T0054460999N
T0054460999N
    ATG
    TIP RT9 CHISEL CARTRIDGE - WMRP
T0054460999N 数据手册
WSM Compact Soldering Stations The world’s first high performance battery powered soldering station. August 2010 WSM Compact Soldering Stations Two Versions: Corded Cat. No. WSM1 Corded AND Battery Powered Cat. No. WSM1C WSM1 Another Weller First! 2 WSM Compact Soldering Stations • Why WSM? • Makes micro tool technology (WMRP) accessible to a wider market • Achieves micro tool performance for 32% less than WD1000M • Introduce an industry first – a high performance, battery powered soldering station (WSM1C) • Target markets • R & D (WSM1 corded version) • Repair and rework sector (WSM1C cordless version) North America Application Support | (866) 498-0484 | weller-na@apextoolgroup.com 3 WSM Compact Soldering Stations Compact, lightweight, and powerful Just put the Weller micro pencil in your hand and you will see and feel the difference. Incomparable comfort and control is yours. – Motion sensor technology initiates power to the pencil after the setback period. Saves energy and extends tip lifetime. – The setback feature saves energy and extends tip lifetime – Integrated heater-in-tip design allows for 4 second heat-up time with just 40 watts of power – High efficiency RT3 (.05”, 1.3 mm) micro-soldering chisel tip with integrated heating element Easy to use Operation is intuitive. You don’t need tons of training. You can be productive immediately. – – – – LCD display screen with touch control Special functions for customized settings (auto-off, setback timer, offset, °F / °C, lockout) Two programmable pre-set temperatures Safety rest with brass wool tip dry cleaning system Weller quality through and through – Integrated tip design Weller’s unique stereo jack plug system is fast, convenient, and secure. Easy to use LCD display screen with touch control Convenience Two programmable pre-set temperature buttons. Set your favorite temperatures and forget it. Made in Germany The quality you have come to expect from a name you trust North America Application Support | (866) 498-0484 | weller-na@apextoolgroup.com What’s in the box? 6 7 4 1 8 5 2 Ordering information: TWSM1 Digital Soldering Station, 50W, 100-240 V WSM1C Digital Rechargeable Soldering Station, 50W, 100-240 V 0058751880 Car Adapter, 12 V, for WSM1C 3 1 2 3 4 5 6 7 8 A complete one-user setup is included: Soldering station with hard-wired pencil Tool holder with brass wool tip dry cleaner RT3 micro-chisel tip ESD grounding plug AC power supply / charger North America power cord European power cord (2 round prongs) Instructions Everything you need to get started. Tips and Accessories Don’t forget the fume extraction! 12 volt car charger For WSM1C Cat. No. 0058751880 Environmental, safety, and health concerns are major industry drivers. Protect your investment with Weller Zero Smog. For more information: (866) 498-0484 Weller-na@apextoolgroup.com www.wellerzerosmog.com Additional tip details available at www.cooperhandtools.com/weller RT-MIL tips are NOT compatible with WSM1 or WSM1C North America Application Support | (866) 498-0484 | weller-na@apextoolgroup.com Specification Comparison Chart Column1 Temperature Range Heat up time zero to 700F Output power Power supply Touch screen Temperature Lockout Temperature pre-set buttons Replaceable pencil? ESD Safe? Weller WSM1 10 sec. 40 W /12 V 100V - 240V Yes Yes 2 No No. Optional grounding kit available soon. 10 sec. 40 W /12 V 100V - 240V Yes Yes 2 No No. Optional grounding kit available soon. No No MIL-SPEC Compliant? Menu Features: Auto Off, Setback Timer, Lockout, Offset,°F/°C. Battery Supply Recharge time Run time Tip selection Setback feature Sugg. List Price Average Tip Price Weller WSM1C 200 - 750 F (50 - 201 - 750 F (50 400 C) 400 C) Yes Weller WD1000M Column3JBC BD-1BA 200-850 F (100 450 C) Yes 34.00 $ 4 sec. 20 W / 24V 120V No Yes No Yes 20 Sec. 70 W / 24V 120V No Yes No Yes 8 sec. 50 W / 24V 100V - 240V No No N/A Yes Yes Yes Yes Yes No. MIL-SPEC pencil and tips available. Yes Yes Yes Yes, Auto Yes, Auto setback and setback and sleep modes, °F Hibernation & °C settings modes with a pin and a key card # lockout lockout Yes 34.00 $ Metcal MX-5020 10 sec. 40 W / 24 V 120V No Yes 3 Yes N/A Lithium Ion N/A N/A 20 min. N/A N/A 60 min. N/A 12 12 12 Yes Yes Yes Accelerometer / Accelerometer / Stop+Go stand / Setback timer Setback timer Setback timer $ 365.00 $ 435.00 $ 523.95 $ Hakko FX-951 200 - 740 F (90 - 400 - 840 F (200 700 UFTC Series - Max. Temp 450 C) - 450 C) 775 F (412 C) 34.00 N/A N/A N/A N/A N/A N/A 14 81 Handpiece Handpiece Placement in the Placement in stand the stand $ 375.00 $ 263.10 $ $10.40 $29.00 standard; standard; $35.00 $ $48.00 for most Long Life expensive Setback N/A N/A N/A 13 Back Labels Yes, Sleep Stand 675.00 29.00 North America Application Support | (866) 498-0484 | weller-na@cooperindustries.com Pricing Information Cat. No. Order No. Description Sugg. List Price – US Sugg. List Price Canada WSM1 TWSM1 Digital Soldering Station, 40W, 120V $365.00 $400.00 WSM1C WSM1C Digital Rechargeable Soldering Station, 40W, 120V $450.00 $500.00 0058751880 T0058751880 Car Adapter, 12V, for WSM1C $12.00 $13.20 RT1 T0054460199 Needle Tip Cartridge for WMRP $32.44 $37.46 RT1SC T0054461299 Micro Chisel Tip Cartridge for WMRP $47.25 $54.56 RT2 T0054460299 Fine Point Tip Cartridge for WMRP $32.44 $37.46 RT3 T0054460399 Chisel Tip Cartridge, WMRP $32.44 $37.46 RT4 T0054460499 Chisel Tip Cartridge for WMRP $32.44 $37.46 RT5 T0054460599 Bent Chisel Tip Cartridge, WMRP $32.44 $37.46 RT6 T0054460699 Round Sloped Tip Cartridge, WMRP $32.44 $37.46 RT7 T0054460799 Knife Tip Cartridge for WMRP $34.07 $39.34 RT8 T0054460899 Chisel Tip Cartridge, WMRP $32.44 $37.46 RT9 T0054460999 Chisel Tip Cartridge, WMRP $32.44 $37.46 RT10 T0054461099 Gull Wing Tip Cartridge, WMRP $32.44 $37.46 RT11 T0054461199 Chisel Tip Cartridge for WMRP $49.00 $50.00 WSM1 is priced 32% lower than WD1000M
T0054460999N 价格&库存
很抱歉,暂时无法提供与“T0054460999N”相匹配的价格&库存,您可以联系我们找货
T0054460999N
  • 1+377.504341+48.98088
库存:57
