54F-713-105
54F-713-105
    APITECHNOLOGIES
    Axial
    CAPFEEDTHRU1000PF300VAXIAL
54F-713-105 数据手册
NOTES: 1. HARDWARE IS INCLUDED 2. MAXIMUM MOUNTING TORQUE: 4 IN-LBS 3. THIS IS A LEAD FREE PRODUCT 4. MAXIMUM REFLOW IS 245°C FOR 5 SECONDS BUSHING FINISH SILVER LEAD FINISH TIN / SILVER CAPACITANCE 1000pF TEMP. RANGE -55°C TO +105°C CURRENT 10 AMPS 125°C 300 VDC WORKING VOLTAGE .187 [4.75] HEX. .094 [2.39] MOUNTING SURFACE .216 [5.49] REF. #8-32UNC-2A THREAD DC RESISTANCE .060 [1.53] POTTING HEIGHT MAX. BOTH ENDS -0 +100% .01 OHMS MAX. MIN. I.L. PER MIL-STD-220 AT 25°C NO LOAD FREQ. MHz I.L. (db) .267±.031 [6.79±.79] 30 11 100 20 300 28 1 GHz 10 GHz 28 28 SCHEMATIC .266 [6.76] MARKING: PART: SF105 BAG: SCI 54F-713-105 DATE CODE LOT # QTY/BAG (200 MAX.) .631±.031 [16.03±.79] RoHS Ø.051 [Ø1.30] (20AWG) 00 01 CHANGE NOTICE REV NO CN 29589-CPD CN 32001-CPD CN 57452-ENG 02 COMPLIANT UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES [MILLIMETERS] DO NOT SCALE THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED DECIMAL .X ± .030 DECIMAL .XX ± .010 DECIMAL .XXX ± .005 ANGLES ± 0° 30' CODE IDENT. NUMBER 0LSP2 FAIRVIEW PENNSYLVANIA SPECTRUM CONTROL INC. Description DWN. P. Wells DATE 1-20-11 ENGR. S. Peters SHEET 1 OF 1 FILTER, SING, BUSHING, #8-32 54F-713-105
54F-713-105 价格&库存
很抱歉,暂时无法提供与“54F-713-105”相匹配的价格&库存,您可以联系我们找货
