SCIF-9925-502
SCIF-9925-502
    APITECHNOLOGIES
    Axial
    5000pF Feed Through Capacitor 100V 5A 10 mOhm Axial, Press Fit
SCIF-9925-502 数据手册
Low Pass EMI Filters the industry’s most complete line of EMI filters gives you more style, size, IL performance and cost alternatives Solder-In Filters offer an ideal solution for applications in critical areas where space does not allow for use of mounting tools or hardware. Available in C, Pi and standard L circuit configurations and primarily used in filtering signal/data lines and AC power lines… LP3-LP7 Miniature Solder-in Filters have a knurled design allowing them to be pressed into place creating a reliable mechanical bond making them an excellent choice for applications where soldering is undesirable… LP8-LP11 Spec Spin Filters are an excellent choice for applications that require many lines to be filtered in close proximity to each other due to their space saving #2-56 threaded miniature EMI spanner design. These filters are designed without a hex and do not require soldering for installation… LP12 Resin Sealed Filters provide excellent environmental protection in a rugged case that is resin sealed at both ends and easily mounted with a tapped hole or through hole. These filters are provided in C, L and Pi configurations with metric threading available… LP13-LP24 High Current Resin Sealed Filters are ideal for use in high current 5 volt logic buss, as well as ±48 VDC telephone rack buss, high current switch mode power supplies and DC charging systems. These filters feature rugged bolt-in style for easy installation… LP25-LP26 Hermetically Sealed Filters feature hermetic glass seals and high EMI filtering performance making them highly reliable in the toughest environmental conditions. These filters are available with C, L, Pi, T and double T configurations with MIL-F-15733 and MILF-28861 QPL filters available… LP27-LP42 Low Pass EMI Advantages API Technologies’ Spectrum Control brand was founded in 1968 as a designer and manufacturer of Electromagnetic Interference (EMI) filters. Today, API continues that work, combining knowledge with excellence. These many years of experience have yielded an engineering-driven team that understands how and where potential EMI problems exist in an electronic system and how to best eliminate them. With an extensive library of standard products and a willingness to develop an application-specific custom solution, our customers count on us to help them satisfy global EMC standards while meeting demanding design parameters. Value Added Assemblies offer flexible solutions by allowing you to add connectors, modify terminations or add wire harnesses, thereby lowering your cost of acquisition and assembly, reducing your production time/costs and inventory, all while giving you a filter assembly that meets your unique design challenges… LP43 ■ ■ ■ ■ ■ ■ Wide range of package sizes, mounting options and circuit configurations offering maximum design flexibility Develop custom application-specific solutions addressing your mechanical and electrical requirements High reliability construction… built in accordance to MIL-PRF-15733 or MIL-PRF-28861 Over 800 standard QPL products and DSCC part numbers Effective filtering up to 18 GHz Reliability testing available for customer specific requirements For complete specs and drawings, visit eis.apitech.com/low_pass_filters.asp API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP1 Solder-in Filters Solder-in filters are ideal for use in critical areas where space does not allow use of mounting tools or hardware. The solder-in feature also allows installation in unison with other board mounted components. Primarily used in filtering signal/data lines and DC power lines. Features ■ Small size to allow effective use of space ■ Voltage ratings to 750 VDC ■ Multiple circuit configurations: C, L & Pi available ■ High temperature construction to prevent reflow during installation ■ MIL-F-15733 QPL versions available ø .062 ± .005 (ø 1.59 ± .13) .359 ± .031 (9.11 ± .79) ø A Max. (ø A Max.) ø .040 ± .005 (ø 1.02 ± .13) ø .281 ± .015 (ø 7.14 ± .38) .093 ± .015 (2.38 ± .38) .390 ± .031 (9.91 ± .79) ø B ± .015 (ø B ± .38) .203 ± .031 (5.15 ± .79) ø .190 Max. (ø 4.83) .170 ± .031 (4.34 ± .79) .140 Max. (3.57 Max.) ø .044 ± .005 (ø 1.12 ± .13) Figure 1 Figure 2 ø .281 ± .015 (ø 7.14 ± .38) F .093 ± .015 (2.38 ± .38) .093 ± .015 (2.38 ± .38) .093 ± .015 (2.38 ± .38) .05 ± .01 (1.27 ± .25) .093 ± .015 (2.38 ± .38) ø .190 Max. (ø 4.83) .343 ± .030 (8.73 ± .76) Figure 3 ø .281 ± .015 (ø 7.14 ± .38) ø .190 Max. (ø 4.83) .093 ± .015 (2.38 ± .38) .093 ± .015 (2.38 ± .38) .05 ± .01 (1.27 ± .25) .093 ± .015 (2.38 ± .38) .328 ± .030 (8.33 ± .76) .343 ± .030 (8.73 ± .76) ø .062 ± .005 (ø 1.59 ± .13) Figure 4 Figure 5 Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP3 Solder-in Filters Solder-in C Circuit Part Number 54-786-003 See Rated Voltage A B I Pg. LP3 125°C Amp for Fig. In (mm) In (mm) DC 0.156 (3.96) 0.203 (5.16) 1 50 10 Cap* 0.30 µF 1 MHz 32 Minimum Insertion Loss (dB) 1 10 30 100 300 MHz MHz MHz MHz GHz 60 66 70 47 54 10 GHz 70 54-785-002 1 100 10 0.05 µF (min) 16 33 41 45 48 50 50 54794002X5R101M 4 — — — — 250 25 100 pF ± 20% — — — — 10 20 20 54803004X5R101M 3 — — — — 250 25 100 pF ± 20% — — — — 10 20 20 54802002X5R101M 2 — — — — 250 25 100 pF ± 20% — — — — 10 20 20 ✝ 54794002X5R471M 4 — — — — 250 25 470 pF ± 20% — — — 12 22 25 25 ✝ 54803004X5R471M 3 — — — — 250 25 470 pF ± 20% — — — 12 22 25 25 54802002X5R471M 2 — — — — 250 25 470 pF ± 20% — — — 12 22 25 25 ✝ 54802002X5V102P 2 — — — — 250 25 1000 pF — — — 15 25 35 40 ✝ 54803004X5V102P 3 — — — — 250 25 1000 pF — — — 15 25 35 40 ✝ 54794002X5V102P 4 — — — — 250 25 1000 pF — — — 15 25 35 40 ✝ 54-786-077 5 — — — — 750 10 1000pF — 4 — 20 25 35 40 0.125 (3.18) 0.184 (4.67) Also available through API’s authorized distributors. * Tolerances are +100/-0% unless noted. ✝ API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP4 Solder-in Filters Solder-in Pi Circuit ø .140 ± .010 (3.56 ± .25) .315 ± .015 (8.00 ± .38) ø D ± .005 (D ± 0.13) A ± .031 (A ± .79) ø .110 ± .005 (ø 2.79 ± .12) B ± .031 (B ± .79) B ± .031 (B ± .79) ø .195 ± .005 (ø 4.95 ± .13) .103 ± .015 (2.6 ± .38) ø D ± .005 (D ± 0.13) ø .140 ± .005 (ø 3.56 ± .12) Figure 1 F .010 (.25) A ± .031 (A ± .79) .115 (2.92) 1.080 ± .031 (27.43 ± .79) Tinned Metal Ground Straps .400 (10.16) ø .140 ± .005 (ø 3.56 ± .12) .093 ± .02 (2.36 ± .51) .156 ± .02 (3.96 ± .51) F Figure 2 B ± .031 (B ± .79) ø .195 ± .005 (ø 4.95 ± .13) A ± .031 (A ± .79) ø 0.32 ± .005 (ø 0.81 ± 0.13) .219 ± .02 (5.56 ± .51) .156 ± .02 (3.96 ± .51) ø .032 ± .005 (ø 0.81 ± 0.13) ø .124 (3.15) .250 (6.35) .415 (10.54) Figure 3 Figure 4 Solder Coating ø .156 ± .015 (ø 3.97 ± .38) ø .085 max. (ø 2.2) ø .040 ± .005 (ø 1.02 ± .13) .265 ± .030 (6.75 ± .76) .020 Ref. (.51) .106 ± .030 (2.69 ± .76) .343 ± .030 (8.73 ± .76) .156 ± .015 (3.97 ± .38) Figure 5 B ± .010 (B ± .25) ø .195 (ø 4.95) ø .145 (ø 3.68) .468 ± .030 (11.91 ± .76) ø .033 min. (.84) A ± .010 (A ± .25) Figure 6 .406 ± .031 (10.31 ± .79) ø .234 max. (ø 5.94) .218 ± .031 (5.54 ± .79) Turret Lead .687 ± .031 (17.45 ± .79) ø .312 ± .031 (7.92 ± .79) Figure 7 .500 ± .031 (12.70 ± .79) Figure 8 F Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP5 Solder-in Filters Solder-in Pi Circuit Rated Voltage M15733 See 125°C D A B I Min MIL Pg. LP5 Part Number Number for Fig. In Cap DC In In AC Amp (mm) (mm) (mm) 3 0.312 (7.92) 0.469 (11.91) 0.032 (0.81) 70 — 10 1500 pF 51-703-013* /62-0003 Minimum Insertion Loss (dB) 10 1 1 10 30 100 300 MHz MHz MHz MHz MHz GHz GHz — 5 12 50 50 65 65 2 0.268 (6.81) 0.780 (19.81) 0.032 (0.81) 70 — 10 0.012 µF 5 22 50 70 70 65 65 ✝ 1234-000* € — 2 0.257 (6.53) 0.780 (19.81) 0.032 (0.81) 70 — 10 0.012 µF 5 25 50 70 70 70 70 51-749-304 — 4 51-750-309* /62-0004 — — — — — — 70 — 10 0.012 µF 5 25 50 70 70 65 65 — — — — — — 1234-001 — 4 70 — 10 0.012 µF 5 25 50 70 70 65 65 ✝ 51-750-301* — 2 0.250 (6.35) 0.780 (19.81) 0.032 (0.81) 70 — 10 0.012 µF 5 25 50 70 70 70 70 ✝ 1233-000* € — 3 0.312 (7.92) 0.780 (19.81) 0.032 (0.81) 70 — 10 0.022 µF 7 35 60 70 70 70 70 ✝ 51-750-302* — 3 0.312 (7.92) 0.780 (19.81) 0.032 (0.81) 70 — 10 0.022 µF 7 25 60 70 70 70 70 51-750-313 /51-0002 3 0.312 (7.92) 0.780 (19.81) 0.032 (0.81) 70 — 10 0.022 µF 7 25 60 70 70 70 70 — 5 200 — 10 1300 pF — 5 15 30 45 55 55 /62-0002 1 1.140 (28.96) 1.277 (32.44) 0.032 (0.81) 200 — 10 1500 pF — 5 12 45 50 70 70 — 1 1.109 (28.17) 1.206 (30.63) 0.032 (0.81) 200 — 10 1500 pF — 5 15 40 50 70 70 — 3 0.312 (7.92) 0.406 (10.31) 0.032 (0.81) 200 — 10 1500 pF — 8 17 45 65 70 70 — 3 0.312 (7.92) 0.406 (10.31) 0.032 (0.81) 200 — 10 1500 pF — 5 15 45 50 70 70 3 0.312 (7.92) 0.406 (10.31) 0.032 (0.81) 200 140 10 1500 pF — 3 15 45 50 70 70 ✝ 51-723-303 51-713-010 ✝ 1251-001 € 51-703-001* ✝ 1203-050 € 51-703-012* /62-0001 — — — — — — 51-713-002 — 1 1.103 (28.01) 1.212 (30.78) 0.032 (0.81) 200 — 10 1500 pF — 5 12 40 70 70 70 1214-029 — 2 0.288 (7.31) 0.780 (19.81) 0.032 (0.81) 200 — 10 1750 pF — 5 15 50 60 60 70 ✝ 1214-007 € — 6 0.093 (2.36) 0.157 (3.99) 200 — 10 1750 pF — 5 15 35 50 60 60 — 2 0.288 (7.31) 0.780 (19.81) 0.032 (0.81) 200 — 10 1750 pF — 8 17 50 65 70 70 — 2 0.288 (7.31) 0.780 (19.81) 0.032 (0.81) 200 — 10 1750 pF — 5 15 50 50 60 60 ✝ 51-707-006* /33-0001 2 0.288 (7.31) 0.780 (19.81) 0.032 (0.81) 200 90 10 1750 pF — 5 15 50 50 60 60 51-707-007 /33-0002 2 0.288 (7.31) 0.780 (19.81) 0.032 (0.81) 200 90 10 1750 pF — 5 15 50 50 60 60 51-707-026 /66-0001 6 0.288 (7.31) 0.157 (3.99) 200 — 10 1750 pF — 5 15 35 50 50 50 — 2 1.123 (28.52) 1.347 (34.21) 0.040 (1.02) 200 — 10 3000 pF — 7 25 50 65 65 65 51-707-002* ✝ 1214-001* ✝ 51-750-322 — — — — 3 0.312 (7.92) 0.406 (10.31) 0.032 (0.81) 200 200 10 5500 pF — 15 30 55 65 70 70 1223-012 — 1 0.240 (6.10) 0.360 (9.14) 0.040 (1.02) 200 — 15 3000 pF — 7 25 50 65 65 65 ✝ 1204-050 € — 7 0.210 (5.34) — — — — 500 — 25 3000 pF — 8 25 50 65 70 70 /40-0001 7 0.234 (5.94) — — — — 500 350 25 3000 pF — 7 25 55 65 70 70 51-703-007* /51-0001 51-704-002 * ✝ € Denotes parts with turret on one end per Figure 8. Also available through API’s authorized distributors. Also available through API’s authorized European distributors/agents. