T0053638699
T0053638699
    ATG
    WFEP FUME EXTRACT 2SPEED 230V
T0053638699 数据手册
WFE P - Tip extraction unit Bestellnr.:0053638699 Portable fume extraction unit 230 V / 50 Hz, for tip suction with built in pump Weller FE soldering irons have an integral smoke tube mounted in the handle. It is positioned directly above the joint during the soldering process to collect any fumes generated. Fume extraction irons can be connected to Weller Zero-Smog Systems WFE and WFE P bench mounted units driving up to 2 irons or WFE 20D mobile unit driving up to 20 irons. Fume extraction attachments can be retro fitted to non fume extraction Weller soldering irons. Top Attributes • Vacuum pump with 2 power stages for higher extraction performance • Height x Diameter 295 x 140 mm • Weight 4 kg • Power input 70 W • Sound level 40 db (A) at 1 m distance • Max. vacuum 30.000 Pa • Max. capacity 2 FE irons • Not for long term usage 24h Technical Data Color Operation mode / speed Filter type Portable Electronic filter control Cooper Tools GmbH Carl-Benz-Str. 2 74354 Besigheim Germany Phone: +49 (0) 7143-580-0 Fax: +49 (0) 7143-580-108 cht-germany@cooperindustries.com www.coopertools.eu Weller Blue 2 operating modes Compact filter (HEPA filter H13 + wide band gas filter 50% active carbon / 50% Puratex) and Fine dust filter F 7 No No Packaging information Shelf pack size (Units per shelf pack) Cooper Tools GmbH Carl-Benz-Str. 2 74354 Besigheim Germany Phone: +49 (0) 7143-580-0 Fax: +49 (0) 7143-580-108 cht-germany@cooperindustries.com www.coopertools.eu Single
T0053638699 价格&库存
很抱歉,暂时无法提供与“T0053638699”相匹配的价格&库存,您可以联系我们找货
