PSM4-103Z-15T0
PSM4-103Z-15T0
    APITECHNOLOGIES
    PSM3
    EMI FILTER
PSM4-103Z-15T0 数据手册
Surface Mount EMI Filters our family of surface mount filters is designed to provide a range of high performance EMI filtering options with a minimal PCB footprint Three Terminal Chips offer superior ability to withstand transient voltages and surges, and deliver excellent filtering performance in high current applications while providing exceptional solderability and resistance to solder heat… SM2-SM7 SA Series Arrays incorporate four lines in one compact footprint. These arrays are nonpolar and designed to minimize residual inductance, thereby ensuring large insertion loss in a wide band and better cross talk control… SM8-SM9 MSM Mini-Surface Mount offers a multilayer electrode structure, high temperature construction and 10 Amps current ratings. The filter chips provide extreme elimination of residual inductance and the self-resonant frequency extends the microwave band… SM11 SSM Square Surface Mount square mechanical geometry enhances SMT soldering in applications up to 10 Amps. These filters come in a Pi circuit configuration and are designed to address EMI/RFI on crowded printed circuit boards… SM12-SM13 PSM Power Surface Mount are the first high temperature surface mount filter designed to effectively filter EMI/RFI at currents up to 20 Amps. These filters come in either a Feed-through or Pi circuit configuration and offer superior high frequency noise suppression… SM14-SM15 Advantages of a Surface Mount Filter With many years of experience in the design and manufacture of filters, API Technologies has a unique perspective on EMI and how to control it. We provide an integrated approach to EMC problems with services such as customer consulting, diagnostic testing, design and manufacturing. By offering a variety of custom assemblies, we are able to unite your specific requirements with our high performance filters. API’s Spectrum Control line of surface mount EMI filters are ideal for a wide range of PCB applications, including: automotive electronics, digital A/V equipment, computers, peripherals, telecommunications, switching power supplies and high current buss lines. MSP Mini Surface Mount Power Filters offers a multilayer electrode structure, high temperature construction and 10 Amps current ratings. The filter chips provide extreme elimination of residual inductance and the self-resonant frequency extends to the microwave band… SM16 MPC Series Miniature PCB Power Filters are designed to fit a wide range of environments. These filters are ideal for personal computers and peripherals, home appliances, measuring instruments and medical equipment, and are all available lead free… SM17-SM20 High Frequency PCB Filters provide EMI filtering to protect low power digital circuits. With mounting directly on the printed circuit board, filtering begins at the source of the problem… SM21 API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM1 Surface Mount EMI Filters Three Terminal Chips Features ■ Excellent performance in high current applications ■ Non-polar, surface mountable ■ Superior filtering characteristics ■ Superb ability to withstand transient voltages and surge ■ Offers exceptional solderability and resistance to solder heat ■ Available in 0603, 0805, 1205 and 1806 body size ■ Two amp current rating available ■ Available lead free/RoHS Compliant Applications ■ Cellular telephones and base stations ■ Telecommunication equipment ■ Industrial electronic interface or programmable controllers ■ Electronic automotive equipment ■ Computer and peripheral equipment Circuit Schematic Input Typical Electrical Characteristics Capacitance Range. . . . . . . . . . . . . . . . . COG (NPO) 22 pF to 470 pF . . . . . . . . . . . . . . . . . . . . . X7R 470 pF to 47,000 pF . . . . . . . . . . . . . . . . . . . . . YV5 220,000 pF . . . . . . . . . . . . . . . . . . . . . X5R 100,000 pF Capacitance Tolerance . . . . . . . . . . . . . . COG (NPO) +50/-20% . . . . . . . . . . . . . . . . . . . . . X7R +50/-20% +80/-20% . . . . . . . . . . . . . . . . . . . . . Y5V +/- 20% . . . . . . . . . . . . . . . . . . . . .X XX5R Temperature Coefficient. . . . . . . . . . . . . . COG (NPO) 0 ±/30 ppm/°C, ..................... -55 to +125°C . . . . . . . . . . . . . . . . . . . . . X7R +/-15%, ..................... -55 to +125°C . . . . . . . . . . . . . . . . . . . . . Y5V -25 to +85˚C -55 to +85˚C . . . . . . . . . . . . . . . . . . . . . X5R Insulation Resistance. . . . . . . up to 100,000 pF 10000 Megohms . . . . . . . . . . . . . . . . . . . . . 47,000 pF 5000 Megohms ....... DC Resistance. . . . . . . . . . . . . . 0.4 Amp or less 0.3 ohm max. . . . . . . . . . . . . . . . . . . . . . 1 Amp 0.08 ohm max. . . . . . . . . . . . . . . . . . . . . . 