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP6 Large Diameter Solder-in High Temp Filters Features ■ .400" diameter mounting vs .128" diameter mounting ■ High temperature construction withstands 300°C installation temperatures ■ Increased capacitance values than standard 9900 series - up to 1.2uF ■ EMI filtering from 500KHz up to 10GHz ■ 15 Amp current rating ■ Ideal for low to medium impedance circuits where large amounts of capacitance to ground can be tolerated (feed-thru “C” circuit) ■ Glass seal one end provides protection from hostile environments and maintain hermeticity ■ Rugged monolithic discoidal capacitor construction ■ Gold plated suited for gold bonding ■ Designed to be soldered into a package, bracket or bulkhead ■ Reverse seal available ■ Special lead length and end terminations available Large Diameter Solder-in High Temp Filters Minimum Insertion Loss (dB) Part Number SCI-9945-125H SCI-9945-504H SCI-9945-754H SCI-9945-105H SCI-9945-503HAC SCI-9945-154HAC SCI-9945-103H SCI-9945-503H Circuit C C C C C C C C AMP 15 15 15 15 15 15 15 15 DC Voltage 50 100 100 100 200* 200* 400 400 Min Cap (µf) 1.2 .50 .75 1.0 .050 .15 .010 .050 500 KHz 33 26 31 31 7 17 — 7 1 MHz 37 34 37 40 15 24 4 15 10 MHz 52 42 43 48 34 38 20 34 100 MHz 70 58 62 64 42 50 34 44 1 GHz 70 70 70 70 70 70 50 70 10 GHz 70 70 70 70 70 70 60 70 * Rated 200VDC or 125VAC/400Hz API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP7 Miniature Solder-in Filters 9900 Series These filters are ideal for microwave applications such as attenuators and oscillators, and perform well in high impedance circuits where large capacitance values are not practical. Features C Circuit L Circuit .625 Ref. .715 Ref. (15.88) (18.16) ■ Miniature size to allow effective use of space ■ Standard capacitance values from 5pF to .033µF ■ Voltage ratings to 200 VDC/115 VAC 0–400 Hz ■ Hermetically sealed on one end allows for through-hole sealing between compartments ■ High temperature construction meets MIL-F-28861 solderability and resistance to soldering heat requirements .25±.03 (6.35±0.76) ø .156 ±.005 (3.96 ±0.13) .020±.005 (0.51±0.13) ■ Available in MIL-C-11015 versions — see page CF10 ■ Gold plating compatible with gold bonding techniques C Circuit .110±.005 (2.79±0.13) L Circuit .200±.005 (5.08±0.13) ø .030 (ø 0.76) ø .128±.005 (3.25±0.13) Glass Seal (STD) Figure 1 Marking C Circuit Color dot standard as follows: ● 101 Green – 100pF ● 272 Red – 2700pF ● 501 Brown – 500pF ● 502 Blue – 5000pF 153 Pink – 15000pF 000 None – 10pF max Glass Seal (Reverse) ● 102 Purple – 1000pF ● ● 122 White 1200pF ● – Figure 1 (Reverse)* Dimensions in inches (mm) Marking L Circuit Color dot standard as follows: ● 100 Violet – 10pF ● 103 2White – .01µF ● 250 Blue – 25pF ● 153 2White – .015µF ● 102 White – 1000pF ● 273 2Red – 27000pF ● 152 White – 1500pF ● 333 2Red – ● 502 Yellow – 5000pF .033µF API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP8 Miniature Solder-in Filters 9900 Series Miniature Solder-in C Circuit Part Number* SCI-9900-153 SCI-9900-303 ✝ SCI-9910-272 ✝ SCI-9910-502 SCI-9900-000 ✝ SCI-9920-101 ✝ SCI-9920-501 ✝ SCI-9920-122 Figure 1 1 1 1 1 1 1 1 Rated Voltage 125°C AC DC 50 50 100 100 200 200 115 200 115 200 115 Minimum Insertion Loss (dB) I Amp 5 5 5 5 5 5 5 5 Min Cap 0.015 µF 0.030 µF 2700 pF 5000 pF 4 pF max. 100 pF 500 pF 1200 pF 1 MHz 7 10 — — — — — — 10 MHz 25 30 10 15 — — — 5 30 MHz 30 35 18 20 — — — 10 100 MHz 40 45 25 30 — 3 15 20 300 MHz 40 50 33 35 — 10 22 28 1 GHz 60 55 40 45 10 20 35 35 10 GHz 60 55 50 55 10 28 40 45 * For reverse glass seal add an “R” to the end of the part number (SCI-9900-153R). Also available through API’s authorized distributors. Parts are RoHS Compliant ✝ Miniature Solder-in L Circuit Rated Voltage 125°C Part Number* SCI-9980-100 SCI-9980-101 SCI-9980-102 SCI-9980-103 SCI-9980-122 SCI-9980-152 SCI-9980-153 SCI-9980-250 SCI-9980-272 SCI-9980-273 SCI-9980-333 SCI-9980-501 SCI-9980-502 Figure 1 1 1 1 1 1 1 1 1 1 1 1 1 DC 200 200 200 200 200 200 200 200 200 50 200 200 200 I Amp 10 10 10 10 10 10 10 10 10 10 10 10 10 Min Cap 10 pF 100 pF 1000 pF .01 uF 1200 pF 1500 pF .015 uF 25 pF 2700 pF 27,000 pF .033 uF 500 pF 5000 pF 1 MHz — — — 8 — — 10 — 8 13 13 — 8 Minimum Insertion Loss (dB) 10 100 1 MHz MHz GHz — — 7 — 5 22 8 25 40 27 48 65 8 28 42 10 28 43 28 50 65 — — 13 13 32 45 33 53 75 35 55 75 — 18 37 17 35 47 10 GHz 20 35 42 65 50 53 65 25 55 75 75 38 55 * Reverse seal available. Add R at the end of the part number. (SCI-9980-102R). Note: Hi-rel versions available. Add R after the first dash. (SCI-R9980-102). Lt circuit part number series SCI-9981-XXX. Parts are RoHS Compliant API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP9 Spec Mini Solder-in Feed-Thru Filters API Technologies miniature solder-in filters are hermetically sealed on one end for thru-hole sealing between compartments allowing it to be soldered into a package, bracket, or bulkhead while maintaining hermetically. These mini EMI filters are ideal for a variety of products intended for use in the microwave frequency spectrum including oscillators, attenuators, and synthesizers. The high temperature construction meets military requirements for solderability and resistance to soldering heat and its high-purity gold plating provides excellent compatibility with gold bonding techniques. Features ■ .120" diameter mounting ■ Capacitance values from 5pF to .027µF ■ RoHS compliant ■ Reverse seal available ■ High temperature construction Part Number SCI-9909-008 SCI-9909-009 SCI-9909-010 SCI-9909-011 SCI-9909-012 SCI-9909-013 SCI-9909-014 SCI-9909-015 SCI-9909-016 SCI-9909-017 SCI-9909-018 SCI-9909-019 SCI-9909-020 Dimensions in inches (mm) DC Amps 5 5 5 5 5 5 5 5 5 5 5 5 5 Working Voltage 200 200 200 200 200 200 200 200 200 100 100 50 50 Cap (µf) 5 10 25 50 100 250 500 1000 1500 2700 5000 10,000 27,000 500 KHz — — — — — — — — — — — — — 1 MHz — — — — — — — — — — — 4 10 Minimum Insertion Loss (dB) 10 100 MHz MHz — — — — — — — — — 3 — 5 — 15 5 20 5 22 10 25 15 30 21 35 28 42 1 GHz — 5 10 10 20 22 35 35 35 40 45 50 55 10 GHz 5 20 25 25 28 30 40 45 45 50 55 60 65 API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP10 Spec Mini-Press 9900 Series This new knurled filter is designed to be pressed into place and create a reliable mechanical bond. This feature makes it an excellent selection for applications where soldering is undesirable. Suitable plating is available that allows gold bonding to the terminals. Applications These filters are ideal for microwave and RF applications such as attenuators, synthesizers, and oscillators. They perform well in high impedance circuits where large capacitance values are not practical. Installation ■ .136" to .137" (3.45-3.48mm) diameter hole ■ Hole must be free of all insulating materials. ■ Installation tool must have a hole of sufficient depth and diameter to accept the terminal of the filter. ■ Installation force must be applied gradually and smoothly until the flange of the filter is seated against the receiving part (request installation instructions). .156 ± .005 dia. (3.96 ± .127 dia.) .625 (15.88) ref. .025 (0.635) .010 .250 ± .002 ± .030 (.254 (6.35 ±.051) ±.762) .030 ± .002 dia. .020 (.762 ± .005 ± .051 (.508 dia.) Epoxy ±.127) Seal .143 ± .002 (3.63 ± .051) Glass Seal End Straight Knurl, 160 D.P. .110 ±.005 (2.79 ±.127) Built and tested in accordance with MIL-F-15733. .128 ± .005 dia. (3.25 ± .127 dia.) Figure 1 Dimensions in inches (mm) Mechanical Specifications Installation . . . . . . . . . . . . . Press-in Plating . . . . . . . . . . . . . . . . Gold Seal . . . . . . . . . . . . . . . . . . Glass sealed on one end, . . . . . . . . . . . . . . . . . . . . . resin sealed on the other end Termination Options . . . . . . Plating suitable for gold . . . . . . . . . . . . . . . . . . . . . bonding Operating Temperature . . . . -55°C to +125°C Circuit Schematic Input Insertion Tool Output Part Number: SCI-9925-200 Ground Rated Voltage 125°C Part Number ✝ SCI-9925-153 ✝ SCI-9925-303 ✝ SCI-9925-502 ✝ SCI-9925-000 ✝ SCI-9925-101 ✝ SCI-9925-501 ✝ SCI-9925-122 SCI-9925-272 Figure 1 1 1 1 1 1 1 1 DC 50 50 100 200 200 200 200 200 Minimum Insertion Loss (dB) I Amp 5 5 5 5 5 5 5 5 Cap 0.015 µF +100%/-0% 0.030 µF +100%/-0% 5000 pF +100%/-0% 10 pF max. 100 pF +100%/-0% 500 pF +100%/-0% 1200 pF +100%/-0% 2700 pF +100%/-0% 1 MHz 7 10 — — — — — — 10 MHz 25 30 15 — — — 5 10 30 MHz 30 35 20 — — — 10 18 100 MHz 40 45 30 — 3 15 20 25 300 MHz 40 50 35 — 10 22 28 33 1 GHz 60 55 45 10 20 35 35 40 10 GHz 60 55 55 10 28 40 45 50 ✝ Also available through API’s authorized distributors. Note: Parts are RoHS Compliant API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP11 Spec Spin Filters API Technologies’ Spectrum Control brand introduces the new space saving #2-56 threaded miniature EMI spanner filter. This new threaded filter is designed without a hex and does not require soldering for installation. These features make it an excellent selection for applications that require many lines to be filtered in close proximity. The easy swap out also allows for flexibility in filter replacement and capacitance substitution. Easy filter substitution also allows for flexibility in filter placement. Custom design queries are always welcome. .020 (0.51) ø.105 ± .005 (2.67) .020 (0.51) .290 (7.36) Applications 1-1/2 Imperfect Threads API’s Spectrum Control brand spanner filter offers superior insertion loss over a broad frequency range when compared to surface mount components. The filter is available in capacitance values up to 10,000 pF, and is featured in a microcircuit package used in microwave applications such as frequency synthesizers, power amplifiers, MMW radio, and is ideal for commercial and high-reliability applications. .024 (0.61) Built and tested in accordance with MIL-F-15733. Dimensions in inches (mm) Lead Finish . . . . . . . . . . . . . Gold Voltage Rating . . . . . . . . . . 