DIFFERENTIAL MODE
Low Current
Ferrite Chip Beads
Steward’s surface mount ferrite chips provide compact, cost effective
EMI filtering for densely packed PCB designs. The small footprint
enables placement very close to troublesome high frequency devices.
Our proprietary SMT construction yields rugged components with
superior impedance vs. frequency characteristics.
Features:
·Small footprint ·Excellent retention under Bias ·Rugged, monolithic construction ·Superior impedance vs. frequency characteristics
·Economical ·Broad range of sizes (from 0402 up to 1812) ·Broad range of impedance values and current ratings
Application:
·Filtering of power input pins and devices using high speed clocks ·Filtering of low frequency input/output signals of shielded
enclosures ·High frequency filtering of medium speed clocks and video signals ·Preventing oscillations in high frequency amplifiers
·Data bus filtration ·Discrete component filtration in power supplies
Test Specifications:
·Maximum current ratings are determined by testing to a maximum temperature rise of 400 C with continuous operating current
·Board level components are rated up to a maximum of 75 volts
Tested with: ·HP4396A (100KHz - 1.8 GHz) or HP8753 (to 6 GHz) Network/Spectrum Analyzer ·HP43961A Impedance Test Kit
·HP16192A Test Fixture or Inter-Continental Microwave custom fixtures ·HP16200A DC Bias Adapter ·Philips PM2811 DC Power
Supply ·Ambient Temperature 23.5oC + 2o ·Bandwidth 3 kHz ·Sweep Time 423 ms ·Impedance is rated at + 25% @100MHz
B
PART NUMBERING SYSTEM
LI
PRODUCT
SERIES CODE
0402
PART
SIZE CODE
E
300
RATED
CURRENT CODE
IMPEDANCE
VALUE CODE
R
PACKAGING
CODE
A
00
C
ADDITIONAL PART
DESCRIPTION
D
Ambient Operating Temperature Range: -55° C to +125° C
PART
NUMBER
A
mm
(inches)
B
mm
(inches)
C
mm
(inches)
D
mm
(inches)
DCR
MAX
OHMS
RATED I MAX
(continuous)
mA
LI0402E300R-00
1.01 + 0.18
(0.040 + 0.007)
0.50 + 0.20
(0.020 + 0.008)
0.50 + 0.20
(0.020 + 0.008)
0.30 MAX
(0.012 MAX)
30
65
68
0.300
500
LI0402E600R-00
1.01 + 0.18
(0.040 + 0.007)
0.50 + 0.20
(0.020 + 0.008)
0.50 + 0.20
(0.020 + 0.008)
0.30 MAX
(0.012 MAX)
60
90
93
0.300
500
LI0402D121R-00
1.01 + 0.18
(0.040 + 0.007)
0.50 + 0.20
(0.020 + 0.008)
0.50 + 0.20
(0.020 + 0.008)
0.30 MAX
(0.012 MAX)
120
175
164
0.400
400
LI0402B301R-00
1.01 + 0.18
(0.040 + 0.007)
0.50 + 0.20
(0.020 + 0.008)
0.50 + 0.20
(0.020 + 0.008)
0.30 MAX
(0.012 MAX)
300
454
351
0.800
200
LI0603G800R-00
1.60 + 0.15
(0.063 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.36 + 0.15
(0.014 + 0.006)
80
120
107
0.200
700
LI0603G121R-00
1.60 + 0.15
(0.063 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.36 + 0.15
(0.014 + 0.006)
120
156
113
0.200
700
LI0603E151R-00
1.60 + 0.15
(0.063 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.36 + 0.15
(0.014 + 0.006)
150
205
160
0.250
500
LI0603G221R-00
1.60 + 0.15
(0.063 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.36 + 0.15
