PA0001
Datasheet revision 2.0
www.Proto-Advantage.com
SOIC-8 to DIP-8 SMT Adapter (150 mil / 200 mil body)
Top side photo (showing pins assembled)
Bottom side photo (showing pins assembled)
Typical IC package accepted (SOIC-8)
Product Highlights
Immersion Gold Finish
Gold Plated Pins
RoHS II and REACH Compliant
Comes Unassembled with Pins Included (Allows easier IC installation before the pins are soldered on)
Top side of board fits surface mount footprint
Bottom side of PCB has pads for two single row surface mount vertical headers (included)
Specifications
PCB dimensions:
PCB construction:
PCB operating temperature range:
PCB reflow maximum temperature:
0.7” x 0.4” x 0.063” (17.78 mm x 10.16 mm x 1.6 mm)
FR-4 UL94V-0
-40°C to +130°C (-40°F to +266°F)
+260°C (500°F)
Application Notes
AN0001: IC Assembly Instructions if Using a Stencil
AN0002: Pin Assembly Instructions
AN0003: Adapter Selection Guide
1
© 2007-2016 Proto Advantage™
DIMENSIONS
REF.
A
B
C
D
e
F
G
H
MIN.
mm
TYP.
MAX.
MIN.
inches
TYP.
MAX.
2.90
2.50
0.60
0.67
1.27
0.300
0.100
0.025
Top View (SMT Footprint)
A
B
C
e
D
(Representative drawing only - not to scale)
2
Bottom View (DIP Pins)
F
H
G
Side View (DIP Pins)
F
3
很抱歉,暂时无法提供与“PA0001-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+103.951291+13.49098
