LI0402B301R-00
LI0402B301R-00
    LAIRD(莱尔德)
    LI0402B301R-00
LI0402B301R-00 数据手册
DIFFERENTIAL MODE Low Current Ferrite Chip Beads Steward’s surface mount ferrite chips provide compact, cost effective EMI filtering for densely packed PCB designs. The small footprint enables placement very close to troublesome high frequency devices. Our proprietary SMT construction yields rugged components with superior impedance vs. frequency characteristics. Features: ·Small footprint ·Excellent retention under Bias ·Rugged, monolithic construction ·Superior impedance vs. frequency characteristics ·Economical ·Broad range of sizes (from 0402 up to 1812) ·Broad range of impedance values and current ratings Application: ·Filtering of power input pins and devices using high speed clocks ·Filtering of low frequency input/output signals of shielded enclosures ·High frequency filtering of medium speed clocks and video signals ·Preventing oscillations in high frequency amplifiers ·Data bus filtration ·Discrete component filtration in power supplies Test Specifications: ·Maximum current ratings are determined by testing to a maximum temperature rise of 400 C with continuous operating current ·Board level components are rated up to a maximum of 75 volts Tested with: ·HP4396A (100KHz - 1.8 GHz) or HP8753 (to 6 GHz) Network/Spectrum Analyzer ·HP43961A Impedance Test Kit ·HP16192A Test Fixture or Inter-Continental Microwave custom fixtures ·HP16200A DC Bias Adapter ·Philips PM2811 DC Power Supply ·Ambient Temperature 23.5oC + 2o ·Bandwidth 3 kHz ·Sweep Time 423 ms ·Impedance is rated at + 25% @100MHz B PART NUMBERING SYSTEM LI PRODUCT SERIES CODE 0402 PART SIZE CODE E 300 RATED CURRENT CODE IMPEDANCE VALUE CODE R - PACKAGING CODE A 00 C ADDITIONAL PART DESCRIPTION D Ambient Operating Temperature Range: -55° C to +125° C PART NUMBER * * * A mm (inches) B mm (inches) C mm (inches) D mm (inches) DCR MAX OHMS RATED I MAX (continuous) mA LI0402E300R-00 1.01 + 0.18 (0.040 + 0.007) 0.50 + 0.20 (0.020 + 0.008) 0.50 + 0.20 (0.020 + 0.008) 0.30 MAX (0.012 MAX) 30 65 68 0.300 500 LI0402E600R-00 1.01 + 0.18 (0.040 + 0.007) 0.50 + 0.20 (0.020 + 0.008) 0.50 + 0.20 (0.020 + 0.008) 0.30 MAX (0.012 MAX) 60 90 93 0.300 500 LI0402D121R-00 1.01 + 0.18 (0.040 + 0.007) 0.50 + 0.20 (0.020 + 0.008) 0.50 + 0.20 (0.020 + 0.008) 0.30 MAX (0.012 MAX) 120 175 164 0.400 400 LI0402B301R-00 1.01 + 0.18 (0.040 + 0.007) 0.50 + 0.20 (0.020 + 0.008) 0.50 + 0.20 (0.020 + 0.008) 0.30 MAX (0.012 MAX) 300 454 351 0.800 200 LI0603G800R-00 1.60 + 0.15 (0.063 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.36 + 0.15 (0.014 + 0.006) 80 120 107 0.200 700 LI0603G121R-00 1.60 + 0.15 (0.063 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.36 + 0.15 (0.014 + 0.006) 120 156 113 0.200 700 LI0603E151R-00 1.60 + 0.15 (0.063 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.36 + 0.15 (0.014 + 0.006) 150 205 160 0.250 500 LI0603G221R-00 1.60 + 0.15 (0.063 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.36 + 0.15 (0.014 + 0.006) 220 279 168 0.300 700 LI0603D301R-00 1.60 + 0.15 (0.063 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.36 + 0.15 (0.014 + 0.006) 300 286 165 0.350 400 LI0805H400R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 40 60 63 0.150 800 LI0805H600R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 60 78 75 0.150 800 LI0805H750R-00 1.60 + 0.15 (0.063 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.36 + 0.15 (0.014 + 0.006) 75 115 115 0.150 800 LI0805H800R-00 1.60 + 0.15 (0.063 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.80 + 0.15 (0.031 + 0.006) 0.36 + 0.15 (0.014 + 0.006) 80 115 100 0.2 700 42 IMPEDANCE ( Z ) TYPICAL OHMS @ 100MHz 500MHz 1GHz PART NUMBER B mm (inches) C mm (inches) D mm (inches) LI0805H121R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 120 167 LI0805H151R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 150 LI0805G301R-00 2.00 + 0.20 (0.079 + 0.008) 1.25 + 0.20 (0.049 + 0.008) 0.90 + 0.20 (0.035 + 0.008) 0.51 + 0.25 (0.020 + 0.010) * LI1206E260R-00 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) * LI1206E520R-00 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) LI1206H900R-00 3.20 + 0.20 (0.126 + 0.008) LI1206H121R-00 DCR MAX OHMS RATED I MAX (continuous) mA 129 0.150 800 207 138 0.150 800 300 248 146 0.200 700 0.51 + 0.25 (0.020 + 0.010) 26 43 50 0.200 700 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 52 800 93 0150 800 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 90 142 156 0.150 800 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 120 144 135 0.150 800 LI1206H151R-00 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 150 173 123 0.150 800 LI1206G301R-00 3.20 + 0.20 (0.126 + 0.008) 1.60 + 0.20 (0.063 + 0.008) 1.10 + 0.20 (0.043 + 0.008) 0.51 + 0.25 (0.020 + 0.010) 300 138 88 0.200 700 LI1806E800R-00 4.50 + 0.254 (0.177 + 0.010) 1.60 + 0.254 (0.063 + 0.010) 1.60 + 0.254 (0.063 + 0.010) 0.51 + 0.25 (0.020 + 0.010) 80 117 124 0.300 500 LI1806E101R-00 4.50 + 0.254 (0.177 + 0.010) 1.60 + 0.254 (0.063 + 0.010) 1.60 + 0.254 (0.063 + 0.010) 0.51 + 0.25 (0.020 + 0.010) 100 131 130 0.300 500 LI1806C151R-00 4.50 + 0.254 (0.177 + 0.010) 1.60 + 0.254 (0.063 + 0.010) 1.60 + 0.254 (0.063 + 0.010) 0.51 + 0.25 (0.020 + 0.010) 150 219 227 0.500 300 LI1812D121R-00 4.50 + 0.254 (0.177 + 0.010) 3.20 + 0.254 (0.126 + 0.010) 1.40 + 0.254 (0.055 + 0.010) 0.46 + 0.20 (0.018 + 0.008) 120 203 195 0.400 400 See Steward web site at www.steward.com for the most recent performance curves. LI0402E300R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 60 LI0402E300R-00 Z vs. Frequency Impedance Under DC Bias 60 50 50 Impedance (W) Impedance (W) * IMPEDANCE ( Z ) TYPICAL OHMS @ 100MHz 500MHz 1GHz DIFFERENTIAL MODE A mm (inches) 40 Z 30 R 20 XL 10 40 30 20 10 0 0 1 10 100 Frequency (MHz) 1000 1 10 100 1000 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 43 LI0402D121R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance DIFFERENTIAL MODE 200 200 150 Impedance (W) Impedance (W) 150 Z 100 R 50 XL 100 50 0 0 10 1 100 1 1000 600 500 500 Impedance (W) 600 400 Z 300 R 200 XL 100 10 100 LI0402B301R-00 Z vs. Frequency Impedance Under DC Bias 400 300 200 100 0 0 1 10 100 1 1000 10 LI0603G800R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 160 1000 LI0603G800R-00 Z vs. Frequency Impedance Under DC Bias 160 120 Impedance (W) 120 Impedance (W) 100 Frequency (MHz) Frequency (MHz) Z 80 R XL 40 0 80 40 0 1 10 100 Frequency (MHz) 1000 1 LI0603G121R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 200 150 R XL 50 100 1000 150 Z 100 10 Frequency (MHz) LI0603G121R-00 Z vs. Frequency Impedance Under DC Bias 200 Impedance (W) Impedance (W) 1000 Frequency (MHz) Frequency (MHz) LI0402B301R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance Impedance (W) LI0402D121R-00 Z vs. Frequency Impedance Under DC Bias 100 50 0 0 1 10 100 Frequency (MHz) 44 1000 1 10 100 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 1000 LI0603G221R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 400 400 DIFFERENTIAL MODE 300 Impedance (W) 300 Impedance (W) LI0603G221R-00 