2 Amp 0.04 ohm max. Rated Voltage . . . . . . . . . . . . . . . . up to 100 VDC Rated Current . . . . . . . . . . . . . . . up to 2 Amps API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM2 Surface Mount EMI Filters Three Terminal Chips Selection Guide Rated Rated IR DC Body Capacitance Capacitance Temp. Voltage Current (Megohms Resistance Size (in picofarad) Tolerance Charact. (Volts DC) (Amps DC) Min.) (ohm Max.) Operating Temp. SF0603C220SBNB-* 0603 22 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF0603C470SBNB-* 0603 47 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF0603C101SBNB-* 0603 100 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF0603C221SBNB-* 0603 220 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF0603X471SBNB-* 0603 470 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF0603X102SBNB-* 0603 1,000 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF0603X222SBNB-* 0603 2,200 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF0603X223SANC-* 0603 22,000 +50/-20% X7R 25 0.5 10,000 0.15 1.0 10,000 Part Number -55/+125°C 0.08 -55/+85°C 0.3 -55/+125°C 10,000 0.3 -55/+125°C 0.4 10,000 0.3 -55/+125°C 50 0.4 10,000 0.3 -55/+125°C X7R 50 0.4 10,000 0.3 -55/+125°C X7R 50 0.4 10,000 0.3 -55/+125°C 22,000 +50/-20% +50/-20% X7R X7R 50 50 0.4 1.0 10,000 10,000 0.3 0.08 -55/+125°C 1205 22 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF1205C470SBNB-* 1205 47 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF1205C101SBNB-* 1205 100 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF1205C221SBNB-* 1205 220 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF1205X471SBNB-* 1205 470 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF1205X102SBNB-* 1205 1,000 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF1205X222SBNB-* 1205 2,200 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF1205X223SBNB-* SF1205X473SBND-* 1205 1205 22,000 47,000 +50/-20% +50/-20% X7R X7R 50 50 0.3 1.0 10,000 5,000 0.3 0.08 -55/+125°C -55/+125°C SF1806C220SDNB-* 1806 22 +50/-20% COG 100 0.3 10,000 0.3 -55/+125°C SF1806C470SDNB-* 1806 47 +50/-20% COG 100 0.3 10,000 0.3 -55/+125°C SF1806C101SDNB-* 1806 100 +50/-20% COG 100 0.3 10,000 0.3 -55/+125°C SF1806C221SDNB-* 1806 220 +50/-20% COG 100 0.3 10,000 0.3 -55/+125°C SF0603R104MAND-* 0603 100,000 +/- 20% X5R 25 SF0805C220SBNC-* 0805 22 +50/-20% COG 50 0.4 10,000 SF0805C470SBNC-* 0805 47 +50/-20% COG 50 0.4 SF0805C101SBNC-* 0805 100 +50/-20% COG 50 SF0805C221SBNC-* 0805 220 +50/-20% COG SF0805X471SBNC-* 0805 470 +50/-20% SF0805X102SBNC-* 0805 1,000 +50/-20% SF0805X222SBNC-* SF0805X223SBND-* 0805 0805 2,200 SF1205C220SBNB-* -55/+125°C SF1806C471SDNB-* 1806 470 +50/-20% COG 100 0.3 10,000 0.3 -55/+125°C SF1806X102SDNB-* 1806 1,000 +50/-20% X7R 100 0.3 10,000 0.3 -55/+125°C SF1806X222SDNB-* 1806 2,200 +50/-20% X7R 100 0.3 10,000 0.3 -55/+125°C SF1806X103SDNB-* 1806 10,000 +50/-20% X7R 100 0.3 10,000 0.3 -55/+125°C SF1806X223SDNB-* 1806 22,000 +50/-20% X7R 100 0.3 10,000 0.3 -55/+125°C 2 AMP FILTER SF1806Y224ZBNE-* 1806 220,000 Bold Letter = High Current Applications † = Temperature Characteristic is +30/-80% +80/-20% Y5V † 50 2.0 1,000 0.04 -25/+85°C -* = Denotes Packaging Style. Replace with T for Tape and Reel or B for Bulk API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM3 Surface Mount EMI Filters Three Terminal Chips Insertion Loss (Per MIL-STD-220) SF0603 Series 1 Amp 1 Amp 80 70 70 70 70 60 50 40 30 20 10 60 50 220 22000 22000 40 30 220 470 470 1000 1000 2200 2200 20 47 10 100 0 0 0.1 0.1 47 22 10 100 100 1000 1000 10 1000010000 Frequency Frequency (MHz)(MHz) 1 1 22 100 60 50 40 30 20 10 Insertion loss (dB) 80 Insertion loss (dB) 80 Insertion loss (dB) Insertion loss (dB) 0.3 0.5 andAmps 0.5 Amps 0.3 and 80 60 50 40 30 20 10 0 0 0.01 0.01 0.1 SF0805 Series 80 0.4 Amp 70 Insertion Loss (dB) Insertion Loss (dB) 1 Amp 80 70 60 50 100 40 220 470 30 1,000 2,200 20 1 10 100 Frequency (MHz) 60 50 22,000 40 30 20 10 47 22 10 0 0.1 1 1 10 10 100 1001000 1000 1000010000 Frequency Frequency (MHz)(MHz) 0 1000 1 10 100 Frequency (MHz) 1000 SF1205 Series 80 0.3 Amp 80 70 60 50 100 40 22,000 30 470 1,000 20 2,200 10 0 220 47 Insertion Loss (dB) Insertion Loss (dB) 70 1 Amp 10 100 Frequency (MHz) 50 47,000 40 30 20 10 22 1 60 0 1000 0.1 1 10 Frequency (MHz) 100 1000 10 Frequency (MHz) 100 1000 SF1806 Series 80 0.3 Amp 80 70 Insertion Loss (dB) Insertion Loss (dB) 70 60 50 100 40 30 220 10,000 22,000 20 470 1,000 2,200 10 0 2 Amp 1 10 100 Frequency (MHz) 47 22 1000 60 50 220,000 40 30 20 10 0 0.1 1 API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM4 LE LE LM T Surface Mount EMI Filters Three Terminal Chips L W Mechanical Dimensions Body Length (L) Body Width (W) Body Thickness (T) End Terminal Length (LE) 0.063 +/-0.006 (1.60 +/-0.15) 0.031 +/-0.006 (0.80+/-0.15) 0.023 +/-0.006 (0.6+/-0.15) 0.008 +/-0.006 (0.2 +/-0.15) 0.020 +/-0.006 (0.5 +/-0.15) 0.079 +/-0.008 (2.0 +/-0.2) 0.049 +/-0.008 (1.25 +/-0.2) 0.032 +/-0.008 (0.8 +/-0.2) 0.012 +/-0.008 (0.3 +/-0.2) 0.024 +/-0.008 (0.6 +/-0.2) 0.126 +/-0.008 (3.2 +/-0.2) 0.049 +/-0.008 (1.25 +/-0.2) 0.028 +/-0.008 (0.7 +/-0.2) 0.016 +/-0.012 (0.4 +/-0.3) 0.043 +/-0.012 (1.1 +/-0.3) 0.177 +/-0.012 (4.5 +/-0.3) 0.063 +/-0.012 (1.6 +/-0.3) 0.039 +/-0.012 (1.0 +/-0.3) 0.020 +/-0.012 (0.5 +/-0.3) 0.055 +/-0.012 (1.4 +/-0.3) Body Style/Size SF0603 SF0805 SF1205 SF1806 Dimensions in inches (mm) Middle Terminal Length (LM) Ordering Information Example: SF0805C221SBNCT This part number represents a three terminal chip with a body size of 0805 with a COG (NPO) dielectric. The capacitance is 220 pF with a capacitance tolerance of +50%/-20%. Voltage rating is 50 Volts DC. It has nickel barrier, solder plated terminations and a current rating of 0.4 Amp, (400 milliamps). The parts are taped and reeled. SF 0805 SF 0603 0805 1205 1806 Style Size C Ceramic C - COG X - X7R Y - Y5V R - X5R 221 Capacitance Code S Capacitance Tolerance First two S - +50%/-20% numbers are Z - +80%/-20% significant, M - +/- 20% the third number refers to number of zeroes B Rated Voltage (Vdc) A - 