(0.014 + 0.006)
220
279
168
0.300
700
LI0603D301R-00
1.60 + 0.15
(0.063 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.36 + 0.15
(0.014 + 0.006)
300
286
165
0.350
400
LI0805H400R-00
2.00 + 0.20
(0.079 + 0.008)
1.25 + 0.20
(0.049 + 0.008)
0.90 + 0.20
(0.035 + 0.008)
0.51 + 0.25
(0.020 + 0.010)
40
60
63
0.150
800
LI0805H600R-00
2.00 + 0.20
(0.079 + 0.008)
1.25 + 0.20
(0.049 + 0.008)
0.90 + 0.20
(0.035 + 0.008)
0.51 + 0.25
(0.020 + 0.010)
60
78
75
0.150
800
LI0805H750R-00
1.60 + 0.15
(0.063 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.36 + 0.15
(0.014 + 0.006)
75
115
115
0.150
800
LI0805H800R-00
1.60 + 0.15
(0.063 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.80 + 0.15
(0.031 + 0.006)
0.36 + 0.15
(0.014 + 0.006)
80
115
100
0.2
700
42
IMPEDANCE ( Z )
TYPICAL OHMS @
100MHz 500MHz 1GHz
PART
NUMBER
B
mm
(inches)
C
mm
(inches)
D
mm
(inches)
LI0805H121R-00
2.00 + 0.20
(0.079 + 0.008)
1.25 + 0.20
(0.049 + 0.008)
0.90 + 0.20
(0.035 + 0.008)
0.51 + 0.25
(0.020 + 0.010)
120
167
LI0805H151R-00
2.00 + 0.20
(0.079 + 0.008)
1.25 + 0.20
(0.049 + 0.008)
0.90 + 0.20
(0.035 + 0.008)
0.51 + 0.25
(0.020 + 0.010)
150
LI0805G301R-00
2.00 + 0.20
(0.079 + 0.008)
1.25 + 0.20
(0.049 + 0.008)
0.90 + 0.20
(0.035 + 0.008)
0.51 + 0.25
(0.020 + 0.010)
LI1206E260R-00
3.20 + 0.20
(0.126 + 0.008)
1.60 + 0.20
(0.063 + 0.008)
1.10 + 0.20
(0.043 + 0.008)
LI1206E520R-00
3.20 + 0.20
(0.126 + 0.008)
1.60 + 0.20
(0.063 + 0.008)
LI1206H900R-00
3.20 + 0.20
(0.126 + 0.008)
LI1206H121R-00
DCR
MAX
OHMS
RATED I MAX
(continuous)
mA
129
0.150
800
207
138
0.150
800
300
248
146
0.200
700
0.51 + 0.25
(0.020 + 0.010)
26
43
50
0.200
700
1.10 + 0.20
(0.043 + 0.008)
0.51 + 0.25
(0.020 + 0.010)
52
800
93
0150
800
1.60 + 0.20
(0.063 + 0.008)
1.10 + 0.20
(0.043 + 0.008)
0.51 + 0.25
(0.020 + 0.010)
90
142
156
0.150
800
3.20 + 0.20
(0.126 + 0.008)
1.60 + 0.20
(0.063 + 0.008)
1.10 + 0.20
(0.043 + 0.008)
0.51 + 0.25
(0.020 + 0.010)
120
144
135
0.150
800
LI1206H151R-00
3.20 + 0.20
(0.126 + 0.008)
1.60 + 0.20
(0.063 + 0.008)
1.10 + 0.20
(0.043 + 0.008)
0.51 + 0.25
(0.020 + 0.010)
150
173
123
0.150
800
LI1206G301R-00
3.20 + 0.20
(0.126 + 0.008)
1.60 + 0.20
(0.063 + 0.008)
1.10 + 0.20
(0.043 + 0.008)
0.51 + 0.25
(0.020 + 0.010)
300
138
88
0.200
700
LI1806E800R-00
4.50 + 0.254
(0.177 + 0.010)
1.60 + 0.254
(0.063 + 0.010)
1.60 + 0.254
(0.063 + 0.010)
0.51 + 0.25
(0.020 + 0.010)
80
117
124
0.300
500
LI1806E101R-00
4.50 + 0.254
(0.177 + 0.010)
1.60 + 0.254
(0.063 + 0.010)
1.60 + 0.254
(0.063 + 0.010)
0.51 + 0.25
(0.020 + 0.010)
100
131
130
0.300
500
LI1806C151R-00
4.50 + 0.254
(0.177 + 0.010)
1.60 + 0.254
(0.063 + 0.010)
1.60 + 0.254
(0.063 + 0.010)
0.51 + 0.25
(0.020 + 0.010)
150
219
227
0.500
300
LI1812D121R-00
4.50 + 0.254
(0.177 + 0.010)
3.20 + 0.254
(0.126 + 0.010)
1.40 + 0.254
(0.055 + 0.010)
0.46 + 0.20
(0.018 + 0.008)
120
203
195
0.400
400
See Steward web site at www.steward.com for the most recent performance curves.
