T0053124699N
T0053124699N
    ATG
    WTT1 TEMP MEASUREMENT 230V
T0053124699N 数据手册
Product information WTT 1 Code No. : T0053124699 Temperature measuring system WTT 1 Temperature measuring system - Temperature range 50°C - 500°C - Tolerance ± 5°C - Dimensions 166 x 115 x 101 mm Technical data The Temperature measuring system WTT 1 is ESD safe. Temperature range: 50°C - 500°C Tolerance: ± 5°C Dimensions(L x W x H): 166 x 115 x 101 mm The WTT 1 digital temperature measuring system has been specially designed for measuring the temperature of soldering iron tips. The probe has a double sensor system and an own internal heat source. The measured temperature is fed to a control system that records the flow of heat in the probe and stabilises it with the aid of the internal heat source. This design ensures that no heat is drawn by the probe from the object to be measured. Erroneous measurements due to the large thermal load of the probe are thus prevented. The measured temperature is indicated on a three-digit LED display to a resolution of 1°C. A red dot in the display is used to indicate the measured value and simplifies the reading of the measured temperature. An adjustable preheat temperature ensures a rapid response even at high temperatures. Different methods of equipotentioal bonding and the ESD appropriate design of the control unit and probe supplement the quality of this measuring unit. Page 1 / 2 Page 2 / 2
T0053124699N 价格&库存
很抱歉,暂时无法提供与“T0053124699N”相匹配的价格&库存,您可以联系我们找货