25 B - 50 D - 100 N Termination N - Ni Barrier, Solder Plated C Current Rating B C D E F G H I - 0.3 A 0.4 A 1A 2A 3A 4A 5A 6A T Packaging T - Tape & Reel B - Bulk API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM5 Surface Mount EMI Filters Three Terminal Chips Soldering Specifications Soldering Instructions Reflow Soldering Flow Soldering Recommended Board Pattern Recommended Board Pattern Top view Top view Bottom view Bottom view E D Connects to top C A B Body Style/Size SF0603 SF0805 SF1205 SF1806 Copper Copper B Through hole .016 to .024 (0.4 to 0.6) Resist C Dimension B 0.047 (1.2) 0.059 (1.5) 0.091 (2.3) 0.138 (3.5) Board Pattern Dimensions in inches (mm) A 0.020 (0.5) 0.024 (0.6) 0.051 (1.3) 0.079 (2.0) C 0.031 (0.8) 0.039 (1.0) 0.047 (1.2) 0.051 (1.3) Recommended Solder Temperature Profile Preheat Solder Cool down Body Style/Size SF0603 SF0805 SF1205 SF1806 Dimension C D 0.047 0.031 (1.2) (0.8) 0.059 0.039 (1.5) (1.0) 0.091 0.047 (2.3) (1.2) 0.138 0.051 (3.5) (1.3) Board Pattern Dimensions in inches (mm) A 0.020 (0.5) 0.024 (0.6) 0.051 (1.3) 0.059 (1.5) Flow Soldering B 0.031 (0.8) 0.031 (0.8) 0.059 (1.5) 0.079 (1.5) E 0.071 (1.8) 0.087 (2.2) 0.118 (3.0) 0.118 (3.0) F 0.016 (0.4) 0.024 (0.6) 0.024 (0.6) 0.024 (0.6) Recommended Solder Temperature Profile Preheat 250 Solder Cool down 250 220 to 240°C 200 Degrees (°C ) Degrees (°C ) Connects to top A Through hole .016 to .024 (0.4 to 0.6) Reflow Soldering 150 100 F 130 to 150°C 50 220 to 250°C 200 150 100 130 to 150°C 50 0 0 60-120 10 max. Seconds 120 min. General Soldering Notes 1. High soldering temperatures and long soldering times can cause leaching of the termination and adversely affect adhesion. These conditions can also decrease capacitance value. Use the above recommended solder temperature cycle. 2. Due to the mechanical characteristic of ceramic composition, aggressive thermal shock will degrade performance. Preheat the assembly before soldering using the above solder temperature profile as a guide. 60-120 3-4 Seconds 120 min. 3. Use mild flux (less than 0.2% by weight of Chlorine), preferable rosin based. If water soluble, wash thoroughly to assure all residue is removed from the underside of components. 4. Ultrasonic Cleaning When using an ultrasonic cleaning method, the following range is recommended: Frequency: Not to exceed 28kHz Output Power: Not to exceed 20W/liter Cleaning Time: 5 minutes max API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM6 Paper Tape Dimensions SF0805 and SF1205 Bodies Package Information Surface Mount EMI Filters Three Terminal Chips Soldering Specifications D1 C2 C1 C T1 E Body Style/Size 4,000 units/reel 4,000 units/reel 4,000 units/reel 2,000 units/reel Chip Cavity Length A B Tape and Reel SF0603 SF0805 SF1205 SF1806 Body Style/ Size F W Package Quantities Width B Width W Tape Center to End F T A Indexing to End E Center to Center C Holes Indexing to Center C1 SF0603 0.039 +/-0.00? (1.0 +/-0.?) 0.075 +/-0.00? (1.9+/-0.?) 0.315 0.138 0.069 +/-0.012 +/-0.002 +/-0.004 (8.0 +/-0.3) (3.5 +/-0.05) (1.75 +/-0.1) 0.157 0.079 +/-0.004 +/-0.004 (4.0 +/-0.1) (2.0 +/-0.1) SF0805 0.064 0.091 +/-0.008 +/-0.008 (1.62 +/-0.2) (2.3 +/-0.2) 0.315 0.138 0.069 +/-0.012 +/-0.002 +/-0.004 (8.0 +/-0.3) (3.5 +/-0.05) (1.75 +/-0.1) SF1205 0.067 0.138 +/-0.008 +/-0.008 (1.70 +/-0.2) (3.5 +/-0.2) 0.315 0.138 0.069 +/-0.012 +/-0.002 +/-0.004 (8.0 +/-0.3) (3.5 +/-0.05) (1.75 +/-0.1) Dimensions in inches (mm) Indexing to Indexing C2 Hole Diameter Indexing D1 Thickness Carrier Overall Tape T (Max.) T1 (Max.) 0.157 +/-0.008 (4.0 +/-0.1) 0.059 +0.004/-0 (1.5 +0.1/-0) 0.043 0.039 (1.1) (1.0) 0.157 0.079 +/-0.004 +/-0.004 (4.0 +/-0.1) (2.0 +/-0.1) 0.157 +/-0.008 (4.0 +/-0.1) 0.059 +0.004/-0 (1.5 +0.1/-0) 0.043 0.039 (1.1) (1.0) 0.157 0.079 +/-0.004 +/-0.004 (4.0 +/-0.1) (2.0 +/-0.1) 0.157 +/-0.008 (4.0 +/-0.1) 0.059 +0.004/-0 (1.5 +0.1/-0) 0.043 0.039 (1.1) (1.0) Tape and Reel Specification Plastic Carrier Tape Dimensions SF1806 Body Package Information D1 Plastic Reel Dimensions Dimensions in inches (mm) Diameter (Max.) Width (Max.) SF1205 7.00 (180) 0.46 (11.5) 7.00 (180) 0.46 (11.5) 7.00 (180) 0.61 (11.5) SF0603 SF1806 Body Style/ Size SF1806 7.00 (180) Chip Cavity Length A C2 T1 E Body Style/Size SF0805 C1 C Width B Width W F W B 0.46 (11.5) Tape Center to End F Indexing to End E 0.071 0.185 0.472 0.217 0.069 +/-0.008 +/-0.008 +/-0.008 +/-0.002 +/-0.004 (1.80 +/-0.2) (4.70 +/-0.2) (12.0 +/-0.2) (5.5 +/-0.05) (1.75 +/-0.1) A Holes Center Indexing Indexing to to Center to Center Indexing C C1 C2 0.157 0.079 0.157 +/-0.004 +/-0.004 +/-0.008 (4.0 +/-0.1) (2.0 +/-0.1) (4.0 +/-0.1) øD Center hole T Dimensions in inches (mm) Hole Diameter Center D (Min.) 0.059 (1.5) Indexing D1 0.059 +0.004/-0 (1.5 +0.1/-0) Thickness Overall Tape T (Max.) T1 (Max.) 0.098 0.024 (2.5) (0.6) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM7 Surface Mount Filter Arrays SA Series Insertion Loss FeaturesDimensions with a high self resonant frequency, ensuring large .125 (3.2±0.2) insertion loss in a wide band. n The common ground electrode built into the chip .062 (1.6±0.2) ensures complete grounding of all lines at the ground on both ends. The filter is designed to control cross talk. .027 (0.7±0.2) n An optimum constant can be selected from the(0.8±0.2) .031 capacity range of 22-22,000 pF to best suit the .015 (0.4±0.2) frequency. .031 (0.8±0.1) n Solder plated nickel barrier terminations