T0053379699N
T0053379699N
    ATG
    WR2000D DESOLDER STATION 230V
T0053379699N 数据手册
Product information WR 2000D Code No. : T0053379699 Repair station Power unit, 300 W, 2 channel digital station with DSX 80 desoldering iron Technical data This station is ESD safe. Simultaneous operation of hot air and desoldering iron is not possible! Dimension L x B x H: 273 x 235 x 102 mm (10,75 x 9,2 x 4,02 inch) Weight: approx. 6,7 kg Channels: 2 Net supply: 230 V Power supply: 250 W Protection class: I Fuse: T500 mA (230V / 50/60 Hz) Fuse overcurrent release: 1,6 A Temperature control of channels: Soldering and desoldering tool, continuously variable from 50°C - 550°C (150°F - 999°F) Temperature control range is tool independent Soldering iron WP 80 / WP 120: 50°C - 450°C (150°F - 850°F) Soldering iron WP 200 / WSP 150: 50°C - 550°C (150°F - 950°F) Desoldering iron DSX 80 / DXV 80 / DSX 120: 50°C - 450°C (150°F - 850°F) Hot air iron HAP 1: 50°C - 550°C (150°F - 950°C) Page 1 / 2 Temperature accuracy: ± 9°C (± 17°F) Temperature stability: ± 2°C (± 4°F) Bleeder: Soldering tip (Tip to ground) conforms IPC-J-001 Bleeder voltage: Soldering tip (Tip to ground) conforms IPC-J-001 Pump: (periodic duty 30/30s) Max. vacuum: 0,7 bar Max. delivery rate: max. 10 l/min Hot air: max. 15 l/min Display: LCD Temperature control: Buttons Equipotentional bonding: Via 3.5 mm pawl socket at the back of device (hard grounded normal state) USB interface: no Rework - Soldering, Desoldering and Hot air ● ● ● ● One station meets the requirements of a rework workplace Unique connecting compatibility of all tools 3 respectively 2 independend tool channels with automatic tool recognition guarantee the simultanuous operation of 2 to 3 soldering tools. Tools are permanentely ready for use Page 2 / 2
T0053379699N 价格&库存
很抱歉,暂时无法提供与“T0053379699N”相匹配的价格&库存,您可以联系我们找货
