EMI-Split Cores for Round Cables Table
SPLIT FERRITE CORES FOR ROUND CABLES
Ambient Temperature Range: -55 ° C to +125 ° C
Part No.
Package
Size
25A0392-0A_
0392
28A0392-0A_
0392
25A0393-0A_
0393
28A0393-0A_
0393
25A0640-0A_
0640
28A0640-0A_
0640
25A2024-0A_
2024
28A2024-0A_
2024
25A2025-0A_
2025
28A2025-0A_
2025
25A2026-0A_
2026
28A2026-0A_
2026
25A2029-0A_
2029
28A2029-0A_
2029
25B0562-3A2
0562
28B0562-3A2
0562
Impedence (Z)
Typical Ohms @
100MHz
300MHz
Cable
Diameter
(mm)
Steward Solid
Core
Equivalent
Height
(mm)
Width
(mm)
Length
(mm)
180
2.67 - 4.57
25B0375-300
12.80
5.30
29.30
2.67 - 4.57
28B0375-300
12.80
5.30
29.30
2.67 - 4.57
25B0375-300
12.24
5.59
25.02
2.67 - 4.57
28B0375-300
12.24
5.59
25.02
8.38 - 8.89
25B0631-100
20.83
9.02
40.38
8.38 - 8.89
28B0631-100
20.83
9.02
40.38
9.53 - 12.70
25B1020-100
29.00
13.00
32.50
9.53 - 12.70
28B1020-100
29.00
13.00
32.50
5.08 - 6.35
25B0562-200
17.90
7.00
32.50
5.08 - 6.35
28B0562-200
17.90
7.00
32.50
5.08 - 6.35
25B0562-200
20.96
6.76
41.68
5.08 - 6.35
28B0562-200
20.96
6.76
41.68
7.62 - 10.16
25B0735-000
21.50
10.00
32.50
7.62 - 10.16
28B0735-000
21.50
10.00
32.50
4.32 - 5.08
25B0562-300
17.32
7.62
56.54
4.32 - 5.08
28B0562-300
17.32
7.62
56.54
130
180
130
238
200
285
240
331
279
331
279
300
209
330
275
Copyright© 1999 Steward | Last Updated: 09/25/00
E-mail: americas@steward.com
http://www.stewtest.com/emi/cables/splitforroundtable.html [2/26/2001 10:15:36 AM]
ROUND CABLES
Split Ferrite Cores For
Round Cables
For retrofit and post-assembly operations, Steward offers a selection of “split”
components. Similar in performance to Steward’s one piece core designs, these
split ferrite cores provide excellent common and differential mode EMI suppression on round cable assemblies. Lightweight, inexpensive plastic snap-on cases
provide secure closure of the split cores onto the cable.
Features:
·Internal core diameters from 5.0mm (0.197”) to 13.0mm (0.51”) radius ·Precision formed smooth surfaces prevent damage to wire
insulation ·Available in Steward broad band (28) or high frequency (25) materials ·Custom designs available
·Plastic cases are UL 94V-0 flame retardant rated ·Saves valuable PC board space ·The in-circuit impedance may be substantially
increased by passing 2 turns of the wire conductor through the ferrite core assembly ·Easy installation
Applications:
·Internal and external power cables ·Internal cables between PC boards and data connectors ·Products with limited PC board
space available for surface mount EMI components ·Monitor cables ·Power supply cables ·Printer cables
Test Specifications:
·HP4396A Network/Spectrum Analyzer ·HP43961A Impedance Test Kit ·HP16192A Test Fixture ·HP16200A DC Bias Adapter
·Philips PM2811 DC Power Supply ·Ambient Temperature 23.5oC ·Bandwidth 3 kHz ·Sweep Time 423 ms
PART NUMBERING SYSTEM
25
A
MATERIAL
TYPE
0392
PRODUCT
CODE
PART
NUMBER
PART
SIZE CODE
2 (Black)
0 (White)
A
DIMENSION
CODE
ASSEMBLY
CASE COLOR
TYPE CODE CODE
Broad band material is 28
High frequency material is 25
Fig
A
mm
(inches)
B
mm
(inches)
C
mm
(inches)
D
mm
(inches)
Cable Diameter
Reference
mm
(inches)
Steward
Solid Core
Equivalent #
_ _A0392-0A _
1
12.80
(0.504)
5.30
(0.209)
29.30
(1.154)
12.40
(0.488)
2.67 - 4.57
(0.105 - 0.180)
_ _A0393-0A _
2
12.24
(0.482)
5.59
(0.220)
25.02
(0.985)
10.06
(0.396)
_ _A0640-0A _
1
20.83
(0.82)
9.02
(0.355)
40.38
(1.59)
_ _A2024-0A _
3
29.00
(1.140)
13.00
(0.510)
_ _A2025-0A _
3
17.90
(0.700)
_ _A2026-0A _
1
_ _A2029-0A _
_ _B0562-3A2
( solid core )
25 Material
@ 300 MHz
28 Material
@ 100 MHz
_ _B0375-300
180
130
2.67 - 4.57
(0.105 - 0.180)
_ _B0375-300
180
130
19.18
(0.755)
8.38 - 8.89
(0.330 - 0.350)
_ _B0631-100
238
200
32.50
(1.280)
29.60
(1.170)
9.53 - 12.70
(0.375 - 0.500)
_ _B1020-100
285
240
7.00
(0.280)
32.50
(1.280)
18.40
(0.720)
5.08 - 6.35
(0.200 - 0.250)
_ _B0562-200
331
279
20.96
(0.825)
6.76
(0.266)
41.680
(1.641)
20.32
(0.800)
5.08 - 6.35
(0.200 - 0.250)
_ _B0562-200
331
279
3
21.50
(0.850)
10.00
(0.390)
32.50
(1.280)
22.30
(0.880)
7.62 - 10.16
(0.300 - 0.400)
_ _B0735-000
300
209
4
17.32
(0.682)
7.62
(0.300)
56.54
(2.226)
5.00
(0.200)
4.32 - 5.08
(0.170 - 0.200)
_ _B0562-300
330
275
- 0A0 = White Plastic Snap On Case
- 0A2 = Black Plastic Snap On Case
All impedance values are NET; they are based on the ferrite cores only.
Figure 2
Figure 1
Figure 4
Figure 3
C
C
C
D
D
C
B
A
A
D
A
B
A
B
86
Typical Impedance (Ohms)
D
B
Solid Core with
Snap-on Plastic Case
STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com
SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694
SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686
很抱歉,暂时无法提供与“25A2024-0A0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+33.38280
- 252+13.32720
- 504+12.88440
- 1008+12.65760
