17100-600
17100-600
    AVENTOOLS(艾文)
    SOLDER POT
17100-600 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address:www.aventools.com Item # 17100-600, 600 Watt Soldering Pot 600 Watt Soldering Pot These soldering pots are portable and used for melting solder, dip soldering small circuit boards, tinning the ends of wire leads etc. 600 WATT SOLDER POT • Tin boiler temp: 0-550ºC. • Self regulating temperature. • ON/OFF power switch and LED indicator for heat. • Size (tub): 6.8" (172mm) L x 5.5" (140mm) W x 2.8" (71mm) H. SPECIFICATIONS Boiler Temperature 0 - 550 ºC Length 6.8 in 172 mm Width 5.5 in 140 mm Height 2.8 in 71 mm Weight 1.5 lb 1/17/2012 | Page 1 of 1
17100-600 价格&库存
很抱歉,暂时无法提供与“17100-600”相匹配的价格&库存,您可以联系我们找货
