T0053118099N
T0053118099N
    ATG
    WCB2 TEMP ANALYZER UNIT 230V
T0053118099N 数据手册
WCB 2 Calibrator - Calibration unit Bestellnr.:0053118099 WCB 2 Calibrator The WCB 2 is an external input unit for programming additional functions. It works with every digital Weller station. The setting is fast and easy. Battery powered supply makes the box independent from any mains and easy to transport. The WCB 2 has an PC interface (RS 232) and an integrated temperature gauge for thermo couple type K (accessory). The following function are available: See Top Attributes. Top Attributes • OFFSET: correction value for soldering tip temperature • SETBACK: Reduction of the set temperature after a specified period of time • LOCK: locking the set temperature • °C / °F: switching temperature display °C / °F • WINDOW: setting a set value window. If the actual temperature is within the set value window a potentialfree contact is activated • Temperature measuring tips are available for each soldering iron Technical Data Target application On/off indicator Build in Light Electronic No No Packaging information Shelf pack size (Units per shelf pack) Single Set No Cooper Tools GmbH Carl-Benz-Str. 2 74354 Besigheim Germany Phone: +49 (0) 7143-580-0 Fax: +49 (0) 7143-580-108 cht-germany@cooperindustries.com www.coopertools.eu
T0053118099N 价格&库存
很抱歉,暂时无法提供与“T0053118099N”相匹配的价格&库存,您可以联系我们找货
