T0053294699N
T0053294699N
    ATG
    WSD 81I SOLDERING STATION 230V F
T0053294699N 数据手册
Product information WSD 81i (wet cleaner) Code No. : T0053294699 Set 1-channel Power unit digital 95 W, 230 V, with soldering iron WSP 80 (80 W, 24 V) with silver line heating technology, Standard LT B soldering tip and safety rest KH 18 with wet cleaner Technical Data This station is ESD safe. ● ● ● Dimensions L x B x H: 166 x 115 x 101 mm (6.54 x 4.53 x 3.98 inch) Mains supply voltage: 230 V 50/60Hz; Power consumption: 95 W Safety class: I, antistatic housing III, soldering tool Fuse T500mA (230V, 50/60 Hz) Temperature range: 50°C - 450°C / 150°F - 850°F Temperature accuracy: ± 2°C Equipotential bonding: Via 3.5 mm pawl socket on back of unit (delivery form: hard grounded without jack plug) Easy operation: Integrated, automatic processes and fewer operating requirements. No calibration needed (IPC compliant). Rugged housing: Made from high quality, tough, antistatic materials and low wear plug and socket connectors. 100% long-term performance: Platinum sensor technology gives precise temperature accuracy and control. Compared to other stations, the WSD 81i offers temperature stability and accuracy without variation over time. Page 1 / 1
T0053294699N 价格&库存
很抱歉,暂时无法提供与“T0053294699N”相匹配的价格&库存,您可以联系我们找货
