MI0603J600R-00
MI0603J600R-00
    LAIRD(莱尔德)
    MI0603J600R-00
MI0603J600R-00 数据手册
DIFFERENTIAL MODE Medium Current Ferrite Chip Beads Steward’s surface mount ferrite chips provide compact, cost effective EMI filtering for densely packed PCB designs. The small footprint enables placement very close to troublesome high frequency devices. Our proprietary SMT construction yields rugged components with superior impedance vs. frequency characteristics. Features: ·Small footprint ·Excellent retention under Bias ·Rugged, monolithic construction ·Superior impedance vs. frequency characteristics ·Economical ·Broad range of sizes (from 0603 up to 1812) ·Broad range of impedance values and current ratings Applications: ·Filtering of power input pins and devices using high speed clocks ·Filtering of low frequency input/output signals of shielded enclosures ·High frequency filtering of medium speed clocks and video signals ·Preventing oscillations in high frequency amplifiers ·Data bus filtration ·Discrete component filtration in power supplies Test Specifications: ·Maximum current ratings are determined by testing to a maximum temperature rise of 400 C with continuous operating current ·Board level components are rated up to a maximum of 75 volts Tested with: ·HP4396A (100KHz - 1.8 GHz) or HP8753 (to 6 GHz) Network/Spectrum Analyzer ·HP43961A Impedance Test Kit ·HP16192A Test Fixture or Inter-Continental Microwave custom fixtures ·HP16200A DC Bias Adapter ·Philips PM2811 DC Power Supply ·Ambient Temperature 23.5oC + 2o ·Bandwidth 3 kHz ·Sweep Time 423 ms ·Impedance is rated at + 25% @100MHz PART NUMBERING SYSTEM MI PRODUCT SERIES CODE 0603 PART SIZE CODE B K RATED CURRENT CODE 300 R IMPEDANCE VALUE CODE PACKAGING CODE - A 00 C ADDITIONAL PART DESCRIPTION D Ambient Operating Temperature Range: -55° C to +125° C PART NUMBER * A mm (inches) B mm (inches) C mm (inches) D mm (inches) DCR MAX OHMS RATED I MAX (continuous) mA MI0603K300R-00 1.60 + 0.15 (0.063 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.36 + 0.15 (0.014 + 0.006) 30 41 43 0.090 1,500 MI0603J600R-00 1.60 + 0.15 (0.063 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.36 + 0.15 (0.014 + 0.006) 60 92 103 0.100 1,000 MI0603J680R-00 1.60 + 0.15 (0.063 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.36 + 0.15 (0.014 + 0.006) 68 106 99 0.100 1,000 MI0805J070R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 7 23 28 0.100 1,000 MI0805K110R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 11 18 19 0.060 1,500 MI0805K170R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 17 24 24 0.060 1,500 MI0805K260R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 26 43 45 0.060 1,500 MI0805K320R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 32 51 51 0.060 1,500 MI0805K400R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 40 60 63 0.050 1,500 MI1206K260R-00 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 26 38 40 0.060 1,500 MI1206K310R-00 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 31 45 50 0.080 1,500 MI1206J700R-00 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 70 104 107 0.100 1,000 MI1206K900R-00 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 90 142 158 0.080 1,500 36 IMPEDANCE ( Z ) TYPICAL OHMS @ 100MHz 500MHz 1GHz STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 PART NUMBER B mm (inches) C mm (inches) D mm (inches) IMPEDANCE ( Z ) TYPICAL OHMS @ 100MHz 500MHz 1GHz DCR MAX OHMS RATED I MAX (continuous) mA MI1206K101R-00 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 100 146 152 0.075 1,500 MI1206L501R-00 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 500 150 82 0.060 2,000 MI1806J800R-00 4.50 + 0.25 (0.177 + 0.010) 1.60 + 0.25 (0.063 + 0.010) 1.60 + 0.25 (0.063 + 0.010) 0.51 + 0.25 (0.020 + 0.010) 80 129 131 0.150 1,000 MI1812K121R-00 4.50 + 0.25 (0.177 + 0.010) 3.20 + 0.25 (0.126 + 0.010) 1.40 + 0.25 (0.055 + 0.010) 0.51 + 0.25 (0.020 + 0.010) 120 198 213 0.060 1,500 DIFFERENTIAL MODE A mm (inches) * See Steward web site at www.steward.com for the most recent performance curves 60 Impedance (W) 60 Impedance (W) MI0603K300R-00 Z vs. Frequency Impedance Under DC Bias MI0603K300R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 40 Z R 20 40 20 XL 0 0 1 10 100 1000 1 10 Frequency (MHz) MI0603J600R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 1000 MI0603J600R-00 Z vs. Frequency Impedance Under DC Bias 120 Impedance (W) Impedance (W) 120 100 Frequency (MHz) 80 Z R 40 80 40 XL 0 0 1 10 1000 100 1 10 MI0603J680R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 100 75 Z R 50 25 1000 MI0603J680R-00 Z vs. Frequency Impedance Under DC Bias 100 Impedance (W) Impedance (W) 75 100 Frequency (MHz) Frequency (MHz) XL 50 25 0 0 1 10 100 Frequency (MHz) 1000 1 10 100 1000 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 37 MI0805K110R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance DIFFERENTIAL MODE 20 20 15 15 Impedance (W) Impedance (W) MI0805K110R-00 Z vs. Frequency Impedance Under DC Bias Z 10 R XL 5 10 5 0 1 10 1000 100 1 Frequency (MHz) MI0805J170R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 40 30 20 Impedance (W) Impedance (W) 1000 Frequency (MHz) MI0805J170R-00 Z vs. Frequency Impedance Under DC Bias 40 30 100 10 Z R 10 20 10 XL 0 0 1 10 1000 100 1 MI0805K260R-00 Z vs. Frequency Impedance Under DC Bias 60 Impedance (W) Impedance (W) 1000 Frequency (MHz) MI0805K260R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 60 100 10 Frequency (MHz) 40 Z R 20 XL 40 20 0 1 10 100 1000 1 10 Frequency (MHz) MI0805K320R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 80 60 Impedance (W) Impedance (W) 1000 MI0805K320R-00 Z vs. Frequency Impedance Under DC Bias 80 60 Z 40 R 20 XL 40 20 0 0 1 10 100 Frequency (MHz) 38 100 Frequency (MHz) 1000 1 10 100 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 1000 80 60 60 Impedance (W) 80 Z 40 R 20 MI0805K400R-00 Z vs. Frequency Impedance Under DC Bias DIFFERENTIAL MODE Impedance (W) MI0805K400R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 40 20 XL 0 0 1 10 1000 100 1 10 Frequency (MHz) MI1206K260R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 50 40 Impedance (W) Impedance (W) 30 Z R 20 XL 10 30 20 10 0 0 1 10 100 1000 1 10 Frequency (MHz) 1000 MI1206K310R-00 Z vs. Frequency Impedance Under DC Bias 60 60 50 50 Impedance (W) Z 40 100 Frequency (MHz) MI1206K310R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance Impedance (W) 1000 MI1206K260R-00 Z vs. Frequency Impedance Under DC Bias 50 40 R 30 20 XL 40 30 20 10 10 0 0 1 10 1000 100 1 10 Frequency (MHz) 100 1000 Frequency (MHz) MI1206J700R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 120 MI1206J700R-00 Z vs. Frequency Impedance Under DC Bias 120 Z Impedance (W) Impedance (W) 100 Frequency (MHz) 80 R 40 XL 80 40 0 0 1 10 100 Frequency (MHz) 1000 1 10 100 1000 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 39 MI1206K900R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance DIFFERENTIAL MODE 200 200 150 Impedance (W) Impedance (W) 150 Z 100 R 50 100 50 XL 0 0 100 10 1 1000 1 Frequency (MHz) 150 Impedance (W) Z R 100 50 XL 0 100 50 0 1 10 100 1000 500 400 Z 300 R Impedance (W) Impedance (W) MI1206L501R-00 Z vs. Frequency Impedance Under DC Bias 600 500 200 XL 400 300 200 100 100 0 0 1 10 100 MI1806J800R-00 Z vs. Frequency Impedance Under DC Bias 150 Impedance (W) Z 100 