Z vs. Frequency Impedance Under DC Bias Z 200 R XL 200 100 100 0 0 1 10 1000 100 LI0603D301R-00 Z vs. Frequency Impedance Under DC Bias 500 400 400 Impedance (W) Z Impedance (W) 1000 Frequency (MHz) LI0603D301R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 500 100 10 1 Frequency (MHz) R 300 200 XL 100 300 200 100 0 0 1 10 80 100 LI0805H400R-00 Z vs. Frequency Impedance Under DC Bias 80 Impedance (W) 60 Z 40 R 20 40 20 XL 0 0 1 10 1000 100 1 10 Frequency (MHz) 100 1000 Frequency (MHz) LI0805H600R-00 Z vs. Frequency Impedance Under DC Bias LI0805H600R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 120 Impedance (W) 120 Impedance (W) 1000 Frequency (MHz) 60 Impedance (W) 10 1 1000 100 Frequency (MHz) LI0805H400R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 80 Z R 40 XL 80 40 0 0 1 10 100 Frequency (MHz) 1000 1 10 100 1000 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 45 LI0805H800R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 120 LI0805H800R-00 Z vs. Frequency Impedance Under DC Bias 120 R 80 Impedance (W) Impedance (W) DIFFERENTIAL MODE Z 40 XL 80 40 0 0 10 1 1 1000 100 Impedance (W) 100 R 50 XL 1 100 50 0 10 100 1000 1 100 10 Frequency (MHz) Frequency (MHz) LI0805H151R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance LI0805H151R-00 Z vs. Frequency Impedance Under DC Bias 200 250 150 R 100 XL 50 1000 200 Z Impedance (W) Impedance (W) 150 Z 250 Impedance (W) LI0805H121R-00 Z vs. Frequency Impedance Under DC Bias 200 150 0 1000 Frequency (MHz) LI0805H121R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 200 100 10 Frequency (MHz) 150 100 50 0 0 1 10 100 1 1000 Frequency (MHz) 1000 400 400 300 300 Z 200 Impedance (W) Impedance (W) 100 Frequency (MHz) LI0805G301R-00 Z vs. Frequency Impedance Under DC Bias LI0805G301R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance R XL 100 200 100 0 0 1 10 100 Frequency (MHz) 46 10 1000 1 10 100 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 1000 LI1206H900R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 200 200 DIFFERENTIAL MODE 150 150 Impedance (W) Impedance (W) LI1206H900R-00 Z vs. Frequency Impedance Under DC Bias Z 100 R 100 50 50 XL 0 0 10 1 Frequency (MHz) LI1206H121R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 160 Impedance (W) Impedance (W) R XL 80 40 0 0 1 10 100 1 1000 10 1000 LI1206H151R-00 Z vs. Frequency Impedance Under DC Bias 250 250 200 200 Impedance (W) Impedance (W) LI1206H151R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance Z 150 R 100 XL 50 100 Frequency (MHz) Frequency (MHz) 150 100 50 0 0 1 10 100 1 1000 10 LI1206G301R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 400 200 R 300 Impedance (W) Z 1000 LI1206G301R-00 Z vs. Frequency Impedance Under DC Bias 400 300 100 Frequency (MHz) Frequency (MHz) Impedance (W) 1000 120 80 40 100 Frequency (MHz) LI1206H121R-00 Z vs. Frequency Impedance Under DC Bias 160 Z 120 10 1 1000 100 XL 100 200 100 0 0 1 10 100 Frequency (MHz) 1000 1 10 100 1000 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 47 LI1806E800R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 150 Z 100 Impedance (W) Impedance (W) DIFFERENTIAL MODE 150 LI1806E800R-00 Z vs. Frequency Impedance Under DC Bias R 50 100 50 XL 0 0 1 10 100 1 1000 150 Impedance (W) R 100 XL 50 1 10 100 50 100 0 1000 1 10 Frequency (MHz) 250 200 200 Impedance (W) Impedance (W) 250 Z 150 R 100 XL 50 100 1000 Frequency (MHz) LI1806C151R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance LI1806C151R-00 Z vs. Frequency Impedance Under DC Bias 150 100 50 