V9000K8-B
Datasheet revision 1.0
www.chipquik.com
Kit of 8 Vacuum Cups
Specifications
Static Dissipative Buna-N Cups
Operating Temperature: -20°C to 120°C
Resistance: 10^8 to 10^11 ohms
Comes with:
Size
3/32”
1/8”
3/16”
1/4"
3/8”
1/2"
5/8”
3/4"
Cup Diameter
0.094” (2.38 mm)
0.125” (3.18 mm)
0.188” (4.76 mm)
0.250” (6.35 mm)
0.375” (9.53 mm)
0.500” (12.7 mm)
0.625” (15.88 mm)
0.750” (19.05 mm)
Mounting Hole Size
0.040”
0.060”
0.060”
0.060”
0.060”
0.060”
0.060”
0.060”
Holds @ 6 In. Hg.
5 grams
10 grams
25 grams
60 grams
150 grams
250 grams
400 grams
600 grams
How to Use
1.
2.
3.
4.
Select a rubber vacuum cup that is slightly smaller than the area at which you want to pick-and-place the part from.
Push the vacuum cup snugly onto the end of the vacuum tool (sold separately).
Make sure that there is no dust on the rubber vacuum cup.
Depress the button on the side of the vacuum tool, and place the soft rubber vacuum cup squarely onto the pick-andplace part, then release the button. This will create a vacuum that will hold the part firmly. Note: it is normal for the
vacuum created to slowly lose its strength over 30-60 seconds, so placing your part within this time is recommended.
5. Move the part to where you want to place it, lower it to the board, then squeeze the button again to release the part.
Applications
Pick-and-place of metal, plastic, or any parts having a smooth non-porous top surface area that the rubber vacuum cup can
seal against. For larger parts, use the larger vacuum cup.
1
© 1994-2019 Chip Quik® Inc.
很抱歉,暂时无法提供与“VCS-9-B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+496.279511+64.32728