50 VDC Bushing Finish . . . . . . . . . . Gold Current Rating . . . . . . . . . . 5 A Tightening Torque . . . . . . . . 14 oz-in (± 2) (0.11Nm) Effective Filtering From . . . . 1 MHz to 10 GHz Capacitance . . . . . . . . . . . . to 10,000 pF Insertion Tool Dielectric Withstanding Voltage . . . . . . . . . . . . . . . . . 125 VDC Max. Tolerance +0%/-20% .240 (6.11) Center Spacing . . . . . . . . . . .0.110" Operating Temperature . . . . -55°C to +125°C Cap (pF) 10 39 100 390 1,000 2,000 3,300 4,700 10,000 .081 (2.06) #2-56 Unc-2A Mechanical Specifications Electrical Specifications Part Number* 54-874-010 54-874-011 54-874-012 54-874-013 54-874-014 54-874-015 54-874-016 54-874-017 54-874-018 .140 (3.57) Part Number: 54-874-020 Circuit Current Voltage DWV I.R. Temperature Range C 5A 50 VDC 125 VDC 1,000 MΩ -55°C to +125°C +50%/-20% +100%/-0% +80%/-20% Note: Parts are RoHS Compliant API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP12 Resin Sealed Bolt-in Filters These filters are easily mounted in a tapped hole or through-hole with supplied nut and lock-washer. The rugged case with resin seals at both ends provides excellent environmental protection. Primarily used in filtering signal/data lines and DC power lines. Features ■ Wide range of sizes: 4-40 thread through 5/16-24 thread ■ Voltage ratings to 500 VDC/220 VAC (400 Hz) ■ MIL-F-15733 QPL filters available ■ Multiple circuit configurations: C, L and Pi ■ Metric threaded filters available, consult factory 4-40 C Circuit .510 ± .031 (13.0 ± .79) .310 ± .031 (7.87 ± .79) .368 ± .031 (9.347 ± .79) .156 Hex. (3.96) .120 (3.05) ø .025 ± .005 (.64 ± .13) .220 (5.59) .156 Hex. (3.96) .120 (3.05) .050 (1.27) ø .032 ± .005 (.810 ± .13) .220 (5.59) #4–40 Unc–2A Thd. #4–40 Unc–2A Thd. Figure 1 F .360 ± .031 (9.144 ± .79) .275 ± .031 (6.99 ± .79) Figure 2 F .240 ± .031 (6.10 ± .79) .156 Hex. (3.96) .120 (3.05) .315 ± .031 (8.00 ± 0.79) .140 (3.56) .225 ± .031 (5.72 ± 0.79) .075 (1.91) .125 Hex. (3.18) ø A ± .005 (± .13) .220 (5.59) #4–40 Unc–2A Thd. Figure 3 F ø .032 (ø 0.81) #4–40 Unc–2A Thd. FigureF 4 Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP13 Resin Sealed Bolt-in Filters 4-40 C Circuit Rated Voltage 125°C DC AC 50 — Minimum Insertion Loss (dB) 10 1 3 1 10 30 100 300 (mm) MHz MHz MHz MHz MHz MHz GHz GHz — — — — 10 — 10 (0.81) — ✝ SCI-9110-100 See Pg. LP12 for Fig. 3 ✝ 9900-381-6004 2 50 — 10 5000 pF — — — — 15 22 30 35 45 55 9900-381-6026 2 50 — 10 0.031 µF — — 12 20 25 35 40 45 55 60 ✝ 9900-381-6006 2 50 — 10 0.045 µF — — 14 22 30 40 45 50 55 60 ✝ 54-790-023 1 100 — 10 0.050 µF — — 15 24 34 41 45 50 60 60 ✝ 54790001X5F101M 1 100 — 10 100 pF ± 20% — — — — — — — 10 20 25 54-790-019 1 100 — 10 2700 pF — — — — 9 18 27 33 35 35 9900-381-6013 2 100 — 10 2700 pF — — — — 10 18 25 33 40 50 54-790-020 1 100 — 10 5600 pF — — — — 15 24 33 37 40 40 SCI-9112-273 3 100 — 3 0.027 µF 0.016 (0.41)* 10 20 30 37 45 45 55 60 SCI-9110-273 3 100 — 10 0.027 µF 0.020 (0.51) 10 20 30 37 45 45 55 60 Part Number I Amp 10 A Min Cap 10 pF In 0.032 54-790-022 1 100 — 10 0.027 µF — — 10 20 30 37 45 50 55 60 ✝ SCI-9112-503 3 100 — 3 0.05 µF 0.016 (0.41)* 15 24 35 41 45 50 60 60 SCI-9110-503 3 100 — 10 0.05 µF 0.020 (0.51) 15 24 35 41 45 50 60 60 54-862-001 4 200 — 10 10 pF — — — — — — — — 10 10 54-862-002 4 200 — 10 100 pF — — — — — — 3 10 20 28 54-862-003 4 200 — 10 1000 pF — — — — — — 15 25 35 40 ✝ 9900-381-6020 2 200 — 10 100 pF — — — — — — 3 10 20 28 SCI-9122-101 3 200 115 3 100 pF 0.016 (0.41)* — — — — — 10 20 20 SCI-9120-101 3 200 115 10 100 pF 0.020 (0.51) — — — — — 10 20 20 9900-381-6021 2 200 — 10 500 pF — — — — — — 15 20 35 40 SCI-9122-102 3 200 115 3 1000 pF 0.016 (0.41)* — — — 11 20 28 28 40 SCI-9120-102 3 200 115 10 1000 pF 0.020 (0.51) — — — 11 20 28 28 40 ✝ 9900-381-6022 2 200 — 10 1200 pF — — — — 5 9 20 28 35 45 SCI-9122-502 3 200 115 3 5000 pF 0.016 (0.41)* — — 15 24 33 37 40 50 SCI-9120-502 3 200 115 10 5000 pF 0.020 (0.51) — — 15 24 33 37 40 50 SCI-9122-103 3 200 115 3 0.01 µF 0.016 (0.41)* — 12 20 29 38 45 50 55 SCI-9120-103 3 200 115 10 0.01 µF 0.020 (0.51) — 12 20 29 38 45 50 55 9900-381-6005 2 200 — 10 0.015 µF — — 7 9 20 29 35 45 50 60 ✝ 54-790-018 1 300 — 10 1000 pF — — — — — 9 20 28 28 40 ✝ 54-790-021 1 300 — 10 0.01 µF — — — 9 20 29 38 45 50 50 * Tinned, steel leads. ✝ Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP14 Resin Sealed Bolt-in Filters 4-40 L and Pi Circuit .360 ± .031 (9.144 ± .79) .240 ± .031 (6.10 ± .79) .156 Hex. (3.96) .120 (3.05) ø A ± .005 (± .13) .220 (5.59) #4–40 Unc–2A Thd. F Figure 1 Dimensions in inches (mm) ✝ 51-729-305 Figure 1 ✝ 51-729-312 Part Number Rated Voltage 125°C DC AC 50 — I Amp 3 CKT Pi A Min Cap 5500 pF In 0.018 Minimum Insertion Loss (dB) 10 1 3 1 10 30 100 300 (mm) MHz MHz MHz MHz MHz MHz GHz GHz 70 70 60 70 40 14 7 (0.46) — 1 50 — 3 Pi 7000 pF 0.018 (0.46) — 8 15 40 65 70 70 70 SCI-3102-002 1 50 — 3 LB 0.075 µF 0.016 (0.41)* 18 25 37 42 52 55 70 70 SCI-3102-000 1 50 — 5 LB 0.075 µF 0.016 (0.41) 18 25 37 42 52 55 70 70 SCI-3102-007 1 50 — 10 LB 0.075 µF 0.025 (0.64) 18 25 37 42 52 55 70 70 ✝ 51-729-304 1 100 — 3 LB 0.022 µF 0.018 (0.46) 7 17 27 34 43 47 55 55 ✝ SCI-3112-002 1 100 — 5 LB 0.027 µF 0.016 (0.41)* 10 20 30 38 45 45 65 70 ✝ SCI-3112-000 1 100 — 5 LB 0.027 µF 0.016 (0.41) 10 20 30 38 45 45 65 70 SCI-3112-007 1 100 — 10 LB 0.027 µF 0.025 (0.64) 10 20 30 38 45 45 65 70 SCI-3112-102 1 100 — 3 LB 0.05 µF 0.016 (0.41)* 15 24 35 42 54 56 70 70 SCI-3112-100 1 100 — 5 LB 0.05 µF 0.016 (0.41) 15 24 35 42 54 56 70 70 SCI-3112-107 1 100 — 10 LB 0.05 µF 0.025 (0.64) 15 24 35 42 54 56 70 70 1 200 — 3 Pi 1500 pF 0.018 (0.46) — — 5 15 42 65 70 70 SCI-3122-002 1 200 115 3 LB 0.01 µF 0.016 (0.41)* — 12 21 30 41 45 70 70 SCI-3122-000 1 200 115 5 LB 0.01 µF 0.016 (0.41) — 12 21 30 41 45 70 70 SCI-3122-007 1 200 115 10 LB 0.01 µF 0.025 (0.64) — 12 21 30 41 45 70 70 ✝ 51-729-303 * Tinned, steel leads. ✝ Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP15 Resin Sealed Bolt-in Filters 6-32 C, L, Pi/6-40 Pi .500 ± .031 (12.7 ± .79) .320 ± .031 (8.13 ± .79) #6-40 Unf–2A Thd. .220 (5.59) ø A ± .005 (± .13) .130 (3.30) ø .032 ± .005 (ø 0.81 ± .79) .050 (1.27) .125 (3.18) .950 ± .031 (24.13 ± .79) .225 (5.72) #6–32 Unc–2A .125 (3.18) Hex. .156 Hex. (3.96) Figure 1 .290 ± .031 (7.37 ± .79) Figure 2 ø .156 (3.96) Same as Figure 1 except with turret lead Figure 3 Dimensions in inches (mm) Part Number ✝ 51-726-008 I Amp 3 CKT Pi Min Cap 5500 pF In 0.018 Minimum Insertion Loss (dB) 10 1 3 1 10 30 100 300 (mm) MHz MHz MHz MHz MHz MHz GHz GHz 14 30 55 70 70 70 7 (0.46) — A 51-726-017 1 50 — 3 Pi 9000 pF 0.018 (0.46) — 8 18 45 65 70 70 70 54-779-019 1 50 — 10 C 0.10 µF 0.032 (0.81) 22 31 40 44 47 55 65 65 ✝ 54779001X5F100M 1 100 — 10 C 10 pF ± 20% 0.032 (0.81) — — — — — — 10 10 ✝ 54779001X5U102P € 1 100 — 10 C 1000 pF 0.032 (0.81) — — — 10 21 28 28 28 54-779-014 1 100 — 10 C 2700 pF 0.032 (0.81) — — 9 18 27 33 35 35 54-779-016 1 100 — 10 C 0.01 µF 0.032 (0.81) — 9 20 29 38 45 50 50 ✝ 51-726-002 3 100 — 10 LB 0.022 µF 0.032 (0.81) 7 17 27 34 43 50 60 60 54-779-017 1 100 — 10 C 0.027 µF 0.032 (0.81) 10 20 30 37 45 50 55 60 54-779-018 1 100 — 10 C 0.050 µF 0.032 (0.81) 15 24 34 41 45 50 60 60 ✝ 51-726-001 1 200 — 3 Pi 1500 pF 0.018 (0.46) — — 5 15 42 65 70 70 ✝ 1289-001 2 200 — 10 Pi 1500 pF 0.032 (0.81) — — 5 15 40 60 60 60 ✝ 1289-004 2 200 — 10 Pi 3000 pF 0.032 (0.81) — — 8 15 50 65 70 70 1 200 — 10 C 5600 pF 0.032 (0.81) — — 15 24 33 37 40 40 54-779-015 ✝ € Figure 1 Rated Voltage 125°C DC AC 50 — Also available through API’s authorized distributors. Also available through API’s authorized European distributors/agents. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP16 Resin Sealed Bolt-in Filters 8-32 C Circuit .421 ± .031 (10.7 ± .79) .890 ± .031 (22.6 ± .79) .328 ± .031 (8.33 ± .79) ø .040 ± .005 (1.02 ± .13) .140 (3.56) .312 ± .031 (7.92 ± .79) .040 Max. (1.02) ø .032 ± .005 (0.81 ± .13) .093 (2.36) .050 (1.27) #8–32 Unc–2A Thd. .234 (5.94) #8–32 Unc–2A Thd. .187 (4.75) Figure 1 FFigure 2 .466 ± .031 (11.84 ± .79) .293 ± .031 (7.44 ± .79) .266 (6.76) ø .032 ± .005 (0.81 ± .13) .187 Hex. (4.75) .266 (6.77) .631 ± .031 (16.03 ± .79) .130 (3.30) .265 ± .031 (6.73 ± .79) ø .051 ± .005 (1.3 ± .13) .093 (2.39) .050 (1.27) #8–32 Unc–2A Thd. #8–32 Unc–2A Thd. Figure 3 Rated Voltage 125°C DC AC 50 — .187 Hex. (4.75) Figure 4 F I Amp 10 Min Cap 0.05 µF Dimensions in inches (mm) Minimum Insertion Loss (dB) 10 1 3 1 10 30 100 300 MHz MHz MHz MHz MHz MHz GHz GHz 45 50 60 60 41 24 35 15 SCI-9200-503 Figure 2 9950-381-6009 3 50 — 10 0.12 µF 20 30 43 45 55 55 55 55 54-785-017 1 50 — 10 0.21 µF 28 37 45 50 55 60 70 70 9950-381-6008 3 70 — 10 0.08 µF 15 24 37 41 51 51 55 55 ✝ 54713001X5F101M 4 100 — 10 80 pF — — — — — 10 20 20 ✝ 54713001X5U102P 4 100 — 10 1000 pF — — — 11 20 28 28 28 54-785-013 1 100 — 10 0.01 µF — 9 20 29 38 45 50 55 SCI-9210-103 2 100 — 10 0.01 µF — 12 20 29 38 45 50 50 SCI-9210-273 2 100 — 10 0.027 µF 10 20 30 36 45 50 55 60 ✝ 54-785-005 1 100 — 10 0.05 µF 15 24 34 41 45 50 60 60 54-785-016 1 100 — 10 0.1 µF 20 29 38 44 47 55 65 65 54-785-011 1 150 — 10 2000 pF — — 8 17 26 32 34 35 54-785-012 1 150 — 10 5000 pF — 6 15 24 33 37 40 40 SCI-9220-101 2 200 115 10 100 pF — — — — — 10 20 25 SCI-9220-102 2 200 115 10 1000 pF — — — 11 20 28 28 28 SCI-9220-502 2 200 115 10 5000 pF — 6 15 24 33 37 40 40 Part Number ✝ .266 (6.77) .187 (4.75) Hex. Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP17 Resin Sealed Bolt-in Filters 8-32 L & Pi Circuit .600 ± .031 (15.24 ± .79) L ± .031 (L ± .79) .132 ± .031 (3.40 ± .79) .093 (2.36) ø .032 ± .005 (0.81 ± .13) ø .040 ± .005 (1.02 ± .13) .187 (4.75) Ref. H ± .031 (H ± .79) .266 (6.77) .050 (1.27) .500 ± .031 (12.70 ± .79) .320 (8.13) Ref. ø .032 ± .005 (0.81 ± .13) .093 (2.36) .320 ± .031 (8.13 ± .79) .150 (3.81) #8–32 Unc–2A Thd. .336 (8.53) .187 Hex. (4.75) .187 (4.75) Hex. Figure 1 #8–32 Unc-2A Thd. Figure 3 Figure 2 .49 Min. (12.45 Min.) .31 Min. (7.9 Min.) .315 (8.00) Max. ø .032 ± .005 (0.81 ± .13) .187 (4.75) Hex. #8–32 Unc–2A Thd. .238 ± .031 (6.05 ± .79) .906 ± .031 (23.01 ± .79) .150 (3.81) .475 ± .031 (12.06 ± .79) .216 (5.49) ø .040 ± .005 (1.02 ± .13) 18 Awg. .311 ± .031 (7.90 ± .79) .162 ± .031 (4.11 ± .79) .138 (3.51) .062 (1.57) .025 (0.64) ø .032 ± .005 (.81 ± .13) #8–32 Unc–2A Thd. .187 (4.75) Hex. #8–32 Unc–2A Thd. .050 (1.27) Figure 4 .216 (5.49) .187 (4.75) Hex. .187 (4.75) .093 (2.36) #8–32 Unc–2A Thd. Figure 6 Figure 5 Part Number 51-712-069 € ✝ 51-712-065 ✝ 1250-054 Rated Voltage Minimum Insertion Loss (dB) M15733 125°C H L MIL I Min 10 1 3 1 10 30 100 300 Number Fig. DC Cap In AC Amp CKT In (mm) (mm) MHz MHz MHz MHz MHz MHz GHz GHz — 70 70 65 70 45 10 18 2 50 — 9 Pi 0.012 µF 0.265 (6.73) 0.413 (10.49) 5 /61-0014 4 50 — 20 Pi 0.012 µF 0.310 (7.87) 0.490 (12.45) — 10 20 30 65 70 70 70 — 2 70 — 10 Pi 5000 pF 0.312 (7.92) 0.500 (12.70) — — 20 30 65 65 70 70 — 3 70 — 10 Pi 0.028 µF 10 14 38 65 75 75 75 75 51-712-055 /43-0002 2 100 70 10 Pi 3000 pF 0.312 (7.92) 0.578 (14.68) — — 5 15 45 50 50 50 ✝ 51-712-014 /28-0001 2 100 70 10 Pi 3000 pF 0.312 (7.92) 0.890 (22.61) — — 5 15 45 60 60 60 51-712-028 /28-0002 5 100 70 10 Pi 3000 pF — — 5 15 45 60 60 60 ✝ 51-712-063* /61-0008 2 100 70 10 Pi 5500 pF 0.312 (7.92) 0.500 (12.70) — — 15 35 65 70 70 70 ✝ 51-712-003 ◊ — 2 100 — 10 LB 0.022 µF 0.280 (7.11) 0.850 (21.59) 7 17 27 34 43 50 60 60 /28-0004 2 100 70 10 LB 0.022 µF 0.312 (7.92) 0.890 (22.61) 10 17 28 34 41 50 60 60 ✝ 51-712-067 /61-0013 2 100 — 10 LB 0.031 µF 0.280 (7.11) 0.890 (22.61) 10 20 30 38 42 52 60 60 51-762-006 /44-0003 6 125 85 15 Pi 65 pF — — — — — — — — — — 16 42 — 6 125 — 15 Pi 1500 pF — — — — — — 5 15 35 45 60 60 ✝ 51-762-005 /44-0002 6 125 85 15 Pi 1500 pF — — — — — — 5 15 25 35 50 50 1250-062 — 1 125 — 15 Pi 3000 pF — — — — — — 5 15 45 45 70 70 ✝ 51-744-003* /44-0001 1 125 85 15 Pi 3000 pF — — — — — — 10 15 30 40 65 65 ✝ 1293-001 51-712-060 ◊ ✝ 1250-059 ✝ € * Dimensions in inches (mm) — — — — — — — — ✝ SCI-3223-000 — 2 200 115 10 Pi 2000 pF 0.312 (7.92) 0.890 (22.61) — — 8 10 48 50 70 70 ✝ 1250-003 € — 2 200 — 10 Pi 3000 pF 0.312 (7.92) 0.890 (22.61) — — 5 15 45 65 70 70 ✝ 51-712-001* — 2 200 — 10 Pi 3000 pF 0.312 (7.92) 0.890 (22.61) — — 5 15 45 65 70 70 1250-049 — 2 200 — 10 Pi 3000 pF 0.312 (7.92) 0.578 (14.68) — — 5 15 45 65 65 60 ✝ 51-744-002 ◊ — 2 200 — 10 Pi 5500 pF 0.265 (6.73) 0.413 (10.49) — 7 14 30 55 70 70 70 ✝ 1293-000 — 3 200 — 10 Pi 0.012 µF 5 10 28 40 65 70 70 70 — Also available through API’s authorized distributors. Also available through API’s authorized European distributors/agents. Denotes parts with turret lead. — — — ◊ Supplied with .040" (1.02mm) diameter lead. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP18 Resin Sealed Bolt-in Filters 10-32 C & Pi Circuit .421 ± .031 (10.7 ± .79) .328 ± .031 (8.33 ± .79) ø A ± .005 (± .13) .140 (3.56) #10–32 Unf–2A Thd. .218 (5.54) .234 (5.94) Figure 1 .500 ± .031 (12.7 ± .79) .359 ± .031 (9.12 ± .79) ø A ± .005 (± .13) .171 (4.34) #10–32 Unf–2A Thd. .328 (8.33) .218 (5.54) Figure 2 Dimensions in inches (mm) Part Number 51-761-002 ✝ Figure 1 Rated Voltage 125°C DC AC 50 — I Amp 10 CKT Pi Min Cap 0.018 µF In 0.032 Minimum Insertion Loss (dB) 10 1 3 1 10 30 100 300 (mm) MHz MHz MHz MHz MHz MHz GHz GHz 14 30 55 70 70 70 70 (0.81) 7 A ✝ 54-786-013 1 50 — 10 C 0.3 µF 0.040 (1.02) 30 38 47 50 55 60 70 70 54-786-028 1 50 — 10 C 0.56 µF 0.040 (1.02) 35 43 50 52 60 65 70 70 ✝ 54-786-014 2 50 — 10 C 0.8 µF 0.040 (1.02) 40 46 52 54 70 70 70 70 51-761-001 1 100 — 10 Pi 0.01 µF 0.032 (0.81) — 10 20 45 65 70 70 70 54-786-027 1 200 — 10 C 0.1 µF 0.040 (1.02) 20 29 38 44 47 55 65 65 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP19 Resin Sealed Bolt-in Filters 12-28 C /12-32 C Circuit .594 ± .031 (15.08 ± .79) .406 ± .031 (10.36 ± .79) .468 ± .031 (11.89 ± .79) ø .051 ± .005 (1.30 ± .13) .156 (3.96) .406 ± .031 (10.36 ± .79) .140 (3.56) #12–32 Unf–2A Thd. #12–28 Unf–2A Thd. .312 (7.92) .250 (6.35) Figure 2 Figure 1 .921 ± .031 (23.4 ± .79) .343 ± .031 (8.71 ± .79) .157 (3.99) .032 ± .005 (0.81 ± .13) .312 (7.92) .234 (5.54) .250 (6.35) .453 ± .031 (11.51 ± .79) .093 Max. (2.36) .359 ± .031 (9.12 ± .79) .281 (7.14) ø .040 ± .005 (1.02 ± .13) .187 (4.75) .062 (1.57) .250 (6.35) #12–32 Unef–2A Thd. .187 (4.75) .311 (7.9) .312 (7.92) .032 (0.81) #12–32 Unef–2A Thd. Figure 4 Figure 3 Dimensions in inches (mm) I Amp 15 CKT C Min Cap 1 µF Minimum Insertion Loss (dB) 10 1 3 1 10 30 100 300 MHz MHz MHz MHz MHz MHz GHz GHz 70 80 40 52 52 70 78 38 9910-381-6004 Figure 4 9910-381-6003 4 50 — 15 C 0.75 µF 35 37 51 51 61 61 65 70 SCI-9310-273 3 100 — 10 C 0.027 µF 10 20 30 37 45 50 55 60 9910-381-6002 4 100 — 15 C 0.30 µF 28 30 45 50 55 55 60 65 54804002X5R101M 2 250 — 10 C 100 pF ± 20% — — — — — 10 20 25 ✝ 54804002X5R471M 2 250 — 10 C 470 pF ± 20% — — — — 12 22 25 28 ✝ 54804002X5V102P 2 250 — 10 C 1000 pF — — — 10 21 28 28 28 54743001X5U102Z 1 250 — 15 C 1000 pF — — — — 20 28 28 28 Part Number ✝ Rated Voltage 125°C DC AC 35 — Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP20 Resin Sealed Bolt-in Filters 12-28 & 12-32 Pi Circuit .921 ± .031 (23.4 ± .79) .359 ± .031 (9.12 ± .79) .453 ± .031 (11.5 ± .79) .343 ± .031 (8.71 ± .79) .157 (3.99) ø A ± .005 (± .13) .187 (4.75) #12–32 Unef–2A Thd. ø .032 ± .005 (ø .81 ± .13) .093 Max. (2.36) .250 (6.35) #12–32 Unef–2A Thd. .281 (7.14) .311 (7.9) .250 (6.35) .187 (4.75) .032 (0.81) Figure 1 Figure 2 .687 ± .031 (17.4 ± .79) B ± .031 (± .79) ø .250 (ø 6.35) .281 (7.14) ø A ± .005 (± .13) #12–32 Unef–2A Thd. B .187 (4.75) .406 (10.31) Same as Figure 3 Except as Shown. Figure 4 .125 (3.18) Figure 3 Same as Figure 1 Except as Shown. Same as Figure 2 Except as Shown. Turret Lead Figure 7 Figure 6 #12–28 Unf–2A Thd. Figure 5 Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP21 Resin Sealed Bolt-in Filters 12-28 & 12-32 Pi Circuit Part Number 51-709-013 SCI-3303-000* Rated Voltage See M15733 125°C Pg. LP20 MIL I Number for Fig. DC AC Amp — 3 50 — 10 Min Cap 0.1 µF Minimum Insertion Loss (dB) 10 1 3 1 10 30 100 300 In In (mm) (mm) MHz MHz MHz MHz MHz MHz GHz GHz 0.040 (1.02) 0.437 (11.10) 10 40 52 70 70 70 70 70 A B — 2 50 — 10 0.15 µF 0.032 (0.81) 0.250 (6.35) 12 43 68 70 70 70 70 70 /61-0009 3 70 — 10 0.012 µF 0.032 (0.81) 0.470 (11.94) — — — — 65 65 65 65 ✝ 1216-001 — 3 70 — 10 0.050 µF 0.032 (0.81) 0.468 (11.89) 15 20 60 65 75 75 75 75 ✝ 1270-016* — 2 100 — 10 5500 pF 0.032 (0.81) 0.250 (6.35) — 7 20 35 65 70 70 70 ✝ 1270-025 — 2 100 — 10 5500 pF 0.032 (0.81) 0.235 (5.97) — 7 20 35 65 70 70 70 ✝ 1201-066 — 1 100 — 10 5500 pF 0.032 (0.81) — 7 20 40 68 70 70 70 51-714-055* /61-0011 2 100 — 10 5500 pF 0.032 (0.81) 0.235 (5.97) — 7 20 — 65 70 70 70 51-714-054* /61-0010 2 100 — 10 5500 pF 0.032 (0.81) 0.250 (6.35) — 7 20 — 65 70 70 70 51-714-053* /61-0007 2 100 70 10 5500 pF 0.032 (0.81) 0.250 (6.35) — 7 — — 65 70 70 70 51-714-058* — 2 100 — 10 0.025 µF 0.032 (0.81) 0.250 (6.35) 10 15 40 60 70 70 70 70 51-714-056 /61-0012 6 100 — 10 0.025 µF 0.032 (0.81) 0.235 (5.97) — — — — 65 65 65 65 — 2 100 — 10 0.10 µF 0.032 (0.81) 0.250 (6.35) 10 40 65 70 70 70 70 70 — 1 200 — 10 1300 pF 0.040 (1.02) — — — — 5 10 35 60 70 70 ✝ 1201-052 — 5 200 — 10 3000 pF 0.032 (0.81) — — — — 5 15 45 45 70 70 ✝ 1201-054 — 1 200 — 10 3000 pF 0.032 (0.81) — — — — 5 15 45 45 70 70 — 2 200 — 10 3000 pF 0.032 (0.81) 0.250 (6.35) — — 5 15 43 60 70 70 — 2 200 — 10 3000 pF 0.032 (0.81) 0.235 (5.97) — — 5 15 45 45 70 70 — 2 200 — 10 3000 pF 0.032 (0.81) 0.235 (5.97) — — 5 15 43 60 70 70 — 2 200 — 10 3000 pF 0.032 (0.81) 0.250 (6.35) — — 5 15 45 45 70 70 51-719-053** /61-0001 5 200 140 10 3000 pF 0.032 (0.81) — — — — — — 45 — 70 70 51-719-054* /61-0002 1 200 140 10 1500 pF 0.032 (0.81) — — — — — — 45 45 70 70 51-714-051* /61-0005 2 200 140 10 1500 pF 0.032 (0.81) 0.250 (6.35) — — — — 45 45 70 70 51-719-023* /43-0001 5 200 140 10 3000 pF 0.032 (0.81) — — — — — 45 45 45 51-714-052* /61-0006 2 200 140 10 3000 pF 0.032 (0.81) 0.235 (5.97) — — — — 45 45 70 70 51-714-004* — 2 200 — 10 5500 pF 0.032 (0.81) 0.235 (5.97) — 7 14 35 60 70 70 70 ✝ 51-719-021 — 1 200 — 10 5500 pF 0.040 (1.02) — 7 14 30 50 65 65 65 €51-714-002* — 2 200 — 10 5500 pF 0.032 (0.81) 0.250 (6.35) — 7 14 35 60 70 70 70 ✝ SCI-3323-000* — 2 200 115 10 0.012 µF 0.032 (0.81) 0.250 (6.35) — — 27 30 70 70 70 70 51-709-015 ✝ SCI-3313-000* 51-719-022 51-714-001* ✝ 1270-024 51-714-003* ✝ 1270-009 — — — — — — — 4 300 — 10 5500 pF 0.032 (0.81) 0.437 (11.10) — — 15 30 65 70 70 70 ✝ 51-709-004 /46-0001 4 300 — 10 5500 pF 0.032 (0.81) 0.437 (11.10) — — — — 65 70 70 70 1201-086 — 1 350 — 10 2500 pF 0.040 (1.02) — — — — 5 10 50 50 65 65 — 1 500 — 10 3000 pF 0.040 (1.02) — — — — 12 20 45 60 60 60 ✝ 1221-001 ✝ 51-719-011 € ✝ Also available through API’s authorized distributors. € Also available through API’s authorized European distributors/agents. * Denotes parts supplied with lead as shown in Figure 7. ** Bushing housing will have 1 1/2 imperfect threads at hex to thread interface. