CHEMTRONICS
Technical Data Sheet
Chem-Wik Rosin
PRODUCT DESCRIPTION
Chem-Wik Rosin is especially designed for
today’s heat sensitive electronic components.
The lighter mass, pure copper braid
construction allows for better thermal
conductivity, even at low temperatures.
Chem-Wik Rosin responds as much as 50%
faster than conventional desoldering braids.
This design minimizes overheating and
requires less “contact” pressure for greater
operator control. All sizes are coated with a
Type “R” organic flux system.
Requires little or no post solder cleaning
No corrosive residues
Optimized weave design for faster
wicking and heat transfer
Halide free
Minimal risk of heat damage to
components and circuit boards
TYPICAL APPLICATIONS
Chem-Wik Rosin desoldering braid safely
removes solder from:
Thru-hole Components
Surface Mount Device Pads
BGA Pads
Micro Circuits
Terminals
Lugs and Posts
Identification Script
TDS # CWik
TYPICAL PRODUCT DATA AND
PHYSICAL PROPERTIES
Chem-Wik Rosin
Flux Type:
Grade WW, Type “R”
Clean-up Required:
Military Specifications:
No
MIL-F-14256F
Shelf Life – 2 years from manufacturer
date
Part #
2-5L
Size
Inches
.030”
Size
Metric
.76mm
5-5L
.050”
1.27mm
7-5L
.075”
1.91mm
10-5L
.100”
2.54mm
STATIC DISSIPATIVE PACKAGING
Static Dissipative packaging is available on
all 5 foot bobbins. The static dissipative
bobbins qualify as electrostatic discharge
protective per DOD Standard 1686 and DOD
Handbook 263. Meets the static delay rate
provision of MIL-B-81705C.
USAGE INSTRUCTIONS
For industrial use only.
Read MSDS carefully prior to use.
1) Choose a Chem-Wik desoldering braid
width equal to or slightly larger than the
pad or connection.
2) Choose a solder iron tip equal to or slightly
smaller than the pad or connection.
3) Set temperature of iron between 600-750°F
4) Place wick on solder joint and place tip of hot
iron on top of wick
5) As solder becomes molten, the color of the
wick will change from copper to silver.
6) Remove wick and iron from solder joint
simultaneously once color change has stopped.
7) The component lead is now clean and free
from solder.
8) Clip and discard the used portion of the wick.
AVAILABILITY
Width
.030”
.050”
.075”
.100”
Color
Code
White
Yellow
Green
Blue
5 ft.
Bobbin
2-5L
5-5L
7-5L
10-5L
25 ft.
Spool
2-25L
5-25L
7-25L
10-25L
Chem-WikRosin is designed to meet
or exceed the following standards:
MIL-F-14256F, Type R
MIL-STD-2000A
MIL-B-81705C
NASA NHB5300.4(3A)
NASA SP-5002
NASA NPC200-4
IPC SF-818
DOD Handbook 263
DOD Standard 1686
BELLCORE TR-NWT-00078
TECHNICAL & APPLICATION
ASSISTANCE
Chemtronics provides a technical hotline to
answer your technical and application related
questions. The toll free number is:
1-800-TECH-401.
50 ft.
Spool
2-50L
5-50L
7-50L
10-50L
100 ft.
Spool
2-100L
5-100L
7-100L
10-100L
500 ft.
Spool
2-500L
5-500L
7-500L
10-500L
NOTE:
This information is believed to be accurate. It is
intended for professional end users having the skills
to evaluate and use the data properly.
CHEMTRONICS does not guarantee the accuracy of
the data and assumes no liability in connection with
damages incurred while using it.
CHEMTRONICS
8125 COBB CENTER DRIVE
KENNESAW, GA 30152
1-770-424-4888
REV. D (08/13)
DISTRIBUTED BY:
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Chemtronics:
50-4-500 80-5-10 50-2-500 80-3-10 80-2-10 50-3-100
很抱歉,暂时无法提供与“80-5-10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+128.782851+16.71367
- 5+116.859025+15.16617
- 10+112.0750210+14.54530
- 25+106.0465025+13.76290
- 50+101.7017450+13.19903
- 100+97.53787100+12.65864
- 500+97.47422500+12.65038