offer good solderability and resistance to soldering heat. n Available lead free/RoHs compliant Circuit Schematic GND 70 Applications Noise reduction for DC lines on computers n Computer peripheral equipment Top side .011 (0.3) Audio Visual Equipment n Cellular telephones & base stations n Telecommunications Equipment PO.031 (0.8) 22000 470 30 1000 100 1 10 100 1000 .015 (0.4) Dimensions Dimensions GND 47 22 GND .125 (3.2±0.2) .062 (1.6±0.2) .102 .027 .023 (0.6)(0.7±0.2) .015 (0.4±0.2) .031 (0.8±0.1) Bottom side Dimensions in inches (mm) Ground pattern Rated Voltage (@ 50/60Hz) Rated Current Ground pattern Temperature IR Characteristic DC Resistance Operating Capacitance Temp (pF) C 22 SA1206C470 C 47 SA1206C221 50 VDC Coppe .031 (0.8±0.2) SA1206C220 Through hole SA1206C101 10000 .015 (0.4) Frequency (MHz) . . . 25 VDC to 50 VDC . . . 0.3 Amps . . . 10,000 MΩ Min. . . . 0.3 Ω Max. . . . -55˚C to +125˚C .102 (2.6) . . . 22 pF to 22,000 pF Copper foil pattern . . . ±20% Specifications .011 (0.3) Top side 2200 20 Bottom side Part Number 220 40 0 0.1 Typical Electrical Characteristics .086 (2.2) 50 10 chip GND Rated Voltage . . . . . . . . Rated Current . . . . . . . . IR . . . . . . . . . . . . . . . . . DC Resistance . . . . . . . . Temperature Range . . . . Capacitance Range . . . . . Capacitance Tolerance . . 60 .086 (2.2) n .039 (1.0) n GND Insertion Loss Insertion Loss (dB) n Equivalent Circuit The filter’s structure minimizes residual inductance C 0.3A DC C Top side 10,000 MΩ 0.3Ω max. .011 (0.3) -55/+125˚C 100 PO.031 (0.8) 220 SA1206R471 U SA1206R102 R 470 SA1206R222 R 2,200 SA1206R223 25 VDC R 22,000 .015 (0.4) .086 (2.2) GND ch 1,000 .039 (1.0) min. Thro API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM8 Surface Mount Filter Arrays SA Series Ordering Information SA 1206 C 220 Style Size Temperature Characteristics Capacitance SA Series 1206 C +/- 30 ppm/˚C 22 pF R +/- 15% M B Capacitance tolerance M = ± 20% Rated Voltage (Vdc) A = 25 B = 50 47 pF U -750 +/- 120 ppm/˚C N B Termination Packaging N = Ni Barrier Solder Plated T - Tape and reel 4,000 pc/reel B - Bulk pack 1,000 pcs/bag 100 pF 220 pF 470 pF 1,000 pF SA Tape and Reel Packaging 2,200 pF 22,000 pF .078 (2.00±0.01) .157 .157 (4.0±0.1) (4.0±0.1) ø .058 (1.5±0.1-0) Dimensions .125 (3.2±0.2) .062 (1.6±0.2) GND .027 (0.7±0.2) .314 (8.0±0.3) .140 (3.60±0.2) Equivalent Circuit .068 (1.75±0.1) .042 (1.1) Max. .137 (3.5±0.05) GND Chip .031 (0.8±0.2) .015 (0.4±0.2) .031 (0.8±0.1) .054 (1.4) Max. .078 (2.00±0.2) Dimensions in inches (mm) Recommended Board Pattern Top side PO.031 (0.8) .011 (0.3) .011 (0.3) Top side PO.031 (0.8) chip chip GND .039 (1.0) .015 (0.4) .086 (2.2) .039 (1.0) .015 (0.4) .086 (2.2) GND GND GND .102 (2.6) .102 (2.6) .023 (0.6) .023 (0.6) Copper foil pattern Copper foil pattern Bottom side Bottom side Ground pattern Through hole Ground pattern Through hole Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM9 Surface Mount Low Pass Filters MSM, SSM, RSM & PSM Series MSM - Miniature Surface Mount Chip Capacitors The MSM series filters feature high temperature construction and have current ratings up to 10 Amps. The filter chips will hardly allow residual inductance and the self-resonant frequency extends to the microwave band. Applications include telecommunication equipment, computer and peripheral equipment and digital AV equipment, medical equipment, DC power supply lines. n n n n n Miniature footprint help in dense circuit configuration Rated at 10 Amps Packaged in tape and reel or bulk form Operating temperature ranges of -25˚C to +85˚C and -55˚C to +125˚C Available lead free/RoHs compliant SSM - Square Surface Mount Filters The SSM series filters feature high temperature construction and have current ratings up to 10 Amps. This filter chip series is nonpolar and surface mountable with excellent performance characteristics and comes in a Pi circuit configuration. Applications include telecommunication equipment, computer and peripheral equipment, digital AV equipment, power amplifiers, power supplies and high current buss lines. n n n n n Square mechanical geometry enhances SMT soldering Rated to 10 Amps Packaged in tape and reel or bulk form Operating temperature range of –55˚C to +125˚C Available lead free/RoHs compliant RSM - Round Surface Mount Filters The RSM series filters feature high temperature construction and have current ratings up to 10 Amps. This filter chip series is nonpolar and surface mountable with excellent performance characteristics and comes in a Pi circuit configuration. Applications include telecommunication equipment, computer and peripheral equipment, digital AV equipment, power amplifiers, power supplies and high current buss lines. n n n n n Round mechanical geometry enhances SMT soldering Rated to 10 Amps Packaged in tape and reel or bulk form Operating temperature range of –55˚C to +125˚C Available lead free/RoHs compliant PSM - Power Surface Mount Filters The PSM series filters feature high temperature construction and have current ratings up to 20 Amps. This filter series is nonpolar and surface mountable with excellent performance characteristics and comes in either a Feed-through or Pi circuit configuration. Applications include telecommunication equipment, computer and peripheral equipment, digital AV equipment, power amplifiers, power supplies and high current buss lines. n n n n n Provides time and costs saving compared to through-hole filters Rated to 20 Amps Packaged in tape and reel or bulk form Operating temperature range of –55˚C to +125˚C Available lead free/RoHs compliant API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM10 60 Insertion Loss (dB) 50 Surface Mount Low Pass Filters MSM Series 271M 40 102Z 30 20 151M 10 MSM .007 (0.2±0.1) Feed-through Input 470M 0 1 Output .049 (1.25±0.2) 100 10 1000 10000 Frequency (MHz) .007 (0.2±0.1) .007 (0.2±0.1) Ground Working Voltage . . . . . . Test Voltage . . . . . . . . . Current Rating . . . . . . . Insulation Resistance . . . Terminations . . . . . . . . . Soldering Conditions . . . .049 (1.25±0.2) . . . 