WDD 81V
- Desoldering Station Set
Bestellnr.:0053256699
Desoldering station diigital 95 W, 230 V compressed air or inert gas operated
Top Attributes
• 1 channel
• Digital controlled electronic for soldering or desoldering tools up to 80 W
• Compressed air converter provides vacuum for the desoldering iron
• Inlet pressure 500 - 600 KPA (58 - 87 psi) oilfree, dry compressed air or inert gas
• Temperature range 50°C - 450°C
• Calibration box WCB 2 (005 31 180 99) may be connected for CALIBRATION, LOCK OUT or OFFSET function
• Portection class 1
• Antistatic housing
• Equipotential bonding (normal state hard grounded)
• Automatic tool recognition
• Dimensions: 166 x 115 x 101 mm (W x L x H)
• For use with external compressed air
Technical Data
Display technology
Equipotential Bonding/ hard grounding explanation
Temperatur control comment
Display included & Size
Display information content
ESD safe
Display backlight
Antistatic housing
Cooper Tools GmbH
Carl-Benz-Str. 2
74354 Besigheim
Germany
Phone: +49 (0) 7143-580-0
Fax: +49 (0) 7143-580-108
cht-germany@cooperindustries.com
www.coopertools.eu
LED
Normal state
Button
Medium
Medium
Yes
Yes
No
Yes
Temperature stability
Power unit wattage
Mains supply Voltage
Power supply frequency
Output voltage
Protection class Soldering iron
Protection class Control/ Power unit
Number of tools controlled simultaneously
Temperature accuracy
Temperature regulation
5 °C
95 W
230 V
50 Hz
24 V
3
1
1
9 °C
50 - 550 °C
Packaging information
Shelf pack size (Units per shelf pack)
Cooper Tools GmbH
Carl-Benz-Str. 2
74354 Besigheim
Germany
www.coopertools.eu
1
很抱歉,暂时无法提供与“T0053256699N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+16363.761261+2118.61763
