17100-150
17100-150
    AVENTOOLS(艾文)
    SOLDERPOT150W
17100-150 数据手册
LEAD FREE SOLDER POT 100W ITEM # RATING POWER TEMPERATURE RANGE MELTING TIME MAX SOLDER WEIGHT SOLDER POT SIZE WEIGHT POT SOLDER CAPACITY 17100-100 100W 200-400°C (392-752°F) 8 minutes 250g (0.55 lbs.) 36mm (1.42”) diameter 0.91kg (2 lbs.) 250g LEAD FREE SOLDER POT 200W 1TEM # 17100-200 RATING POWER TEMPERATURE RANGE MELTING TIME 200W 200-400°C (392-752°F) 8 minutes MAX SOLDER WEIGHT SOLDER POT SIZE WEIGHT 800g (1.76 lbs.) 80mm (3.15”) diameter 1.36kg (3 lbs.) POT SOLDER CAPACITY 800g LEAD FREE SOLDER POT 150W ITEM # RATING POWER TEMPERATURE RANGE MELTING TIME MAX SOLDER WEIGHT SOLDER POT SIZE WEIGHT POT SOLDER CAPACITY 17100-150 150W 200-400°C (392-752°F) 8 minutes 500g (1.10 lbs.) 50mm (1.96”) diameter 0.91kg (2 lbs.) 500g Aven Lead Free Solder Pots The Aven Lead Free Solder Pots are ideal for tinning the ends of stranded wire leads, pre-tinning small electrical parts, re-tinning soldering iron tips and dip soldering small circuit boards. The variable temperature heating element liquifies solder quickly and provides excellent thermal stability. The crucible is made from stainless steel with titanium plating, featuring corrosion resistance and prolonged service life. The Aven Lead Free Solder Pot is suitable for melting solder, plastic, resin and more. Available in 100W, 150W & 200W Email | sales@aveninc.com Features • Heating element liquifies solder quickly and provides excellent thermal stability • Crucible is made from stainless steel with titanium plating, featuring corrosion resistance and prolonged service life • Suitable for melting solder, plastic, resin and more • Ideal for tinning ends of stranded wire leads, pre-tinning small electrical parts and dip soldering small circuit boards aveninc.com Phone | 734.973.0099
17100-150 价格&库存
很抱歉,暂时无法提供与“17100-150”相匹配的价格&库存,您可以联系我们找货