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP22 Resin Sealed Bolt-in Filters 5/16-24 & 5/16-32 C & Pi Circuit .750 ± .031 (19.05 ± .79) .562 ± .031 (14.27 ± .79) .437 (11.10) .375 (9.53) .250 (6.35) ø .057 ± .005 (1.45 ± .13) .750 ± .031 (19.05 ± .79) 5/16–24 Unf–2A Thd. .562 ± .031 (14.27 ± .79) .437 (11.10) .094 (2.39) .375 (9.53) .250 (6.35) Figure 1 .562 ± .031 (14.27 ± .79) .750 ± .031 (19.05 ± .79) .437 (11.10) ø .057 ± .005 (1.45 ± .13) .375 (9.53) 5/16–32 Unc–2A Thd. .250 (6.35) .094 (2.39) Figure 2 ø .057 ± .005 (1.45 ± .13) 5/16–32 Unef–2A Thd. .220 (5.59) Dimensions in inches (mm) Figure 3 Rated Voltage 125°C DC AC 100 — SCI-9510-503 M15733 MIL Number — Fig. 1 SCI-3513-000 — 1 100 SCI-3523-000 — 1 SCI-3543-000 — 1 SCI-9550-102 — ✝ 1202-052 ✝ 1202-054 Minimum Insertion Loss (dB) 10 1 3 1 10 30 100 300 MHz MHz MHz MHz MHz MHz GHz GHz 41 45 60 60 60 24 35 15 I Amp 25 CKT C Min Cap 0.05 µF — 25 Pi 0.1 µF 10 18 28 37 70 70 70 70 200 115 25 Pi 0.02 µF — — 25 50 66 66 70 70 400 220 25 Pi 6000 pF — — 15 35 54 65 70 70 1 500 115 25 C 1000 pF — — — 11 20 28 28 28 — 1 500 — 25 Pi 3000 pF — — 10 35 55 55 70 70 — 2 500 — 25 Pi 3000 pF — — 10 35 55 55 70 70 51-702-020* /61-0003 3 500 350 25 Pi 3000 pF — — — 35 55 55 70 70 51-702-021 Part Number /61-0004 3 500 350 25 Pi 3000 pF — — 10 35 55 55 70 70 SCI-9550-332 — 1 500 115 25 C 3300 pF — — 12 20 30 33 40 40 SCI-3553-000 — 1 500 220 25 Pi 0.012 µF — — 18 28 52 52 70 70 — 2 700 — 25 Pi 2000 pF — — 5 20 50 55 70 70 ✝ 1202-005 ✝ Also available * Denotes parts through API’s authorized distributors. with 5/16-24 Threads API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP23 Metric Resin Sealed Bolt-in Filters M3 Pi Circuit & M4 C Circuit 0.158 ±0.008 Hex (4.00 ±0.2) 0.197 (5.00) 0.060 (1.52) Max Potting Height 2 Plcs. 0.060 (1.53) Max Potting Height 2 Pl. 0.472 (12.00) ±0.031 0.552 ±0.040 (14.00 ±1.0) 0.125 ±0.008 (3.18 ±0.2) Mounting Surface 0.197 (5.00) Mounting Surface 0.158 ±0.008 (4.0 ±0.2) 1 Imperfect Thread 0.552 ±0.040 (14.00 ±1.0) M4 X 0.7 0.276 (7.00) M3 X 0.5 Thread 0.630 (16.00) ±0.031 0.032 (0.80) 0.354 (9.00) ±0.031 0.31 (0.80) Dimensions in inches (mm) 51-831-004 Figure 1 Rated Voltage 125°C DC 100 I Amp 3 CKT Pi 51-831-011 1 100 10 51-831-012 1 100 10 51-831-013 1 100 51-831-014 1 51-831-015 Min Cap 1000 pF Temperature Range -55°C to +125°C Pi 100 pF -55°C to +125°C Pi 1500 pF -55°C to +125°C 10 Pi 3000 pF -55°C to +125°C 70 10 Pi 5500 pF -55°C to +125°C 1 100 10 Pi 12000 pF -55°C to +125°C 54-863-004 2 100 10 C 10000 pF -55°C to +125°C 54-863-005 2 100 10 C 100 pF -55°C to +125°C 54-863-007 2 100 10 C 1000 pF -55°C to +125°C 54-863-008 2 100 10 C 2000 pF -55°C to +125°C 54-863-010 2 100 10 C 4700 pF -55°C to +125°C Part Number RoHS available. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP24 High Current/High Voltage Resin Sealed Filters High current filters are ideal for use in high current 5 volt logic buss, but also can be used for ±48 VDC telephone rack buss, high current switch mode power supplies and DC charging systems. High voltage filters find use in high voltage power supplies and applications requiring U.L. Hi-Pot. Installation Notes for Figure 1 & 2 — see below (Figure 3 see page CF6) Features ■ Current ratings up to 100 Amps ■ Continuous voltage ratings up to 1250 VDC/240 VAC (400Hz) 1. Mounting installation torque Method A: Mounting in full threaded through-hole Maximum torque: 96 in-lbs ■ U.L. 1459 recognized and CSA C22.2 approved versions available ■ Rugged bolt-in style for easy installation Method B: Mounting w/hardware Maximum torque: 84 in-lbs 2. Terminal installation torque Maximum torque: 20 in-lbs Note: Use two-wrench method to install terminal hardware 1-1/2 Imperfect Thds. 5/16–24 Unf–2A Thd. .250 (6.35) .060 Max., Typ. ø .062 ± .005 (1.58 ± .13) Typ. .250 (6.35) Min. .250 (6.35) .250 (6.35) Min. Typ. . .250 (6.35) Figure 3 .815 ( Hex. .500 (12.7) Hex. .563 ( Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP25 High Current/High Voltage Resin Sealed Filters High Current High Voltage Feed-through 1.000 ± .031 (25.4 ± .79) 1.250 ± .031 (31.8 ± .79) .312 (7.93) .375 (9.53) .250 Flats ø .051 ± .005 (ø 1.30 ± .13) .327 Max. (8.30 Max.) .578 Max. (14.68 Max.) Mounting Surface 5/16–24 Unf–2A Figure 4 .990 ± .031 (25.15 ± .79) .500 (12.7) .325 (8.26) ø .057 ± .005 (ø 1.45 ± .13) .075 (1.91) .740 ± .031 (18.61 ± .79) Mounting Surface 3/8–32unef–2A Thd. .375 (9.53) .500 (12.70) .689 ± .031 (17.5 ± .79) .937 ± .031 (23.8 ± 79) .020 (.51) Figure 5 .125 (3.18) 3/8–32 Unef–2A Thd. Figure 6 Dimensions in inches (mm) Rated Voltage 125°C DC AC*** 60 — I Amp 50 CKT C Min Cap 0.22 µF Minimum Insertion Loss (dB) 10 1 3 1 10 30 100 300 MHz MHz MHz MHz MHz MHz GHz GHz 50 50 40 50 50 50 30 20 54-848-005* Figure 1 54-853-001* 2 60 — 50 C 0.22 µF 20 30 40 50 50 50 50 50 54-853-004 € 2 200 140 100 C 0.22 µF 20 30 40 50 50 50 50 50 54-848-008 1 200 140 100 C 0.22 µF 20 30 40 50 50 50 50 50 54-844-001** 3 600 240 25 C 4700 pF ± 20% — — 12 20 30 33 50 50 54-844-002** 3 600 240 25 C 0.01 µF ± 20% 3 7 20 25 35 40 57 57 54-763-008 4 750 — 25 C 1000 pF — — — 10 20 28 28 28 54-763-009 4 750 — 25 C 4000 pF — — 10 22 32 35 35 40 54-789-003 5 1250 — 25 C 4000 pF — — 6 20 30 35 35 35 ✝ 1280-060 € 6 2500 — 25 Pi 1500 pF — — 5 15 50 50 50 50 Part Number ✝ Also available through API’s authorized distributors. € Also available through API’s authorized European distributors/agents. * Denotes parts that are UL recognized to UL 60950 and certified to CSA C22.2 ** Denotes parts that meet 1500 VAC Dielectric Withstanding Voltage per UL 1283 *** AC Voltage to be 400Hz and CSA C22.2 API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP26 Hermetically Sealed Threaded Case Filters This series of filters features hermetic glass seals and high EMI filtering performance. They are excellent for critical applications that demand high reliability in the toughest environmental conditions and provide broadband high performance EMI filtering from 10 KHz to over 10 GHz. Features ■ ■ ■ ■ ■ ■ ■ MIL-F-15733 and MIL-F-28861, DSCC 84084 QPL filters available Popular .375", .410" and .690" case diameters Voltage ratings from 50 V to 400 VDC/240 AC, 400 Hz Impervious to high moisture environments, solvents and severe environmental conditions High temperature terminal construction D-slotted bushings High reliability testing available Thread length: A - 0.187 (4.76) B - 0.312 (7.92) L .200 (5.08) A/B .160 (4.064) Max. ø .385 Max. (9.78) 1/4–28 Unf–2A Thd. .050 (1.27) x .070 (1.78) Slot, both ends .176 (4.47) L Figure 1 A/B .160 (4.064) Max. ø .385 Max. (9.78) .115 Ref. (2.92) #12–32 Unef–2A Thd. Note: ø .410 Max. for M28861 parts .050 (1.27) x .070 (1.78) Slot, both ends Figure 2 Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP27 Hermetically Sealed Threaded Case Filters .375 ø C Circuit Standard See Pg. MIL LP26 No for Fig. — 1 Rated Voltage 85°C 125°C DC AC DC AC 80 — 50 — 54-370-007 — 1 80 — 50 — 15 2.800 0.005 0.576 (14.630) A 20 34 39 50 60 70 70 54-371-001 — 1 80 — 50 — 15 4.000 0.005 0.688 (17.475) A 26 40 46 55 60 70 70 54-367-005 — 1 150 — 100 — 15 0.450 0.005 0.387 (9.830) A 6 19 25 36 55 70 70 — 1 200 — 150 125 15 0.150 0.005 0.387 (9.830) A — 6 15 26 42 55 70 54-367-007 — 1 250 — 200 125 15 0.015 0.005 0.387 (9.830) A — — — 6 25 45 50 ✝ 54-367-006 — 1 250 — 200 125 15 0.250 0.005 0.387 (9.830) A — 14 19 30 50 65 70 54-370-006 — 1 250 — 200 125 15 0.500 0.005 0.630 (16.002) A 7 20 28 39 55 70 70 9923-100-6004 — 1 400 — 400 240 15 0.060 0.005 0.415 (10.541) A — 5 10 18 38 55 70 Part Number ✝ 54-367-008 ✝ 9920-100-6002 .375 ø C Circuit MIL Qualified M15733 See Pg. M28861◊ LP26 Part Number MIL No for Fig. 1 54-367-054 1-012◊ Minimum Insertion Loss (dB) DCR Max Max Thd 30 150 300 L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.005 0.387 (9.830) A 15 28 33 44 60 70 70 (See MIL index on pages CF9-11 for complete MIL part number listing) Min Cap I Amp µF 15 1.200 Minimum Insertion Loss (dB) DCR Max Max Thd 30 150 300 L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.008 0.410 (10.414) B 40 70 28 33 70 15 40 1-002◊ 1 — — 50 — 15 1.200 0.008 0.410 (10.414) A 15 28 33 40 40 70 70 54-370-032 49-0008 1 — — 50 — 15 2.100 0.010 0.576 (14.630) A 20 33 40 50 65 70 70 1-014◊ 1 — — 70 — 15 0.700 0.008 0.410 (10.414) B 10 24 30 40 40 64 70 54-370-030 34-0035 2 — — 100 — 10 0.300 0.004 0.474 (12.040) A 7 19 25 35 55 70 70 54-367-051 1-006◊ 1 — — 100 — 15 0.450 0.008 0.410 (10.414) A 6 19 25 36 40 60 70 54-367-056 1-016◊ 1 — — 100 — 15 0.450 0.008 0.410 (10.414) B 6 19 25 36 40 60 70 54-367-057 1-018◊ 1 — — 150 — 15 0.250 0.008 0.410 (10.414) B — 14 20 31 40 56 70 54-367-053 1-010◊ 1 — — 200 125 15 0.150 0.008 0.410 (10.414) A — 10 16 26 40 52 70 54-367-058 1-020◊ 1 — — 200 125 15 0.150 0.008 0.410 (10.414) B — 10 16 26 40 52 70 54-370-034 49-0010 1 — — 330 — 15 0.062 0.004 0.680 (17.272) A — 2 7 17 37 55 70 54-367-049 54-367-055 ✝ Rated Voltage 85°C 125°C DC AC DC AC 50 — — — Min Cap I Amp µF 15 1.400 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP28 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End .375 ø L Circuit Thread length: A - 0.187 (4.76) B - 0.312 (7.92) L .200 (5.08) A/B 1/4–28 Unf–2A Thd. .160 (4.064) Max. .200 (5.08) .347 (8.814) ø .385 Max. (9.78) .050 (1.27) x .070 (1.78) Slot, both ends .080 (2.032) Max. 1/4–28 Unf–2A Thd. 1/4–28 Unf–2A Thd. Figure 1 .200 (5.08) .467 (11.86) Max. Note: ø .410 Max. for M28861 parts ø .040 ± .001 (1.02 ± .025) ø .410 (10.41) Max. A/B L Figure 2 Resin Sealed Not Hermetically Sealed ø .040 ± .001 (1.02 ± .025) Typ. L A/B .200 (5.08) 1/4–28 Unf–2A Thd. ø .410 (10.41) Max. Figure 3 .200 (5.08) 1/4–28 Unf–2A Thd. #16Awg, .051 (1.30) ø ø .040 (1.02) A/B L ø .385 (9.78) Max. .343 (8.712) Max. L A/B .250 ± .030 (6.35 ± 0.8) ø .385 (9.78) Max. Figure 5 Dimensions in inches (mm) Figure 4 .375 ø L Standard Low Profile Rated Voltage Min I Cap 85°C 125°C MIL µF No Figure DC AC DC AC Amp 50 — — 80 — 15 1.200 1 Minimum Insertion Loss (dB) DCR Max Max Thd 30 150 300 L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz A 0.005 LB 0.370 (9.398) 60 25 34 44 15 70 70 ✝ 51-359-001 € — 1 80 — 50 — 15 1.400 0.005 LB 0.370 (9.398) A 15 28 33 44 60 70 70 SCI-1021-000 — 2* 80 — 50 — 15 1.400 0.003 LB 0.280 (7.112) A 15 28 33 44 60 70 70 ✝ 9053-100-0001 — 1 80 — 50 — 15 1.400 0.005 LB 0.370 (9.398) A 15 25 34 44 60 70 70 ✝ 51-717-001 € — 2* 80 — 50 — 15 1.400 0.005 LB 0.325 (8.255) A 15 28 33 44 60 70 70 Part Number ✝ 9051-100-0000 51-344-006 — 4 80 — 50 — 15 1.400 0.005 LB 0.330 (8.382) A 15 28 33 44 60 70 70 ✝ SCI-1020-000 — 1 80 — 50 — 15 1.400 0.003 LB 0.370 (9.398) A 15 28 33 44 60 70 70 SCI-1021-020 — 2 ◊* 80 — 50 — 15 1.400 0.003 LB 0.280 (7.112) B 15 28 33 44 60 70 70 ✝ SCI-1020-020 — 1 80 — 50 — 15 1.400 0.003 LB 0.370 (9.398) B 15 28 33 44 60 70 70 SCI-1150-001 — 1 80 — 50 — 15 2.800 0.003 LB 0.450 (11.430) B 20 34 40 49 60 70 70 9051-101-0018 — 5 80 — 50 — 25 1.400 0.001 LB 0.450 (11.430) A 15 25 34 44 60 70 70 ✝ 9053-100-0008 — 1 100 — 70 — 15 0.700 0.005 LB 0.370 (9.398) A 9 20 29 39 52 70 70 * Part is resin sealed, this is not a hermetic