T0053420699N
T0053420699N
    ATG
    WX 2 CONTROL UNIT 230V F/G
T0053420699N 数据手册
October 2010 WX 2 Control Unit NEW Technical Data WX 2 Dimensions L x B x H (mm) L x B x H (inch) Weight Mains voltage Power input Protection class Protection Temperature range Display 170 x 151 x 130 6,69 x 5,94 x 5,12 ca. 3,2 kg 230 V, 50 Hz 200 W (240 W) I, case antistatic Mains fuse T2 A adjustable 50° C – 550° C (150° F – 999° F) Adjustable temperature range depends of tools. ± 9° C (± 17° F) ± 2° C (± 4° F) 3,5 mm jack socket on the back of the unit Aluminium base with antistatic, black coating, antistatic plastic case 6 touch keys,turn-and-klick wheel with enter key and finger guide, patented glass capacitive touch screen with antistatic, chemical and temperature resistant coating. Back lit LC-Display Order No. T0053420699 Temperature accuracy Temperature stability Equipotential bonding Material case Capacitive touch-screen www.weller.eu October 2010 WX 2 sets: WX 2010 WX 2 soldering station with 2x WXP 120 soldering irons, 120 W/24 V and 2 safety rests WDH 10 Order No. T0053421699 WX 2021 WX 2 soldering station with WXMP Micro soldering iron, 40 W/12 V / safety rest WDH 50 and WXMT Micro tweezer, 2x 40 W/12 V / safety rest WDH 60 Order No. T0053422699 WX Adapter for PC WX Adapter for WFE / WHP WX connection cable Order No. T0058764711 Order No. T0058764712 Order No. T0058764710 www.weller.eu October 2010 Compatible Tools WXP 120 Soldering iron with safety rest WDH 10 •120 W, 24 V •Soldering work ranging from small to large parts requiring high temperatures is a snap with this model. •XT soldering tip Order No. T0052920299 WXP 200 Soldering iron with safety rest WDH 31 •200 W, 24 V •Ideal for soldering work requiring extreme heat, e.g. LED backplanes. •XHT soldering tip Order No. T0052920299 WXMP Micro soldering iron with safety rest WDH 50 •40 W, 12 V •Dynamic performance thanks to build-in active soldering tip, best suited for work under a microscope. •RT soldering tip Order No. T0052920499 WXMT Micro tweezer with safety rest WDH 60 •2 x 40 W, 12 V •Ideal for soldering and desoldering very small SMD parts. •RTW soldering tip Order No. T0051317899 www.weller.eu October 2010 Fume extractions solutions The Weller® Zero-Smog® systems put an end to pollution from soldering fumes or vapours from adhesives. The Zero-Smog® systems can be connected directly using the WX port and controlled via the WX display. Order No. T0053626671 WFE 2S with automatic pressure control T0053626699 T0053649699 T0053658699 T0053647699 Portable fume extraction for volume extraction with built-in turbine and automatic pressure control for constant air flow WFE 2S Portable fume extraction for volume extraction with built-in turbine WFE 4S Mobile fume extraction for volume extraction with built-in turbine WFE 8S Mobile fume extraction for volume extraction with built-in pre-filter for solder machines WFE 20D Fume extraction for tip extraction applications with built-in turbine Heating plates The Weller® heating plates are used to preheat electronic components and can be connected directly using the WX port and controlled via the WX display. Order No. T0053364899 WHP 1000 heating plate 1000 W/230 V, heating surface: 220 x 150 mm (heat) T0053338699 WHP 3000 Infrared heating plate, 600 W/230 V, with easy fix board holder, heating surface: 120 x 190 mm (heat) T0053364699 WHP 3000 Infrared heating plate, 1200 W/230 V, with easy fix board holder, heating surface: 190 x 245 mm (heat) Cooper Tools GmbH A company of Apex Tool Group, LLC. Carl-Benz-Straße 2 74354 Besigheim, Germany Tel.: +49 (0) 7143 580-0 Fax: +49 (0) 7143 580-108 www.weller.eu
T0053420699N 价格&库存
很抱歉,暂时无法提供与“T0053420699N”相匹配的价格&库存,您可以联系我们找货
