PU120T
PU120T
    ATG
    POWERUNIT120V-WTCPT
PU120T 数据手册
2/4/2016 Catalog No. PU120T Product Detail Weller  Power Unit for WTCPT Temperature Controlled Soldering Station Product Details Catalog No. PU120T UPC Code 037103001115 Wattage 60 W Soldering TC201T Pencil(s) Temperature 600° F to 800° F Range Voltage 120 V/24 V Input/Output Supplied Tip(s) PTA 7 Iron Stand PH1201ESD Temperature Not Specified A ccuracy Packaging Industrial Box/Carton Literature T550733.pdf Tech. Spec. Solder_Safety_Warnings.pdf Low Res. Image PU120T_100.jpg High Res. Image PU120T_300.jpg Stock Item Normal Stock Item Package Details (Dimensions) Product Features: Voltage: 120V (input); 24V (output) Power consumption: 60 watts Temperature range 600°F ­ 800°F (316°C ­ 427°C) Footprint: 4 1/2" x 5 15/16" x 3 5/8" (114mm x 150mm x 91mm) Weight: 3.9 lb (1.78 kg) ESD Safe? Yes http://www.apexhandtools.com/brands/CF_Files/model_detail.cfm?upc=037103001115 1/2 2/4/2016 Catalog No. PU120T Product Detail http://www.apexhandtools.com/brands/CF_Files/model_detail.cfm?upc=037103001115 2/2
PU120T 价格&库存
很抱歉,暂时无法提供与“PU120T”相匹配的价格&库存,您可以联系我们找货
