T0053426699N
T0053426699N
    ATG
    DESOLDERSOLDER200W2CH230V
T0053426699N 数据手册
Product information WX 2021 Set Code No. : T0053422699 Power unit with 2 channels Power unit WX 2, 200 W, soldering iron WXMP, 55 W, 12 V, with Active Tip Technology, soldering tip RT 3, safety rest WDH 51, micro tweezers WXMT, 2 x 40 W, 12 V, with Active Tip Technology, standard tip RTW 2 and safety rest WDH 60 with dry cleaner Technical Data This station is ESD safe. Dimensions L x W x H: 170 x 151 x 130 mm (6,69 x 5,94 x 5,12 inch) Weight: approx. 3,2 kg Channels: 2 Power supply: 230 V, 50 Hz Power consumption: 200 W (255 W) Protection class: I Temperature range: Adjustable from 50°C - 550°C (150°F - 999°C) Adjustable temperature range varies among tools Temperature accuracy: ± 9°C (± 17°F) Temperature stability: ± 2°C (± 4°F) Equipotential bonding: Via 3,5 mm pawl socket on back of device Material touch panel: Made of antistatic coated material Dimensions touch panel: 74 x 38 mm Resolution: 255 x 127 (128) dots Page 1 / 2 Display backlighting: 4 LEDs Equipotentional bonding: The 3,5 mm switch offers four different options: a) Hard grounded without plug (original delivery) b)Equipotential bonding: with plug, compensation line on center contact c)Potential free: with plug d) Soft grounded: with plug and soldered resistor grounded via selected resistor USB interface: USB interface in front of firmware updates, parameterization and monitoring USB interface supports all standard USBflash drive types Power unit WX 2 ● ● ● ● ● ● ● ● ● ● ● Innovative operation concept Robust touch screen with ESD safe glas Intuitive use with turn-click-wheel with enter key and finger guide. Blue LED backlighting Multilingual menu navigation High functionality No safety rest with Stop & Go function needed thanks to integrated acceleration sensor Optimized precision, better stability by sensor in the soldering iron Specific parameterization of tool by storgage medium in hand piec. Visual process control via blue LED ring light All WX tools connectable Page 2 / 2
T0053426699N 价格&库存
很抱歉,暂时无法提供与“T0053426699N”相匹配的价格&库存,您可以联系我们找货
