SMD2040
SMD2040
    CHIPQUIK
    SOLDER SPHERES SAC305 .020 DIAM
SMD2040 数据手册
SMD2040 Datasheet revision 1.3 www.chipquik.com Sn96.5/Ag3.0/Cu0.5 Solder Spheres for BGAs Product Highlights Chip Quik® BGA solder spheres are manufactured from virgin materials to meet or exceed the requirements of building or repairing BGA packages. Chip Quik® BGA solder spheres also exceed both the IPC and MIL standards for purity levels and size tolerances. Nominal sizes are available from 8 to 30 mil. Product Specifications Part Number  SMD2016  SMD2016‐25000  SMD2020  SMD2020‐25000  SMD2024  SMD2024‐25000  SMD2028  SMD2028‐25000  SMD2032  SMD2032‐25000  SMD2036  SMD2036‐25000  SMD2040  SMD2040‐25000  SMD2050  SMD2050‐25000  SMD2055  SMD2055‐25000  SMD2060  SMD2060‐25000  Alloy  Melting Point  Diameter  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  0.008" (0.2mm)  0.010" (0.25mm)  0.012" (0.3mm)  0.014" (0.35mm)  0.016" (0.4mm)  Sn96.5/Ag3.0/Cu0.5  Shelf Life: Test Results Test J-STD-004 or other requirements as stated Conflict Minerals Compliance REACH Compliance 217‐220°C (423‐428°F)  0.018" (0.45mm)  0.020" (0.5mm)  0.024" (0.6mm)  0.025" (0.63mm)  0.030" (0.76mm)  >24 months Test Requirement Result Electronic Industry Citizenship Coalition (EICC) Articles 33 and 67 of Regulation (EC) No 1907/2006 Compliant Conforms to the following Industry Standards: J-STD-006C, Amendments 1 & 2 (Solder Alloys and Fluxed/Non-Fluxed Solders): RoHS 2 Directive 2011/65/EU: 1 Quantity (by weight)  © 1994-2018 Chip Quik® Inc. Contains no substance >0.1% w/w that is listed as a SVHC or restricted for use in solder materials Yes Yes Additional Alloys Available Part Number  SMD2140  SMD2140‐25000  SMD2150  SMD2150‐25000  SMD2165  SMD2165‐25000  SMD2170  SMD2170‐25000  SMD2180  SMD2180‐25000  SMD2185  SMD2185‐25000  SMD2190  SMD2190‐25000  SMD2195  SMD2195‐25000  SMD2200  SMD2200‐25000  SMD2205  SMD2205‐25000  SMD2215  SMD2215‐25000  2 Alloy  Melting Point  Diameter  0.008" (0.2mm)  0.010" (0.25mm)  0.012" (0.3mm)  0.014" (0.35mm)  0.016" (0.4mm)  Sn63/Pb37  183°C (361°F)  0.018" (0.45mm)  0.020" (0.5mm)  0.022" (0.55mm)  0.024" (0.6mm)  0.025" (0.63mm)  0.030" (0.76mm)  © 1994-2018 Chip Quik® Inc. Quantity (by weight)  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000  250,000  25,000
SMD2040 价格&库存
很抱歉,暂时无法提供与“SMD2040”相匹配的价格&库存,您可以联系我们找货
