October 2010
WX 2
Control Unit
NEW
Technical Data WX 2
Dimensions
L x B x H (mm)
L x B x H (inch)
Weight
Mains voltage
Power input
Protection class
Protection
Temperature range
Display
170 x 151 x 130
6,69 x 5,94 x 5,12
ca. 3,2 kg
230 V, 50 Hz
200 W (240 W)
I, case antistatic
Mains fuse T2 A
adjustable 50° C – 550° C
(150° F – 999° F)
Adjustable temperature range
depends of tools.
± 9° C (± 17° F)
± 2° C (± 4° F)
3,5 mm jack socket on the
back of the unit
Aluminium base with antistatic,
black coating, antistatic plastic
case
6 touch keys,turn-and-klick
wheel with enter key and
finger guide, patented glass
capacitive touch screen with
antistatic, chemical and
temperature resistant coating.
Back lit LC-Display
Order No.
T0053420699
Temperature accuracy
Temperature stability
Equipotential bonding
Material case
Capacitive touch-screen
www.weller.eu
October 2010
WX 2 sets:
WX 2010
WX 2 soldering station with 2x WXP 120 soldering irons,
120 W/24 V and 2 safety rests WDH 10
Order No.
T0053421699
WX 2021
WX 2 soldering station with WXMP Micro soldering iron,
40 W/12 V / safety rest WDH 50 and WXMT Micro tweezer,
2x 40 W/12 V / safety rest WDH 60
Order No.
T0053422699
WX Adapter for PC
WX Adapter for WFE / WHP
WX connection cable
Order No. T0058764711
Order No. T0058764712
Order No. T0058764710
www.weller.eu
October 2010
Compatible Tools
WXP 120 Soldering iron with safety rest WDH 10
•120 W, 24 V
•Soldering work ranging from small to large parts
requiring high temperatures is a snap with this model.
•XT soldering tip
Order No.
T0052920299
WXP 200 Soldering iron with safety rest WDH 31
•200 W, 24 V
•Ideal for soldering work requiring extreme heat,
e.g. LED backplanes.
•XHT soldering tip
Order No.
T0052920299
WXMP Micro soldering iron with safety rest WDH 50
•40 W, 12 V
•Dynamic performance thanks to build-in active
soldering tip, best suited for work under a microscope.
•RT soldering tip
Order No.
T0052920499
WXMT Micro tweezer with safety rest WDH 60
•2 x 40 W, 12 V
•Ideal for soldering and desoldering very small SMD
parts.
•RTW soldering tip
Order No.
T0051317899
www.weller.eu
October 2010
Fume extractions solutions
The Weller® Zero-Smog® systems put an end to pollution
from soldering fumes or vapours from adhesives. The
Zero-Smog® systems can be connected directly using
the WX port and controlled via the WX display.
Order No.
T0053626671 WFE 2S with automatic pressure control
T0053626699
T0053649699
T0053658699
T0053647699
Portable fume extraction for volume
extraction with built-in turbine and automatic pressure control for constant air flow
WFE 2S
WFE 4S
Mobile fume extraction for volume extraction
WFE 8S
with built-in pre-filter for solder machines
WFE 20D
Fume extraction for tip extraction
applications with built-in turbine
Heating plates
The Weller® heating plates are used to preheat electronic
components and can be connected directly using the WX
Order No.
T0053364899 WHP 1000
heating plate 1000 W/230 V,
heating surface: 220 x 150 mm (heat)
T0053338699 WHP 3000
Infrared heating plate, 600 W/230 V,
with easy fix board holder,
heating surface: 120 x 190 mm (heat)
T0053364699 WHP 3000
Infrared heating plate, 1200 W/230 V,
heating surface: 190 x 245 mm (heat)
Cooper Tools GmbH
A company of Apex Tool Group, LLC.
Carl-Benz-Straße 2
74354 Besigheim, Germany
Tel.:
+49 (0) 7143 580-0
Fax:
+49 (0) 7143 580-108
www.weller.eu
很抱歉,暂时无法提供与“T0053422699N”相匹配的价格&库存,您可以联系我们找货
