2163
2163
    ADAFRUIT
    SOLDERINGIRON50W120V
2163 数据手册
  Atten 50-Watt Soldering Iron - SA-50 PRODUCT ID: 2163      Description Treat yourself with this wonderful pen type Atten 50-Watt Soldering Iron. We love the durability, strong grounded cord, nice handle, and fast heat up designed with PTC ceramic material! When you don't need a full soldering 'station' this pen type iron will fulfill your needs. At 50W it can handle any task you throw at it, and the lovely adjustable knob on the side lets you set the temperature so you get just the right temperature for your lead or lead free solder. Once it is cooled off, you can easily coil it up and toss it into your workbox to keep your desk top clear. This iron is an adjustable 50W iron with a temperature range from 200-500°C, For most lead free soldering, try 400°C. For lead-based solder, 350°C will do. Adjust as necessary! It's not as powerful or easy-to-use as the full stand-up Hakko but it is a lot more portable. Comes with: o o o 1x Soldering Iron  1x Soldering Iron Holder  1x Manual  Comes with a fairly generic soldering tip, you can swap the tip for any 'Hakko compatible' tip Note: Shipping weight reflects UPS' new dimensional weight regulations.  Technical Details o o o o o o o o o o Power consumption: 50W  Input voltage: AC (100V‐120V) 60Hz   Temperature Range: 200°C~500°C (392°F~932°F)  Temperature stability (still air, no load): ±2°C  Temperature accuracy: ±10°C  Tip to ground impedance:
很抱歉,暂时无法提供与“2163”相匹配的价格&库存,您可以联系我们找货