part. Also available through API’s authorized distributors. Also available through API’s authorized European distributors/agents. ✝ € ◊ Note: 0.462" (11.73mm) length from mounting surface to end of lead — not 0.347" (8.8mm). API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP29 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End .375 ø L Standard Low Profile continued Rated Voltage Min See Pg. I Cap 85°C 125°C MIL LP28 Part Number µF No for Fig DC AC DC AC Amp 100 — 70 — 15 0.750 2* ✝ 9050-100-0008 — Minimum Insertion Loss (dB) DCR Max Max Thd 30 150 300 L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.005 LB 0.325 (8.255) A 70 70 39 52 9 20 29 ✝ 9053-100-0002 — 1 150 — 100 — 15 0.500 0.005 LB 0.370 (9.398) A 4 12 21 31 48 70 70 SCI-1250-001 — 1 150 — 100 — 15 0.500 0.003 LB 0.450 (11.430) B 8 20 25 34 50 64 70 €SCI-2150-000 — 1 150 — 100 — 15 1.000 0.003 LB 0.450 (11.430) A 10 25 30 41 56 70 70 SCI-2150-001 — 100 — — 1 150 15 1.000 0.003 LB 0.450 (11.430) B 10 25 30 41 56 70 70 ✝ 51-717-007 — 2* 250 125 200 125 15 0.015 0.005 LB 0.325 (8.255) A — — — 6 25 38 45 ✝ 51-359-007 — 1 250 125 200 125 15 0.012 0.005 LB 0.370 (9.398) A — — — 6 25 38 50 — 2 350 125 300 125 15 0.150 0.008 LB 0.325 (8.255) A — 10 15 25 40 52 60 €SCI-2350-000 — 1 300 125 300 125 15 0.250 0.003 LB 0.450 (11.430) A 4 15 21 31 50 70 70 SCI-2350-001 — 1 300 125 300 125 15 0.250 0.003 LB 0.450 (11.430) B 4 15 21 31 50 70 70 9050-100-0011 * Part is resin sealed, this is not a hermetic part. (See MIL index on pages CF9-11 for complete MIL part number listing) .375 ø L Circuit MIL Qualified Low Profile Rated Voltage Min M15733 See Pg. I Cap 85°C 125°C M28861◊ LP28 Part Number MIL No for Fig DC AC DC AC Amp µF 50 — — 10 1.400 1 ✝ 51-359-021 38-0004 ✝ € Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz A 0.008 LB 0.370 (9.398) 60 44 33 28 15 70 70 ✝ 51-359-024 38-0005 1 80 — 50 — 10 1.400 0.008 LB 0.370 (9.398) A 15 28 33 44 60 70 70 ✝ 51-359-051 58-0001 1 80 — 50 — 10 1.400 0.008 LB 0.545 (13.843) A 15 28 33 44 60 70 70 51-359-105 58-0004 1 80 — 50 — 10 1.400 0.008 LT 0.545 (13.843) B 15 28 33 44 60 70 70 ✝ 51-359-044 49-0006 1 100 — 50 — 15 1.200 0.010 LB 0.370 (9.398) A 15 28 33 44 60 70 70 ✝ 51-359-055 49-0007 3 100 — 50 — 15 1.200 0.010 LB 0.450 (11.43) A 15 28 33 44 60 70 70 51-359-081 1-001◊ 1 — — 50 — 15 1.400 0.008 LB 0.410 (10.414) A 15 28 33 40 40 70 70 51-359-086 1-011◊ 1 — — 50 — 15 1.400 0.008 LB 0.410 (10.414) B 15 28 33 40 40 70 70 ✝ 51-359-053 49-0001 4 100 — 50 — 15 0.680 0.010 LB 0.319 (8.103) A 8 20 28 38 55 70 70 51-359-082 1-003◊ 1 — — 70 — 15 0.700 0.008 LB 0.410 (10.414) A 10 24 30 40 40 64 70 51-359-083 1-005◊ 1 — — 100 — 15 0.450 0.008 LB 0.410 (10.414) A 6 19 25 36 40 60 70 51-359-088 1-015◊ 1 — — 100 — 15 0.450 0.008 LB 0.410 (10.414) B 6 19 25 36 40 60 70 51-359-084 1-007◊ 1 — — 150 — 15 0.250 0.008 LB 0.410 (10.414) A — 14 20 31 40 56 70 51-359-050 38-0008 1 — — 200 125 15 0.150 0.008 LB 0.370 (9.398) A — — — 6 25 42 60 51-359-085 1-009◊ 1 — — 200 125 15 0.150 0.008 LB 0.410 (10.414) A — 10 16 26 40 52 70 51-359-090 1-019◊ 1 — — 200 125 15 0.150 0.008 LB 0.410 (10.414) B — 10 16 26 40 52 70 Also available through API’s authorized distributors. Also available through API’s authorized European distributors/agents. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP30 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End .375 ø L Circuit L .200 (5.08) A/B .160 (4.064) Max. .200 (5.08) L .190 Max. (3.81) ø .385 Max. (9.78) .050 (1.27) x .070 (1.78) Slot, both ends 1/4–28 Unf–2A Thd. .150 (3.81) Max. A/B ø .385 Max. (9.78) Figure 1 .115 Ref. (2.92) Thread length: A - 0.187 (4.76) B - 0.312 (7.92) Note: ø .410 Max. for M28861 parts 1/4–28 Unf–2A Thd. ø .060 (1.524) Ref. Both ends F Dimensions in inches (mm) .375 ø L Circuit Standard Product Part Number 51-353-007 51-353-095 — 1 80 — 50 — 0.15 1.400 12.000 LT 0.960 (24.384) A 21 52 64 70 70 70 70 51-353-003 — 1 80 — 50 — 0.45 1.400 1.200 LB 0.770 (19.558) A 16 31 37 55 70 70 70 51-353-099 — 1 80 — 50 — 1.00 1.400 0.250 LT 0.770 (19.558) A 16 33 44 70 70 70 70 LT 0.770 (19.558) A 15 28 33 46 70 70 70 LB 0.450 (11.430) A 15 28 33 44 60 70 70 51-353-100 ✝ 9200-300-0025 ✝ Rated Voltage Minimum Insertion Loss (dB) DCR Max Min Max Thd 30 150 300 I L Cap 85°C 125°C MIL 1 1 10 100 Ohms CKT µF No Figure DC AC DC AC Amp In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz — 80 — 50 — 0.06 1.400 70.000 LB 0.770 (19.558) A 44 70 70 70 70 70 70 1 — 1 80 — 50 — 1.400 0.015 — 1 80 — 50 — 10.00 1.200 0.010 5.00 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP31 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End .375 ø L Circuit Standard Product continued Rated Voltage Min See Pg. I Cap 85°C 125°C MIL LP30 Part Number µF No for Fig DC AC DC AC Amp 80 — 50 — 10.00 1.200 1 ✝ 9200-303-0095 — Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.010 LB 0.450 (11.430) B 44 60 33 15 28 70 70 51-353-101 — 1 80 — 50 — 10.00 1.400 0.010 LT 0.450 (11.430) A 14 28 33 44 60 70 70 51-353-109 — 1 80 — 50 — 10.00 1.400 0.010 LT 0.450 (11.430) B 15 28 33 44 60 70 70 51-353-120 — 1 150 — 100 — 1.00 0.750 0.250 LB 0.758 (19.253) A 9 27 36 57 70 70 70 9000-103-0019 — 1 150 — 100 — 5.00 0.450 0.015 LT 0.758 (19.253) B 6 20 26 37 68 70 70 SCI-2120-014 — 1 150 — 100 — 10.00 1.000 0.003 LB 0.450 (11.430) B 14 28 34 44 52 70 70 51-353-110 — 1 250 — 200 125 1.00 0.250 0.250 LT 0.758 (19.253) A — 17 29 50 70 70 70 ✝ 51-353-111 — 1 250 — 200 125 1.00 0.250 0.250 LB 0.758 (19.253) A — 17 29 50 70 70 70 51-353-112 — 1 250 — 200 125 3.00 0.250 0.050 LT 0.758 (19.253) A — 13 20 35 70 70 70 ✝ 51-353-113 — 1 250 — 200 125 3.00 0.250 0.050 LB 0.758 (19.253) A — 13 20 35 70 70 70 51-353-114 — 1 250 — 200 125 5.00 0.250 0.015 LT 0.758 (19.253) A — 12 20 30 62 70 70 51-353-116 — 1 250 — 200 125 10.00 0.250 0.010 LT 0.450 (11.430) A — 15 20 30 50 70 70 SCI-2320-010 — 1 300 — 300 125 0.50 0.150 1.000 LB 0.758 (19.253) B — 23 35 56 70 70 70 SCI-2320-004 — 1 300 — 300 125 1.00 0.150 0.250 LB 0.758 (19.253) A — 10 21 41 70 70 70 SCI-2320-005 — 1 300 — 300 125 2.00 0.150 0.063 LB 0.758 (19.253) A — 8 14 30 70 70 70 SCI-2320-006 — 1 300 — 300 125 3.00 0.150 0.027 LB 0.758 (19.253) A — 8 14 26 64 70 70 SCI-2320-007 — 1 300 — 300 125 10.00 0.150 0.003 LB 0.450 (11.430) A — 8 14 25 45 52 70 SCI-2320-014 — 1 300 — 300 125 10.00 0.150 0.003 LB 0.450 (11.430) B — 8 14 25 45 52 70 (See MIL index on pages CF9-11 for complete MIL part number listing) .375 ø L Circuit MIL Qualified Profile Rated Voltage Min M15733 See Pg. I Cap LP30 85°C 125°C MIL Part Number µF for Fig DC AC DC AC Amp No — — 50 — 0.50 1.400 1 51-390-018 23-0026 ✝ Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.360 LB 0.630 (16.002) A 70 70 70 12 36 48 69 51-390-026 23-0038 1 — — 50 — 1.00 1.400 0.140 LB 0.630 (16.002) A 11 26 36 55 70 70 70 51-390-034 23-0050 1 — — 50 — 2.00 1.400 0.070 LB 0.630 (16.002) A 10 24 32 48 70 70 70 ✝ 51-353-067 24-0006 1 80 — 50 — 10.00 1.400 0.010 LB 0.760 (19.304) B 15 28 31 42 56 70 70 51-353-207 34-0007 1 — — 50 — 10.00 1.400 0.010 LB 0.760 (19.304) A 15 28 31 42 56 70 70 51-444-072 58-0002 1 80 — 50 — 10.00 1.400 0.008 LT 0.545 (13.843) A 15 28 33 44 60 70 70 ✝ 51-353-066 24-0005 1 80 — 50 — 10.00 1.400 0.010 LB 0.760 (19.304) A 15 28 31 42 56 70 70 51-353-287 39-0014 1 — — 50 — 10.00 1.400 0.003 LT 0.760 (19.304) B 14 28 34 44 52 70 70 ✝ 51-444-060 24-0008 1 80 — 50 — 10.00 1.400 0.010 LT 0.740 (18.796) B 15 28 31 42 56 70 70 ✝ 51-343-028 38-0002 1 — — 50 — 15.00 1.400 0.008 LB 0.481 (12.217) A 15 28 33 44 64 70 70 ✝ 51-343-034 38-0006 1 — — 50 — 15.00 1.400 0.008 LB 0.481 (12.217) B 15 28 33 44 64 70 70 51-353-053 25-0003 1 — — 100 — 1.00 0.450 0.250 LB 0.738 (18.745) A 6 23 34 55 70 70 70 ✝ 51-353-054 25-0005 1 — — 100 — 5.00 0.450 0.015 LT 0.758 (19.253) A 6 17 23 35 69 70 70 ✝ 51-353-055 25-0008 1 — — 100 — 5.00 0.450 0.015 LB 0.738 (18.745) A 6 17 23 35 69 70 70 51-353-155 39-0008 1 — — 100 — 5.00 0.450 0.015 LB 0.760 (19.304) A 6 20 26 35 60 60 70 51-444-039 25-0017 1 — — 100 — 5.00 0.450 0.015 LT 0.758 (19.253) B 6 17 23 35 69 70 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP32 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End .375 ø L Circuit MIL Qualified Profile Rated Voltage Min M15733 See Pg. I Cap LP30 85°C 125°C MIL Part Number µF for Fig DC AC DC AC Amp No — — 100 5.00 0.450 1 51-444-040 25-0020 ✝ continued (See MIL index on pages CF9-11 for complete MIL part number listing) Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.015 LB 0.738 (18.745) B 70 70 69 23 6 17 35 51-353-156 39-0009 1 — — 100 10.00 0.450 0.003 LT 0.760 (19.304) A 6 20 26 35 56 60 70 51-353-157 39-0010 1 — — 100 10.00 0.450 0.003 LB 0.760 (19.304) A 6 20 26 35 56 60 70 ✝ 51-353-076 26-0001 1 — — 150 125 1.00 0.250 0.250 LT 0.758 (19.253) A — 13 24 45 80 70 70 ✝ 51-353-077 26-0003 1 — — 150 125 1.00 0.250 0.250 LB 0.738 (18.745) A — 13 24 45 80 70 70 51-444-043 26-0013 1 — — 150 125 1.00 0.250 0.250 LT 0.758 (19.253) B — 13 24 45 80 70 70 51-444-044 26-0015 1 — — 150 125 1.00 0.250 0.250 LB 0.738 (18.745) B — 13 24 45 80 70 70 51-390-040 23-0058 1 — — 150 2.00 0.250 0.070 LT 0.630 (16.002) A 3 15 23 38 60 70 60 51-390-039 23-0057 1 — — 150 2.00 0.250 0.070 LT 0.630 (16.002) B 3 15 23 38 60 70 60 51-444-005 34-0015 1 — — 150 125 3.00 0.150 0.050 LT 0.758 (19.253) B — 8 15 30 68 70 70 ✝ 51-353-078 26-0004 1 — — 150 125 3.00 0.250 0.050 LT 0.758 (19.253) A — 8 15 30 68 70 70 ✝ 51-353-079 26-0006 1 — — 150 125 3.00 0.250 0.050 LB 0.738 (18.745) A — 8 15 30 68 70 70 ✝ 51-444-046 26-0018 1 — — 150 125 3.00 0.250 0.050 LB 0.738 (18.745) B — 8 15 30 68 70 70 51-444-047 26-0019 1 — — 150 125 5.00 0.250 0.015 LT 0.758 (19.253) B — 8 14 25 58 70 70 ✝ 51-353-080 26-0007 1 — — 150 125 5.00 0.250 0.015 LT 0.758 (19.253) A — 8 14 25 58 70 70 51-353-081 26-0010 1 — — 150 125 5.00 0.250 0.015 LB 0.738 (18.745) A — 8 14 25 58 70 70 51-444-027 34-0030 1 — — 200 125 5.00 0.250 0.150 LB 0.900 (22.860) A 2 15 21 32 60 70 70 51-444-117 54-0018 2 — — 300 125 1.00 0.150 0.250 LB 0.740 (18.796) A — 