LI0402E300R-00
Z, R, XL vs. Frequency
Impedance, Resistance, Inductive Reactance
60
LI0402E300R-00
Z vs. Frequency
Impedance Under DC Bias
60
50
50
Impedance (W)
Impedance (W)
IMPEDANCE ( Z )
TYPICAL OHMS @
100MHz 500MHz 1GHz
DIFFERENTIAL MODE
A
mm
(inches)
40
Z
30
R
XL
10
40
30
10
100
Frequency (MHz)
1000
1
10
100
1000
Frequency (MHz)
STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com
SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694
SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686
43
LI0402D121R-00
DIFFERENTIAL MODE
200
200
150
Impedance (W)
Impedance (W)
150
Z
100
R
50
XL
100
50
1
100
1
1000
600
500
500
Impedance (W)
600
400
Z
300
R
200
XL
100
10
100
LI0402B301R-00
Z vs. Frequency
400
300
200
100
10
100
1
1000
10
LI0603G800R-00
160
1000
LI0603G800R-00
Z vs. Frequency
160
120
Impedance (W)
120
Impedance (W)
100
Frequency (MHz)
Frequency (MHz)
Z
80
R
XL
40
40
10
100
Frequency (MHz)
1000
1
LI0603G121R-00
200
150
R
XL
50
100
1000
150
Z
100
10
Frequency (MHz)
LI0603G121R-00
Z vs. Frequency
200
Impedance (W)
Impedance (W)
1000
Frequency (MHz)
Frequency (MHz)
LI0402B301R-00
Impedance (W)
LI0402D121R-00
Z vs. Frequency
100
50
10
100
Frequency (MHz)
44
1000
1
10
100
Frequency (MHz)
1000
LI0603G221R-00
400
400
DIFFERENTIAL MODE
300
Impedance (W)
300
Impedance (W)
LI0603G221R-00
Z vs. Frequency
Z
200
R
XL
200
100
100
10
1000
100
LI0603D301R-00
Z vs. Frequency
500
400
400
Impedance (W)
Z
Impedance (W)
1000
Frequency (MHz)
LI0603D301R-00
500
100
10
1
Frequency (MHz)
R
300
200
XL
100
300
200
100
10
80
100
LI0805H400R-00
Z vs. Frequency
80
Impedance (W)
60
Z
40
R
XL
10
1000
100
1
10
Frequency (MHz)
100
1000
Frequency (MHz)
LI0805H600R-00
Z vs. Frequency
LI0805H600R-00
120
Impedance (W)
120
Impedance (W)
1000
Frequency (MHz)
60
Impedance (W)
10
1
1000
100
Frequency (MHz)
LI0805H400R-00
80
Z
R
40
XL
80
40
10
100
Frequency (MHz)
1000
1
10
100
1000
Frequency (MHz)
45
LI0805H800R-00
120
LI0805H800R-00
Z vs. Frequency
120
R
80
Impedance (W)
Impedance (W)
DIFFERENTIAL MODE
Z
40
XL
80
40
1
1
1000
100
Impedance (W)
100
R
50
XL
1
100
50
100
1000
1
100
10
Frequency (MHz)
Frequency (MHz)
LI0805H151R-00
LI0805H151R-00
Z vs. Frequency
200
250
150
R
100
XL
50
1000
200
Z
Impedance (W)
Impedance (W)
150
Z
250
Impedance (W)
LI0805H121R-00
Z vs. Frequency
200
150
Frequency (MHz)
