17100-300
17100-300
    AVENTOOLS(艾文)
    SOLDER POT
17100-300 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address:www.aventools.com Item # 17100-300, 300 Watt Soldering Pot 300 Watt Soldering Pot These soldering pots are portable and used for melting solder, dip soldering small circuit boards, tinning the ends of wire leads etc. 300 WATT SOLDER POT • HI/LO switch selectable for temperature. • Temperature regulated between 420-450°C. • Size (tub): 2.4" (60mm) dia. x 1.6" (40mm) D. SPECIFICATIONS Temperature 420 to 450 ºC Tub Diameter 2.4 in 60 mm Depth 1.6 in 40 mm Weight 6 lb 1/17/2012 | Page 1 of 1
17100-300 价格&库存
很抱歉,暂时无法提供与“17100-300”相匹配的价格&库存,您可以联系我们找货