50 VDC . . . 150 VDC . . . 10 Amps max. . . . 1.0 MΩ . . . Ni-Barrier . . . Max. 250˚C-5 sec. .078 (2.0±0.2) MSM .049 (1.25±0.2) Dimensions in inches (mm) MSM Ordering Information MSM 4 T 470M 10 T Style Circuit Configuration 4 - Feed-Through Temperature Characteristic R - +/-15% T - +22/-33% V - +22/-82% Capacitance Current Rating 10 Amps Packaging MSM (Miniature) Specifications Part Number Temperature Characteristics Value 47 pF Capacitance Tolerance Through Current Rating Rated Rating Rating 50VDC Temperature Range Full-face ground .070 (1.8) -55/+125˚C -55/+125˚C -55/+125˚C -25/+85˚C Copper foil pattern Resist MSM Tape and Reel Unit:Packaging mm Size difference: ±0.1 .110 (2.8) Thickness of copper foil: 35µm Bottom side ø .058 (1.5±0.1-0) .078 (2.00±0.05) .157 .157 (4.0±0.1) (4.0±0.1) Full-face ground .070 (1.8) .023 (0.6) Max. .068 (1.75±0.1) .314 (8.0±0.2) .090 (2.3±0.2) .098 .047 (2.5) (1.2) T - Tape and Reel 2,000 pcs/reel hole .023 (ø 0.6) B - Bulk packBottom side 1,000pcs/reel .031 (0.8) .058 (1.5) MSM Recommended Board Pattern Surface +50/- 20% .098 .047 (2.5) (1.2) +50/-20% 10A 47pF 150pF 270pF 1000pF Through hole .023 (ø 0.6) Tolerance Surface Capacitance MSM4T470M10 T MSM4R151M10 R MSM4R271M10 R MSM4V102M10 V .137 (3.50±.05) Chip .031 (0.8) .058 (1.5) .110 (2.8) Copper foil pattern ø .058 (1.5±0.1-0) .078 (2.00±0.05) .157 .157 (4.0±0.1) (4.0±0.1) Resist .057 (1.45±0.2) ø .045 (1.15±0.05) Center hole .117 (3.0) Max. Unit: mm Size difference: ±0.1 Thickness of copper foil: 35µm Note: Exclusively for reflow soldering Dimensions in inches (mm) .023 (0.6) Max. .068 (1.75±0.1) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com .137 API TECHNOLOGIES’ SPECTRUM CONTROL GmbH (3.50±.05)• Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 (8.0±0.2) 90 ±0.2) .078 (2.0±0.2) Insertion Loss SM11 Pi Insertion Loss 100 Typical SMT Applications 90 Surface Mount Low Pass Filters SSM Insertion Loss (dB) SSM & RSM Series * See note 4000 2500 1500 1000 820 470 130 100 68 80 Pi 70 60 50 40 30 20 Input Output 10 0 0.01 Ground 100 . . . 100 VDC . . . 250 VDC . . . Max. 10 Amps . . . Min. 104 MΩ . . . Silver Ni-Tin plated . . . Max. 250°C -5 sec. . . . None . . . Bulk or tape and reel Note: Insertion loss shown for the following SSM values* only: 101Z 501P 202P *Additional IL charts available by request. RSM 0.1 1 10 Frequency (MHz) 100 1 10 Frequency (MHz) 100 * See note 4000 2500 1500 1000 820 470 135 100 68 80 70 60 50 40 30 pf pf pf pf pf pf pf pf pf 20 10 0 0.01 0.1 SSM Electrodes .026 ± .014 (0 .65 ± 0 .35) .026 ± .014 (0 .65 ± 0 .35) .083 ± .004 (2 .1 ± 0 .1) Output Ground Working Voltage . . . . . . Test Voltage . . . . . . . . . Current . . . . . . . . . . . . . Insulation Resistance . . . . . . . . . . . Terminations . . . . . . . . . Soldering Conditions . . . . . . . . . . . Marking. . . . . . . . . . . . . Packaging. . . . . . . . . . . . . . . 100 VDC . . . 250 VDC . . . Max. 10 Amps .02 (0 .5) min. .113 (2 .87) .315 (8 .0) max. Note: Insertion loss shown for the following RSM values only: 152P 402Z .02 (0 .5) min. .02R max. (0 .5) (4 plcs) RSM . . . Min. 104 MΩ . . . Silver Ni-Tin plated . . . Max. 250°C -5 sec. . . . None . . . Bulk or tape and reel 1000 3000 * Capacitance values for insertion loss curves are displayed left to right in the order shown. Pi Input 1000 3000 Shielded or Partition Applications 90 Insertion Loss (dB) Working Voltage . . . . . . Test Voltage . . . . . . . . . Current . . . . . . . . . . . . . Insulation Resistance . . . . . . . . . . . Terminations . . . . . . . . . Soldering Conditions . . . . . . . . . . . Marking. . . . . . . . . . . . . Packaging. . . . . . . . . . . . pf pf pf pf pf pf pf pf pf .315 (8 .00) Max. .083±.004 (2 .1 ± 1 .0) .020 ( .500) Min. .012/.040 (0 .3/1 .0) NI/SN OVER AG PLATED TUBE 0.232 (5 .90) ± 0.26 .113 (2 .58) ±.014 ( .35) 0.020 ( .500) Min. .012/.040 (0 .3/1 .0) Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM12 Surface Mount Low Pass Filters SSM & RSM Series SSM & RSM Ordering Information Example: SSM1-101Z-05T 1 * SSM Style SSM (Square) RSM (Round) - 101Z Circuit Configuration 1 - Pi - 05 Current Rating Capacitance = Also available through API’s authorized distributors. a Also available through API’s authorized European distributors/agents. = SSM1-152P-05-T1 a Code Value Tolerance 101Z 100 pF +80/-20% 501P 500 pF +100/-0% 152P 1500 pF +100/-0% 202P 2000 pF +100/-0% 402E 4000 pF ±25 402Z 4000 pF +80/-20% 05 - 5 Amps 10 - 10 Amps T 1 Packaging Tape and Reel T - Tape and reel packaging B - Bulk packaging 1 - 1,000 pieces 6 - 6,000 pieces Note: Tape and reel packaging - 1,000 pieces (7”) and 6,000 pieces (13”) * Add “F” before “-” for RoHS compliant version SSM/RSM Tape and Reel Packaging .098 (2 .50) .013 (0 .33) .059 (1 .50) .157 (4 .00) .079 (2 .00) .295 (7 .50) SSM Recommended Board Pattern .043 (1 .1) .043 (1 .1) .069 (1 .75) .093 (2 .36) Min. .315 (8 .00) .630 (16 .0) .157 (4 .00) .059 (1 .50) .102 (2 .6) Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM13 Feed-Through Insertion Loss 80 Pi Input 50 40 30 20 Output Ground 10 0 0.01 Ground . . . 