1000 Frequency (MHz) MI1806J800R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 150 100 10 1 1000 Frequency (MHz) Impedance (W) 1000 Frequency (MHz) MI1206L501R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 600 100 10 1 Frequency (MHz) R 50 XL 0 100 50 0 1 10 100 Frequency (MHz) 40 1000 200 200 150 100 10 Frequency (MHz) MI1206K101R-00 Z vs. Frequency Impedance Under DC Bias MI1206K101R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance Impedance (W) MI1206K900R-00 Z vs. Frequency Impedance Under DC Bias 1000 1 10 100 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 1000 MI1812K121R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 200 Z 150 Impedance (W) Impedance (W) 200 R 100 XL 50 DIFFERENTIAL MODE 150 MI1812K121R-00 Z vs. Frequency Impedance Under DC Bias 100 50 0 0 1 10 100 Frequency (MHz) 1000 1 10 100 1000 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 41 STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 E A C D W B T 21.0 + 0.8 (0.82 + 0.031) 2.0 + 0.5 (0.08 + 0.020) 8.0 + 1.0 (0.32 + 0.039) 1.0 (0.039) E W T 13.0 + 0.5 (0.51 + 0.020) 95.0 + 1.0 (3.74 + 0.039) 330.0 / 178.0 + 2.0 (13.00 / 7.00 + 0.078) D C B A Reel Specifications Blank 90 (3.543) Min Minimum of 160mm (6.30) of empty pockets with cover G Chips F T F1 A0 A F0 8 O MAX Blank B C Drawing Direction B 5 O MAX 230 (9.05) Min 390-560 (15.35-22.05) D D0 13" 3.99 3.51 + 0.10 5.08 4.78 + 0.10 1.73 + 0.10 5.50 + 0.05 1.75 + 0.10 8.00 + 0.10 1.50 + 0.25 2.00 + 0.05 1.50 + 0.10 12.00 + 0.30 / - 0.10 4.00 + 0.10 0.29 + 0.013 (0.157) (0.138 + 0.004) (0.200) (0.188 + 0.004) (0.068 + 0.004) (0.217 + 0.002) (0.069 + 0.004) (0.315 + 0.004) (0.059 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.472 + 0.012 / - 0.004) (0.157 + 0.004) (0.011 + 0.0005) MI1812 H 7" 5.23 4.88 + 0.10 1.98 + 0.10 5.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.50 + 0.25 2.00 + 0.05 1.50 + 0.10 12.00 + 0.30 / - 0.10 4.00 + 0.10 0.29 + 0.013 2.46 1.98 + 0.10 (0.097) (0.078 + 0.004) (0.206) (0.192 + 0.004) (0.078 + 0.004) (0.217 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.059 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.472 + 0.012 / - 0.004) (0.157 + 0.004) (0.011 + 0.0005) MI1806 DIFFERENTIAL MODE E 13" 2.21 1.88 + 0.10 3.76 3.56 + 0.10 1.10 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 (0.087) (0.074 + 0.004) (0.148) (0.140 + 0.004) (0.043 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) MI1206L Reel Size 13" T 3.76 3.56 + 0.10 1.91 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 2.21 1.88 + 0.10 (0.087) (0.074 + 0.004) (0.148) (0.140 + 0.004) (0.075 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) H MI1206K G 7" F1 2.21 1.88 + 0.10 3.76 3.56 + 0.10 1.40 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 (0.087) (0.074 + 0.004) (0.148) (0.140 + 0.004) (0.055 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) F0 MI1206 F 7" E 2.49 2.31 + 0.10 1.91 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 1.85 1.55 + 0.10 (0.073) (0.061 + 0.004) (0.098) (0.091 + 0.004) (0.051 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) D0 MI0805K D 7" C 1.85 1.55 + 0.10 2.49 2.31 + 0.10 1.30 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 (0.073) (0.061 + 0.004) (0.098) (0.091 + 0.004) (0.051 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) B0 MI0805 B 7" A0 3.76 3.56 + 0.10 1.91 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 2.21 1.88 + 0.10 (0.087) (0.074 + 0.004) (0.148) (0.140 + 0.004) (0.075 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) A MI0603 P/N MI Tape Specifications Tape & Reel Specifications 67
MI0603J600R-00 价格&库存
很抱歉,暂时无法提供与“MI0603J600R-00”相匹配的价格&库存,您可以联系我们找货