0 0 1 10 100 1 1000 10 LI1812D121R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 250 100 1000 Frequency (MHz) Frequency (MHz) LI1812D121R-00 Z vs. Frequency Impedance Under DC Bias 250 200 Impedance (W) 200 Impedance (W) 1000 150 Z 0 Z 150 R 100 XL 50 150 100 50 0 0 1 10 100 Frequency (MHz) 48 100 LI1806E101R-00 Z vs. Frequency Impedance Under DC Bias 200 200 Impedance (W) 10 Frequency (MHz) Frequency (MHz) LI1806E101R-00 Z, R, XL vs. Frequency Impedance, Resistance, Inductive Reactance 1000 1 10 100 Frequency (MHz) STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686 1000 66 E A C D W B T 330.0 / 178.0 + 2.0 (13.00 / 7.00 + 0.078) 95.0 + 1.0 (3.74 + 0.039) 13.0 + 0.5 (0.51 + 0.020) 21.0 + 0.8 (0.82 + 0.031) 2.0 + 0.5 (0.08 + 0.020) 8.0 + 1.0 (0.32 + 0.039) 1.0 (0.039) A B C D E W T Reel Specifications Blank 90 (3.543) Min Minimum of 160mm (6.30) of empty pockets with cover G Chips F T F1 A0 A F0 B C Drawing Direction 230 (9.05) Min 390-560 (15.35-22.05) Blank 8 O MAX D D0 B 5 O MAX 13" 5.08 4.78 + 0.10 1.73 + 0.10 5.50 + 0.05 1.75 + 0.10 8.00 + 0.10 1.50 + 0.25 2.00 + 0.05 1.50 + 0.10 12.00 + 0.30 / - 0.10 4.00 + 0.10 0.29 + 0.013 3.99 3.51 + 0.10 (0.157) (0.138 + 0.004) (0.200) (0.188 + 0.004) (0.068 + 0.004) (0.217 + 0.002) (0.069 + 0.004) (0.315 + 0.004) (0.059 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.472 + 0.012 / - 0.004) (0.157 + 0.004) (0.011 + 0.0005) LI1812 H 7" 5.23 4.88 + 0.10 1.98 + 0.10 5.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.50 + 0.25 2.00 + 0.05 1.50 + 0.10 12.00 + 0.30 / - 0.10 4.00 + 0.10 0.29 + 0.013 2.46 1.98 + 0.10 (0.097) (0.078 + 0.004) (0.206) (0.192 + 0.004) (0.078 + 0.004) (0.217 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.059 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.472 + 0.012 / - 0.004) (0.157 + 0.004) (0.011 + 0.0005) LI1806 E 7" 3.87 3.61 + 0.10 1.52 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 3.33 2.90 + 0.10 (0.131) (0.114 + 0.004) (0.153) (0.142 + 0.004) (0.060 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) LI1210 Reel Size 7" T 3.76 3.56 + 0.10 1.91 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 2.21 1.88 + 0.10 (0.087) (0.074 + 0.004) (0.148) (0.140 + 0.004) (0.075 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) H LI1206 G 7" F1 2.49 2.31 + 0.10 1.30 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 1.85 1.55 + 0.10 (0.073) (0.061 + 0.004) (0.098) (0.091 + 0.004) (0.051 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) F0 LI0805 F 7" E 3.76 3.56 + 0.10 1.91 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 2.21 1.88 + 0.10 (0.087) (0.074 + 0.004) (0.148) (0.140 + 0.004) (0.075 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) D0 LI0603 D 7" C 1.80 1.15 + 0.10 0.85 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 1.20 1.60 + 0.10 (0.047) (0.063 + 0.004) (0.071) (0.045 + 0.004) (0.033 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) B0 LI0402 B 13" A0 2.21 1.88 + 0.10 3.76 3.56 + 0.10 1.40 + 0.10 3.50 + 0.05 1.75 + 0.10 4.00 + 0.10 1.00 + 0.25 2.00 + 0.05 1.50 + 0.10 8.00 + 0.30 / - 0.10 4.00 + 0.10 0.25 + 0.013 (0.087) (0.074 + 0.004) (0.148) (0.140 + 0.004) (0.055 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005) A DA1206 P/N DA & LI Tape Specifications DIFFERENTIAL MODE Tape & Reel Specifications STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694 SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686
LI0402B301R-00 价格&库存
很抱歉,暂时无法提供与“LI0402B301R-00”相匹配的价格&库存,您可以联系我们找货
LI0402B301R-00
  • 24000+0.3333524000+0.04313