200 VDC @ -55°C to +125°C . . . 700 VDC . . . 20 Amps (Feed-through) max. 10 Amps (Pi) max. . . . 1.0 GΩ @ 25°C 80 1 10 Frequency (MHz) 100 1000 3000 * See note 0.01 uF 4000 pf 2500 pf 1500 pf 1000 pf 820 pf 470 pf 130 pf 100 pf 68 pf 60 50 40 30 20 . . . 4.0% maximum . . . Max. .0005Ω, typ. .0002Ω 0.1 Shielded or Partition Applications 70 Insertion Loss (dB) Voltage Rating DC . . . . DWV . . . . . . . . . . . . . . Current Rating . . . . . . . . . . . . . . .................. Insulation Resistance . . . . . . . . . . . Dissipation Factor . . . . . . . . . . . . . . D.C.R. . . . . . . . . . . . . . Insertion Loss (dB) Feed-Through Output 0.01 uF 4000 pf 2500 pf 1500 pf 1000 pf 820 pf 470 pf 130 pf 100 pf 68 pf 60 PSM Series Input * See note 70 Surface Mount Low Pass Filters PSM Typical SMT Applications 10 0 0.01 0.1 1 10 Frequency (MHz) 100 1000 3000 * Capacitance values for insertion loss curves are displayed left to right in the order shown. PSM .026 (0.66) .120 (3.00) Sq. (both ends) .057 (1.46) .026 (0.66) .120 (3.00) .010 (0.25) Pi Insertion Loss 100 Typical SMT Applications 90 * See note 4000 2500 1500 1000 820 470 130 100 68 .025 (0.63) Ref. .070 (1.75) (4x both ends) Middle terminal .235 (6.00) Insertion Loss (dB) 80 70 60 50 40 30 pf pf pf pf pf pf pf pf pf 20 .325 (8.25) Max. 10 Tolerances: ± .010 (.254) 0 0.01 Dimensions in inches (mm) 100 1 10 Frequency (MHz) 100 1 10 Frequency (MHz) 100 1000 3000 Shielded or Partition Applications 90 80 Insertion Loss (dB) 0.1 70 60 50 40 30 * See note 4000 2500 1500 1000 820 470 135 100 68 pf pf pf pf pf pf pf pf pf 20 10 0 0.01 0.1 1000 3000 API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM14 Surface Mount Low Pass Filters PSM Series PSM Ordering Information Example: PSM4-402Z-20T0 PSM 4 Style Circuit Configuration 1 - Pi 4 - Feed-through PSM (Power) = Also available through API’s authorized distributors. - 402Z - Capacitance n n n 0 Tape and Reel Current Packaging Rating 10 - 10 Amps T - Tape and reel (Pi) packaging 20 - 20 Amps B - Bulk packaging (Feed-through) Value* 680M 68 pF ±20% 101M 100 pF ±20% 131P 130 pF +100/-0% 471P 470 pF +100/-0% 821M 820 pF ±20% 102M 1000 pF ±20% 152M 1500 pF ±20% 252P 2500 pF +100/-0% 402Z 4000 pF +80/20% * Other capacitance values available as special order. .01 µF +80/-20% ** Technical Notes n T Code 103Z** Tolerance 20 0 - 500 pieces 2 - 2,000 pieces Note: Tape and reel packaging - 500 pieces (7”) and 2,000 pieces (13”) Available in Feed-through circuit only. PSM Tape and Reel Packaging Soldering recommendations supplied upon request Reflow temperature limit is 250°C Unit weight is approximately 0.4 grams Tape and reel packaging available for automated assembly .150 (3 .81) .013 (0 .33) .059 (1 .50) .157 (4 .00) .079 (2 .00) .295 (7 .50) .069 (1 .75) .320 (8 .13) .630 (16 .0) .315 (8 .00) .133 (3 .38) .059 (1 .50) Dimensions in inches (mm) PSM Recommended Board Pattern .285 (7 .25) Solder paste pattern Recommended pad, must be able to support continuous signal current X = 0.350" minimum for 1 oz. copper (0.036 mm thickness) X = 0.200" minimum for 2 oz. copper (0.071 mm thickness) For low current (10 Amp or less) X = 0.130" minimum for 1 oz. copper (0.036 mm thickness for 10 Amp and 0.5 oz. copper - 0.018 mm thickness for 5 Amp or less) Dimensions in inches (mm) X 0.10 (2 .54) .070 (1 .75) .050 (1 .27) 120° .065 (1 .65) .100 (2 .54) .040 (1 .00) min. .125 (3 .20) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM15 Mini Surface Mount Power Filters MSP Series Features Designed for 10A DC power lines Offers high insertion loss in a wide frequency band by combining feed-through capacitors, multilayer ceramic capacitors and ferrite bead inductors with high self resonance frequency. Compact EMI package with plus and minus lines Circuit Schematic Applications Electronic measuring instruments Industrial equipment Automotive electronics Switching power supplies DC-DC converters Insertion Loss 100 Dimensions Insertion Loss (dB) 90 .285 (7.24) .269 (6.83) .115 (2.92) IN .008 (.20) OUT .024 (.61) .100 (2.54) .058 (1.47) .306 .292 (7.77) (7.42) 70 60 50 40 30 20 10 0 0.01 .100 (2.54) 0.1 1 10 100 1000 10000 Frequency (MHz) .065 (1.65) + .280 (7.11) 80 Dimensions in inches (mm) Specifications Model MSP-007-050 MSP-010-050 Rated Voltage Rated Current Insulation Resistance 50VDC 10A 500M Ωmin. Operating Temp. -30°C ~ +105°C -55°C ~ +125°C Capacitance 1.0µF±20% Measurement voltage: 1 Vms 0.47µF±20% Test frequency: 1kHz ± 10% API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM16 Miniature PCB Power Filters MPC Series 61-MPC Series Tested and found to be IAW VDE 0565 Part 3 Rugged construction design enables parts to perform in industrial environments. The 61-MPC series is ideally suited for products that must conform to FCC part 15 regulations. Agency approvals: UL recognized, CSA certified, TUV approved. Applications include: n n n n n n Circuit Diagrams Circuit 1 Personal computers and peripherals Measuring instruments Home appliances and vacuum cleaners Monitor and display units Switching power supplies Available lead free/RoHs compliant Circuit 2 11-MPC Series