Product information
WR 2002 Set
Code No. : T0053380699
Repair station
Power unit, 300 W, 2 channel digital station with WP 80 & DSX 80 irons
Technical data
This station is ESD safe.
Simultaneous operation of hot air and desoldering iron is not possible!
Dimension L x B x H:
273 x 235 x 102 mm (10,75 x 9,2 x 4,02 inch)
Weight:
approx. 6,7 kg
Channels:
2
Net supply:
230 V
Power supply:
250 W
Protection class:
I
Fuse:
T500 mA (230V / 50/60 Hz)
Fuse overcurrent
release:
1,6 A
Temperature control
of channels:
Soldering and desoldering tool, continuously
variable from 50°C - 550°C (150°F - 999°F)
Temperature control range is tool independent
Soldering iron WP 80 / WP 120: 50°C - 450°C (150°F - 850°F)
Soldering iron WP 200 / WSP 150: 50°C - 550°C (150°F - 950°F)
Desoldering iron DSX 80 / DXV 80 / DSX 120: 50°C - 450°C (150°F - 850°F)
Hot air iron HAP 1: 50°C - 550°C (150°F - 950°C)
Page 1 / 2
Temperature
accuracy:
± 9°C (± 17°F)
Temperature stability:
± 2°C (± 4°F)
Bleeder:
Soldering tip (Tip to ground) conforms IPC-J-001
Bleeder voltage:
Pump:
(periodic duty 30/30s)
Max. vacuum:
0,7 bar
Max. delivery rate:
max. 10 l/min
Hot air:
max. 15 l/min
Display:
LCD
Temperature control:
Buttons
Equipotentional
bonding:
Via 3.5 mm pawl socket at the back of device (hard grounded normal state)
USB interface:
no
Rework - Soldering, Desoldering and Hot air
One station meets the requirements of a rework workplace
Unique connecting compatibility of all tools
3 respectively 2 independend tool channels with automatic tool recognition guarantee the simultanuous
operation of 2 to 3 soldering tools.
Tools are permanentely ready for use
Page 2 / 2
很抱歉,暂时无法提供与“T0053380699N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+28553.863571+3694.53078
