T0053378699N
T0053378699N
    ATG
    WR2000A HOT AIR STATION 230V
T0053378699N 数据手册
Product information WR 2000A Code No. : T0053378699 Repair Station Power unit, 300 W, 2 channel digital station with hot air iron HAP 1 (100 W, 24 V), hot air nozzle R06, safety rest WDH 30 and power cable Technical data This station is ESD safe. Simultaneous operation of hot air and desoldering iron is not possible! Dimension L x B x H: 273 x 235 x 102 mm (10,75 x 9,2 x 4,02 inch) Weight: approx. 6,7 kg Channels: 2 Net supply: 230 V Power supply: 300 W Protection class: I Fuse: T500 mA (230V / 50/60 Hz) Fuse overcurrent release: 1,6 A Temperature control of channels: Soldering and desoldering tool, continuously variable from 50°C - 550°C (150°F - 999°F) Temperature control range is tool independent Soldering iron WP 80 / WP 120: 50°C - 450°C (150°F - 850°F) Soldering iron WP 200 / WSP 150: 50°C - 550°C (150°F - 950°F) Desoldering iron DSX 80 / DXV 80 / DSX 120: 50°C - 450°C (150°F - 850°F) Hot air iron HAP 1: 50°C - 550°C (150°F - 950°C) Page 1 / 2 Temperature accuracy: ± 9°C (± 17°F) Temperature stability: ± 2°C (± 4°F) Bleeder: Soldering tip (Tip to ground) conforms IPC-J-001 Bleeder voltage: Soldering tip (Tip to ground) conforms IPC-J-001 Pump: (periodic duty 30/30s) Max. vacuum: 0,7 bar Max. delivery rate: max. 10 l/min Hot air: max. 15 l/min Display: LCD Temperature control: Buttons Equipotentional bonding: Via 3.5 mm pawl socket at the back of device (hard grounded normal state) USB interface: no Rework - Soldering, Desoldering and Hot air ● ● ● ● One station meets the requirements of a rework workplace Unique connecting compatibility of all tools 3 respectively 2 independend tool channels with automatic tool recognition guarantee the simultanuous operation of 2 to 3 soldering tools. Tools are permanentely ready for use Page 2 / 2
T0053378699N 价格&库存
很抱歉,暂时无法提供与“T0053378699N”相匹配的价格&库存,您可以联系我们找货