Power filters are available in PCB mount, bolt-in, fast-on tab or solder lug. The 11-MPC series is ideally suited for products that have been limited board space and require a low cost alternative. Available in both metal and plastic cases. Applications include: n n n n n Circuit 3 Personal computers and peripherals Digital equipment Measuring instruments and medical equipment TV & VCR monitors and display units Available lead free/RoHs compliant Circuit 4 MPC-010/-015 Series The compact design of the MPC-010 and -015 series power filters integrates a feed-through capacitor, multilayer ceramic capacitor and ferrite bead inductors. This series is ideally suited for dense PCB’s and where both positive and negative lines have reduced EMI in one housing. Applications include: n n n n n n Circuit 5 DC power lines on industrial equipment Measuring instruments Home appliances and vacuum cleaners Monitor and display units Switching power supplies Available lead free/RoHs compliant Circuit 6 API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM17 Miniature PCB Power Filters MPC Series Specifications Rated Voltage (@ 50/60Hz) Model Rated Current 61-MPC-010-1-11 Leakage Current (Max.) Inductance (L1) 1.6A 250VAC 61-MPC-025-1-11 3.6A 11-MPC-001-5-A 1A Figure 40˚C 1 A 6.0mH 0.1mA 2.5A 61-MPC-036-1-11 Circuit Diagram 11mH 1A 61-MPC-016-1-11 Temperature Rise (Max.) 2.4mH 1.2mH B 3 120/250VAC 30°C 0.50mA 4 F 3A 11-MPC-003-5-E B1 11-MPC-006-5-B 6A 11-MPC-006-5-C 3 0.2mA 16A 11-MPC-016-5-B MPC-010-050 50 VDC MPC-010-250 250 VDC MPC-015-050 50VDC 10A D 6 C 5 G 15A Note: Test voltage: 1500VAC one minute, line to ground. Insulation resistance: 300 MΩ min. at 500VDC. Voltage drop: 1V max. at rated current. Weight: 17.5g Figure B 4 — .031 (.8) Figure B1 4 2 Figure A 3 1 0.6 0.9 (16) (25) .551 (14) .767 (19.5) .059 (1.5) 1.239 (31.5) .767 (19.5) Figure C 0.4 (10) 0.6 (16) 0.9 (25) .590 (15) .354 (9) Figure D 0.6 (15) ø0.2 (5) Figure E ø0.03 (1) (5X) .03 (1) (5X) .30 (7.5) 1.9 (30) .30 (7.5) 1.99 0.9 (25).007 (50.8) 2.5 (64) 1.4 (36) .60 (15) ±.07 1.4 (36) 1.8 (45) .15 (4) 0.03 (0.8) 0.03 (0.7) 0.6 (16) 0.6 (15) ±.07 0.45 (11.5) 0.65 (16.6) .45 (11.5) 1.4 (35) .45 (11.5) 0.17 (4.4) 0.48 (12.1) 0.45 (11.5) Figure G 1.1 (27) 1.1 1.8 (28)(45) 0.4 (10) 6.5 (25.59) Figure F 1.4 (35.5) 1.9 (49) 0.4 (10) 1.38 (35) .79 (20) 1.1 (29) 1.7 (44) 1.06 27) ( 0.8 (20) 0.4 (10) 0.03 (0.8) 0.03 (0.8) 0.03 (0.7) 0.10 0.10 0.10 (2.5) (2.5) (2.5) 0.10 0.10 (2.5) (2.5) 0.03 (0.8) 0.6±0.1 Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM18 Miniature PCB Power Filters MPC Series 61-MPC Series Common Mode 120 1 3 Filter 2 4 Oscillator 50Ω 50Ω Level Meter 50Ω 1 3 Filter 2 4 (Test circuit 2) Oscillator 50Ω 100 Current (%) Common mode with Y cap. (Test circuit 1) Temperature Characteristics 50Ω Level Meter 50Ω 80 60 40 20 0 61-MPC 80 Insertion Loss (dB) 30 40 50 60 70 80 Ambient Temperature (°C) 90 100 Y Cap 2 X 3300pF 70 Normal Mode 61-MPC-010-1-11 60 50 40 61-MPC-025-1-11 20 0 0.1 Oscillator 50Ω 50Ω 50Ω Level Meter 50Ω 61-MPC-036-1-11 0.2 0.5 1 2 5 Frequency (MHz) 10 20 50 61-MPC 61-MPC 80 80 70 70 Insertion Loss (dB) 61-MPC-010-1-11 60 50 40 30 61-MPC-016-1-11 20 61-MPC-025-1-11 10 0 0.1 1 3 Filter 2 4 (Test circuit 3) 61-MPC-016-1-11 30 10 Insertion Loss (dB) 0 0.5 1 50 61-MPC-010-1-11 40 61-MPC-016-1-11 30 61-MPC-025-1-11 20 61-MPC-036-1-11 10 61-MPC-036-1-11 0.2 60 2 5 Frequency (MHz) 10 20 50 0 0.1 0.2 0.5 1 2 5 10 20 50 Frequency (MHz) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM19 Miniature PCB Power Filters MPC Series 11-MPC Series Common Mode Normal Mode 1 3 Filter 2 4 Oscillator 50Ω 50Ω Oscillator 50Ω 80 80 80 70 70 70 70 50 70 50 70 40 60 40 60 30 50 30 50 20 40 20 40 11-MPC-001-2-B 11-MPC-001-2-B 11-MPC-001-5-A 11-MPC-001-5-A 11-MPC-001-5-B 11-MPC-001-5-B 11-MPC-001-2-B 11-MPC-001-2-B 10 10 30 30 0 0 200.120 0.1 0.2 10 10 0 0 0.1 0.1 0.2 11-MPC-002-5-D 11-MPC-002-5-D 11-MPC-002-5-B 11-MPC-002-5-B 11-MPC-002-5-D 11-MPC-002-5-D 0.2 0.5 0.5 1 12 2 5 5 10 11-MPC-002-5-B 11-MPC-002-5-B Frequency (MHz) (MHz) Frequency 0.2 0.5 0.5 1 12 2 5 5 10 1020 20 50 50 Insertion Loss Insertion (dB) Loss (dB) 80 11-MPC-001-5-A 11-MPC-001-5-A 11-MPC-001-5-B 11-MPC-001-5-B 80 50 70 50 70 40 60 40 60 30 50 30 50 20 40 20 50 11-MPC-002-5-D 11-MPC-002-5-D 11-MPC-001-5-B 11-MPC-001-5-B 11-MPC-002-5-D 11-MPC-002-5-D 11-MPC-001-2-B 11-MPC-001-2-B 0.5 1 0.2 0.5 0.5 1 Frequency Frequency (MHz)(MHz) 80 70 70 70 70 40 60 30 50 20 40 10 10 30 30 0 0 200.120 0.1 0.2 10 11-MPC-006-5-C 11-MPC-006-5-C 11-MPC-016-5-B 11-MPC-016-5-B 11-MPC-016-5-B 11-MPC-016-5-B 0.2 0.5 0.5 1 12 2 5 5 10 1020 20 50 50 Frequency (MHz) (MHz) Frequency 10 0 0 0.1 0.1 0.2 0.2 0.5 0.5 1 12 2 MPC-010 & 015 Series 5 12 2 5 5 10 10 20 20 50 20 50 50 50 5 10 11-MPC-003;-006;-016 11-MPC-003;-006;-016 60 60 80 Insertion Loss (dB) Loss (dB) Insertion 11-MPC-006-5-C 11-MPC-006-5-C 11-MPC-003;-006;-016 11-MPC-003;-006;-016 60 Insertion Loss Insertion (dB) Loss (dB) 80 50 70 2 5 1020 5 10 11-MPC-001-5-A 11-MPC-001-5-A Frequency (MHz) (MHz) Frequency 11-MPC-002-5-B 11-MPC-002-5-B 11-MPC-003;-006;-016 11-MPC-003;-006;-016 80 Insertion Loss (dB) Loss (dB) Insertion Insertion Loss Insertion (dB) Loss (dB) 11-MPC-003;-006;-016 11-MPC-003;-006;-016 80 11-MPC-003-5-E 11-MPC-003-5-E 50 70 11-MPC-006-5-B 11-MPC-006-5-B 40 60 11-MPC-003-5-E 11-MPC-003-5-E 30 50 11-MPC-006-5-B 11-MPC-006-5-B 20 40 12 Frequency Frequency (MHz)(MHz) 80 60 80 11-MPC-001-5-A 