10 21 41 70 70 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP33 Hermetically Sealed Threaded Case Filters .375 ø Pi Circuit Thread length: A - 0.187 (4.76) B - 0.312 (7.92) L A/B .160 (4.064) Max. .200 (5.08) ø .385 Max. (9.779) .115 Ref. (2.921) .050 (1.27) x .070 (1.78) Slot, both ends A/B L .200 (5.08) Max. .150 (3.81) Max. 1/4–28 Unf–2A Thd. Figure 1 ø .385 Max. (9.779) .062 (1.52) ø Hole Both ends 1/4–28 Unf–2A Thd. .115 Ref. (2.92) Figure 2 Dimensions in inches (mm) .375 ø Pi Circuit Standard Product MIL No Figure — 2 Rated Voltage 85°C 125°C DC AC DC AC 50 — 80 — SCI-2030-004 — 2 80 — 50 SCI-2030-005 — 2 80 — 50 SCI-2030-006 — 2 80 — SCI-2030-013 — 2 80 — ✝ 9001-100-1080 — 1 80 ✝ 9001-100-1081 — 1 SCI-2130-009 — 51-311-319 Min Cap I Amp µF 0.50 1.500 Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 1.000 0.758 (19.253) B 70 70 70 70 70 66 24 — 1.00 1.500 0.250 0.758 (19.253) A 15 54 70 70 70 70 70 — 2.00 1.500 0.063 0.758 (19.253) A — 45 62 70 70 70 70 50 — 3.00 1.500 0.027 0.758 (19.253) A — 35 55 70 70 70 70 50 — 3.00 1.500 0.027 0.758 (19.253) B — 35 55 70 70 70 70 — 50 — 5.00 2.800 0.015 0.758 (19.253) A — 18 60 70 70 70 70 80 — 50 — 10.0 2.800 0.005 0.758 (19.253) A 21 32 40 35 68 70 70 1 150 — 100 — 0.25 1.000 4.000 0.758 (19.253) B 28 70 70 70 70 70 70 — 1 150 — 100 — 0.50 1.000 0.600 0.758 (19.253) A — 51 69 70 70 70 70 — 1 150 — 100 — 0.50 1.000 0.600 0.758 (19.253) A 6 39 68 70 70 70 70 — 1 150 — 100 — 1.00 1.000 0.250 0.758 (19.253) A — 41 60 70 70 70 70 — 1 150 — 100 — 1.00 1.000 0.250 0.758 (19.253) A — 28 59 70 70 70 70 51-311-321 — 1 150 — 100 — 3.00 1.000 0.060 0.758 (19.253) A — 16 41 70 70 70 70 ✝ 51-311-322 — 1 150 — 100 — 5.00 1.000 0.015 0.758 (19.253) A — — 28 65 70 70 70 SCI-2130-007 — 1 150 — 100 — 10.0 1.000 0.003 0.758 (19.253) A 9 24 29 40 70 70 70 SCI-2130-014 — 1 150 — 100 — 10.0 1.000 0.005 0.758 (19.253) B 9 24 29 40 70 70 70 51-311-316 — 1 250 125 200 125 1.00 0.300 0.250 0.758 (19.253) A — 20 40 70 70 70 70 51-311-317 — 1 250 125 200 125 3.00 0.300 0.050 0.758 (19.253) A — — 20 55 70 70 70 ✝ 9001-100-1025 — 1 250 125 200 125 5.00 0.300 0.015 0.758 (19.253) A — — 12 50 70 70 80 SCI-2330-009 — 1 300 125 300 125 0.25 0.300 4.000 0.758 (19.253) B 8 50 66 70 70 70 70 SCI-2330-010 — 1 300 125 300 125 0.50 0.300 1.000 0.758 (19.253) B — 40 56 70 70 70 70 SCI-2330-012 — 1 300 125 300 125 2.00 0.300 0.063 0.758 (19.253) B — 18 33 63 70 70 70 SCI-2330-007 — 1 300 125 300 125 10.0 0.300 0.003 0.758 (19.253) A — 14 20 30 70 70 70 Part Number SCI-2030-010 ✝ 9001-100-1010 51-311-320 ✝ 9001-100-1013 ✝ Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP34 Hermetically Sealed Threaded Case Filters (See MIL index on pages CF9-11 for complete MIL part number listing) .375 ø Pi Circuit MIL Qualified Product See Pg. M15733 LP33 Part Number MIL No for Fig. 1 51-390-305 23-0017 ✝ Rated Voltage 85°C 125°C DC AC DC AC — — 50 — Min Cap I Amp µF 0.30 2.800 Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.770 0.730 (18.542) B 80 80 80 80 29 73 80 51-390-314 23-0042 1 — — 50 — 1.00 2.800 0.140 0.730 (18.542) A 8 52 71 80 80 80 80 ✝ 51-390-318 23-0054 1 — — 50 — 2.00 1.500 0.070 0.730 (18.542) A — 46 65 80 80 80 80 ✝ 51-390-317 23-0053 1 — — 50 — 2.00 1.500 0.070 0.730 (18.542) B — 46 65 80 80 80 80 51-311-311 25-0010 1 — — 100 — 0.25 0.900 1.500 0.793 (20.142) A — 48 66 80 80 80 70 ✝ 51-311-308 25-0002 1 — — 100 — 1.00 0.500 0.250 0.793 (20.142) A — 33 52 80 80 80 70 ✝ 51-311-309 25-0004 1 — — 100 — 3.00 0.660 0.050 0.793 (20.142) A — 17 34 68 80 80 70 ✝ 51-311-310 25-0006 1 — — 100 — 5.00 0.900 0.015 0.793 (20.142) A — — 17 57 80 80 70 51-353-344 39-0011 1 — — 100 — 10.0 0.990 0.003 0.760 (19.304) A 9 24 29 40 70 70 70 51-353-345 39-0012 1 — — 100 — 10.0 0.990 0.003 0.760 (19.304) A 9 24 29 40 70 70 70 ✝ 51-311-314 26-0011 1 — — 150 125 0.25 0.300 1.500 0.793 (20.142) A — 29 47 70 80 80 70 51-390-312 23-0036 1 — — 150 — 0.50 0.500 0.360 0.730 (18.542) A — 48 66 70 70 70 70 51-390-311 23-0035 1 — — 150 — 0.50 0.500 0.360 0.730 (18.542) B — 48 66 70 70 70 70 ✝ 51-353-336 26-0002 1 — — 150 125 1.00 0.300 0.250 0.793 (20.142) A — 11 32 63 80 80 70 51-390-315 23-0047 1 — — 150 — 1.00 0.500 0.140 0.730 (18.542) B — 32 51 70 70 70 70 51-311-312 26-0005 1 — — 150 125 3.00 0.300 0.050 0.793 (20.142) A — 5 6 47 80 80 70 51-311-408 54-0005 2 — — 300 115 1.00 0.300 0.250 0.761 (19.329) A — 23 43 70 70 70 70 Also available through API’s authorized distributors. Transient Suppression Pi Filters Transient Suppressor* Minimum Insertion Loss (dB) Max See Pg. Rated Max DCR Min Thd 30 300 Length LP33 Volt. 1 RDC VR* Min Cap I BV* IT* IPP* 1 10 100 for Fig. VDC Amp In (mm) Lgth KHz KHz MHz MHz MHz GHz µF Mohms Ohms (VDC) (VDC) (MA) (A) 70 70 70 57 1 5 23 51-570-300 0.50 1.400 0.500 0.600 6.5 7.22/7.98 10 44.7 1.179 (29.947) A 70 Part Number 51-570-301 1 5 1.00 1.400 0.500 0.350 6.5 7.22/7.98 10 44.7 1.179 (29.947) A 3 47 70 70 70 70 51-570-302 1 5 3.00 1.400 0.500 0.060 6.5 7.22/7.98 10 44.7 1.179 (29.947) A — 23 58 70 70 70 51-570-303 1 5 5.00 1.400 0.500 0.015 6.5 7.22/7.98 10 44.7 1.179 (29.947) A — 17 48 70 70 70 51-570-304 1 5 10.00 1.400 0.500 0.005 6.5 7.22/7.98 10 44.7 1.179 (29.947) A 16 26 35 40 60 70 51-570-310 1 28 0.50 1.400 30.000 0.600 33.0 36.7/40.6 1 9.4 1.179 (29.947) A 23 57 70 70 70 70 51-570-311 1 28 1.00 1.400 30.000 0.350 33.0 36.7/40.6 1 9.4 1.179 (29.947) A 3 47 70 70 70 70 51-570-312 1 28 3.00 1.400 30.000 0.060 33.0 36.7/40.6 1 9.4 1.179 (29.947) A — 23 58 70 70 70 51-570-313 1 28 5.00 1.400 30.000 0.015 33.0 36.7/40.6 1 9.4 1.179 (29.947) A — 17 48 70 70 70 51-570-314 1 28 10.00 1.400 30.000 0.005 33.0 36.7/40.6 1 9.4 1.179 (29.947) A 16 26 35 40 60 70 51-570-320 1 50 0.50 1.400 50.000 0.600 58.0 64.4/71.2 1 5.3 1.179 (29.947) A 23 57 70 70 70 70 51-570-321 1 50 1.00 1.400 50.000 0.350 58.0 64.4/71.2 1 5.3 1.179 (29.947) A 3 47 70 70 70 70 51-570-322 1 50 3.00 1.400 50.000 0.060 58.0 64.4/71.2 1 5.3 1.179 (29.947) A — 23 58 70 70 70 51-570-323 1 50 5.00 1.400 50.000 0.015 58.0 64.4/71.2 1 5.3 1.179 (29.947) A — 17 48 70 70 70 51-570-324 1 50 10.00 1.400 50.000 0.005 58.0 64.4/71.2 1 5.3 1.179 (29.947) A 16 26 35 40 60 70 * Transient Suppression definitions and ratings VR = Reverse standoff voltage BV = Breakdown voltage IPP = Max. peak pulse current IT = Test current API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP35 Hermetically Sealed Threaded Case Filters .375 ø T Circuit Thread length: A - 0.187 (4.76) B - 0.312 (7.92) L .200 (5.08) A/B .160 (4.064) Max. ø .385 Max. (9.78) .115 Ref. (2.92) .050 (1.27) x .070 (1.78) Slot, both ends 1/4–28 Unf–2A Thd. Figure 1 Dimensions in inches (mm) Note: Max. O.D. is ø .416" for Military QPL Filters. .375 ø T Circuit Standard Product Part Number SCI-2040-012 ✝ MIL No Figure — 1 Rated Voltage 85°C 125°C DC AC DC AC 80 — 50 — Min Cap I Amp µF 2.00 1.400 Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.126 1.071 (27.203) B 55 70 70 70 30 8 22 SCI-2040-013 — 1 80 — 50 — 3.00 1.400 0.054 1.071 (27.203) B 8 22 28 43 70 70 70 ✝ 9004-100-2017 — 1 80 — 50 — 15.0 1.400 0.005 1.179 (29.947) A 17 27 34 44 60 70 70 SCI-2140-004 — 1 150 — 100 — 1.00 0.500 0.500 1.070 (27.178) A 4 25 40 70 70 70 70 SCI-2140-006 — 1 150 — 100 — 3.00 0.500 0.054 1.071 (27.203) A 4 19 24 39 70 70 70 SCI-2140-007 — 1 150 — 100 — 10.0 0.500 0.010 1.071 (27.203) A 4 19 24 34 57 70 70 SCI-2340-009 — 1 300 — 300 125 0.25 0.150 8.000 1.071 (27.203) B 11 57 70 70 70 70 70 SCI-2340-004 — 1 300 — 300 125 1.00 0.150 0.500 1.071 (27.203) A — 13 29 59 70 70 70 SCI-2340-013 — 1 300 — 300 125 3.00 0.150 0.054 1.071 (27.203) B — 8 14 29 70 70 70 SCI-2340-014 — 1 300 — 300 125 10.0 0.150 0.010 1.071 (27.203) B — 8 14 24 47 70 70 Also available through API’s authorized distributors. (See MIL index on pages CF9-11 for complete MIL part number listing) .375 ø T Circuit MIL Qualified Product M15733 MIL Part Number No Figure 1 51-382-609 25-0024 ✝ Rated Voltage 85°C 125°C DC AC DC AC — — 100 — Min Cap I Amp µF 2.00 0.750 Minimum Insertion Loss (dB) DCR Max Max Thd 30 150 300 L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.100 1.179 (29.947) B 10 22 31 80 70 70 55 51-382-603 25-0007 1 — — 100 — 4.00 0.750 0.063 1.345 (34.163) A 10 22 28 43 80 70 70 ✝ 51-351-604 26-0012 1 — — 150 125 2.00 0.250 0.100 1.179 (29.947) A — 13 21 43 80 70 70 51-351-603 26-0008 1 — — 150 125 4.00 0.250 0.063 1.345 (34.163) A — 11 18 33 80 70 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP36 Hermetically Sealed Threaded Case Filters .375 ø TT Circuit Standard Product See Pg. MIL LP35 No for Fig. — 1 Rated Voltage 85°C 125°C DC AC DC AC — — 50 — Minimum Insertion Loss (dB) DCR Max Min Max Thd 30 150 300 L Cap I 1 1 10 100 Ohms Amp µF In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 70 70 70 70 0.25 1.500 12.000 1.241 (31.521) B 70 70 70 SCI-2060-013 — 1 — — 50 — 3.00 1.500 0.081 1.241 (31.521) B — 33 54 70 70 70 70 SCI-2060-007 — 1 — — 50 — 10.0 1.500 0.006 1.241 (31.521) A 15 29 35 42 55 70 70 SCI-2060-014 — 1 — — 50 — 10.0 1.500 0.006 1.241 (31.521) B 15 29 35 42 55 70 70 SCI-2160-011 — 1 — — 100 — 1.00 1.500 0.750 1.241 (31.521) B 12 52 70 70 70 70 70 SCI-2160-012 — 1 — — 100 — 2.00 1.500 0.189 1.241 (31.521) B — 33 56 70 70 70 70 SCI-2160-013 — 1 — — 100 — 3.00 1.500 0.081 1.241 (31.521) B — 24 54 70 70 70 70 SCI-2160-014 — 1 — — 100 — 10.0 1.400 0.006 1.241 (31.521) B 12 25 32 42 70 70 70 SCI-2360-011 — 1 — — 300 125 1.00 0.500 0.750 1.241 (31.521) B — 48 70 70 70 70 70 Part Number SCI-2060-009 SCI-2360-006 — 1 — — 300 125 3.00 0.500 0.080 1.241 (31.521) A — 12 38 70 70 70 70 SCI-2360-007 — 1 — — 300 125 10.0 0.500 0.006 1.241 (31.521) A 5 18 24 34 55 70 70 SCI-2360-014 — 1 — — 300 125 10.0 0.500 0.006 1.241 (31.521) B 5 18 24 34 55 70 70 API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP37 Hermetically Sealed Threaded Case Filters .690 ø C Circuit L .560 Max. (14.22) .250 (6.35) .312 (7.92) ø .687 ± .015 (17.45 ± .38) L 5/16–24 Unf–2A Thd. .062 (1.57) x .125 (3.17) Slot, both ends .735 Max. (18.62) .115 ± .005 (2.92 ± .127) .250 (6.35) .312 (7.92) Figure 1 ø .687 ± .015 (17.45 ± .38) .093 (2.36) ø Hole, both ends 5/16–24 Unf–2A Thd. Figure 2 Dimensions in inches (mm) .690 ø C Circuit Standard Product Part Number ✝ 9932-100-6004 54-310-001 MIL No Figure — 1 Rated Voltage 85°C 125°C DC AC DC AC 200 — 150 — 300 1 — 300 125 DCR Max Ohms 0.005 In 0.702 (mm) (17.831) 0.500 0.005 0.560 (14.224) Min Cap I Amp µF 15 2.600 15 Max L Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz 10 29 39 50 60 70 70 6 19 25 36 50 70 70 54-310-005 — 2 250 — 200 125 25 0.500 0.005 0.750 (19.050) 6 19 25 36 50 70 70 54-310-009 — 1 450 240 400 240 15 0.250 0.005 0.560 (14.224) — 14 19 30 45 60 70 — 1 450 240 400 240 15 0.250 0.005 0.560 (14.224) — 14 19 30 50 70 70 ✝ 9932-100-6005 .690 ø C Circuit MIL Qualified Product M15733 MIL Figure Part Number No 1 54-310-039 34-0037 Rated Voltage 85°C 125°C DC AC DC AC — — 275 125 Min Cap I Amp µF 15 0.200 DCR Max Ohms 0.005 Max L In 0.575 (mm) (14.605) Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz 5 15 21 31 51 70 70 .690 ø C Circuit DSCC 84084 Product 84084 Part Number No Figure -001 1 54-310-042 ✝ Rated Voltage 85°C 125°C DC AC DC AC — — 400 230 Min Cap I Amp µF 15 0.150 DCR Max Ohms 0.005 Max L In 0.700 (mm) (17.780) Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz — 10 16 26 40 52 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP38 Hermetically Sealed Threaded Case Filters .690 ø L Circuit L .560 Max. (14.22) .250 (6.35) .312 (7.92) ø .687 ± .015 (17.45 ± .38) 5/16–24 Unf–2A Thd. .062 (1.57) x .125 (3.17) Slot, both ends .115 ± .005 (2.92 ± .127) L .735 Max. (18.62) .250 (6.35) .312 (7.92) Figure 1 ø .687 ± .015 (17.45 ± .38) .093 (2.36) ø Hole, both ends 5/16–24 Unf–2A Thd. Figure 2 Dimensions in inches (mm) .690 ø L Circuit Standard Product MIL No Figure — 1 Rated Voltage 85°C 125°C DC AC DC AC 150 — 100 — Min Cap I Amp µF 10.0 1.400 Minimum Insertion Loss (dB) DCR Max Max L 1 30 150 300 1 10 100 Ohms CKT In (mm) KHz KHz KHz MHz MHz MHz GHz 0.005 LT 0.905 (22.987) 16 44 60 70 24 34 70 SCI-6120-008 — 1 150 — 100 — 10.0 2.600 0.006 LB SCI-6120-009 — 1 150 — 100 — 20.0 2.600 0.001 51-320-041 — 1 250 — 200 125 10.0 0.500 0.008 51-320-024 — 1 450 240 400 240 1.00 0.360 51-320-100 — 1 450 240 400 240 ✝ 51-320-026 — 1 450 240 400 51-320-103 — 1 450 240 51-322-007 — 1 450 51-322-015 — 2 450 51-322-036 — 2 9010-100-0054 — SCI-6320-004 — Part Number 9010-100-0049 ✝ 0.959 (24.359) 18 32 39 49 70 70 70 LB 0.560 (22.987) 18 32 39 49 60 70 70 LT 0.905 (22.987) 5 19 25 35 50 70 70 0.210 LT 0.905 (22.987) 5 30 38 60 70 70 70 1.00 0.250 0.210 LT 0.905 (22.987) — 21 33 55 70 70 70 240 3.00 0.360 0.030 LT 0.905 (22.987) 5 19 25 45 70 70 70 400 240 5.00 0.360 0.010 LB 0.905 (22.987) — 12 18 30 60 70 70 240 400 240 15.0 0.360 0.007 LB 0.650 (16.510) 5 19 25 35 48 62 70 240 400 240 25.0 0.360 0.007 LT 0.750 (19.050) 5 17 23 34 48 62 70 450 240 400 240 25.0 0.250 0.007 LB 0.750 (19.050) — 10 16 29 45 60 70 1 450 240 300 240 1.00 0.150 0.250 LT 0.905 (22.987) — 14 32 52 70 70 70 1 300 — 300 125 1.00 0.400 0.300 LB 0.959 (24.359) 6 24 35 56 70 70 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP39 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End (See MIL index on pages CF9-11 for complete MIL part number listing) .690 ø L Circuit MIL Qualified Product M15733 See Pg. LP38 MIL Part Number No for Fig. 1 ✝ 51-320-015 27-0005 Rated Voltage 85°C 125°C DC AC DC AC — — 200 125 Min Cap I Amp µF 3.00 0.250 Minimum Insertion Loss (dB) DCR Max Max L 1 30 150 300 1 10 100 Ohms CKT In (mm) KHz KHz KHz MHz MHz MHz GHz 0.033 LT 0.900 (22.860) — 70 14 21 80 70 39 51-320-017 27-0008 1 — — 200 125 5.00 0.250 0.016 LT 0.900 (22.860) — 13 19 32 69 70 70 51-320-018 27-0009 1 — — 200 125 5.00 0.250 0.016 LB 0.900 (22.860) — 13 19 32 69 70 70 51-323-003 27-0011 1 — — 200 125 10.0 0.250 0.005 LT 1.031 (26.187) — 13 19 30 61 70 70 51-323-004 27-0012 1 — — 200 125 10.0 0.250 0.005 LB 1.031 (26.187) — 13 19 30 61 70 70 ✝ 51-322-009 27-0014 2 — — 200 125 15.0 0.250 0.007 LT 1.763 (44.780) — 19 25 36 60 70 70 51-322-017 34-0002 2 — — 200 125 20.0 0.360 0.050 LB 1.763 (44.780) — 19 25 35 57 70 70 .690 ø L Circuit DSCC 84084 Product See Pg. 84084 LP38 Part Number No for Fig. -004 1 51-320-162 ✝ Rated Voltage 85°C 125°C DC AC DC AC — — 400 230 Min Cap I Amp µF 1.00 0.150 Minimum Insertion Loss (dB) DCR Max Max L 1 30 150 300 1 10 100 Ohms CKT In (mm) KHz KHz KHz MHz MHz MHz GHz LT 0.905 (22.987) — 0.150 30 60 70 70 19 46 51-320-163 -005 1 — — 400 230 1.00 0.150 0.150 LB 0.905 (22.987) — 19 30 51-320-164 -006 1 — — 400 230 3.00 0.150 0.026 LT 0.905 (22.987) — 11 19 51-320-165 -007 1 — — 400 230 3.00 0.150 0.026 LB 0.905 (22.987) — 11 19 51-320-166 -008 1 — — 400 230 5.00 0.150 0.013 LT 0.905 (22.987) — 10 51-320-167 -009 1 — — 400 230 5.00 0.150 0.013 LB 0.905 (22.987) — 10 51-320-168 -010 1 — — 400 230 10.0 0.150 0.008 LT 0.905 (22.987) — 51-320-169 -011 1 — — 400 230 10.0 0.150 0.008 LB 0.905 (22.987) — 46 60 70 70 36 60 70 70 36 60 70 70 16 28 54 70 70 16 28 54 70 70 10 16 25 48 70 70 10 16 25 48 70 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP40 Hermetically Sealed Threaded Case Filters .690 ø Pi Circuit L .560 Max. (14.22) .250 (6.35) .312 (7.92) L .555 Max. (14.10) ø .687 ± .015 (17.45 ± .38) .250 (6.35) .312 (7.92) .115 ± .005 (2.921 ± .127) .062 (1.57) x .125 (3.18) Slot, both ends ø .687 ± .015 (17.45 ± .38) 5/16–24 Unf–2A Thd. .140 Max. (3.56) Figure 1 .062 (1.57) x .125 (3.18) Slot, both ends 5/16–24 Unf–2A Thd. Figure 2 Dimensions in inches (mm) .690 ø Pi Circuit Standard Product MIL No Figure — 1 Rated Voltage 85°C 125°C DC AC DC AC 150 — 100 — Min Cap I Amp µF 1.00 2.800 DCR Max Ohms 0.210 In 1.195 (mm) (30.353) SCI-6130-009 — 1 150 — 100 20.0 5.200 0.001 1.195 (30.353) 23 31 35 35 70 70 70 51-321-317 — 1 450 240 400 *240 1.00 0.720 0.400 1.195 (30.353) — 53 70 70 70 70 70 ✝51-321-318 — 1 450 240 400 *240 3.00 0.720 0.030 1.195 (30.353) — 31 51 70 70 70 70 ✝51-321-319 — 1 450 240 400 *240 5.00 0.720 0.020 1.195 (30.353) — 11 30 65 70 70 70 Part Number 51-321-322 — Max L Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz 35 69 70 70 70 70 70 * 0-60 Hz (See MIL index on pages CF8-10 for complete MIL part number listing) .690 ø Pi Circuit MIL Qualified Product M15733 MIL Figure Part Number No 1 51-321-312 27-0004 Rated Voltage 85°C 125°C DC AC DC AC — — 200 125 Min Cap I Amp µF 1.00 0.500 DCR Max Ohms 0.250 In 1.195 (mm) (30.353) Max L Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz — 47 65 80 80 70 70 51-323-313 27-0003 1 — — 200 125 1.00 0.500 0.270 1.031 (26.187) — 43 61 80 80 70 70 51-321-313 27-0010 1 — — 200 125 5.00 0.500 0.024 1.195 (30.353) — 10 28 64 80 70 70 ✝ 51-321-314 27-0013 1 — — 200 125 10.0 0.500 0.008 1.195 (30.353) — 16 18 48 80 70 70 51-321-329 34-0005 1 — — 200 125 10.0 0.500 0.075 1.195 (30.353) — 16 18 48 80 70 70 .690 ø Pi Circuit DSCC 84084 Product Min Cap I Amp µF 1.00 0.200 DCR Max Ohms 0.150 In 1.200 (mm) (30.480) 2 — — 400 230 3.00 0.200 0.026 1.200 (30.480) — — 30 60 80 80 80 2 — — 400 230 5.00 0.200 0.013 1.200 (30.480) — — 12 50 80 80 80 2 — — 400 230 10.0 0.200 0.008 1.200 (30.480) — — — 30 80 80 80 51-321-398 Figure 2 51-321-399 -014 51-321-400 -015 51-321-401 -016 Part Number ✝ Rated Voltage 85°C 125°C DC AC DC AC — — 400 230 84084 No -013 Max L Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz — 27 46 74 80 80 80 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP41 Hermetically Sealed Threaded Case Filters .690 ø T Circuit .250 (6.35) .560 Max. (14.22) L .312 (7.92) ø .687 ± .015 (17.45 ± 0.38) .115 ± .005 (2.92 ± .127) .062 (1.57) x .125 (3.18) Slot, both ends 5/16–24 Unf–2A Thd. .591 Max. (15.01) L .250 (6.35) .312 (7.92) Figure 1 ø .680 Max. (17.272) .125 Ref. (3.175) 5/16–24 Unf–2A Thd. .062 (1.57) x .125 (3.18) Slot, both ends Figure 2 Dimensions in inches (mm) .690 ø T Circuit Standard Product MIL No Figure — 1 Rated Voltage 85°C 125°C DC AC DC AC 150 — 100 — Min Cap I Amp µF 1.00 2.600 DCR Max Ohms 0.600 In 1.195 (mm) (30.353) SCI-6140-006 — 1 150 — 100 — 3.00 2.600 0.100 1.195 (30.353) 21 35 46 70 70 70 70 SCI-6140-007 — 1 150 — 100 — 5.00 2.600 0.060 1.195 (30.353) 21 34 41 58 70 70 70 SCI-6140-009 — 1 150 — 100 — 20.0 2.600 0.002 1.195 (30.353) 21 35 41 50 60 70 70 51-321-649 — 1 250 125 200 125 2.00 0.360 0.090 1.195 (30.353) — 24 38 65 70 70 70 ✝ 51-321-610 — 1 450 240 400 240 1.00 0.360 0.600 1.195 (30.353) 7 43 60 70 70 70 70 Part Number SCI-6140-004 Max L (See MIL index on pages CF8-10 for complete MIL part number listing) .690 ø T Circuit MIL Qualified Product M15733 MIL Figure Part Number No 1 51-321-607 27-0017 ✝ Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz 23 54 70 70 70 70 70 Rated Voltage 85°C 125°C DC AC DC AC — — 200 125 Min Cap I Amp µF 1.50 0.250 DCR Max Ohms 0.133 In 1.195 (mm) (30.353) Max L Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz — 19 32 62 70 70 70 51-321-608 27-0018 1 — — 200 125 4.00 0.250 0.025 1.195 (30.353) — 14 21 36 70 70 70 51-321-670 54-0017 2 — — 300 115 10.0 0.500 0.006 1.177 (29.896) 5 20 23 35 60 70 60 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP42 Value-Added Low Pass Filter Assemblies API Technologies’ Spectrum Control line of value-added low pass filters provide flexible solutions to meet your unique design challenges. Our manufacturing process allows you to add connectors, modify terminations or add wire harnesses without adding much cost or drastically increasing lead times. For custom requirements and exceptional needs, contact our design/manufacturing team. Incorporate specific terminations, connectors or wire harnesses to accommodate your application. Lower the cost of acquisition and assembly. Reduce production operations and lead times. Our value-added services: • Allow you to stream-line your bill of materials. • Reduce inventory/production costs. • Offer custom application-specific low pass filter assemblies. Build-to-order low pass filters. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP43
SCIF-9925-502 价格&库存
很抱歉,暂时无法提供与“SCIF-9925-502”相匹配的价格&库存,您可以联系我们找货
