0052920999
0052920999
    ATG
    SOLDER PENCIL W/WDH10 STAND
0052920999 数据手册
WX 1 Soldering Station Built from our customers’ best ideas. The new WX 1 control unit from Weller. A new era in soldering. Technical Data Dimensions 6.69 x 5.94 x 5.12 in. 170 x 151 x 130 mm 7.00 lb. 3.2 kg 120 V, 50 Hz 200 W 150°F - 999°F 50°C - 550°C LxWxH Weight Mains voltage Power input Temperature range +/- 17° F +/- 9° C +/- 4°F +/- 2° C Case material Aluminum base with antistatic black coating; antistatic polyamide synthetic case Capacitive touchscreen Display Order No. WX 2 control unit shown here Intuitive use Multiple language menu navigation Temperature range depends on connected tool. Temperature accuracy Temperature stability 6 touch keys, turn-and-click wheel with enter key and finger guide, patented glass capacitive touch screen with antistatic, chemical and temperature resistant coating. Back lit LC-Display, 255 x 128 dpi WX1 Multi-purpose USB port Weller | P.O. Box 728 | 1000 Lufkin Road | Apex, NC 27502-0728 | United States www.apextoolgroup.com | weller-na@apextoolgroup.com | (866) 498-0484 ©2011 Apex Tool Group, LLC WX tool connection WX 1 Soldering Station Available Configurations: WX 1010 •WX 1 control unit •WX 120 soldering pencil, 120W / 24V, XTB tip •WDH 10 safety rests with WDC2 dry cleaner WX 1 control unit with WXP 120 (120 W / 24 V) soldering pencil and WDH 10 safety rest Order No. WX1010 WX 1011 •WX 1 control unit •WXMP Micro soldering pencil, 40W / 12V, RT3 tip •WDH 50 safety rest with WDC2 dry cleaner Order No. WX1011 WX 1 control unit with WXMP Micro soldering pencil (40W / 12V) and WDH 50 safety rest WX 1012 •WX 1 control unit •WXP 65 soldering pencil, 65W / 24V, XNT 1 tip •WDH 50 safety rest with WDC2 dry cleaner Order No. WX1011 WX 1 control unit with WXMP Micro soldering pencil (40W / 12V) and WDH 50 safety rest Weller | P.O. Box 728 | 1000 Lufkin Road | Apex, NC 27502-0728 | United States www.apextoolgroup.com | weller-na@apextoolgroup.com | (866) 498-0484 ©2011 Apex Tool Group, LLC WX 1 Soldering Station Compatible Tools WXP 120 Soldering iron with safety rest WDH 10 •120 W, 24 V •Soldering work ranging from small to large parts requiring high temperatures is a snap with this tool. •XT soldering tip WXP 120 set with safety rest WDH 10 Order No. 0052920299 (0052920199 for pencil only) WXP 200 Soldering iron with safety rest WDH 31 •200 W, 24 V •Ideal for soldering work requiring extreme heat, eg. LED backplanes •XHT soldering tip WXP 200 set with safety rest WDH 31 Order No. 0052920699 (0052920599 for pencil only) WXMP Micro soldering iron with safety rest WDH 50 •40 W, 12 V •Dynamic performance thanks to built-in active soldering tip, best suited for work under a microscope. •RT soldering tip WXMP set with safety rest WDH 50 Order No. 0052920499 (0052920399 for pencil socket only) WXMT Micro tweezers with safety rest WDH 60 •2 x 40 W, 12 V •Ideal for soldering and desoldering very small SMD parts. •RTW soldering tip WXMT set with safety rest WDH 60 Order No. 0051317899 (0051317799 for tweezer socket only ) Weller | P.O. Box 728 | 1000 Lufkin Road | Apex, NC 27502-0728 | United States www.apextoolgroup.com | weller-na@apextoolgroup.com | (866) 498-0484 ©2011 Apex Tool Group, LLC WX 1 Soldering Station Compatible Tools (cont.) WXP 65 Soldering iron with safety rest WDH 10 •65 W, 24 V •Very fast heat up time. Suitable for small, extremely precise soldering •XNT soldering tip WXP 65 set with safety rest WDH 10 Order No. 0052921299 (0052921199 for pencil only) WXP 80 Soldering iron with safety rest WDH 10 •80 W, 24 V •Soldering work ranging from small to large parts requiring high temperatures is a snap with this tool. •LT soldering tip WXP 80 set with safety rest WDH 10 Order No. 0052920999 (0052920899 for pencil only) WX Adapter for PC Order No. 0058764711 WX Adapter for fume extractors and pre-heaters* Order No. 0058764712 WX connection cable Order No. 0058764710 WX 1 Soldering Station XNT Series Soldering Tips A B C Cat. No. Style In. mm In. In. mm T0054485099 XNT 1 0.010 0.25 not measured 1.06 27 T0054485199 XNT A 0.063 1.6 0.4 1.10 28 T0054485299 XNT 1S 0.008 0.2 not measured 1.12 28.5 T0054485399 XNT D 0.157 4 0.8 1.10 28 T0054485499 XNT GW not measured 1.30 33 T0054485599 XNT 4 0.047 1.2 not measured 1.16 29.5 T0054485699 XNT 6 0.063 1.6 0.016 0.4 1.16 29.5 T0054485799 XTN B 0.094 2.4 0.031 0.8 1.06 27 T0054485899 XNT C 0.126 3.2 0.031 0.8 1.06 27 T0054485999 XNT H 0.031 0.8 0.016 0.4 1.10 28 T0054486099 XNT K 0.047 1.2 0.016 0.4 1.10 28 T0054486299 XNT 1SC 0.016 0.4 0.006 0.15 1.06 27 T0054486399 XTN KN 0.079 2 not measured 1.30 33 not measured 0.016 0.031 mm WX 1 Soldering Station These accessories can be controlled by the WX 1 for a unified bench top solution. Fume extraction solutions The Weller Zero-Smog® systems put an end to pollution form soldering fumes or vapors from adhesives. The Zero-Smog systems can be connected directly using the WX port and controlled via the WX display with the accessory adapter and connection cable. Order No. WFE2S Portable fume extraction for volume extraction with built-in turbine. Up to 4 workstations. WFE4S Mobile fume extraction for volume extraction with built-in turbine. Up to 8 workstations. WFE8S Mobile fume extraction for volume extraction with built-in pre-filter for solder machines. Up to 8 workstations. WFE20D Fume extraction for tip extraction applications with built-in turbine. Up to 20 workstations. Fume extraction Fume extraction solutions The Weller heating plates are used to preheat electronic components and can be connected directly using the WX port and controlled via the WX display. Order No. WHP1000 Heating plate WHP3000 Heating plate, 1000 W/120 V, heating surface 220 x 150 mm Infrared heating plate, 600 W/120 V, with easy fix board holder, heating surface 120 x 190 mm Weller | P.O. Box 728 | 1000 Lufkin Road | Apex, NC 27502-0728 | United States www.apextoolgroup.com | weller-na@apextoolgroup.com | (866) 498-0484 ©2011 Apex Tool Group, LLC
0052920999 价格&库存
很抱歉,暂时无法提供与“0052920999”相匹配的价格&库存,您可以联系我们找货