11-MPC-001-5-A 11-MPC-002-5-B 11-MPC-002-5-B 0.2 0.5 10 0 0 0.1 0.1 0.2 50 11-MPC-001-5-B 11-MPC-001-5-B 11-MPC-001-2-B 20 11-MPC-001-2-B 40 10 10 30 30 0 0 200.120 0.1 0.2 10 10 20 50Ω Level Meter 50Ω 11-MPC-001;-002 11-MPC-001;-002 60 60 80 Insertion Loss (dB) Loss (dB) Insertion 11-MPC-001;-002 11-MPC-001;-002 60 60 80 50Ω 11-MPC-001;-002 11-MPC-001;-002 80 Insertion Loss (dB) Loss (dB) Insertion Insertion Loss Insertion (dB) Loss (dB) 11-MPC-001;-002 11-MPC-001;-002 1 3 Filter 2 4 50Ω Level Meter 50 70 40 60 30 50 20 40 10 10 30 30 0 0 200.120 0.1 0.2 10 10 20 20 50 50 Frequency Frequency (MHz)(MHz) 80 11-MPC-016-5-B 11-MPC-016-5-B 50 70 11-MPC-003-5-E 11-MPC-003-5-E 40 60 11-MPC-016-5-B 11-MPC-016-5-B 30 50 11-MPC-003-5-E 20 11-MPC-003-5-E 40 0.2 0.5 0.5 1 0.2 0.5 0.5 1 10 0 0 0.1 0.1 0.2 11-MPC-006-5-C 11-MPC-006-5-C 11-MPC-006-5-B 11-MPC-006-5-B 11-MPC-006-5-C 11-MPC-006-5-C 1020 20 50 5 10 50 11-MPC-006-5-B 11-MPC-006-5-B Frequency (MHz) (MHz) Frequency 12 12 2 2 5 5 5 10 10 20 20 50 50 Frequency Frequency (MHz)(MHz) 100 Insertion Loss (dB) 90 80 MPC-010-050 MPC-015-050 70 60 50 40 MPC-010-250 30 20 10 0 0.01 0.1 1 10 100 1000 10000 Frequency (MHz) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 SM20 Through-hole Filters High Frequency PCB Filters API Technologies’ Spectrum Control line of high frequency PCB filter provides EMI filtering to protect low power digital circuits, while meeting most government and industrial specifications for EMI control. With low assembly and installation costs, the PCB filter helps keep your project on budget. By mounting the PCB filter at the source of the problem, we eliminate the need for additional filtering at other points in the circuit. The filter mounts directly to a printed circuit board with no mounting bracket or plate needed, providing you with a lower total installed cost. In addition, the PCB filter can be flowsoldered with other components. API’s PCB filter has built-in standoffs, which allow for cleaning or coating beneath the filter, and the filter is encapsulated for environmental protection. Features n n n n n Provides EMI filtering to protect low power digital circuits - helps equipment meet FCC and VDE specifications Mounts directly to printed circuit board with no bracket or plate for lower applied costs - can be flow soldered with other components Encapsulated for environmental protection Mounts on PCB to begin filtering at the source of the problem Built-in standoffs permit cleaning or coating under the filter Circuit Schematic Typical Electrical Characteristics . . . Max. 10A DC; 0.3A RF . . . Max. 50 VDC, -25°C to +85°C . . . 800 pF min. . . . 0.1 Max. Current . . . . . . . . . . . . . Operating Voltage . . . . . Capacitance . . . . . . . . . . Dissipation Factor . . . . . Dielectric Withstanding Voltage . . Insulation Resistance . . . .................. Direct Current Resistance . . . . . . . . . . . Minimum No-Load Insertion Loss . . . . . . . . . . . 125 VDC for 5 seconds . . . Min. 100 MegOhms at 100 VDC . . . for 2 minutes and 25°C . . . 0.002 ohms Max. . . . Per MIL-STD-220 at 25°C; PCB mounted, 50 ohm strip line 3dB @ 8 MHz 10dB @ 25 MHz 15dB @ 50 MHZ 20dB @ 100 MHz-1GHz Preformed to Recommended Mounting Configuration Part Number 842448-2 Recommended Mounting Configuration Pi Input Output .600±.030 (15 .24±0 .76) .062 Ground (1 .57) Ref. ±.015 .300 (7 .62±0 .38) .015 (0 .38) Ref. Ground Lead .062 (1 .57) Ref. .062 (1 .57) Ref. + + .200±.010 (5 .08±0 .25) .032 (0 .81) Dia. .240±.020 Ground.040 (6 .10±0 .51) .062 (1 .57) Ref. Lead (1 .02) Dia. .300±.015 Ground ±0 .38 (7 .62 ) Lead .520 (13 .21) Ref. ±0 .25 1.040 (26 .42) .300±.005 (7 .62±0 .13) .300±.010 (7 .62±0 .25) + + .055±.002 (1 .4±0 .05) Dia. + .040±.002 .055±.002 .055±.002 (1 .4±0 .05) (1 .02±0 .05) (1 .4±0 .005) Ground Dia. Dia. Dia. Lead .300±.015 (7 .62±0 .38) .062 (1 .57) Ref. Dimensions in inches (mm) .015 (0 .38) Ref. .300±.010 (7 .62±0 .25) ±.010 .015 (0 .38) Ref. .300±.005 (7 .62±0 .13) 1.040 (26 .42) .600 Standard Configuration (15 .24 ) Recommended PCB Hole Layout ±.010 ±.030 .600 .600±0 .25 (15 .24 (15 .24±0 .76) ) .062 (1 .57) Ref. .600±.030 (15 .24±0 .76) .032 (0 .81) Dia. .040±.002 (1 .02±0 .05) Dia. Ground Lead .520 (13 .21) Ref. .125±.025 Dimensions in inches (mm) (3 .18±0 .64 ) Part Number 842448-1 + .055±.002 (1 .4±0 .005.240 ) ±.020 .040 Dia.(6 .10±0 .51) (1 .02) Dia. .200±.010 (5 .08±0 .25) .125±.025 (3 .18±0 .64) Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 ±.010 .600 (15 .24±0 .25) SM21
PSM4-103Z-15T0
1. 物料型号:文档列出了多种型号的EMI滤波器,包括但不限于: - 三端子芯片(Three Terminal Chips) - SA系列阵列(SA Series Arrays) - MSM迷你表面安装(MSM Mini-Surface Mount) - PSM功率表面安装(PSM Power Surface Mount) - MSP迷你表面安装电源滤波器(MSP Mini Surface Mount Power Filters) - MPC系列微型PCB电源滤波器(MPC Series Miniature PCB Power Filters)
2. 器件简介:这些滤波器设计用于提供高性能的EMI过滤选项,同时最小化PCB占用空间。它们适用于多种PCB应用,包括汽车电子、数字音视频设备、计算机、外设、通信、开关电源和高电流总线。
3. 引脚分配:文档提供了详细的引脚分配图和机械尺寸,包括端子长度和宽度。
4. 参数特性:包括电容范围、电容公差、温度系数、绝缘电阻、直流电阻和额定电压等。
5. 功能详解:每种型号的滤波器都有其特定的应用和性能特点,例如三端子芯片在高电流应用中提供卓越的性能,SA系列阵列设计用于最小化残余电感,PSM系列滤波器设计用于有效过滤高达20安培电流的EMI/RFI。
6. 应用信息:滤波器适用于多种应用,如移动电话和基站、电信设备、工业电子接口或可编程控制器、汽车电子设备、计算机和外设设备等。
7. 封装信息:提供了不同尺寸的封装信息,如0603、0805、1205和1806,以及它们的引脚分配和机械尺寸。
8. 订购信息:给出了订购时使用的部件编号示例和说明,包括尺寸、电容值、电容公差、电压等级、电流等级和封装方式。
9. 焊接说明:提供了焊接时的一般注意事项、推荐的焊接温度曲线、推荐的板图案尺寸以及超声波清洗的推荐参数。
10. 电气特性:包括典型电气特性图表,展示了不同型号滤波器在不同频率下的插入损耗。
PSM4-103Z-15T0 价格&库存
很抱歉,暂时无法提供与“PSM4-103Z-15T0”相匹配的价格&库存,您可以联系我们找货
