 120 195 155 0.050 2,500 MI1812K121R-00 4532 (1812) 120 198 213 0.060 1,500 MI0603L301R-00 300 225 120 0.100 2,000 MI0603K501R-00 500 180 50 0.150 1,500 LI0402E300R-00 MI0603J601R-00 600 400 200 0.200 1,000 7 23 28 0.100 MI0805K110R-00 11 18 19 MI0805K170R-00 17 24 MI0805K260R-00 26 MI0805K320R-00 Low Current Chips 1005 (0402) 30 65 68 0.300 500 LI0402E600R-00 60 90 93 0.300 500 1,000 LI0402D121R-00 120 175 164 0.400 400 0.060 1,500 LI0402B241R-00 240 65 68 0.400 200 24 0.060 1,500 LI0402B301R-00 300 454 351 0.800 200 43 45 0.060 1,500 LI0603G600R-00 60 115 118 0.200 700 32 51 51 0.060 1,500 LI0603G800R-00 80 120 107 0.200 700 MI0805K400R-00 40 60 63 0.050 1,500 LI0603G121R-00 120 156 113 0.200 700 MI0805M201R-00 200 210 115 0.050 2,500 LI0603E141R-00 140 228 144 0.250 500 MI0805M221R-00 220 274 167 0.050 2,500 LI0603E151R-00 150 210 150 0.250 500 MI0805J070R-00 2012 (0805) continued on right. Steward 1608 (0603) continued on next page U.S.A. • Telephone: +1-(423)-867-4100 • Fax +1-(423)-867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: +44-(0)-1506-414200 • Fax +44-(0)-1506-410694 SINGAPORE • Telephone: +65-337-9667 • Fax +65-337-9686 BROCH0009 4/2001 REV 5 Page 3 METRIC IMPEDANCE ( Z ) ( EIA ) TYPICL OHMS @ PKG. SIZE 100MHz 500MHz 1GHz PART NUMBER DCR MAX OHMS RATED I MAX (continuous) mA Low Current Chips (Continued) PART NUMBER METRIC IMPEDANCE ( Z ) ( EIA ) TYPICL OHMS @ PKG. 100MHz 500MHz 1GHz SIZE DCR MAX OHMS RATED I MAX (continuous) mA High Impedance Chips (Continued) LI0603G221R-00 220 279 168 0.300 700 HZ0603B751R-00 750 331 168 0.600 200 LI0603D301R-00 300 286 165 0.350 400 HZ0603B102R-00 1,000 376 187 0.600 200 40 60 63 0.150 800 HZ0603A152R-00 1,500 426 216 1.500 100 LI0805H600R-00 60 78 75 0.150 800 HZ0805E401R-00 400 390 180 0.300 500 LI0805H750R-00 75 112 113 0.150 800 HZ0805G471R-00 470 286 150 0.350 700 LI0805H800R-00 80 116 98 0.150 800 HZ0805E601R-00 600 304 151 0.300 500 LI0805H121R-00 120 167 129 0.150 800 HZ0805D102R-00 1,000 328 168 0.350 400 LI0805H151R-00 150 207 138 0.150 800 HZ0805D152R-00 1,500 265 140 0.400 400 LI0805G221R-00 220 229 139 0.300 700 HZ0805C202R-00 2,000 345 175 0.500 300 LI0805G301R-00 300 248 146 0.200 700 HZ1206E601R-00 600 202 103 0.300 500 26 38 40 0.200 500 HZ1206E801R-00 800 137 95 0.300 500 LI1206E520R-00 52 83 92 0.150 500 HZ1206D102R-00 1,000 185 100 0.400 400 LI1206H900R-00 90 142 156 0.150 800 HZ1206E152R-00 1,500 115 99 0.300 500 LI1206H121R-00 120 144 135 0.150 800 HZ1206C202R-00 2,000 427 231 0.500 300 LI1206H151R-00 150 173 123 0.150 800 LI1206F241R-00 240 354 164 0.300 600 DA1206E300R-00 LI1206G301R-00 300 138 88 0.200 700 2012 (0805) LI0805H400R-00 3216 (1206) LI1206E260R-00 2012 (0805) 3216 (1206) 4-Line Chip Arrays 3216 (1206) 30 55 64 0.300 500 DA1206D600R-00 60 115 60 0.200 400 LI1210E600R-00 3225 (1210) 60 92 97 0.300 500 DA1206C121R-00 120 181 151 0.200 300 LI1806E800R-00 4516 (1806) 80 117 124 0.300 500 DA1206C151R-00 150 195 198 0.200 300 LI1806E101R-00 100 131 130 0.300 500 DA1206C221R-00 220 450 90 0.350 300 LI1806C151R-00 150 219 227 0.500 300 DA1206D301R-00 300 437 245 0.400 400 120 203 195 0.400 400 DA1206B471R-00 470 510 90 0.500 200 DA1206B601R-00 600 475 230 0.600 200 DA1206B102R-00 1,000 520 240 0.800 200 4532 (1812) LI1812D121R-00 High Impedance Chips HZ0402A601R-00 1005 (0402) 600 644 399 1.000 100 HZ0603C601R-00 1608 (0603) 600 338 171 0.450 300 continued on right Steward U.S.A. • Telephone: +1-(423)-867-4100 • Fax +1-(423)-867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: +44-(0)-1506-414200 • Fax +44-(0)-1506-410694 SINGAPORE • Telephone: +65-337-9667 • Fax +65-337-9686 BROCH0009 4/2001 REV 5 Page 4 Chip Size Metric ( EIA ) Pkg. Size B A C D Equivalent Circuit 1 2 A mm (inches) Land Patterns for Reflow Soldering B mm (inches) C mm (inches) D mm (inches) L** G H 0.30 MAX (0.012 MAX) 2.10 (0.083) 0.50 (0.020) 0.55 (0.022) 1005 (0402) 1.01 + 0.18 0.50 + 0.20 0.50 + 0.20 (0.040 + 0.007) (0.020 + 0.008) (0.020 + 0.008) 1608 (0603) 1.60 + 0.15 0.80 + 0.15 0.80 + 0.15 0.36 + 0.15 (0.063 + 0.006) (0.031 + 0.006) (0.031 + 0.006) (0.014 + 0.006) 2.60 (0.102) 0.60 (0.023) 0.80 (0.031) 2012 (0805) 2.00 + 0.20 1.25 + 0.20 0.90 + 0.20 0.51 + 0.25 (0.079 + 0.008) (0.049 + 0.008) (0.035 + 0.008) (0.020 + 0.010) 3.00 (0.118) 1.00 (0.039) 1.00 (0.039) 2012 (0805) 2.00 + 0.20 1.25 + 0.20 1.25 + 0.20 0.51 + 0.25 (0.079 + 0.008) (0.049 + 0.008) (0.049 + 0.008) (0.020 + 0.010) 3.00 (0.118) 1.00 (0.039) 1.00 (0.039) 3216 (1206) 3.20 + 0.20 1.60 + 0.20 1.10 + 0.20 0.51 + 0.25 (0.126 + 0.008) (0.063 + 0.008) (0.043 + 0.008) (0.020 + 0.010) 4.40 (0.173) 2.20 (0.087) 1.40 (0.055) 3225 (1210) 3.20 + 0.20 2.50 + 0.20 1.40 + 0.20 0.46 + 0.20 (0.126 + 0.008) (0.098 + 0.008) (0.055 + 0.008) (0.018 + 0.008) 4.06 (0.160) 1.62 (0.084) 2.92 (0.115) 4030 (1612) 4.06 + 0.20 3.05 + 0.20 2.28 + 0.20 0.46 + 0.20 (0.160 + 0.008) (0.120 + 0.008) (0.090 + 0.008) (0.018 + 0.008) 8.64 (0.340) 2.13 (0.084) 4.06 (0.160) 4516 (1806) 4.50 + 0.25 1.60 + 0.25 1.60 + 0.25 0.51 + 0.25 (0.177 + 0.010) (0.063 + 0.010) (0.063 + 0.010) (0.020 + 0.010) 5.70 (0.224) 2.70 (0.106) 1.40 (0.055) 4532 (1812) 3.20 + 0.25 1.40 + 0.25 0.46 + 0.20 4.50 + 0.25 (0.177 + 0.010) (0.126 + 0.010) (0.055 + 0.010) (0.018 + 0.008) 5.90 (0.232) 2.57 (0.101) 4.22 (0.166) 5650 (2220) 5.59 + 051 5.08 + 0.25 3.45 + 0.25 0.76 + 0.25 (0.220 + 0.020) (0.200 + 0.010) (0.136 + 0.010) (0.030 + 0.008) 9.19 (0.362) 3.07 (0.121) 6.10 (0.240) 6350 (2520) 5.00 + 0.25 3.00 + 0.25 0.76 + 0.25 6.40 + 0.51 (0.252 + 0.020) (0.197 + 0.010) (0.118 + 0.010) (0.030 + 0.010) 9.50 (0.374) 3.81 (01507) 6.10 (0.240) 8530 (3312) 8.50 + 0.20 3.05 + 0.20 2.28 + 0.20 0.51 + 0.25 (0.335 + 0.008) (0.120 + 0.008) (0.090 + 0.008) (0.020 + 0.010) 13.08 (0.515) 6.48 (0.255) 4.06 (0.160) 4-Line Chip Array Size Metric ( EIA ) Pkg. Size B A C D 3216 (1206) A mm (inches) B mm (inches) Chip Bead Land Patterns for Reflow Soldering C mm (inches) D mm (inches) 1.60 + 0.20 1.10 + 0.20 0.40 + 0.15 3.20 + 0.20 (0.126 + 0.008) (0.063 + 0.008) (0.043 + 0.008) (0.016 + 0.006) L** G H E 2.85 (0.112) 0.40 (0.016) 2.44 (0.096) 0.79 (0.031) Recommended Soldering Conditions E G H E Equivalent Circuit 8 7 6 5 L 4-Line Array 1 2 3 ** - For wave soldering, add 0.762mm (0.030”) to the L dimension 4 Steward Steward Steward 5 Cochrane Square Brucefield Industry Park Livingston EH54 9DR Scotland, UK Phone: +44-(0)1506-414200 Fax: +44-(0)1506-410694 Internet: http://www.steward.com e-mail: europe@steward.com 1200 East 36th Street P.O. Box 510 Chattanooga, Tennessee 37401-0510 U.S.A. Phone: +1-(423)-867-4100 Fax: +1-(423)-867-4102 Internet: http://www.steward.com e-mail: americas@steward.com 47 Hill Street, #08-07 SCCCI Building Singapore 179365 Phone: +65-337-9667 Fax: +65-337-9686 Internet: http://www.steward.com e-mail: asia@steward.com e-mail: stewarda@pacific.net.sg BROCH0009 4/2001 REV 5
LI1210E600R-00 价格&库存
很抱歉,暂时无法提供与“LI1210E600R-00”相匹配的价格&库存,您可以联系我们找货
