TECHNICAL DATA SHEET
Semiconductor Solutions
TSF-6522
No-Clean Tacky Soldering Flux
PRODCUT DESCRIPTION
Kester TSF-6522 is a no-clean tacky soldering flux formula designed to be used with a rotating
disc, a doctor blade or a drum fluxer. TSF-6522 can also be used in dot dispensing for
BGA/PGA sites or in a rework application for surface mount packages. TSF-6522 maintains its
activity and dispensing characteristics for up to 8 hours and can be used in a wide range of
temperature and humidity conditions. Kester maintains the highest standards by manufacturing
TSF-6522 under a vacuum environment.
READ ENTIRE TECHNICAL DATA SHEET BEFORE USING THIS PRODUCT
FEATURES & BENEFITS
High tack values and long tack life
Leaves bright/shiny solder joints after reflow
Can reflow in air or nitrogen environments
Classified as ROL0 per J-STD-004B
Compliant to Bellcore GR-78
RoHS COMPLIANCE
This product meets the requirements of the Restriction of Hazardous Substances (RoHS)
Directive, 2011/65/EU for the stated banned substances.
PHYSICAL PROPERTIES
Viscosity (typical): 285 poise
Malcom Viscometer @ 10 rpm and 25 °C
Initial Tackiness (typical): 100 grams
Tested to J-STD-005, IPC-TM-650, Method 2.4.44
Acid Number: 75.4 mg KOH/g of flux
Tested to J-STD-004, IPC-TM-650, Method 2.3.13
TSF-6522
Technical Data Sheet
Issue: 29 December 2020
Page 1 of 4
RELIABILITY PROPERTIES
Copper Mirror Corrosion: Low
Tested to J-STD-004, IPC-TM-650, Method 2.3.32
Copper Corrosion: Low
Tested to J-STD-004, IPC-TM-650, Method 2.6.15
Silver Chromate: Pass
Tested to J-STD-004, IPC-TM-650, Method 2.3.33
Chloride and Bromides: None Detected
Tested to J-STD-004, IPC-TM-650, Method 2.3.35
Fluorides by Spot Test: Pass
Tested to J-STD-004, IPC-TM-650, Method 2.3.35.1
SIR, IPC (Typical): Pass
Tested to J-STD-004, IPC-TM-650, Method 2.6.3.7
Blank
TSF-6522
Day 1
3.1*1010 Ω
2.6*109 Ω
Day 4
1.3*1010 Ω
4.2*1010 Ω
Day 7
8.8*1010 Ω
6.4*1010 Ω
STANDARD APPLICATIONS
TSF-6522 was designed for pin transfer, dot dispensing and/or syringe applications. This flux
can be used as a tack and flux vehicle for soldering components to a solid solder deposit (SSD),
or precision pad technology (PPT) board surfaces. TSF-6522 is great for rework applications on
all PCB packages. TSF-6522 can be used in BGA/PGA sphere/pin attachment vehicle or for
repair and reballing/repinning. This flux works on flip chip, chip scale package and flip chip
bumping sites assemblies as a soldering flux.
TSF-6522
Page 2 of 4
PRINTING PARAMETERS
Temperature/Humidity
Optimal ranges are 21 to 25 °C (70 to 77 °F)
and 35 to 65% RH
RECOMMENDED REFLOW PROFILE
Optimal activation temperatures are 130 to 185 °C (266 to 365 °F). See the Soak Zone in
diagrams below. This allows the use of TSF- 6522 in a leaded or lead-free application. In a
leaded application, the soak zone time (150 to 184 °C) can be 60 to 90 seconds. The typical
peak temperature will be 205 to 215 °C degrees with 60 to 90 seconds over reflow (183 °C). in a
lead-free application the soak zone time (150 to 217 °C) can be 60 to 90 seconds. The typical
peak temperature will be 235 to 245 °C degrees with 60 to 90 seconds over reflow (217 °C).
CLEANING
TSF-6522 is a no-clean chemistry. The residues do not need to be removed for typical
applications. If residue removal is required, call Kester Technical Support.
TSF-6522
Page 3 of 4
SAFETY & WARNING
It is recommended that the company/operator read and review the Safety Data Sheets for the
appropriate health and safety warnings before use. Safety Data Sheets are available.
STORAGE
Refrigeration is the recommended optimum storage condition for TSF-6522 to maintain
consistent viscosity, reflow characteristics and overall performance. TSF-6522 should be
stabilized at room temperature prior to printing. TSF-6522 should be kept at standard
refrigeration conditions, 0 to 10 °C (32 to 50 °F). Please contact Kester Technical Support if you
require additional advice with regard storage and handling of this material. Shelf life is 6 months
from the date of manufacture when handled properly and held at 0 to 10 °C (32 to 50 °F).
CONTACT INFORMATION
To confirm this document is the most recent version, please contact
techinfo@MacDermidAlpha.com
www.macdermidalpha.com
North America
3950 Johns Creek Ct, Suite 300
Suwanee, GA 30024 USA
908.791.2300
Europe
Unit 2, Genesis Business Park
Albert Drive
Woking, Surrey, GU21 5RW, UK
44.01483.758400
Asia Pacific
14 Joo Koon Crescent, Singapore
629014
65.6430.0700
Also read carefully warning and safety information on the Safety Data Sheet. This data sheet contains technical information required for safe and economical operation of this product. READ IT
THOROUGHLY PRIOR TO PRODUCT USE . Emergency safety directory assistance: US 1 202 464 2554, Europe + 44 1235 239 670, Asia + 65 3158 1074, Brazil 0800 707 7022 and 0800 172 020,
Mexico 01800 002 1400 and (55) 5559 1588
DISCLAIMER: All statements, technical information and recommendations contained herein are based on tests we believe to be reliable, but the accuracy or completeness thereof is not
guaranteed. No statement or recommendation shall constitute a representation unless set forth in an agreement signed by officers of seller and manufacturer. NO WARRANTY OF
MERCHANTABILITY, WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE OR ANY IMPLIED WARRANTY IS MADE. The following warranty is made in lieu of such warranties and all
other warranties, express, implied, or statutory. Products are warranted to be free from defects in material and workmanship at the time sold. The sole obligation of seller and manufacturer
under this warranty shall be to replace any noncompliant product at the time sold. Under no circumstances shall manufacturer or seller be liable for any loss, damage or expense, direct,
indirect, incidental or consequential, arising out of the inability to use the product. Notwithstanding the foregoing, if products are supplied in response to a customer request that specifies
operating parameters beyond those stated above, or if products are used under conditions exceeding said parameters, the customer by acceptance or use thereof assumes all risk of product
failure and of all direct, indirect, incidental and consequential damages that may result from use of the products under such conditions, and agrees to exonerate, indemnify, defend and hold
harmless MacDermid, Incorporated and its affiliates therefrom. No suggestion for product use nor anything contained herein shall be construed as a recommendation to use any product in a
manner that infringes any patent or other intellectual property rights, and seller and manufacturer assume no responsibility or liability for any such infringement.
© 2019 MacDermid, Inc. and its group of companies. All rights reserved. “(R)” and “TM” are registered trademarks or trademarks of MacDermid, Inc. and its group of companies in the United
States and/or other countries.
TSF-6522
Page 4 of 4