LI0805H121R-00
200
100
10
Frequency (MHz)
150
100
50
10
100
1
1000
Frequency (MHz)
1000
400
400
300
300
Z
200
Impedance (W)
Impedance (W)
100
Frequency (MHz)
LI0805G301R-00
Z vs. Frequency
LI0805G301R-00
R
XL
100
200
100
10
100
Frequency (MHz)
46
10
1000
1
10
100
Frequency (MHz)
1000
LI1206H900R-00
200
200
DIFFERENTIAL MODE
150
150
Impedance (W)
Impedance (W)
LI1206H900R-00
Z vs. Frequency
Z
100
R
100
50
50
XL
1
Frequency (MHz)
LI1206H121R-00
160
Impedance (W)
Impedance (W)
R
XL
80
40
10
100
1
1000
10
1000
LI1206H151R-00
Z vs. Frequency
250
250
200
200
Impedance (W)
Impedance (W)
LI1206H151R-00
Z
150
R
100
XL
50
100
Frequency (MHz)
Frequency (MHz)
150
100
50
10
100
1
1000
10
LI1206G301R-00
400
200
R
300
Impedance (W)
Z
1000
LI1206G301R-00
Z vs. Frequency
400
300
100
Frequency (MHz)
Frequency (MHz)
Impedance (W)
1000
120
80
40
100
Frequency (MHz)
LI1206H121R-00
Z vs. Frequency
160
Z
120
10
1
1000
100
XL
100
200
100
10
100
Frequency (MHz)
1000
1
10
100
1000
Frequency (MHz)
47
LI1806E800R-00
150
Z
100
Impedance (W)
Impedance (W)
DIFFERENTIAL MODE
150
LI1806E800R-00
Z vs. Frequency
R
50
100
50
XL
10
100
1
1000
150
Impedance (W)
R
100
XL
50
1
10
100
50
100
1
10
Frequency (MHz)
250
200
200
Impedance (W)
Impedance (W)
250
Z
150
R
100
XL
50
100
1000
Frequency (MHz)
LI1806C151R-00
LI1806C151R-00
Z vs. Frequency
150
100
50
10
100
1
1000
10
LI1812D121R-00
250
100
1000
Frequency (MHz)
Frequency (MHz)
LI1812D121R-00
Z vs. Frequency
250
200
Impedance (W)
200
Impedance (W)
1000
150
Z
Z
150
R
100
XL
50
150
100
50
10
100
Frequency (MHz)
48
100
LI1806E101R-00
Z vs. Frequency
200
200
Impedance (W)
10
Frequency (MHz)
Frequency (MHz)
LI1806E101R-00
1000
1
10
100
Frequency (MHz)
1000
66
E
A
C
D
W
B
T
330.0 / 178.0 + 2.0
(13.00 / 7.00 + 0.078)
95.0 + 1.0
(3.74 + 0.039)
13.0 + 0.5
(0.51 + 0.020)
21.0 + 0.8
(0.82 + 0.031)
2.0 + 0.5
(0.08 + 0.020)
8.0 + 1.0
(0.32 + 0.039)
1.0
(0.039)
A
B
C
D
E
W
T
Reel Specifications
Blank
90 (3.543) Min
Minimum of 160mm (6.30)
of empty pockets with cover
G
Chips
F
T
F1
A0
A
F0
B
C
Drawing Direction
230 (9.05) Min
390-560 (15.35-22.05)
Blank
8 O MAX
D
D0
B
5 O MAX
13"
5.08
4.78 + 0.10
1.73 + 0.10
5.50 + 0.05
1.75 + 0.10
8.00 + 0.10
1.50 + 0.25
2.00 + 0.05
1.50 + 0.10
12.00 + 0.30 / - 0.10
4.00 + 0.10
0.29 + 0.013
3.99
3.51 + 0.10
