SMDTCLF
SMDTCLF
    CHIPQUIK
    SOLDER TIP CLEANER LEAD FREE
SMDTCLF 数据手册
S M D T C LF Datasheet revision 1.1 www.chipquik.com Lead Free Soldering Iron Tip Cleaner and Tinner Product Highlights Cleans and re-coats lead free soldering iron tips to prolong tip life How to use Chip Quik Tip Tinner / Cleaner 1. Turn soldering iron on to normal working temperature, hot enough to melt SAC305 (Sn96.5/Ag3.0/Cu0.5) or Tin/Copper (Sn99.3/Cu0.7) solder. Usually a soldering iron tip temperature of 700-800 Fahrenheit (370-425 Celsius) is appropriate. Allow iron tip to reach full operating temperature. 2. Press iron tip into solid tip tinner/cleaner mixture. 3. Allow a few seconds for some of the solid tip tinner/cleaner mixture to melt. As it melts it will clean the iron tip and then coat it with a protective layer of lead free alloy. 4. Proceed to use your soldering iron as normal to solder joints. 5. Repeat cleaning/tinning as often as necessary to keep tip clean and shiny, and prolong tip life. Storage and Handling Store refrigerated or at room temperature 3-25°C (37-77°F). Do not freeze. Conforms to the following Industry Standards: J-STD-004B, Amendment 1 (Solder Fluxes): J-STD-005A (Solder Pastes): J-STD-006C, Amendments 1 & 2 (Solder Alloys and Fluxed/Non-Fluxed Solders): RoHS 2 Directive 2011/65/EU: 1 © 1994-2021 Chip Quik® Inc. Yes Yes Yes Yes
SMDTCLF 价格&库存
很抱歉,暂时无法提供与“SMDTCLF”相匹配的价格&库存,您可以联系我们找货
SMDTCLF
    库存:60
    SMDTCLF
    • 1+90.926121+11.80055
