Product information
WX 1010 Set
Code No. : T0053418699
Power unit with 1 channel
WX 1 Power unit 200 W, 230 V with WXP 120 soldering iron (120 W ⁄ 24 V) Power Response Technology and
safety rest WDH 10 with dry cleaner
Technical Data
This station is ESD safe.
Dimensions L x W x
H:
170 x 151 x 130 mm (6,69 x 5,94 x 5,12 inch)
Weight:
approx. 3,2 kg
Channels:
1
Power supply:
230 V, 50 Hz
Power consumption:
200 W
Protection class:
I
Temperature range:
Adjustable from 50°C - 550°C (150°F - 999°C)
Adjustable temperature range varies among tools
Temperature
accuracy:
± 9°C (± 17°F)
Temperature stability:
± 2°C (± 4°F)
Equipotential
bonding:
Via 3,5 mm pawl socket on back of device
Material touch panel:
Made of antistatic coated material
Dimensions touch
panel:
74 x 38 mm
Resolution:
255 x 127 (128) dots
Page 1 / 2
Display backlighting:
4 LEDs
Equipotentional
bonding:
The 3,5 mm switch offers four different
options:
a) Hard grounded without plug (original
delivery)
b)Equipotential bonding: with plug,
compensation line on center contact
c)Potential free: with plug
d) Soft grounded: with plug and soldered
resistor grounded via selected resistor
USB interface:
USB interface in front of firmware updates, parameterization and
monitoring
USB interface supports all standard USBflash drive types
Power unit WX 1
Innovative operation concept
Robust touch screen with ESD safe glas
Intuitive use with turn-click-wheel with enter key and finger guide.
Blue LED backlighting
Multilingual menu navigation
High functionality
No safety rest with Stop & Go function needed thanks to integrated acceleration sensor
Optimized precision, better stability by sensor in the soldering iron
Specific parameterization of tool by storgage medium in hand piec.
Visual process control via blue LED ring light
All WX tools connectable
Page 2 / 2
很抱歉,暂时无法提供与“T0053418699N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7781.026871+1010.32764
