T0053171699N
T0053171699N
    ATG
    WHA900 HOT AIR STATION 230V
T0053171699N 数据手册
Product information WHA 900 Code No. : T0053171699 Hot Air Station Set Hot Air Station 650 W ⁄ 230 V with built-in Turbine - For easy repair applications and heating processes as e.g. shrinking - Brushless turbine for ideal hot air flow - Hot air temperature is electronically controlled Technical Data This station is ESD safe. Dimensions L x W xH: 210 x 170 x 110 mm Mains voltage: 230 V Power consumption: 650 W Hot air pencil output: 612 W Fuse: T4A Temperature control: infinitely variable between 50°C and 550°C Control accuracy: ± 30°C (± 54°F) Flow control: infinitely variable between 5 - 50 l/min Noise level: 56dB(A) distance 1m at max. airflow level Page 1 / 1
T0053171699N 价格&库存
很抱歉,暂时无法提供与“T0053171699N”相匹配的价格&库存,您可以联系我们找货