(0.157) (0.138 + 0.004) (0.200) (0.188 + 0.004) (0.068 + 0.004) (0.217 + 0.002) (0.069 + 0.004) (0.315 + 0.004) (0.059 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.472 + 0.012 / - 0.004) (0.157 + 0.004) (0.011 + 0.0005)
LI1812
H
7"
5.23
4.88 + 0.10
1.98 + 0.10
5.50 + 0.05
1.75 + 0.10
4.00 + 0.10
1.50 + 0.25
2.00 + 0.05
1.50 + 0.10
4.00 + 0.10
0.29 + 0.013
2.46
1.98 + 0.10
(0.097) (0.078 + 0.004) (0.206) (0.192 + 0.004) (0.078 + 0.004) (0.217 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.059 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.472 + 0.012 / - 0.004) (0.157 + 0.004) (0.011 + 0.0005)
LI1806
E
7"
3.87
3.61 + 0.10
1.52 + 0.10
3.50 + 0.05
1.75 + 0.10
4.00 + 0.10
1.00 + 0.25
2.00 + 0.05
1.50 + 0.10
8.00 + 0.30 / - 0.10
4.00 + 0.10
0.25 + 0.013
3.33
2.90 + 0.10
(0.131) (0.114 + 0.004) (0.153) (0.142 + 0.004) (0.060 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005)
LI1210
Reel
Size
7"
T
3.76
3.56 + 0.10
1.91 + 0.10
3.50 + 0.05
1.75 + 0.10
4.00 + 0.10
1.00 + 0.25
2.00 + 0.05
1.50 + 0.10
4.00 + 0.10
0.25 + 0.013
2.21
1.88 + 0.10
(0.087) (0.074 + 0.004) (0.148) (0.140 + 0.004) (0.075 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005)
H
LI1206
G
7"
F1
2.49
2.31 + 0.10
1.30 + 0.10
3.50 + 0.05
1.75 + 0.10
4.00 + 0.10
1.00 + 0.25
2.00 + 0.05
1.50 + 0.10
4.00 + 0.10
0.25 + 0.013
1.85
1.55 + 0.10
(0.073) (0.061 + 0.004) (0.098) (0.091 + 0.004) (0.051 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005)
F0
LI0805
F
7"
E
3.76
3.56 + 0.10
1.91 + 0.10
3.50 + 0.05
1.75 + 0.10
4.00 + 0.10
1.00 + 0.25
2.00 + 0.05
1.50 + 0.10
4.00 + 0.10
0.25 + 0.013
2.21
1.88 + 0.10
D0
LI0603
D
7"
C
1.80
1.15 + 0.10
0.85 + 0.10
3.50 + 0.05
1.75 + 0.10
4.00 + 0.10
1.00 + 0.25
2.00 + 0.05
1.50 + 0.10
4.00 + 0.10
0.25 + 0.013
1.20
1.60 + 0.10
(0.047) (0.063 + 0.004) (0.071) (0.045 + 0.004) (0.033 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005)
B0
LI0402
B
13"
A0
2.21
1.88 + 0.10
3.76
3.56 + 0.10
1.40 + 0.10
3.50 + 0.05
1.75 + 0.10
4.00 + 0.10
1.00 + 0.25
2.00 + 0.05
1.50 + 0.10
4.00 + 0.10
0.25 + 0.013
(0.087) (0.074 + 0.004) (0.148) (0.140 + 0.004) (0.055 + 0.004) (0.138 + 0.002) (0.069 + 0.004) (0.157 + 0.004) (0.039 + 0.010) (0.079 + 0.002) (0.059 + 0.004) (0.315 + 0.012 / - 0.004) (0.157 + 0.004) (0.010 + 0.0005)
A
DA1206
P/N
DA & LI Tape Specifications
DIFFERENTIAL MODE
Tape & Reel Specifications
